path: root/drivers/scsi/advansys.c
2007-10-12[SCSI] advansys: Create AdvLoadMicrocodeMatthew Wilcox
Split AdvLoadMicrocode out of AdvInitAsc3550Driver, AdvInitAsc38C0800Driver and AdvInitAsc38C1600Driver. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Create AdvBuildCarrierFreelistMatthew Wilcox
Split AdvBuildCarrierFreelist out of AdvInitAsc3550Driver, AdvInitAsc38C0800Driver and AdvInitAsc38C1600Driver. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Fix VLB driver nameMatthew Wilcox
You can't have two drivers for the same bus type with the same name. Since ISA and VLB are both isa_drivers, rename the VLB one to advansys_vlb. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Move documentation to Documentation/scsiMatthew Wilcox
The 700+-line comment at the top of the advansys driver fits more comfortably in Documentation/scsi. Delete the sections on: - kernels supported - other files modified (obsolete) - source comments (obsolete) - tests to run - release history (that's what a VCS is for) - contacting connectcom (the domain has expired and the phone number is now in use by another organisation) Known problems/fix list is moved down to the section where jejb put his FIXME. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: use memcpy instead of open-coded loopMatthew Wilcox
Use memcpy to initialise eep_config instead of a loop. For AdvInitFrom38C1600EEP where we need to modify the default EEPROM configuration, do it after the loop, and do it using the structure definition, not by finding the right byte. I think it was wrong for big-endian machines. Also delete some non-useful comments and prototypes. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove pci_slot_infoMatthew Wilcox
The driver kept a copy of the PCI config address; refer to the pci_dev associated with the card instead. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Remove library-style callback routinesMatthew Wilcox
Convert adv_isr_callback, adv_async_callback and asc_isr_callback into direct calls. Remove the unused asc_exe_callback. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Move struct device out of the cfg structuresMatthew Wilcox
The cfg structures are supposed to be disposable after initialisation; with the 'dev' used for DMA mapping in there, that's not possible. Move the dev to the board. Also inline AscInitFromAscDvcVar into its only caller, remove some unnecessary prototypes and sort out a few minor formatting issues. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Stop using n_io_port in Scsi_Host structureMatthew Wilcox
n_io_port isn't suitable for advansys because some of the boards have more than 255 bytes of io port space. There's already a driver-private replacement, asc_n_io_port, but for some reason the driver was still setting and occasionally reporting n_io_port. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: ioremap no longer needs page-aligned addressesMatthew Wilcox
At some point during Linux 2.1 development, ioremap() gained the ability to handle addresses which weren't page-aligned. Also expand the CONFIG_PCI range to encompass that entire section of wide board initialisation, since all wide boards are PCI. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: delete AscGetChipBusTypeMatthew Wilcox
By moving a test from AscGetChipBusType into its only caller, we can delete the whole function Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: misc reformattingMatthew Wilcox
Remove some useless forward declarations Reformat some comments, debug messages, and the occasional piece of real code Removal of unnecessary braces Remove duplicate setting of shost->irq Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: remove INQUIRY sniffingMatthew Wilcox
Use slave_configure() to do all the work that used to be done in AscInquiryHandling and AdvInquiryHandling. Split slave_configure into two functions, one for wide and one for narrow controllers. Remove some unused definitions, duplicate definitions, unnecessary declarations, and scsireqq, cap_info and inquiry from struct asc_board. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: remove AscCompareString()Matthew Wilcox
AscCompareString() is just another name for strncmp Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: More PCI cleanupsMatthew Wilcox
- Remove wrappers around the PCI configuration space accessors - Call pci_set_master() instead of poking at config space directly - Move the latency setting into one function called for both narrow and wide boards. - Tidy up AdvInitGetConfig() a little. - Delete a few unused prototypes and definitions. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Update resource managementMatthew Wilcox
Make sure the resources are reserved and released by all the callers of advansys_board_found(). This eliminates the check_region-style race. It also allows us to use the pci_request_regions() API. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Convert to ISA driver modelMatthew Wilcox
