path: root/drivers/s390/char/sclp_vt220.c
2008-03-05[S390] sclp_vt220: speed up console output for interactive workChristian Borntraeger
Currently an output buffer can wait up to HZ/2 until the buffer is flushed. The wait time is noticeable in interactive tools like mc. Change the value to HZ/20, which seems enough for interactive work. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-02-19[S390] sclp: clean up send/receive naming schemePeter Oberparleiter
Make state change events adjust the correct mask by cleaning up naming inconsistencies. Also remove chance for lockup by removing unnecessary mask related check before reading events. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-02-09[S390] sclp_vt220: Fix vt220 initializationChristian Borntraeger
There are two problems in the vt220 intialization: o Currently the vt220 console looses early printk events until the the vt220 tty is registered. o console should work if tty_register fails sclp_vt220_con_init calls __sclp_vt220_init and register_console. It does not register the driver with the sclp core code via sclp_register. That results in an sclp_send_mask=0. Therefore, __sclp_vt220_emit will reject buffers with EIO. Unfortunately register_console will cause the printk buffer to be sent to the console and, therefore, every early message gets dropped. The sclp_send_mask is set later during boot, when sclp_vt220_tty_init calls sclp_register. The solution is to move the sclp_register call from sclp_vt220_tty_init to __sclp_vt220_init. This makes sure that the console is properly registered with the sclp subsystem before the first log buffer messages are passed to the vt220 console. We also adopt the cleanup on error to keep the console alive if tty_register fails. Thanks to Peter Oberparleiter and Heiko Carstens for review and ideas for improvement. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-02-05[S390] sclp_tty/sclp_vt220: Fix scheduling while atomicChristian Borntraeger
Under load the following bug message appeared while using sysrq-t: BUG: scheduling while atomic: bash/3662/0x00000004 0000000000105b74 000000003ba17740 0000000000000002 0000000000000000 000000003ba177e0 000000003ba17758 000000003ba17758 0000000000105bfe 0000000000817ba8 000000003f2a5350 0000000000000000 0000000000000000 000000003ba17740 000000000000000c 000000003ba17740 000000003ba177b0 0000000000568630 0000000000105bfe 000000003ba17740 000000003ba17790 Call Trace: ([<0000000000105b74>] show_trace+0x13c/0x158) [<0000000000105c58>] show_stack+0xc8/0xfc [<0000000000105cbc>] dump_stack+0x30/0x40 [<000000000012a0c8>] __schedule_bug+0x84/0x94 [<000000000056234e>] schedule+0x5ea/0x970 [<0000000000477cd2>] __sclp_vt220_write+0x1f6/0x3ec [<0000000000477f00>] sclp_vt220_con_write+0x38/0x48 [<0000000000130b4a>] __call_console_drivers+0xbe/0xd8 [<0000000000130bf0>] _call_console_drivers+0x8c/0xd0 [<0000000000130eea>] release_console_sem+0x1a6/0x2fc [<0000000000131786>] vprintk+0x262/0x480 [<00000000001319fa>] printk+0x56/0x68 [<0000000000125aaa>] print_cfs_rq+0x45e/0x4a4 [<000000000012614e>] sched_debug_show+0x65e/0xee8 [<000000000012a8fc>] show_state_filter+0x1cc/0x1f0 [<000000000044d39c>] sysrq_handle_showstate+0x2c/0x3c [<000000000044d1fe>] __handle_sysrq+0xae/0x18c [<00000000002001f2>] write_sysrq_trigger+0x8a/0x90 [<00000000001f7862>] proc_reg_write+0x9a/0xc4 [<00000000001a83d4>] vfs_write+0xb8/0x174 [<00000000001a8b88>] sys_write+0x58/0x8c [<0000000000112e7c>] sysc_noemu+0x10/0x16 [<0000020000116f68>] 0x20000116f68 The problem seems to be, that with a full console buffer, release_console_sem disables interrupts with spin_lock_irqsave and then calls the console function without enabling interrupts. __sclp_vt220_write checks for in_interrupt, to decide if it can schedule. It should check for in_atomic instead. The same is true for sclp_tty.c. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-07-27[S390] Fix sclp_vt220 error handling.Heiko Carstens
Also convert to slab_is_available() as an indicator if get_zeroed_page() will work or not. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-07-27[S390] Get rid of new section mismatch warnings.Heiko Carstens
2007-04-27[S390] sclp: fix coding style.Stefan Haberland
Use only capital letters for defines. Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] Convert memory detection into C code.Heiko Carstens
Hopefully this will make it more maintainable and less error prone. Code makes use of search_exception_tables(). Since it calls this function before the kernel exeception table is sorted, there is an early call to sort_main_extable(). This way it's easy to use the already present infrastructure of fixup sections. Also this would allows to easily convert the rest of head[31|64].S into C code. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] Get rid of a lot of sparse warnings.Heiko Carstens
