Some rtc drivers use the ioctl method instead of the alarm_irq_enable
method for enabling alarm interupts. With the new virtualized RTC
rework, its important for drivers to use the alarm_irq_enable instead.
This patch converts the drivers that use the AIE ioctl method to
use the alarm_irq_enable method. Other ioctl cmds are left untouched.
I have not been able to test or even compile most of these drivers.
Any help to make sure this change is correct would be appreciated!
CC: Alessandro Zummo <a.zummo@towertech.it>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
Reported-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
Tested-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org>
drivers/rtc/rtc-vr41xx.c: In function 'vr41xx_rtc_irq_set_freq':
drivers/rtc/rtc-vr41xx.c:217: warning: comparison of distinct pointer types lacks a cast
drivers/rtc/rtc-vr41xx.c:217: warning: right shift count >= width of type
drivers/rtc/rtc-vr41xx.c:217: warning: passing argument 1 of '__div64_32' from incompatible pointer type
include/asm-generic/div64.h:35: note: expected 'uint64_t *' but argument is of type 'long unsigned int *'
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Move the power of 2 check on frequencies down into individual rtc drivers
This is to allow for non power of 2 real time clock periodic interrupts
such as those on the pxa27x to be found in the new pxa27x-rtc driver
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
This patch fixes a bunch of irq checking misuses. Most drivers were
getting irq via platform_get_irq(), which returns -ENXIO or r->start.
rtc-cmos.c is special. It is using PNP and platform bindings. Hopefully
nobody is using PNP IRQ 0 for RTC. So the changes should be safe.
rtc-sh.c is using platform_get_irq, but was storing a result into an
unsigned type, then was checking for < 0. This is fixed now.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
Implement the ioctls RTC_PIE_ON, RTC_PIE_OFF, RTC_IRQP_SET and
RTC_IRQP_READ in the standard RTC way.
Thanks Dave for noticing it.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable RTC
platform drivers, to re-enable module auto loading.
[dbrownell@users.sourceforge.net: more drivers, minor fix]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Greg KH <greg@kroah.com>
- vr41xx_rtc_read_alarm() reports alarm enabled.
- vr41xx_rtc_set_alarm() sets alarm disable/enable by rtc_wkalrm.enabled.
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
This patch removes class_device from the programming interface that the RTC
framework exposes to the rest of the kernel. Now an rtc_device is passed,
which is more type-safe and streamlines all the relevant code.
Acked-By: Alessandro Zummo <a.zummo@towertech.it>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Update RTC framework so that drivers can constify their method tables, moving
them from ".data" to ".rodata". Then update the drivers.
locking init cleanups:
- convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK()
- convert rwlocks in a similar manner
this patch was generated automatically.
Motivation:
- cleanliness
- lockdep needs control of lock initialization, which the open-coded
variants do not give
- it's also useful for -rt and for lock debugging in general
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Centralize CAP_SYS_XXX checks to avoid duplicate code and missing checks in
the drivers.
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Appropriately use -ENOIOCTLCMD and -ENOTTY when the ioctl is not
implemented by a driver.
(akpm: we're not allowed to return -ENOIOCTLCMD to userspace. This patch does
the right thing).
This patch updates VR4100 series RTC driver.
* This driver supports new RTC subsystem.
* Simple set time/read time test worked fine.
