path: root/drivers/rtc/rtc-v3020.c
2009-12-16rtc: fix driver data issues in several rtc driversAlessandro Zummo
Herton Ronaldo Krzesinski recently raised up, and fixed, an issue with the rtc_cmos driver, which was referring to an inconsistent driver data. This patch ensures that driver data registration happens before rtc_device_register(). Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Thomas Hommel <thomas.hommel@gefanuc.com> Acked-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Andrew Sharp <andy.sharp@onstor.com> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alexander Bigga <ab@mycable.de> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Mark Zhan <rongkai.zhan@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-12rtc: v3020: fix v3020_mmio_read_bit()Scott Valentine
v3020_mmio_read_bit() always returns 0 when left_shift > 7. v3020_mmio_read_bit()'s return type is (unsigned char). The code returns a value masked by (1 << left_shift) that is casted to the return type. If left_shift is larger than 7, the cast will always result in a 0 return value. The problem was discovered with left_shift = 16, and the included patch corrects the problem. The bug was introduced in the last (Apr 3 2009) commit of the file, kernel versions 2.6.30 and later. Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: Raphael Assenat <raph@8d.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02rtc-v3020: add ability to access v3020 chip with GPIOsMike Rapoport
The v3020 RTC can be connected to GPIOs as well as to memory-like interface. Add ability to use GPIO bit-bang for v3020 read-write access. [akpm@linux-foundation.org: fix off-by-one in error path] Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01rtc-v3020: coding style cleanupMike Rapoport
2008-10-20drivers/rtc/: use bcd2bin/bin2bcdAdrian Bunk
Change drivers/rtc/ to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28rtc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11rtc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable RTC platform drivers, to re-enable module auto loading. [dbrownell@users.sourceforge.net: more drivers, minor fix] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-11RTC v3020 fixesMike Rapoport
Fix off-by-one in month calculations Add delay for bus accesses to satisfy Tw > 500ns Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Raphael Assenat <raph@8d.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-17[PATCH] rtc: fix printk of 64-bit res on 32-bit platformJeff Garzik
With 64-bit resources on 32-bit platforms, the resource address might be larger than a void*. Fix printk to work regardless of resource size. Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] constify rtc_class_ops: update driversDavid Brownell
Update RTC framework so that drivers can constify their method tables, moving them from ".data" to ".rodata". Then update the drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove unnecessary check in drivers/rtc/rtc-v3020.cEric Sesterhenn
Looks like the probe function always gets a valid pdev, and checking it after dereferencing it is pretty useless. This patch removes the check (cid #1365) Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Raphael Assenat <raph@raphnet.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Add v3020 RTC supportRaphael Assenat
This patch adds support for the v3020 RTC from EM Microelectronic. The v3020 RTC is designed to be connected on a bus using only one data bit. Since any data bit may be used, it is necessary to specify this to the driver by passing a struct v3020_platform_data pointer (see include/linux/rtc-v3020.h) to the driver. Part of the following code comes from the kernel patchs produced by Compulab for their products. The original file (available here: http://raph.people.8d.com/misc/emv3020.c) was released under the terms of the GPL license. [akpm@osdl.org: cleanups] Signed-off-by: Raphael Assenat <raph@raphnet.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
