path: root/drivers/s390/char/raw3270.c
2011-05-23[S390] get rid of unused variablesHeiko Carstens
Remove trivially unused variables as detected with -Wunused-but-set-variable. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-03-23[S390] ccw_driver: remove duplicate membersSebastian Ott
Remove the owner and name members of struct ccw_driver and convert all drivers to store this data in the embedded struct device_driver. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-01-05[S390] 3270: add support for irq statisticsHeiko Carstens
Add support for 3270 I/O interrupt statistics in /proc/interrupts. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-06[S390] 3270 console build fixSebastian Ott
Fix this build failure: drivers/s390/built-in.o: In function `raw3270_pm_unfreeze': (.text+0x3ac04): undefined reference to `ccw_device_force_console' with: CONFIG_TN3270=y CONFIG_TN3270_CONSOLE=n CONFIG_TN3215_CONSOLE=n Reported-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-22[S390] driver_data accessMartin Schwidefsky
Replace the remaining direct accesses to the driver_data pointer with calls to the dev_get_drvdata() and dev_set_drvdata() functions. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-22[S390] 3270 console: convert from bootmem to slabHeiko Carstens
The slab allocator is earlier available so convert the bootmem allocations to slab/gfp allocations. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (64 commits) debugfs: use specified mode to possibly mark files read/write only debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem. xen: remove driver_data direct access of struct device from more drivers usb: gadget: at91_udc: remove driver_data direct access of struct device uml: remove driver_data direct access of struct device block/ps3: remove driver_data direct access of struct device s390: remove driver_data direct access of struct device parport: remove driver_data direct access of struct device parisc: remove driver_data direct access of struct device of_serial: remove driver_data direct access of struct device mips: remove driver_data direct access of struct device ipmi: remove driver_data direct access of struct device infiniband: ehca: remove driver_data direct access of struct device ibmvscsi: gadget: at91_udc: remove driver_data direct access of struct device hvcs: remove driver_data direct access of struct device xen block: remove driver_data direct access of struct device thermal: remove driver_data direct access of struct device scsi: remove driver_data direct access of struct device pcmcia: remove driver_data direct access of struct device PCIE: remove driver_data direct access of struct device ... Manually fix up trivial conflicts due to different direct driver_data direct access fixups in drivers/block/{ps3disk.c,ps3vram.c}
2009-06-16[S390] pm: con3270 power management callbacks.Martin Schwidefsky
Introduce the power management callbacks to the 3270 driver. On suspend the current 3270 view is deactivated and for non-console 3270 device the release callback is done. This disconnects the current tty / fullscreen application from the 3270 device. On resume the current view is reactivated, on the tty you get a fresh login. If the system panics before the 3270 device has been resumed, the ccw device for the 3270 console is reactivated with ccw_device_force_console. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2009-06-15s390: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Thanks to Sebastian Ott <sebott@linux.vnet.ibm.com> for fixing a few typos in my original version of this patch. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: linux-s390@vger.kernel.org Cc: linux390@de.ibm.com Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16device create: s390: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-10[S390] more bus_id -> dev_name conversionsCornelia Huck
Some further bus_id -> dev_name() conversions in s390 code. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-21device create: s390: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-14[S390] Cleanup 3270 printk messages.Martin Schwidefsky
Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] drivers/s390: Eliminate NULL test and memset after alloc_bootmemJulia Lawall
As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b, alloc_bootmem and related functions never return NULL and always return a zeroed region of memory. Thus a NULL test or memset after calls to these functions is unnecessary. drivers/s390/char/raw3270.c | 11 +---------- drivers/s390/char/sclp_con.c | 2 -- 2 files changed, 1 insertion(+), 12 deletions(-) This was fixed using the following semantic patch. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression E; statement S; @@ E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...) ... when != E ( - BUG_ON (E == NULL); | - if (E == NULL) S ) @@ expression E,E1; @@ E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...) ... when != E - memset(E,0,E1); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] cio: introduce fcx enabled scsw formatPeter Oberparleiter
Extend the scsw data structure to the format required by fcx. Also provide helper functions for easier access to fields which are present in both the traditional as well as the modified format. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-05-30[S390] 3270: fix race with stack local wait_queue_head_t.Martin Schwidefsky
A wait_event call with a stack local wait_queue_head_t structure that is used to do the wake up for the wait_event is inherently racy. After the wait_event finished the wake_up call might not have completed yet. Remove the stack local wait_queue_head_t from raw3270_start_init and use the global raw3270_wait_queue instead. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] use LIST_HEAD instead of LIST_HEAD_INITDenis Cheng
single list_head variable initialized with LIST_HEAD_INIT could almost always can be replaced with LIST_HEAD declaration, this shrinks the code and looks better. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-10-22[S390] struct class_device -> struct device conversion.Cornelia Huck
Convert struct class_device users under drivers/s390/char to use struct device. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-08-22[S390] vmur: fix diag14 exceptions with addresses > 2GB.Michael Holzheu
There are several s390 diagnose calls, which must be executed below the 2GB memory boundary. In order to enforce this, those diagnoses must be compiled into the kernel. Currently diag 14 can be called within the vmur kernel module from addresses above 2GB. This leads to specification exceptions. This patch moves diag10, diag14 and diag210 into the new diag.c file. Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-07-27[S390] Get rid of new section mismatch warnings.Heiko Carstens
2007-05-31[S390] raw3270: use mutex instead of semaphoreChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-10[S390] cio: Get rid of _ccw_device_get_device_number().Cornelia Huck
The function shouldn't have existed in the first place (not MSS-aware). Introduce a new function ccw_device_get_id() that extracts the ccw_dev_id structure of a ccw device and convert all users of _ccw_device_get_device_number to ccw_device_get_id. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-05[S390] Get rid of a lot of sparse warnings.Heiko Carstens
2006-07-18[S390] sysfs_create_xxx return values.Heiko Carstens
Take return values of sysfs_create_group & friends into account. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-12[S390] Fix sparse warnings.Heiko Carstens
2006-06-29[S390] modular 3270 driver.Martin Schwidefsky
The initial i/o to a 3270 device is done using the static module variables raw3270_init_data and raw3270_init_request. If the 3270 device driver is built as a module and gets loaded above 2GB, the initial i/o will fail because these variables will get addresses > 2GB. To make it work the two variables are moved to struct raw3270 and the data structure is allocated with GFP_DMA. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-03-26[PATCH] sem2mutex: misc static one-file mutexesIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jens Axboe <axboe@suse.de> Cc: Neil Brown <neilb@cse.unsw.edu.au> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: Greg KH <greg@kroah.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] s390: kzalloc() conversion in drivers/s390Eric Sesterhenn
Convert all kmalloc + memset sequences in drivers/s390 to kzalloc usage. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-18[PATCH] s390: fix class_device_create calls in 3270 the driverMartin Schwidefsky
Add the missing NULL argument to the class_device_create calls. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: drivers/s390Jesper Juhl
This is the drivers/s390/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/s390/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Cornelia Huck <cohuck@de.ibm.com> Acked-by: Stefan Bader <Stefan.Bader@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] s390: 3270 fullscreen viewRichard Hitt
Martin Schwidefsky <schwidefsky@de.ibm.com> Fix fullscreen view of the 3270 device driver. Signed-off-by: Richard Hitt <rbh00@utsglobal.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] s390: disconnected 3270 consoleMartin Schwidefsky
Fix reboot with a disconnected 3270 console. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/char/raw3270.c - drivers/net/netiucv.c: update ↵Yani Ioannou
device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
