path: root/drivers/rtc
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-01[PATCH] rtc-sysfs fixAndrew Morton
It's not clear how this thinko got through.. Cc: Olaf Hering <olaf@aepfle.de> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] RTC: rtc-ds1553, rtc-ds1742 updateAtsushi Nemoto
Check return value of sysfs_create_bin_file(). Fix polarity of RTC_BATT_FLAG bit in DS1742. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] AT91rm9200 RTC can issue system wakeup eventsDavid Brownell
This lets the at91rm9200 RTC alarm be a system wakeup irq, according to the setting of /sys/devices/platform/at91_rtc/power/wakeup. User code can set the alarm, put the system into a low power mode, and then rely on it waking up no later than the specified moment. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] constify rtc_class_ops: update driversDavid Brownell
Update RTC framework so that drivers can constify their method tables, moving them from ".data" to ".rodata". Then update the drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] RTC class: error checksDavid Brownell
The rtc_is_valid_tm() routine needs to treat some of the fields it checks as unsigned, to prevent wrongly accepting invalid rtc_time structs; this is the same approach used elsewhere in the RTC code for such tests. Conversely, rtc_proc_show() is missing one invalid-day-of-month test that rtc_is_valid_tm() makes: there is no day zero. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] RTC class uses subsys_initDavid Brownell
This makes RTC core components use "subsys_init" instead of "module_init", as appropriate for subsystem infrastructure. This is mostly useful for statically linking drivers in other parts of the tree that may provide an RTC interface as a secondary functionality (e.g. part of a multifunction chip); they won't need to worry so much about drivers/Makefile link order. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] RTC class: Kconfig improvementsDavid Brownell
Small updates to make the RTC class Kconfig text be more informative. This should help folk used to the drivers/char/rtc.c support, or a single RTC, be slightly less surprised by the differences. Also, adds a new RTC_DEBUG option to predefine DEBUG in the framework and its drivers, while debugging. That's getting to be a standard idiom, and it's pretty useful. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] rtc driver rtc-pcf8563 century bit inversedJean-Baptiste Maneyrol
The century bit PCF8563_MO_C in the month register is misinterpreted. It is set to 1 for the 20th century and 0 for 21th, and the driver is expecting the opposite behavior. Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove unnecessary check in drivers/rtc/rtc-v3020.cEric Sesterhenn
Looks like the probe function always gets a valid pdev, and checking it after dereferencing it is pretty useless. This patch removes the check (cid #1365) Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Raphael Assenat <raph@raphnet.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] rtc: remove superfluous call to call to cdev_del()Rolf Eike Beer
If cdev_add() fails there is no good reason to call cdev_del(). Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] RTC: more XSTP/VDET support for rtc-rs5c348 driverAtsushi Nemoto
If the chip detected "oscillator stop" condition, show an warning message. And initialize it with the Epoch time instead of leaving it with unknown date/time. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Fix typo in rtc kconfigPavel Machek
Fix simple typo in RTC_HCTOSYS option. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27rtc: New RTC driver for SuperH On-Chip RTC.Paul Mundt
This replaces the old SH RTC driver, and allows us to clean quite a lot of things up on the board-specific side. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-08-27[PATCH] rtc-s3c.c: fix time setting checksBen Dooks
Fix the year check on setting the time with the S3C24XX RTC driver. Also move the debug to before the set to see what is going on if it does fail. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] drivers/rtc: fix rtc-s3c.cBen Dooks
In the cleanups of drivers/rtc/s3c-rtc.c, the base address for the registers got broken. This patch fixes that by ensuring the readb/writeb are all prefixed with the base returned from ioremap()ing the registers. Also fix check for valid year range, which was the wrong way around. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] RTC subsystem, Add ISL1208 supportHerbert Valerio Riedel
