path: root/drivers/s390/char/vmlogrdr.c
2008-02-26Update the i.MX31 Kernel to 2.6.232.6.23-mx31ads-2008022618072.6.23-mx31-200802261807Justin Waters
This is the result of a brute-force attempt to update the kernel to 2.6.23. Now that we have a git tree, our effort will be a little nicer in the future. Signed-off-by: Justin Waters <justin.waters@timesys.com>
2007-04-27[S390] SPIN_LOCK_UNLOCKED cleanup in drivers/s390Milind Arun Choudhary
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead. Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] vmlogrdr: stop IUCV connection in vmlogrdr_release.Ursula Braun
Reopen of /dev/account failed. The IUCV path has to be terminated in vmlogrdr_release. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-12[PATCH] mark struct file_operations const 5Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-08[S390]: Adapt vmlogrdr driver to new IUCV APIMartin Schwidefsky
Adapt vmlogrdr character device driver to new IUCV API Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-05[S390] Get rid of a lot of sparse warnings.Heiko Carstens
2006-07-12[S390] Fix sparse warnings.Heiko Carstens
2006-03-24[PATCH] s390: kzalloc() conversion in drivers/s390Eric Sesterhenn
Convert all kmalloc + memset sequences in drivers/s390 to kzalloc usage. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] arguments out of order in class_device_create() call (s390)Al Viro
2005-10-28[PATCH] Driver Core: fix up all callers of class_device_create()Greg Kroah-Hartman
The previous patch adding the ability to nest struct class_device changed the paramaters to the call class_device_create(). This patch fixes up all in-kernel users of the function. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-25[PATCH] s390: add vmcp interfaceChristian Borntraeger
Add interface to issue VM control program commands. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/char/raw3270.c - drivers/net/netiucv.c: update ↵Yani Ioannou
device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-20[PATCH] class: convert drivers/* to use the new class api instead of ↵gregkh@suse.de
class_simple Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