Register two isa_drivers, one for ISA and one for VLB, in order to preserve detection order. When deleting advansys_detect, we lose the last vestiges of the code that limited IO port scanning. This code has been effectively disabled for many years anyway; I'll restore it in a module_param later. We also lose the code that placed all ISA PnP cards into WaitForKey state -- drivers shouldn't be doing this anyway. The asc_host array goes away too. Also remove some IOADR and other definitions, such as ASC_NUM_BOARD_SUPPORTED. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Convert to EISA driver modelMatthew Wilcox
- Switch EISA probing to the driver model - Remove some now-unused macros and functions - Update the FIXME now that we use the correct driver model probing API Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Convert to PCI driver modelMatthew Wilcox
- Add a pci_driver interface for the PCI advansys devices (for ISA/EISA/VLB devices, we still call advansys_detect). - Many functions are converted from __init to __devinit to allow hotplug PCI to work. - Only keep devices found by advansys_detect in the asc_host list. - Rename asc_board_count to asc_legacy_count. New asc_board_count is only used to generate a unique name for each device. - Remove some now-unused macros and struct definitions Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Move to scsi hotplug initialisation modelMatthew Wilcox
- Switch from scsi_register/scsi_unregister to scsi_host_alloc, scsi_add_host, scsi_scan_host and scsi_host_put. - Rename the scsi_host_template to advansys_template - Use module_init and module_exit instead of scsi_module.c - Remove protection against advansys_detect being called twice Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Make advansys_board_found a little more readableMatthew Wilcox
- Put all the error cleanup at the end of the function and goto the appropriate label - Split advansys_wide_init_chip out of advansys_board_found - Split advansys_wide_free_mem out of advansys_board_found. Use it from advansys_release - Use GFP_KERNEL, not GFP_ATOMIC, when allocating memory during initialisation - Eliminate lots of PROC_FS ifdefs by removing the ifdefs around the prtbuf struct member Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Stop checking the scsi_cmnd belongs to our Scsi_HostMatthew Wilcox
The interrupt routines used to walk the list of Scsi_Hosts belonging to this driver to make sure that the scsi_cmnd belonged to one of them. This is a waste of time and gets in the way of later cleanups, so delete it. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Improve interrupt handlerMatthew Wilcox
Pass the Scsi_Host to the interrupt handler, rather than polling all hosts for each interrupt. Return IRQ_NONE if we didn't handle this interrupt Don't set the IRQF_DISABLED flag; this is not a fast-executing interrupt handler. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: Clean up proc_info implementationMatthew Wilcox
Just use the Scsi_Host passed in, rather than looking through the driver's own array of boards for one that matches it. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] advansys: undate version, copyright, etcMatthew Wilcox
Update the version to 3.4 Add my copyright Add myself to MAINTAINERS Exercise my right to change the license from dual BSD/GPL to GPL Don't force the definition of CONFIG_ISA on x86 Always include pci.h Stop including stat.h Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-27[SCSI] advansys: lindent and other large, uninteresting changesMatthew Wilcox
- Run Lindent - Move advansys_detect and advansys_release to the end of the file - Split advansys_board_found out of advansys_detect - Rename a few variables, such as shp to shost and pci_devp to pdev - Turn STATIC into static Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-27[SCSI] advansys: cleanupsAdrian Bunk
- remove the unneeded advansys.h - remove the unused advansys_setup() - make needlessly global functions static Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-07[SCSI] advansys: clean up warningsKen Witherow
Fix typecast warnings and switch from check_region to request_region (akpm: Ken and Jeffrey Phillips Freeman <jeffreyfreeman@syncleus.com> are possible advansys testers) Signed-off-by: Ken Witherow <ken@krwtech.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-03[SCSI] advansys: wrap PCI table inside ifdef CONFIG_PCIRandy Dunlap
The Advansys ISA/EISA/PCI driver has a compile error when CONFIG_PCI=n, so wrap the pci_device_id table inside ifdef CONFIG_PCI. drivers/scsi/advansys.c: At top level: drivers/scsi/advansys.c:18219: error: array type has incomplete element type drivers/scsi/advansys.c:18221: error: 'PCI_ANY_ID' undeclared here (not in a function) make[2]: *** [drivers/scsi/advansys.o] Error 1 make[1]: *** [drivers/scsi] Error 2 make: *** [drivers] Error 2 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-10[PATCH] NULL noise removal: advansysAl Viro
2006-10-10[PATCH] advansys __iomem annotationsAl Viro
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-08-04[SCSI] advansys pci tweaks.Dave Jones
