path: root/drivers/scsi/dpt_i2o.c
2008-11-15[SCSI] dpt_i2o: fix transferred data length for scsi_set_resid()Miquel van Smoorenburg
dpt_i2o.c::adpt_i2o_to_scsi() reads the value at (reply+5) which should contain the length in bytes of the transferred data. This would be correct if reply was a u32 *. However it is a void * here, so we need to read the value at (reply+20) instead. The value at (reply+5) is usually 0xff0000, which is apparently 'large enough' and didn't cause any trouble until 2.6.27 where commit 427e59f09fdba387547106de7bab980b7fff77be Author: James Bottomley <James.Bottomley@HansenPartnership.com> Date: Sat Mar 8 18:24:17 2008 -0600 [SCSI] make use of the residue value caused this to become visible through e.g. iostat -x . Signed-off-by: Miquel van Smoorenburg <mikevs@xs4all.net> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-16device create: scsi: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Cc: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21device create: scsi: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Cc: James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-20dpt_i20: BKL pushdownJonathan Corbet
Add lock_kernel() calls to adpt_open() Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-05-08drivers/scsi/dpt_i2o.c: fix build on alphaAndrew Morton
alpha: drivers/scsi/dpt_i2o.c:1997: error: implicit declaration of function 'adpt_alpha_info' drivers/scsi/dpt_i2o.c: At top level: drivers/scsi/dpt_i2o.c:2032: warning: conflicting types for 'adpt_alpha_info' drivers/scsi/dpt_i2o.c:2032: error: static declaration of 'adpt_alpha_info' follows non-static declaration drivers/scsi/dpt_i2o.c:1997: error: previous implicit declaration of 'adpt_alpha_info' was here Due to a copy-n-paste error in drivers/scsi/dpti.h. Fix that up and remove some of the many daft static-declarations-in-a-header which this driver enjoys. Cc: Miquel van Smoorenburg <miquels@cistron.nl> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic94xx: fix section mismatch [SCSI] u14-34f: Fix 32bit only problem [SCSI] dpt_i2o: sysfs code [SCSI] dpt_i2o: 64 bit support [SCSI] dpt_i2o: move from virt_to_bus/bus_to_virt to dma_alloc_coherent [SCSI] dpt_i2o: use standard __init / __exit code [SCSI] megaraid_sas: fix suspend/resume sections [SCSI] aacraid: Add Power Management support [SCSI] aacraid: Fix jbod operations scan issues [SCSI] aacraid: Fix warning about macro side-effects [SCSI] add support for variable length extended commands [SCSI] Let scsi_cmnd->cmnd use request->cmd buffer [SCSI] bsg: add large command support [SCSI] aacraid: Fix down_interruptible() to check the return value correctly [SCSI] megaraid_sas; Update the Version and Changelog [SCSI] ibmvscsi: Handle non SCSI error status [SCSI] bug fix for free list handling [SCSI] ipr: Rename ipr's state scsi host attribute to prevent collisions [SCSI] megaraid_mbox: fix Dell CERC firmware problem
2008-05-02[SCSI] dpt_i2o: sysfs codeMiquel van Smoorenburg
Create a /sys/class/dpt_i2o directory and populate it with dptiN directories. Each dptiN directory contains a "dev" file that makes udev create /dev/dptiN Signed-off-by: Miquel van Smoorenburg <miquels@cistron.nl> Acked-by: Mark Salyzyn <Mark_Salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] dpt_i2o: 64 bit supportMiquel van Smoorenburg
This is the code to actually support 64 bit platforms. 64 bit DMA is enabled on both x86_32 PAE and 64 bit platforms. This code is based in part on the unofficial adaptec 64-bit dpt_i2o driver update that I got from Mark Salyzyn at Adaptec. Signed-off-by: Miquel van Smoorenburg <miquels@cistron.nl> Acked-by: Mark Salyzyn <Mark_Salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] dpt_i2o: move from virt_to_bus/bus_to_virt to dma_alloc_coherentMiquel van Smoorenburg
