Signed-off-by: Jayamohan Kallickal <jayamohan.kallickal@emulex.com>
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Fix be2iscsi driver to use a separate pointer for each irq action->name
field and avoid display corruption in /proc/interrupts. The be2iscsi driver
was using a single static array in a function for the irq action->name field.
This results in garbage output from /proc/interrupts
The pointer for action->name is garbage and scribbles the output on the screen.
This patch fixes the problem:
156: 0 0 0 0 0 0
0 0 0 0 0 0 0
0 0 0 0 0 0 0
0 0 0 0 PCI-MSI-X beiscsi_msix_0017
This patch is based on Prarit's patch here:
http://www.spinics.net/lists/linux-scsi/msg52325.html
but I have fixed up the failure paths and removed
redundant check for !i suggested by Eike.
This patch renames the following iscsi_proto.h structures to avoid
namespace issues with drivers/target/iscsi/iscsi_target_core.h:
*) struct iscsi_cmd -> struct iscsi_scsi_req
*) struct iscsi_cmd_rsp -> struct iscsi_scsi_rsp
*) struct iscsi_login -> struct iscsi_login_req
This patch includes useful ISCSI_FLAG_LOGIN_[CURRENT,NEXT]_STAGE*,
and ISCSI_FLAG_SNACK_TYPE_* definitions used by iscsi_target_mod, and
fixes the incorrect definition of struct iscsi_snack to following
RFC-3720 Section 10.16. SNACK Request.
Also, this patch updates libiscsi, iSER, be2iscsi, and bn2xi to
use the updated structure definitions in a handful of locations.
Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
Bump version.
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
- Modifying copyright year to 2011
- Replacing Serverengines with Emulex as Serverengines Corp
has been acquired by Emulex Corp
Signed-off-by: Jayamohan Kallickal <jayamohank@serverengines.com>
This patch increases the max_sectors to 2048
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
This patch contains changes for adding support for iscsi_boot.
Have modified to make read of mac address from chip as a function.
The mac_address is being cached after teh first call as it is
not expected to change
be2iscsi driver should #include linux/if_ether.h since it uses
sysfs_format_mac().
It should also depend on NET since it selects SCSI_ISCSI_ATTRS,
which depends on NET.
These changes fix a build error when CONFIG_NET is not enabled:
ERROR: "sysfs_format_mac" [drivers/scsi/be2iscsi/be2iscsi.ko] undefined!
Acked-by: Jayamohan Kallickal <jayamohank@serverengines.com>
This patch ensures that the same ITT is maintained across
all login pdu's
These changes allow the driver to support crashdump. We need to reset the
chip incase of a crashdump
The latest checkpatch.pl throws some new warnings. Fixing it
to get rid of a bunch of warnings
This patch fixes some situations where enough resources were not
avaialable when targets exceeded a certain limit
This patch cleans up device and target reset handling
for the driver
This patch contains changes to support the BE3 chip
This patch replaces 2009 with 2010 in copyright statement
The number of SGE's supported is fixed to what the
chip expects. Also, the max sectors set to tested values
This patches enables async mode for mcc rings so that
multiple requests can be queued.
This patch will link the current allocated wrb with the next
wrb that will be allocated. This is a requirement from the chip.
This patch enablesi be2iscsi to use the start number and number
of cids/icd provided by FW rather than hard coded values.
This patch enables msix for be2iscsi. It also enables use
of mcc_rings for fw commands. Since the mcc eq creation is
dependent on msix I am sending as one patch
This patch contains changes to use pci_pools for iscsi hdr
instead of pci_alloc_consistent. Here we alloc and free to pool
for every IO
v3:
- Remove cleanup loop in beiscsi_session_destroy
- Fixup for allocation failure handling in beiscsi_alloc_pdu
- Removed unused variable in beiscsi_session_destroy.
[jejb: fix up pci_pool_alloc address sizing problem]
This patch contains changes that allow iscsi_session_setup
to allocate private space for LLD's
Acked-by: Mike Christie <michaelc@cs.wisc.edu>
[v2: fixed up virt_to_bus() issue spotted by sfr]
