commit a18a920c70d48a8e4a2b750d8a183b3c1a4be514 upstream.
This patch validates sdev pointer in scsi_dh_activate before proceeding further.
Without this check we might see the panic as below. I have seen this
panic multiple times..
Call trace:
#0 [ffff88007d647b50] machine_kexec at ffffffff81020902
#1 [ffff88007d647ba0] crash_kexec at ffffffff810875b0
#2 [ffff88007d647c70] oops_end at ffffffff8139c650
#3 [ffff88007d647c90] __bad_area_nosemaphore at ffffffff8102dd15
#4 [ffff88007d647d50] page_fault at ffffffff8139b8cf
[exception RIP: scsi_dh_activate+0x82]
RIP: ffffffffa0041922 RSP: ffff88007d647e00 RFLAGS: 00010046
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 00000000000093c5
RDX: 00000000000093c5 RSI: ffffffffa02e6640 RDI: ffff88007cc88988
RBP: 000000000000000f R8: ffff88007d646000 R9: 0000000000000000
R10: ffff880082293790 R11: 00000000ffffffff R12: ffff88007cc88988
R13: 0000000000000000 R14: 0000000000000286 R15: ffff880037b845e0
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0000
#5 [ffff88007d647e38] run_workqueue at ffffffff81060268
#6 [ffff88007d647e78] worker_thread at ffffffff81060386
#7 [ffff88007d647ee8] kthread at ffffffff81064436
#8 [ffff88007d647f48] kernel_thread at ffffffff81003fba
Signed-off-by: Babu Moger <babu.moger@netapp.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Commit db422318cbca55168cf965f655471dbf8be82433 ([SCSI] scsi_dh:
propagate SCSI device deletion) introduced a regression where the device
reference is not dropped prior to scsi_dh_activate's early return from
the error path.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Cc: stable@kernel.org # 2.6.38
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
tables.
Previously we were using strncmp in order to avoid having to include
whitespace in the devlist, but this means "HSV1000" matches a device
list entry that says "HSV100", which is wrong. This patch changes
scsi_dh.c to use scsi_devinfo's matching functions instead, since they
handle these cases correctly.
Currently, when scsi_dh_activate() returns with an error
(e.g. SCSI_DH_NOSYS) the activate_complete callback is not called and
the error is not propagated to DM mpath.
When a SCSI device attached to a device handler is deleted, userland
processes currently performing I/O on the device will have their I/O
hang forever.
- Set SCSI_DH_NOSYS error when the handler is in the process of being
deleted (e.g. the SCSI device is in a SDEV_CANCEL or SDEV_DEL state).
- Set SCSI_DH_DEV_OFFLINED error when device is in SDEV_OFFLINE state.
- Call the activate_complete callback function directly from
scsi_dh_activate if an error has been set (when either the scsi_dh
internal data has already been deleted or is in the process of being
deleted).
The patch was tested in an iSCSI environment, RDAC H/W handler and
multipath. In the following reproduction process, dd will I/O hang
forever and the only way to release it will be to reboot the machine:
1) Perform I/O on a multipath device:
dd if=/dev/dm-0 of=/dev/zero bs=8k count=1000000 &
2) Delete all slave SCSI devices contained in the mpath device:
I) In an iSCSI environment, the easiest way to do this is by
stopping iSCSI:
/etc/init.d/iscsi stop
II) Another way to delete the devices is by applying the following
bash scriptlet:
dm_devs=$(ls /sys/block/ | grep dm- | xargs)
for dm_dev in $dm_devs; do
devices=$(ls /sys/block/$dm_dev/slaves)
for device in $devices; do
echo 1 > /sys/block/$device/device/delete
done
done
NOTE: when DM mpath's fail_path uses blk_abort_queue this scsi_dh change
isn't strictly required. However, DM mpath's call to blk_abort_queue
will soon be reverted because it has proven to be unsafe due to a race
(between blk_abort_queue and scsi_request_fn) that can lead to list
corruption. Therefore we cannot rely on blk_abort_queue via fail_path,
but even if we could this scsi_dh change is still preferrable.
Signed-off-by: Menny Hamburger <Menny_Hamburger@Dell.com>
Reviewed-by: Babu Moger <babu.moger@lsi.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Create the sysfs file, dh_state even if the new SCSI device is not
in the any of the device handler's internal lists.
Signed-Off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Acked-by: Hannes Reinecke <hare@suse.de>
Make scsi_dh_activate() function asynchronous, by taking in two additional
parameters, one is the callback function and the other is the data to call
the callback function with.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
When we moved the device handler functionality from dm layer to SCSI layer
we dropped the parameter functionality.
This path adds an interface to scsi dh layer to set device handler
parameters.
Basically, multipath layer need to create a string with all the parameters
and call scsi_dh_set_params() after it called scsi_dh_attach() on a
device.
If a device handler provides such an interface it will handle the parameters
as it expects them.
Reported-by: Eddie Williams <Eddie.Williams@steeleye.com>
Tested-by: Eddie Williams <Eddie.Williams@steeleye.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Problem reported: http://marc.info/?l=dm-devel&m=124585978305866&w=2
scsi_dh does not do a refernce count for attach/detach, and this affects
the way it is supposed to work with multipath when a device is not
in the dev_list of the hardware handler.
This patch adds a reference count that counts each attach.
Create a cache of devices that are seen in a system. This will avoid
the unnecessary traversal of the device list in the scsi_dh when there
are multiple luns of a same type.
Signed-off-by: Hannes Reinecke <hare@suse.de>
multipath keeps a separate device table which may be
more current than the built-in one.
So we should make sure to always call ->attach whenever
a multipath map with hardware handler is instantiated.
And we should call ->detach on removal, too.
[sekharan: update as per comments from agk]
Implement a 'dh_state' sdev attribute for dynamic device handler
manipulation. A read on the attribute will return the name of
the currently attached device handler or 'detached' if no handler
is attached.
The attribute allows the following strings to be written:
- The name of the device handler to be attached if the state is
'detached'.
- 'activate' to trigger path activation if a device handler
is attached.
- 'detach' to detach the currently attached device handler.
Instead of having each and every driver implement its own
device table scanning code we should rather implement a common
routine and scan the device tables there.
This allows us also to implement a general notifier chain
callback for all device handler instead for one per handler.
[sekharan: Fix rejections caused by conflicting bug fix]
Some of the storage devices (that can be accessed through multiple paths),
do need some special handling for
1. Activating the passive path of the storage access.
2. Decode and handle the special sense codes returned by the devices.
3. Handle the I/Os being sent to the passive path, especially
during the device probe time.
when accessed through multiple paths.
As of today this special device handling is done at the dm-multipath
layer using dm-handlers. That works well for (1); for (2) to be handled
at dm layer, scsi sense information need to be exported from SCSI to dm-layer,
which is not very attractive; (3) cannot be done at all at the dm layer.
Device handler has been moved to SCSI mainly to handle (2) and (3) properly.
Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com>
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