Remove virt_to_bus/bus_to_virt code from dpt_i2o, and use dma_alloc_coherent() / dma_free_coherent(). This is in preparation of 64-bit support, dma_alloc_coherent() can allocate memory in the lower 32 bits of physical memory which is needed because the HBA only supports message blocks under 4GB This code is based in part on the unofficial adaptec 64-bit dpt_i2o driver update that I got from Mark Salyzyn at Adaptec. Signed-off-by: Miquel van Smoorenburg <miquels@cistron.nl> Acked-by: Mark Salyzyn <Mark_Salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] dpt_i2o: use standard __init / __exit codeMiquel van Smoorenburg
Update dpt_i2o.c to use the standard __init / __exit code instead of the legacy '#include "scsi_module.c"' code. This is needed in preparation of 64-bit support. scsi_module.c calls scsi_add_host() with the device pointer set to NULL, and that crashes code like arch/x64/kernel/pci-gart_64.c::need_iommu(). The reboot_notifier code is deleted because it wasn't compiled in ever anyway, and it would be useless to duplicate it in the new code. Signed-off-by: Miquel van Smoorenburg <miquels@cistron.nl> Acked-by: Mark Salyzyn <Mark_Salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-28scsi: fix integer as NULL pointer warningsHarvey Harrison
drivers/scsi/aic7xxx/aic7770_osm.c:53:58: warning: Using plain integer as NULL pointer drivers/scsi/aic7xxx/aic7xxx_osm_pci.c:355:47: warning: Using plain integer as NULL pointer drivers/scsi/aic7xxx/aic7xxx_osm_pci.c:372:55: warning: Using plain integer as NULL pointer drivers/scsi/aha152x.c:997:28: warning: Using plain integer as NULL pointer drivers/scsi/aha152x.c:1003:28: warning: Using plain integer as NULL pointer drivers/scsi/aha152x.c:1165:46: warning: Using plain integer as NULL pointer drivers/scsi/fdomain.c:1446:40: warning: Using plain integer as NULL pointer drivers/scsi/sym53c8xx_2/sym_hipd.c:1650:51: warning: Using plain integer as NULL pointer drivers/scsi/sym53c8xx_2/sym_hipd.c:3171:42: warning: Using plain integer as NULL pointer drivers/scsi/sym53c8xx_2/sym_hipd.c:5732:52: warning: Using plain integer as NULL pointer drivers/scsi/ncr53c8xx.c:8189:31: warning: Using plain integer as NULL pointer drivers/scsi/ncr53c8xx.c:8225:34: warning: Using plain integer as NULL pointer drivers/scsi/dpt_i2o.c:156:32: warning: Using plain integer as NULL pointer drivers/scsi/ultrastor.c:954:42: warning: Using plain integer as NULL pointer drivers/scsi/ultrastor.c:1104:18: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] dpt_i2o: use constant instead of bare valueSalyzyn, Mark
0x02 becomes SAM_STAT_CHECK_CONDITION Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-12-18[SCSI] dpt_i2o: driver is only 32 bit so don't set 64 bit DMA maskJames Bottomley
This fixes a potential corruption bug where the truncation would cause reading or writing to the wrong memory area on machines with >4GB of main memory. Cc: Stable Kernel Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-12-10revert "dpt_i2o: convert to SCSI hotplug model"Andrew Morton
revert commit 55d9fcf57ba5ec427544fca7abc335cf3da78160 Author: Matthew Wilcox <matthew@wil.cx> Date: Mon Jul 30 15:19:18 2007 -0600 [SCSI] dpt_i2o: convert to SCSI hotplug model - Delete refereces to HOSTS_C - Switch to module_init/module_exit instead of detect/release - Don't pass around the host template and rename it to adpt_template - Switch from scsi_register/scsi_unregister to scsi_host_alloc, scsi_add_host, scsi_scan_host and scsi_host_put. Because it caused (for unknown reasons) Andres' all-data-reads-as-zeroes problem, reported at http://groups.google.com/group/fa.linux.kernel/msg/083a9acff0330234 Cc: Matthew Wilcox <matthew@wil.cx> Cc: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Anders Henke <anders.henke@1und1.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16[SCSI] add use_sg_chaining option to scsi_host_templateFUJITA Tomonori