Add support for the I2C-attached Intersil ISL1208 RTC chip. [akpm@osdl.org: cleanups, fixlets] Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-13[MIPS] vr41xx: Move IRQ numbers to asm-mips/vr41xx/irq.hYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] RTC: class driver for Samsung S3C series SoCBen Dooks
This is a renamed and tested version of the previous S3C24XX RTC class driver. The driver has been renamed from the original s3c2410-rtc, which is now too narrow for the range of devices supported. The rtc-s3c has been chosen as there is the distinct possibility of this driver being carried forward into newer Samsung SoC silicon. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30fix a typo in the RTC_CLASS help textAdrian Bunk
This patch fixes a typo spotted by Matt LaPlante <webmaster@cyberdogtech.com>. This patch fixes kernel Bugzilla #6704. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-28[PATCH] RTC: add rtc-rs5c348 driverAtsushi Nemoto
Add an SPI driver for the Ricoh RS5C348 RTC chip. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] rtc: fix idr lockingSonny Rao
We need to serialize access to the global rtc_idr even in this error path. Signed-off-by: Sonny Rao <sonny@burdell.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] RTC: Add a comment for ENOIOCTLCMD in ds1553_rtc_ioctlAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] spin/rwlock init cleanupsIngo Molnar
locking init cleanups: - convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK() - convert rwlocks in a similar manner this patch was generated automatically. Motivation: - cleanliness - lockdep needs control of lock initialization, which the open-coded variants do not give - it's also useful for -rt and for lock debugging in general Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] RTC: add rtc-ds1742 driverAtsushi Nemoto
Add an RTC driver for the Dallas DS1742 RTC chip. [akpm@osdl.org: cleanups, compile fix] Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] RTC: add rtc-ds1553 driverAtsushi Nemoto
Add an RTC driver for the Dallas DS1553 RTC chip. [akpm@osdl.org: cleanups, compile fix] Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] at91rm9200-rtc-driver-tidyAndrew Morton
- whitespace fixes (80-col display) - one unneeded cast of void* Cc: Andrew Victor <andrew@sanpeople.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] AT91RM9200 RTC driverAndrew Victor
Adds support for the RTC integrated in the Atmel AT91RM9200 SoC. Driver was originally written for 2.4 by Rick Bronson. Then converted to 2.6 ARM RTC API by Steven Scholz. Now converted to the RTC class model. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] RTC: Add rtc_year_days() to calculate tm_ydayAndrew Victor
RTC: Add exported function rtc_year_days() to calculate the tm_yday value. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Add v3020 RTC supportRaphael Assenat
This patch adds support for the v3020 RTC from EM Microelectronic. The v3020 RTC is designed to be connected on a bus using only one data bit. Since any data bit may be used, it is necessary to specify this to the driver by passing a struct v3020_platform_data pointer (see include/linux/rtc-v3020.h) to the driver. Part of the following code comes from the kernel patchs produced by Compulab for their products. The original file (available here: http://raph.people.8d.com/misc/emv3020.c) was released under the terms of the GPL license. [akpm@osdl.org: cleanups] Signed-off-by: Raphael Assenat <raph@raphnet.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Add max6902 RTC supportRaphael Assenat
Add support for the MAX6902 SPI RTC chip. Tested on a pxa2xx cpu. The compulab code comes from the kernel patch the produce for their cn-x255 board. (inside a zip file on the http://www.compulab.co.il/x255/html/x255-developer.htm) The original file (drivers/char/max6902.c) was GPL, which is of course an appropriate licence: /* * max6902.c * * Driver for MAX6902 RTC * * Copyright (C) 2004 Compulab Ltd. * * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. * * */ For reference, you can get the original file here: http://raph.people.8d.com/misc/max6902.c [akpm@osdl.org: cleanups] Signed-off-by: Raphael Assenat <raph@raphnet.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] rtc subsystem: add capability checksAlessandro Zummo
Centralize CAP_SYS_XXX checks to avoid duplicate code and missing checks in the drivers. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] rtc subsystem, fix capability checks in kernel interfaceAlessandro Zummo
Remove commented capability checks and add some others. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] drivers/acorn/char/pcf8583.[hc] vs. RTC subsystemG. Liakhovetski
