path: root/drivers/s390/cio
2009-01-09[S390] qdio: fix broken pointer in case of CONFIG_DEBUG_FS is disabledJan Glauber
If CONFIG_DEBUG_FS is disabled debugfs_create_file returns -ENODEV instead of zero. Since the return value is stored and used at shutdown to remove existing entries an OOPS may be triggered. Add a check of the debugfs_create_file return value and in case of an error set the entry to NULL so it will be ignored at shutdown. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-01-08fix similar typos to successfullColy Li
When I review ocfs2 code, find there are 2 typos to "successfull". After doing grep "successfull " in kernel tree, 22 typos found totally -- great minds always think alike :) This patch fixes all the similar typos. Thanks for Randy's ack and comments. Signed-off-by: Coly Li <coyli@suse.de> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jeremy Kerr <jk@ozlabs.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-31[PATCH] improve idle cputime accountingMartin Schwidefsky
Distinguish the cputime of the idle process where idle is actually using cpu cycles from the cputime where idle is sleeping on an enabled wait psw. The former is accounted as system time, the later as idle time. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] convert cio printks to pr_xxx macros.Michael Ernst
Signed-off-by: Michael Ernst <mernst@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: use pim to check for multipath.Sebastian Ott
To check if multipath is available we count the bits set in lpm, which could change over time (via configure [on|off] of a path). The following patch uses the pim (which is persistent) for this decision. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: commit all pmcw changes.Sebastian Ott
Sometimes we change the pmcw configuration but don't call msch to transmit these changes to the channel subsystem. The patch fixes this by calling cio_commit_config in such cases. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: introduce cio_commit_configSebastian Ott
To change the configuration of a subchannel we alter the modifiable bits of the subchannel's schib field and issue a modify subchannel. There can be the case that not all changes were applied -or worse- quietly overwritten by the hardware. With the next store subchannel we obtain the current state of the hardware but lose our target configuration. With this patch we introduce a subchannel_config structure which contains the target subchannel configuration. Additionally the msch wrapper cio_modify is replaced with cio_commit_config which copies the desired changes to a temporary schib. msch is then called with the temporary schib. This schib is only written back to the subchannel if all changes were applied. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: introduce cio_update_schibSebastian Ott
There is the chance that we get condition code 0 for a stsch but the resulting schib is not vaild. In the current code there are 2 cases: * we do a check for validity of the schib after stsch, but at this time we have already stored the invaild schib in the subchannel structure. This may lead to problems. * we don't do a check for validity, which is not that good either. The patch addresses both issues by introducing the stsch wrapper cio_update_schib which performs stsch on a local schib. This schib is only written back to the subchannel if it's valid. side note: For some functions (chp_events) the return codes are different now (-ENXIO vs -ENODEV) but this shouldn't do harm since the caller doesn't check for _specific_ errors. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: Use device_is_registered().Cornelia Huck
Check if a ccw device is registered via device_is_registered() and not via the old kludge of checking the membership in driver core internal klists. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: Dont call ->release directly.Cornelia Huck
Just put the cdev's reference count to give up our reference. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: Dont fail probe for I/O subchannels.Cornelia Huck
If we fail the probe for an I/O subchannel, we won't be able to unregister it again since there are no sch_event() callbacks for unbound subchannels. Just succeed the probe in any case and schedule unregistering the subchannel. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: Only register ccw_device for registered subchannel.Cornelia Huck
