path: root/drivers/rtc/rtc-x1205.c
2012-10-06drivers/rtc/rtc-x1205.c: convert struct i2c_msg initialization to C99 formatShubhrajyoti D
Convert the struct i2c_msg initialization to C99 format. This makes maintaining and editing the code simpler. Also helps once other fields like transferred are added in future. Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com> Reviewed-by: Felipe Balbi <balbi@ti.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23rtc: convert rtc i2c drivers to module_i2c_driverAxel Lin
Factor out some boilerplate code for i2c driver registration into module_i2c_driver. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Piotr Ziecik <kosmo@semihalf.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Scott Wood <scottwood@freescale.com> Cc: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Cc: Mike Rapoport <mike@compulab.co.il> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Roman Fietze <roman.fietze@telemotive.de> Cc: Herbert Valerio Riedel <hvr@gnu.org> Cc: Alexander Bigga <ab@mycable.de> Cc: Dale Farnsworth <dale@farnsworth.org> Cc: Gregory Hermant <gregory.hermant@calao-systems.com> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Martyn Welch <martyn.welch@ge.com> Cc: Byron Bradley <byron.bbradley@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31rtc: Add module.h to implicit users in drivers/rtcPaul Gortmaker
The module.h was implicitly everywhere, but when we clean that up, the implicit users will compile fail; fix them up in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2009-12-16rtc-x1205: unconditionally set date when setting clockJohannes Weiner
All callsites of x1205_set_datetime() want the date to be set as well, so remove the flag parameter and set it unconditionally. Signed-off-by: Johannes Weiner <jw@emlix.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-01rtc-x1205: reset clock to sane state after power failureJohannes Weiner
When detecting power failure, the probe function would reset the clock time to defined state. However, the clock's _date_ might still be bogus and a subsequent probe fails when sanity-checking these values. Change the power-failure fixup code to do a full setting of rtc_time, including a valid date. Signed-off-by: Johannes Weiner <jw@emlix.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-01rtc-x1205: fix rtc_time to y2k register value conversionJohannes Weiner
The possible CCR_Y2K register values are 19 or 20 and struct rtc_time's tm_year is in years since 1900. The function translating rtc_time to register values assumes tm_year to be years since first christmas, though, and we end up storing 0 or 1 in the CCR_Y2K register, which the hardware does not refuse to do. A subsequent probing of the clock fails due to the invalid value range in the register, though. [ And if it didn't, reading the clock would yield a bogus year because the function translating registers to tm_year is assuming a register value of 19 or 20. ] This fixes the conversion from years since 1900 in tm_year to the corresponding CCR_Y2K value of 19 or 20. Signed-off-by: Johannes Weiner <jw@emlix.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20drivers/rtc/: use bcd2bin/bin2bcdAdrian Bunk
Change drivers/rtc/ to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04rtc-x1205: Fix alarm setMichael Hamel
I have discovered that the current version of rtc-x1205.c does not work correctly when asked to set the alarm time by the RTC_WKALM_SET ioctl() call. This happens because the alarm registers do not behave like the current-time registers. They are non-volatile. Two things go wrong: - the X1205 requires a 10 msec delay after any attempt to write to the non-volatile registers. The x1205_set_datetime() routine does the write as 8 single-byte writes without any delay. Only the first write succeeds. The second is NAKed because the chip is busy. - the X1205 resets the RWEL bit after any write to the non-volatile registers. This would lock out any further writes after the first even with a 10msec delay. I fix this by doing a single 8-byte write and then waiting 10msec for the chip to be ready. A side effect of this change is that it will speed up x1205_rtc_set_time() which uses the same code. I have also implemented the 'enable' bit in the rtc_wkalm structure, which the existing driver does not attempt to do. I have modified both x1205_rtc_set_alarm() to set the AL0E bit, and x1205_rtc_read_alarm() to return it. I have tested this patch on a LinkSys NSLU2 under OpenWRT, but on no other hardware. On the NSLU2 the X1205 correctly asserts its IRQ pin when the alarm time matches the current time. [akpm@linux-foundation.org: clean up over-parenthesisation] Signed-off-by: Michael Hamel <mhamel@adi.co.nz> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29i2c: Convert most new-style drivers to use module aliasingJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. Update most new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. I've left the video drivers apart (except for SoC camera drivers) as they're a bit more diffcult to deal with, they'll have their own patch later. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Jochen Friedrich <jochen@scram.de>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-04-28rtc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28rtc-x1205: new style conversionAlessandro Zummo
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-27i2c: normal_i2c can be made const (rtc drivers)Jean Delvare
Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it>
2007-07-12i2c: Delete outdated x1205 driver documentationJean Delvare
The x1205 driver moved to the RTC subsystem and was significantly modified since then, so just delete the outdated documentation. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Alessandro Zummo <alessandro.zummo@towertech.it>
2007-02-13i2c: Stop using i2c_adapter.class_devJean Delvare
Stop using i2c_adapter.class_dev, as it is going to be removed soon. Luckily, there are only 4 RTC drivers affected. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Alessandro Zummo <a.zummo@towertech.it>
2006-12-10[PATCH] RTCs don't use i2c_adapter.devDavid Brownell
Update more I2C drivers that live outside drivers/i2c to understand that using adapter->dev is not The Way. When actually referring to the adapter hardware, adapter->class_dev.dev is the answer. When referring to a device connected to it, client->dev.dev is the answer. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] RTC: handle sysfs errorsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] constify rtc_class_ops: update driversDavid Brownell
Update RTC framework so that drivers can constify their method tables, moving them from ".data" to ".rodata". Then update the drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: compact error messagesAlessandro Zummo
Move registration error message from drivers to core. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: fix proc outputAlessandro Zummo
Move the "24hr: yes" proc output from drivers to rtc proc code. This is required because the time value in the proc output is always in 24hr mode regardless of the driver. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: whitespaces and error messages cleanupAlessandro Zummo
- fix whitespace - remove some debugging in excess Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: X1205 sysfs cleanupAlessandro Zummo
Fix sysfs show() return code Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC subsystem: X1205 driverAlessandro Zummo
A port of the existing x1205 driver under the new RTC subsystem. It is actually under test within the NSLU2 project (http://www.nslu2-linux.org) and it is working quite well. It is the first driver under this new subsystem and should be used as a guide to port other drivers. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