This option is true if a low-level driver can support sg chaining. This will be removed eventually when all the drivers are converted to support sg chaining. q->max_phys_segments is set to SCSI_MAX_SG_SEGMENTS if false. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-12[SCSI] dpt_i2o: Fix section mismatchJoe Korty
Fix section mismatch in the Adaptec DPT SCSI Raid driver. WARNING: vmlinux.o(.init.text+0x1fcd2): Section mismatch: reference to .exit.text:adpt_exit (between 'adpt_init' and 'ahc_linux_init') This warning is due to adaptec device detection calling the exit routine on failure to properly register the adaptec device. The exit routine + call was added on July 30 by Commit: 55d9fcf57ba5ec427544fca7abc335cf3da78160 Author: Matthew Wilcox Subject: [SCSI] dpt_i2o: convert to SCSI hotplug model. Mathew: isn't a module exit routine a little too strong to be calling on the failure of a single device? Module exit implies that other, non-failing adaptec raid devices will also get shut down. Signed-off-by: Joe Korty <joe.korty@ccur.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] kmalloc + memset conversion to kzallocMariusz Kozlowski
In NCR_D700, a4000t, aic7xxx_old, bvme6000, dpt_i2o, gdth, lpfc, megaraid, mvme16x osst, pluto, qla2xxx, zorro7xx Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-31[SCSI] dpt_i2o: convert to SCSI hotplug modelMatthew Wilcox
- Delete refereces to HOSTS_C - Switch to module_init/module_exit instead of detect/release - Don't pass around the host template and rename it to adpt_template - Switch from scsi_register/scsi_unregister to scsi_host_alloc, scsi_add_host, scsi_scan_host and scsi_host_put. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Acked-by: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-31[SCSI] dpt_i2o: convert to use the data buffer accessorsFUJITA Tomonori
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Jens Axboe <jens.axboe@oracle.com> did the for_each_sg cleanup. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> ACK. Code inspected. Driver changes NOT unit tested or compile tested. Acked-by: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-08Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (58 commits) [SCSI] zfcp: clear boxed flag on unit reopen. [SCSI] zfcp: clear adapter failed flag if an fsf request times out. [SCSI] zfcp: rework request ID management. [SCSI] zfcp: Fix deadlock between zfcp ERP and SCSI [SCSI] zfcp: Locking for req_no and req_seq_no [SCSI] zfcp: print S_ID and D_ID with 3 bytes [SCSI] ipr: Use PCI-E reset API for new ipr adapter [SCSI] qla2xxx: Update version number to 8.01.07-k7. [SCSI] qla2xxx: Add MSI support. [SCSI] qla2xxx: Correct pci_set_msi() usage semantics. [SCSI] qla2xxx: Attempt to stop firmware only if it had been previously executed. [SCSI] qla2xxx: Honor NVRAM port-down-retry-count settings. [SCSI] qla2xxx: Error-out during probe() if we're unable to complete HBA initialization. [SCSI] zfcp: Stop system after memory corruption [SCSI] mesh: cleanup variable usage in interrupt handler [SCSI] megaraid: replace yield() with cond_resched() [SCSI] megaraid: fix warnings when CONFIG_PROC_FS=n [SCSI] aacraid: correct SUN products to README [SCSI] aacraid: superfluous adapter reset for IBM 8 series ServeRAID controllers [SCSI] aacraid: kexec fix (reset interrupt handler) ...