There is a race between io_subchannel_register() and io_subchannel_sch_event() which may cause a subchannel to be unregistered because it is no longer operational before io_subchannel_register() had run. We need to check whether the subchannel is still registered before the ccw device can be registered and just bail out if it is not. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: Fix I/O subchannel refcounting.Cornelia Huck
Subchannel refcounting was incorrect in some places, especially a refcount was missing when ccw_device_call_sch_unregister() was called and the refcount was not correctly switched after moving devices. Fix this by establishing the following rules: - The ccw_device obtains a reference on its parent subchannel when dev.parent is set and gives it up in its release function. This is needed because we need a parent reference for correct refcounting even before the ccw device is (if at all) registered. - When calling device_move(), obtain a reference on the new subchannel before moving the ccw device and give up the reference on the old parent after moving. This brings the refcount in line with the first rule. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: Fix reference counting for online/offline.Cornelia Huck
The current code attempts to get an extra reference count for online devices by doing a get_device() in ccw_device_online() and a put_device() in ccw_device_done(). However, this - incorrectly obtains an extra reference for disconnected devices becoming available again (since they are already online) - needs special checks for css_init_done in order to handle the console device - is not obvious and - may incorretly drop a reference count in ccw_device_done() if that function is called after path verification for a device that just became not operational. So let's just get the reference in ccw_device_set_online() and drop it in ccw_device_set_offline(). (Unfortunately, we still need the special case in io_subchannel_probe().) Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: Put referernce on correct device after moving.Cornelia Huck
2008-12-25[S390] cio: fix ccwgroup online vs. ungroup race conditionPeter Oberparleiter
Ensure atomicity of ungroup operation to prevent concurrent ungroup and online processing which may lead to use-after-release situations. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: move irritating comment.Sebastian Ott
Due to former patches a comment and device id initialization were split from the addressed function call in io_subchannel_probe. Move it back to where it belongs. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] cio: get rid of compile warningHeiko Carstens
Move cio_tpi() to the rest of the CONFIG_CCW_CONSOLE functions to get rid of this one: drivers/s390/cio/cio.c:115: warning: 'cio_tpi' defined but not used Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] qdio: fix error reporting for hipersocketsJan Glauber
Hipersocket connections can encounter temporary busy conditions. In case of the busy bit set we retry the SIGA operation immediatelly. If the busy condition still persists after 100 ms we fail and report the error to the upper layer. The second stage retry logic is removed. In case of ongoing busy conditions the upper layer needs to reset the connection. The reporting of a SIGA error is now done synchronously to allow the network driver to requeue the buffers. Also no error trace is created for the temporary SIGA errors so the error message view is not flooded. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] qdio: improve inbound buffer acknowledgementJan Glauber
- Use automatic acknowledgement of incoming buffers in QEBSM mode - Move ACK for non-QEBSM mode always to the newest buffer to prevent a race with qdio_stop_polling - Remove the polling spinlock, the upper layer drivers return new buffers in the same code path and could not run in parallel - Don't flood the error log in case of no-target-buffer-empty - In handle_inbound we check if we would overwrite an ACK'ed buffer, if so advance the pointer to the oldest ACK'ed buffer so we don't overwrite an empty buffer in qdio_stop_polling Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] qdio: rework debug feature loggingJan Glauber
- make qdio_trace a per device view - remove s390dbf exceptions - remove CONFIG_QDIO_DEBUG, not needed anymore if we check for the level before calling sprintf - use snprintf for dbf entries - add start markers to see if the dbf view wrapped - add a global error view for all queues Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] qdio: fix compile warning under 31 bitJan Glauber
