All num, magic and owner are set by alloc_tty_driver. No need to
re-set them on each allocation site.
pti driver sets something different to what it passes to
alloc_tty_driver. It is not a bug, since we don't use the lines
parameter in any way. Anyway this is fixed, and now we do the right
thing.
Acked-by: Tilman Schmidt <tilman@imap.cc>
The patch "tty: now phase out the ioctl file pointer for good" missed
the tty3270 driver. This is the missing piece.
All keyboard ioctls are compatible, so we can simply
move the compat handling into the vt and tty3270 drivers.
Lockdep found a problem with the lock order of the view lock and the
ccw device lock. raw3270_activate_view/raw3270_deactivate_view first
take the ccw device lock then call the activate/deactivate functions
of the view which take view lock. The update functions of the
con3270/tty3270 view will first take the view lock, then take the
ccw device lock. To fix this the activate/deactivate functions are
changed to avoid taking the view lock by moving the functions calls
that modify the 3270 output buffer to the update function which is
called by a timer.
The tty3270_notifier that calls tty_register_device / tty_unregister_device
is harmful in two ways:
1) the device node that is create is wrong because the minor numbers for
3270 tty start with 1 and tty_notifier passes the minor as index.
2) If 1) is corrected you'll get a warning:
WARNING: at fs/sysfs/dir.c:462 sysfs_add_one+0x4c/0x60()
sysfs: duplicate filename '227:1' can not be created
The 227:1 link is already created by raw3270_create_attributes to refer
to ../../class/tty/tty<devno>. There cannot be two links.
Extend the scsw data structure to the format required by fcx. Also
provide helper functions for easier access to fields which are present
in both the traditional as well as the modified format.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
The wrong function got coverted ;)
CC drivers/s390/char/tty3270.o
drivers/s390/char/tty3270.c:1747:
warning: initialization from incompatible pointer type
Acked-by: Alan Cox <alan@redhat.com>
Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Put the changes into the drivers first. This will still compile/work but
produce a warning if bisected so can still be debugged
Signed-off-by: Alan Cox <alan@redhat.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Also removes a bunch of ^L in drivers/s390/cio/cmf.c
This is the grungy swap all the occurrences in the right places patch that
goes with the updates. At this point we have the same functionality as
before (except that sgttyb() returns speeds not zero) and are ready to
begin turning new stuff on providing nobody reports lots of bugs
If you are a tty driver author converting an out of tree driver the only
impact should be termios->ktermios name changes for the speed/property
setting functions from your upper layers.
If you are implementing your own TCGETS function before then your driver
was broken already and its about to get a whole lot more painful for you so
please fix it 8)
Also fill in c_ispeed/ospeed on init for most devices, although the current
code will do this for you anyway but I'd like eventually to lose that extra
paranoia
[akpm@osdl.org: bluetooth fix]
[mp3@de.ibm.com: sclp fix]
[mp3@de.ibm.com: warning fix for tty3270]
[hugh@veritas.com: fix tty_ioctl powerpc build]
[jdike@addtoit.com: uml: fix ->set_termios declaration]
Signed-off-by: Martin Peschke <mp3@de.ibm.com>
Acked-by: Peter Oberparleiter <oberpar@de.ibm.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
As part of an SMP cleanliness pass over UML, I consted a bunch of
structures in order to not have to document their locking. One of these
structures was a struct tty_operations. In order to const it in UML
without introducing compiler complaints, the declaration of
tty_set_operations needs to be changed, and then all of its callers need to
be fixed.
This patch declares all struct tty_operations in the tree as const. In all
cases, they are static and used only as input to tty_set_operations. As an
extra check, I ran an i386 allyesconfig build which produced no extra
warnings.
53 drivers are affected. I checked the history of a bunch of them, and in
most cases, there have been only a handful of maintenance changes in the
last six months. serial_core.c was the busiest one that I looked at.
Call init_timer only once fpr tp->timer in tty3270.
Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
I've always found this flag confusing. Now that devfs is no longer around, it
has been renamed, and the documentation for when this flag should be used has
been updated.
Also fixes all drivers that use this flag.
Also fixes all drivers that set this field.
Convert all kmalloc + memset sequences in drivers/s390 to kzalloc usage.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Fix fullscreen view of the 3270 device driver.
Signed-off-by: Richard Hitt <rbh00@utsglobal.com>
infrastructure for it.
Let it rip!