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] TTY layer buffering revampAlan Cox
The API and code have been through various bits of initial review by serial driver people but they definitely need to live somewhere for a while so the unconverted drivers can get knocked into shape, existing drivers that have been updated can be better tuned and bugs whacked out. This replaces the tty flip buffers with kmalloc objects in rings. In the normal situation for an IRQ driven serial port at typical speeds the behaviour is pretty much the same, two buffers end up allocated and the kernel cycles between them as before. When there are delays or at high speed we now behave far better as the buffer pool can grow a bit rather than lose characters. This also means that we can operate at higher speeds reliably. For drivers that receive characters in blocks (DMA based, USB and especially virtualisation) the layer allows a lot of driver specific code that works around the tty layer with private secondary queues to be removed. The IBM folks need this sort of layer, the smart serial port people do, the virtualisers do (because a virtualised tty typically operates at infinite speed rather than emulating 9600 baud). Finally many drivers had invalid and unsafe attempts to avoid buffer overflows by directly invoking tty methods extracted out of the innards of work queue structs. These are no longer needed and all go away. That fixes various random hangs with serial ports on overflow. The other change in here is to optimise the receive_room path that is used by some callers. It turns out that only one ldisc uses receive room except asa constant and it updates it far far less than the value is read. We thus make it a variable not a function call. I expect the code to contain bugs due to the size alone but I'll be watching and squashing them and feeding out new patches as it goes. Because the buffers now dynamically expand you should only run out of buffering when the kernel runs out of memory for real. That means a lot of the horrible hacks high performance drivers used to do just aren't needed any more. Description: tty_insert_flip_char is an old API and continues to work as before, as does tty_flip_buffer_push() [this is why many drivers dont need modification]. It does now also return the number of chars inserted There are also tty_buffer_request_room(tty, len) which asks for a buffer block of the length requested and returns the space found. This improves efficiency with hardware that knows how much to transfer. and tty_insert_flip_string_flags(tty, str, flags, len) to insert a string of characters and flags For a smart interface the usual code is len = tty_request_buffer_room(tty, amount_hardware_says); tty_insert_flip_string(tty, buffer_from_card, len); More description! At the moment tty buffers are attached directly to the tty. This is causing a lot of the problems related to tty layer locking, also problems at high speed and also with bursty data (such as occurs in virtualised environments) I'm working on ripping out the flip buffers and replacing them with a pool of dynamically allocated buffers. This allows both for old style "byte I/O" devices and also helps virtualisation and smart devices where large blocks of data suddenely materialise and need storing. So far so good. Lots of drivers reference tty->flip.*. Several of them also call directly and unsafely into function pointers it provides. This will all break. Most drivers can use tty_insert_flip_char which can be kept as an API but others need more. At the moment I've added the following interfaces, if people think more will be needed now is a good time to say int tty_buffer_request_room(tty, size) Try and ensure at least size bytes are available, returns actual room (may be zero). At the moment it just uses the flipbuf space but that will change. Repeated calls without characters being added are not cumulative. (ie if you call it with 1, 1, 1, and then 4 you'll have four characters of space. The other functions will also try and grow buffers in future but this will be a more efficient way when you know block sizes. int tty_insert_flip_char(tty, ch, flag) As before insert a character if there is room. Now returns 1 for success, 0 for failure. int tty_insert_flip_string(tty, str, len) Insert a block of non error characters. Returns the number inserted. int tty_prepare_flip_string(tty, strptr, len) Adjust the buffer to allow len characters to be added. Returns a buffer pointer in strptr and the length available. This allows for hardware that needs to use functions like insl or mencpy_fromio. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