The QEBSM instructions are only available for CONFIG_64BIT, they are not used under 31 bit. Make compiler happy about the false positive: drivers/s390/cio/qdio_main.c: In function ?qdio_inbound_q_done?: drivers/s390/cio/qdio_main.c:532: warning: ?state? may be used uninitialized in this function Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] qdio: add eqbs/sqbs instruction countersJan Glauber
Add counters for the eqbs and sqbs instructions that indicate how often we issued the instructions and how often the instructions returned with less buffers than specified. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-25[S390] qdio: fix qeth port count detectionJan Glauber
qeth needs to get the port count information before qdio has allocated a page for the chsc operation. Extend qdio_get_ssqd_desc() to store the data in the specified structure. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-11-14[S390] cio: Fix refcount after moving devices.Cornelia Huck
In ccw_device_move_to_orphanage(), a replacing ccw_device is searched via get_{disc,orphaned}_ccwdev_by_dev_id() which obtain a reference on the returned ccw_device. This reference must be given up again after the device has been moved to its new parent. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-28[S390] qdio: remove incorrect memsetJan Glauber
Remove the memset since zeroing the string is not needed and use snprintf instead of sprintf. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-28[S390] qdio: prevent double qdio shutdown in case of I/O errorsJan Glauber
In case of I/O errors on a qdio subchannel qdio_shutdown may be called twice by the qdio driver and by zfcp. Remove the superfluous shutdown from qdio and let the upper layer driver handle the error condition. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] Move private simple udelay function to arch/s390/lib/delay.c.Heiko Carstens
Move cio's private simple udelay function to lib/delay.c and turn it into something much more readable. So we have all implementations at one place. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] qdio enhanced SIGA (iqdio) support.Klaus-Dieter Wacker
Add support for z10 HiperSockets multiwrite SBALs on output queues. This is used on LPAR with EDDP enabled devices. Signed-off-by: Klaus-Dieter Wacker <kdwacker@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] cio: fix cio_tpi.Heiko Carstens
In cio_tpi only disable bottom halves when not in interrupt context. Otherwise a WARN_ON gets triggered. Besides that, when we are in interrupt context bottom halves are disabled anyway. Fixes this one: Badness at kernel/softirq.c:77 Modules linked in: CPU: 2 Not tainted 2.6.26 #4 Process swapper (pid: 0, task: 000000003fe83db0, ksp: 000000003fea7d28) Krnl PSW : 0404c00180000000 0000000000053f4e (__local_bh_disable+0xbe/0xcc) R:0 T:1 IO:0 EX:0 Key:0 M:1 W:0 P:0 AS:3 CC:0 PM:0 EA:3 Krnl GPRS: 0000000000008ee0 00000000005f95e0 0000000000000000 0000000000000001 000000000020be92 0000000000000000 0000000000000210 00000000005d36c0 000000003fb5f4d8 0000000000000000 000000000020bed0 000000003fb5f3c8 00000000009be920 0000000000364898 000000003fb5f408 000000003fb5f3c8 Krnl Code: 0000000000053f42: bf2f1000 icm %r2,15,0(%r1) 0000000000053f46: a774ffc5 brc 7,53ed0 0000000000053f4a: a7f40001 brc 15,53f4c >0000000000053f4e: a7280001 lhi %r2,1 0000000000053f52: 50201000 st %r2,0(%r1) 0000000000053f56: a7f4ffbd brc 15,53ed0 0000000000053f5a: 0707 bcr 0,%r7 0000000000053f5c: a7f13fc0 tmll %r15,16320 Call Trace: ([<0000000000000210>] 0x210) [<0000000000053f86>] local_bh_disable+0x2a/0x38 [<000000000020bed0>] wait_cons_dev+0xd4/0x154 [<0000000000247cb2>] raw3215_make_room+0x6a/0x1a8 [<000000000024861a>] raw3215_write+0x86/0x28c [<00000000002488a0>] con3215_write+0x80/0x110 [<000000000004c3e0>] __call_console_drivers+0xc8/0xe4 [<000000000004c47e>] _call_console_drivers+0x82/0xc4 [<000000000004c744>] release_console_sem+0x218/0x2c0 [<000000000004cf64>] vprintk+0x3c0/0x504 [<0000000000354a4a>] printk+0x52/0x64 [<0000000000088004>] __print_symbol+0x40/0x50 [<0000000000071dbc>] print_stack_trace+0x78/0xac [<0000000000079e78>] print_lock_dependencies+0x148/0x208 [<000000000007a050>] print_irq_inversion_bug+0x118/0x15c [<000000000007a106>] check_usage_forwards+0x72/0x84 [<000000000007a36e>] mark_lock+0x1d2/0x594 [<000000000007baca>] __lock_acquire+0x886/0xf48 [<000000000007c234>] lock_acquire+0xa8/0xe0 [<0000000000350316>] _write_lock+0x56/0x98 [<000000000026cd92>] zfcp_erp_adapter_reopen+0x4e/0x8c [<000000000026f1e8>] zfcp_qdio_int_resp+0x2e4/0x2f4 [<00000000002210f4>] qdio_int_handler+0x274/0x888 [<00000000002177b6>] ccw_device_call_handler+0x6e/0xd8 [<0000000000215336>] ccw_device_irq+0xd6/0x160 [<0000000000212f88>] io_subchannel_irq+0x8c/0x118 [<000000000020c120>] do_IRQ+0x1d0/0x1fc [<00000000000270b2>] io_return+0x0/0x8 [<000000000001c8a4>] cpu_idle+0x178/0x21c ([<000000000001c884>] cpu_idle+0x158/0x21c) [<00000000003483a2>] start_secondary+0xb6/0xc8 INFO: lockdep is turned off. Last Breaking-Event-Address: [<0000000000053f4a>] __local_bh_disable+0xba/0xcc Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] cio: Correct use of ! and &Julia Lawall
In commit e6bafba5b4765a5a252f1b8d31cbf6d2459da337, a bug was fixed that involved converting !x & y to !(x & y). The code below shows the same pattern, and thus should perhaps be fixed in the same way. In particular, the result of !scsw_stctl(&request->irb.scsw) & SCSW_STCTL_STATUS_PEND is always just !scsw_stctl(&request->irb.scsw). The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression E; constant C; @@ ( !E & !C | - !E & C + !(E & C) ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] cio: inline assembly cleanupPeter Oberparleiter
Fix incorrect in- and output constraints, remove volatile declaration of inline assembly parameters and reformat constraint declarations to be more consistent. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] bus_id -> dev_set_name() for css and ccw bussesCornelia Huck
Convert remaining s390 users setting bus_id to dev_set_name() or init_name. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] bus_id ->dev_name() conversions in qdioMartin Schwidefsky
Use dev_name() in the new qdio driver. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] more bus_id -> dev_name conversionsCornelia Huck
Some further bus_id -> dev_name() conversions in s390 code. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] bus_id -> dev_set_name() changesCornelia Huck
Convert most s390 users setting bus_id to dev_set_name(). css and ccw busses are deferred since they need some special treatment. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] bus_id -> dev_name conversionsKay Sievers
bus_id -> dev_name() conversions in s390 code. [cornelia.huck@de.ibm.com: minor adaptions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] cio: introduce purge function for /proc/cio_ignorePeter Oberparleiter
Allow users to remove blacklisted ccw devices by using the /proc/cio_ignore interface: echo purge > /proc/cio_ignore will remove all devices which are offline and blacklisted. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] cio: move device unregistration to dedicated work queuePeter Oberparleiter
Use dedicated slow path work queue when unregistering a device due to a user action. This ensures serialialization of other register/ unregister requests. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-10[S390] qdio: speed up multicast traffic on full HiperSocket queueUrsula Braun
If an asynchronous HiperSockets queue runs full, no further packet can be sent. In this case the next initiative to give transmitted skbs back to the stack is triggered only by a 10-seconds qdio timer. This timer has been introduced for low multicast traffic scenarios to guarantee freeing of skbs in a limited amount of time. For high HiperSocket multicast traffic scenarios progress checking on the outbound queue should be enforced by tasklet rescheduling. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-03[S390] qdio: prevent stack clobberJan Glauber
Don't print more information than fits into the string on the stack. Combine the informational output of qdio to fit into one line. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-09-16[S390] cio: fix orb initialization in cio_start_keyStefan Weinhuber
The functions cio_tm_start_key and cio_start_key use the same private orb structure of a subchannel, so the orb needs to be cleared of old data before it is used again. A respective memset is missing from cio_start_key and hereby added. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-09-16[S390] cio: Fix driver_data handling for ccwgroup devices.Cornelia Huck