A port of the driver for the pcf8583 i2c rtc controller to the generic RTC framework by Alessandro Zummo. Based on drivers/acorn/char/{pcf8583.[hc],i2c.c}. Hopefully, acorn can be converted too to use this driver in the future. Signed-off-by: G. Liakhovetski <gl@dsa-ac.de> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] RTC: rtc-dev UIE emulationAtsushi Nemoto
Import genrtc's RTC UIE emulation (CONFIG_GEN_RTC_X) to rtc-dev driver with slight adjustments/refinements. This makes UIE-less rtc drivers work better with programs doing read/poll on /dev/rtc, such as hwclock. This emulation should not harm rtc drivers with UIE support, since rtc_dev_ioctl() calls underlaying rtc driver's ioctl() first. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] "RTC-framework" driver for DS1307 and similar RTC chipsDavid Brownell
This is an "RTC-framework" driver for DS1307 and similar RTC chips, It should be a full replacement for the existing ds1337.c driver (using the older RTC glue), giving a net increase in the number of RTC chips that work out-of-the-box. There's a whole cluster of RTCs that are very similar, but the 1337 driver was a bit too picky to work with most of them. Still no support for RTC alarm IRQs (on chips that support them). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Add driver for ARM AMBA PL031 RTCDeepak Saxena
Add a driver for the ARM PL031 RTC found on some ARM SOCs. The driver is fairly trivial as the RTC only provides a read/write and alarm capability. [akpm@osdl.org: compile fix] Signed-off-by: Deepak <dsaxena@plexity.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-05[PATCH] m48t86: ia64 build fixAndrew Morton
From: Andrew Morton <akpm@osdl.org> drivers/rtc/rtc-m48t86.c: In function `m48t86_rtc_read_time': drivers/rtc/rtc-m48t86.c:51: error: structure has no member named `ia64_mv' drivers/rtc/rtc-m48t86.c:55: error: structure has no member named `ia64_mv' drivers/rtc/rtc-m48t86.c:56: error: structure has no member named `ia64_mv' drivers/rtc/rtc-m48t86.c:57: error: structure has no member named `ia64_mv' drivers/rtc/rtc-m48t86.c:58: error: structure has no member named `ia64_mv' drivers/rtc/rtc-m48t86.c:60: error: structure has no member named `ia64_mv' readb() and writeb() are macros on ia64. Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] rtc subsystem: use ENOIOCTLCMD and ENOTTY where appropriateAlessandro Zummo
Appropriately use -ENOIOCTLCMD and -ENOTTY when the ioctl is not implemented by a driver. (akpm: we're not allowed to return -ENOIOCTLCMD to userspace. This patch does the right thing). Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-06[ARM] rtc-sa1100: fix compiler warnings and error cleanupRussell King
Fix: drivers/rtc/rtc-sa1100.c: In function `sa1100_rtc_proc': drivers/rtc/rtc-sa1100.c:298: warning: unsigned int format, long unsigned int arg (arg 3) and arrange for sa1100_rtc_open() to pass the devid to free_irq() rather than NULL. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-01[PATCH] RTC: rtc-dev tweak for 64-bit kernelAtsushi Nemoto
Make rtc-dev work well on 64-bit platforms with 32-bit userland. On those platforms, users might try to read 32-bit integer value. This patch make rtc-dev's read() work well for both "int" and "long" size. This tweak is came from genrtc driver. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: VR41XX cleanupAlessandro Zummo
Clean up kconfig entry for the rtc-vr41xx. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: VR41XX driverYoichi Yuasa
This patch updates VR4100 series RTC driver. * This driver supports new RTC subsystem. * Simple set time/read time test worked fine. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: SA1100 cleanupAlessandro Zummo
- convert printks to dev_xxx - remove messages in excess Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: compact error messagesAlessandro Zummo
Move registration error message from drivers to core. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: RS5C372 sysfs fixAlessandro Zummo
Fix sysfs show() return code Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: fix proc outputAlessandro Zummo
Move the "24hr: yes" proc output from drivers to rtc proc code. This is required because the time value in the proc output is always in 24hr mode regardless of the driver. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: whitespaces and error messages cleanupAlessandro Zummo
- fix whitespace - remove some debugging in excess Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: X1205 sysfs cleanupAlessandro Zummo