2007-05-06[SCSI] dpt_i2o: kmalloc/memset->kzallocvignesh.babu@wipro.com
Replacing kmalloc/memset combination with kzalloc. Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-01[SCSI] dpt_i2o: remove dead codeAdrian Bunk
The Coverity checker spotted this dead code introduced by commit a07f353701acae77e023f6270e8af353b37af7c4. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-12[PATCH] mark struct file_operations const 6Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-04[SCSI] scsi: remove hosts.hHenne
Remove the obsolete hosts.h file under drivers/scsi. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-23[SCSI] Switch some more scsi drivers to pci_get_device and refcounted pci ↵Alan Cox
structures Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-19[SCSI] remove unnecessary includes of linux/config.h from drivers/scsi/Dave Jones
kbuild includes this automatically these days. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[SCSI] I2O: move pci_request_regions() just behind pci_enable_device()Salyzyn, Mark
The problem in dpt_i2o could be the pci config space accesses it triggers as it loads, dangerous to do if there is any I/O activity going on in the other driver (probable if a boot driver I guess). I approve this patch to dpt_i2o.c, and am applying it to the Adaptec branch of the driver. Thanks for the investigation Ryoji. --- In linux 2.6.15, data transfer does hang when both dpt_i2o and i2o_block drivers are loaded. It seems that location of pci_request_regions() are wrong. I moved it just behind pci_enable_device() like other drivers, and it becomes fine. Signed-off-by: Ryoji Kamei <kamei@miraclelinux.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] turn most scsi semaphores into mutexesArjan van de Ven
the scsi layer is using semaphores in a mutex way, this patch converts these into using mutexes instead Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-18[PATCH] dpt_i2o fix for deadlock conditionSalyzyn, Mark
Miquel van Smoorenburg <miquels@cistron.nl> forwarded me this fix to resolve a deadlock condition that occurs due to the API change in 2.6.13+ kernels dropping the host locking when entering the error handling. They all end up calling adpt_i2o_post_wait(), which if you call it unlocked, might return with host_lock locked anyway and that causes a deadlock. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-27[PATCH] drivers/scsi/dpt_i2o.c: fix a NULL pointer dereferenceAdrian Bunk
The Coverity checker spotted this obvious NULL pointer dereference. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Mark Salyzyn <mark_salyzyn@adaptec.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: drivers/scsiJesper Juhl
This is the drivers/scsi/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/scsi/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] drivers/scsi: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_uninterruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-09[SCSI] dpt_i2o pci_request_regions fixSalyzyn, Mark
Originally From: Andrew Morton <akpm@osdl.org> Altered By: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> There is an additional 'build fix' patch that Andrew Morton submitted on the kernel list (I have changed out his dpr_i2o with dpt_i2o below though). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-08-08[SCSI] Bug 4940 Repeatable Kernel Panic on Adaptec 2015S I20 device on bootupJames Bottomley
From: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> Prevent driver from loading if another driver (i2o) has already claimed the resources associated with the card. Discussion associated with this bug can be referenced at http://bugzilla.kernel.org/show_bug.cgi?id=4940 where it was agreed to use pci_request_regions in both the dpt_i2o and the i2o driver to prevent both drivers loading on the same adapter(s). Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Rejections fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-11[SCSI] dpt_i2o warning fixAndrew Morton
drivers/scsi/dpt_i2o.c: In function `adpt_queue': drivers/scsi/dpt_i2o.c:385: warning: unused variable `timeout' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-26[SCSI] remove scsi_cmnd.eh_stateChristoph Hellwig
it's never set to anything, and just three broken drivers are looking at it and doing odd things. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-25[PATCH] drivers/scsi/dpt*: remove version.h dependenciesAdrian Bunk
This patch removes version.h dependencies. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] dpt_i2o: fix waitqueue abuseAndrew Morton
The driver plays with waitqueue internals and fails to compile after Ben's "aio: make wait_queue ->task ->private" patch. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-17[SCSI] allow sleeping in ->eh_host_reset_handler()Jeff Garzik
2005-05-20[SCSI] drivers/scsi/dpt_i2o.c: fix compile warningsBenoit Boissinot
This patch fixes the following warnings: drivers/scsi/dpt_i2o.c: In function ‘adpt_isr’: drivers/scsi/dpt_i2o.c:2030: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c:2031: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c:2042: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c:2043: warning: passing argument 2 of ‘writel’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c:2046: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c:2048: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c:2055: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c:2062: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c:2069: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c: In function ‘adpt_i2o_to_scsi’: drivers/scsi/dpt_i2o.c:2239: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c:2243: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c:2248: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast drivers/scsi/dpt_i2o.c:2259: warning: passing argument 1 of ‘readl’ makes pointer from integer without a cast It define variables which are only used with a type of 'void __iomem *' with this type instead of the incorrect 'unsigned long' type. It also remove pointless casts. Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] drivers/scsi/dpt_i2o.c: cleanup useless codeBenoit Boissinot
This patch removes the array 'hbas' as it seems to be useless and redundant with the linked list hbas_chain. Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