Remove a lot of duplicate #defines from the advansys driver, and make them look like PCI IDs as defined elsewhere in the kernel. Also add a module table so that it automatically gets picked up by tools relying on modinfo output (like say, distro installers). Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26spelling fixesAndreas Mohr
acquired (aquired) contiguous (contigious) successful (succesful, succesfull) surprise (suprise) whether (weather) some other misspellings Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-25[PATCH] advansys section fixesRandy Dunlap
Priority: not critical. Mark 3 functions __init. Saves a little memory. This makes these functions' calls to AdvWaitEEPCmd() (which is __init) be clean (i.e., eliminates text -> init -> text call chain). Fix multiple section mismatch warnings: WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet3550EEPConfig' (at offset 0x7a22) and 'AdvSet38C0800EEPConfig' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet3550EEPConfig' (at offset 0x7a4e) and 'AdvSet38C0800EEPConfig' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet3550EEPConfig' (at offset 0x7a79) and 'AdvSet38C0800EEPConfig' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet3550EEPConfig' (at offset 0x7aa2) and 'AdvSet38C0800EEPConfig' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet3550EEPConfig' (at offset 0x7abb) and 'AdvSet38C0800EEPConfig' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C0800EEPConfig' (at offset 0x7ae0) and 'AdvSet38C1600EEPConfig' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C0800EEPConfig' (at offset 0x7b0c) and 'AdvSet38C1600EEPConfig' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C0800EEPConfig' (at offset 0x7b37) and 'AdvSet38C1600EEPConfig' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C0800EEPConfig' (at offset 0x7b60) and 'AdvSet38C1600EEPConfig' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C0800EEPConfig' (at offset 0x7b79) and 'AdvSet38C1600EEPConfig' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C1600EEPConfig' (at offset 0x7b9e) and 'AdvExeScsiQueue' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C1600EEPConfig' (at offset 0x7bca) and 'AdvExeScsiQueue' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C1600EEPConfig' (at offset 0x7bf5) and 'AdvExeScsiQueue' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C1600EEPConfig' (at offset 0x7c1e) and 'AdvExeScsiQueue' WARNING: drivers/scsi/advansys.o - Section mismatch: reference to .init.text: from .text between 'AdvSet38C1600EEPConfig' (at offset 0x7c37) and 'AdvExeScsiQueue' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-29[SCSI] advansys driver: limp along on x86Linus Torvalds
Let people enable the advansys driver on x86-32, even though it's broken on other architectures due to missing DMA mapping infrastructure. It's used by Jeffrey Phillips Freeman <jeffreyfreeman@syncleus.com> and possibly others. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-11-07[PATCH] kfree cleanup: drivers/scsiJesper Juhl
This is the drivers/scsi/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/scsi/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-08[SCSI] add global timeout to the scsi mid-layerJames Bottomley
There are certain rogue devices (and the aic7xxx driver) that return BUSY or QUEUE_FULL forever. This code will apply a global timeout (of the total number of retries times the per command timer) to a given command. If it is exceeded, the command is completed regardless of its state. The patch also removes the unused field in the command: timeout and timeout_total. This solves the problem of detecting an endless loop in the mid-layer because of BUSY/QUEUE_FULL bouncing, but will not recover the device. In the aic7xxx case, the driver can be recovered by sending a bus reset, so possibly this should be tied into the error handler? Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-26[SCSI] remove scsi_cmnd->abort_reasonChristoph Hellwig
Never used for anything but printing it out in debug routines. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-26[SCSI] remove scsi_set_deviceChristoph Hellwig
scsi_add_host is the proper place to set the device, but people copy the scsi_set_device usage from older drivers again and again. note that this leaves some legacy drivers like qlogicisp/qlogicfc without pci association in sysfs, but they're scheduled to go away soon anyway. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-18[PATCH] scsi: remove meaningless scsi_cmnd->serial_number_at_timeout field
scsi_cmnd->serial_number_at_timeout doesn't serve any purpose anymore. All serial_number == serial_number_at_timeout tests are always true in abort callbacks. Kill the field. Also, as ->pid always equals ->serial_number and ->serial_number doesn't have any special meaning anymore, update comments above ->serial_number accordingly. Once we remove all uses of this field from all lldd's, this field should go. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-18[PATCH] scsi: remove unused scsi_cmnd->internal_timeout field
scsi_cmnd->internal_timeout field doesn't have any meaning anymore. Kill the field. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