Since 16f7f9564c3ae190954f2ec55f385a268b93ac4d, we've seen oopses when grouping/ungrouping devices: Unable to handle kernel pointer dereference at virtual kernel address 0000000000 114000 Oops: 0004 [#1] PREEMPT SMP Modules linked in: bonding qeth_l2 dm_multipath sunrpc qeth_l3 dm_mod qeth chsc_ sch ccwgroup CPU: 1 Not tainted 2.6.26-29.x.20080815-s390xdefault #1 Process iperf (pid: 24412, task: 000000003f446038, ksp: 000000003c929e08) Krnl PSW : 0404d00180000000 000003e00006f6e6 (qeth_irq+0xda/0xb28 [qeth]) R:0 T:1 IO:0 EX:0 Key:0 M:1 W:0 P:0 AS:3 CC:1 PM:0 EA:3 Krnl GPRS: 0000000000000000 000003e000000003 0000000000000000 0000000000114ccc 000000003fb82e48 000003e00006f60c 000000000000000c 000000003ce72100 0000000000114944 000000003fb82e48 0000000000114ccc 000000003fe8fd28 000003e000066000 000003e000076128 000000003fe8fdb8 000000003fe8fd28 Krnl Code: 000003e00006f6da: bf3f2024 icm %r3,15,36(%r2) 000003e00006f6de: a774023c brc 7,3e00006fb56 000003e00006f6e2: a7280000 lhi %r2,0 >000003e00006f6e6: 5020a1a0 st %r2,416(%r10) 000003e00006f6ea: 58109000 l %r1,0(%r9) 000003e00006f6ee: a7111000 tmll %r1,4096 000003e00006f6f2: a77400f9 brc 7,3e00006f8e4 000003e00006f6f6: 8810000c srl %r1,12 Call Trace: ([<000000003fe8fd20>] 0x3fe8fd20) [<000000000033bf2a>] ccw_device_call_handler+0xb2/0xd8 [<0000000000339e1c>] ccw_device_irq+0x124/0x164 [<0000000000339758>] io_subchannel_irq+0x8c/0x118 [<00000000003309ba>] do_IRQ+0x192/0x1bc [<0000000000114f66>] io_return+0x0/0x8 [<00000000001149cc>] sysc_do_svc+0x0/0x22 ([<0000000000114a18>] sysc_noemu+0x10/0x16) [<00000200002e047c>] 0x200002e047c Last Breaking-Event-Address: [<000003e00006f6d6>] qeth_irq+0xca/0xb28 [qeth] The problem is that dev->driver_data for a ccw device is NULL, while it should point to the ccwgroup device it is a member of. This happened due to incorrect cleanup if creating a ccwgroup device failed because the ccw devices were already grouped. Fix this by setting cdev[i] to NULL in the error handling of ccwgroup_create_from_string() after we give up our reference and by checking if the driver_data points to the ccwgroup device in ccwgroup_release() just to be really sure. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-09-09[S390] cio: allow offline processing for disconnected devicesPeter Oberparleiter
When disconnected ccw devices are removed, the device has to be set offline, otherwise there will be side effects including a reference count imbalance. This patch modifies ccw_device_offline to work for devices in disconnecte/not operational state. ccw_device_offline is called by cio for devices which are online during device removal. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-09-09[S390] cio: handle ssch() return codes correctly.Cornelia Huck
ssch() has two classes of return codes: - condition codes (0-3) which need to be translated to Linux error codes - Linux error codes (-EIO on exceptions) which should be passed to the caller (instead of erronously being handled like condition code 3) Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-09-09[S390] cio: Correct cleanup on error.Cornelia Huck
Fix cleanup on error in chp_new() and init_channel_subsystem() (must not call kfree() on structures that had been registered). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-21[S390] cio: call ccw driver notify function with lock heldPeter Oberparleiter
Calling a ccw driver's notify function without the ccw device lock held opens up a race window between discovery and handling of a change in the device operational state. As a result, the device driver may encounter unexpected device malfunction, leading to out-of-retry situations or similar. Remove race by extending the ccw device lock from state change discovery to the calling of the notify function. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-21[S390] cio: fix ccw group device cleanupPeter Oberparleiter
Fix ccw group device initialization: initialize device object before using reference counting during cleanup. Fixes the following message when group device initialization fails (e.g. because too few devices where specified): kobject: '<NULL>' (..): is not initialized, yet kobject_put() is being called. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-21[S390] qdio: remove the module_get & module_put pairJan Glauber
Increasing the qdio reference count for every used subchannel is unnecessary since unloading qdio (if build as a module) is only possible if other modules that use qdio are unloaded. Unloading modules that use qdio in turn requires that these modules shut down all qdio subchannels. Therefore the additional module_get reference is not needed. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
