path: root/drivers/s390/sysinfo.c
2007-02-05[S390] Calibrate delay and bogomips.Martin Schwidefsky
Preset the bogomips number to the cpu capacity value reported by store system information in SYSIB 1.2.2. This value is constant for a particular machine model and can be used to determine relative performance differences between machines. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-09-20[S390] cleanup sysinfo and add system z9 specific extensions.Martin Schwidefsky
With System z9 additional fields have been added to the output of the store system information instruction. This patch adds the new model information field and the alternate cpu capability fields to the output of /proc/sysinfo. While we at it clean up the code as well. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
