path: root/drivers/rtc/rtc-s3c.c
2011-12-09drivers/rtc/rtc-s3c.c: fix driver clock enable/disable balance issuesJonghwan Choi
If an error occurs after the clock is enabled, the enable/disable state can become unbalanced. Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14drivers/rtc/rtc-s3c.c: fix no occurrence of alarm interruptDonggeun Kim
The driver does not generate an alarm interrupt even though a time for an alarm is set. This results from disabling rtc_clk after setting the alarm time. To generate an alarm interrupt the driver should maintain its enabled state for rtc_clk the until alarm interrupt occurs. This patch permits generation of an alarm interrupt. [akpm@linux-foundation.org: make s3c_rtc_alarm_clk_lock local to s3c_rtc_alarm_clk_enable()] Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25drivers/rtc/rtc-s3c.c: allow multiple open / allow no-ioctl-open'ed rtc to ↵MyungJoo Ham
have irq. The previous rtc-s3c had two issues related with its IRQ. 1. Users cannot open rtc multiple times because an open operation calls request_irq on the same IRQ. (e.g., two user processes wants to open and read RTC time from rtc-s3c at the same time) 2. If alarm is set and no one has the rtc opened with filesystem (either the alarm is set by kernel/boot-loader or user set an alarm and closed rtc dev file), the pending bit is not cleared and no further interrupt is invoked. When the alarm is used by the system itself such as a resume from suspend-to-RAM or other Low-power modes/idle, this is a critical issue. This patch mitigates these issues by calling request_irq at probe and free_irq at remove. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-25drivers/rtc/rtc-s3c.c: correct debug messagesMyungJoo Ham
RTC-S3C used to print out debug messages incorrectly. This patch corrects incorrect outputs. (undecoded bcd numbers, incorrectly decoded register values) This patch affects the pr-debug messages only. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25drivers/rtc/rtc-s3c.c: support clock gatingDonggeun Kim
Add support for clock gating. Power consumption can be reduced by setting rtc_clk disabled state except for when RTC related registers are accessed. Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: KyungMin Park <kyungmin.park@samsung.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ben Dooks <ben@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-11drivers/rtc/rtc-s3c.c: fixup wake support for rtcBen Dooks
The driver is not balancing set_irq and disable_irq_wake() calls, so ensure that it keeps track of whether the wake is enabled. The fixes the following error on S3C6410 devices: WARNING: at kernel/irq/manage.c:382 set_irq_wake+0x84/0xec() Unbalanced IRQ 92 wake disable Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-29RTC: Fix s3c compile error due to missing s3c_rtc_setpieVasily Khoruzhick
s3c_rtc_setpie was removed, and it resulted in compiler error: drivers/rtc/rtc-s3c.c: In function s3c_rtc_release drivers/rtc/rtc-s3c.c:339:2: error: implicit declaration of function s3c_rtc_setpie Fix it by removing s3c_rtc_release calls. [jstultz: An identical fix was also sent in by Jiri Pinkava <jiri.pinkava@vscht.cz>] CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_freq()John Stultz
With the generic rtc code now emulating PIE mode irqs via an hrtimer, no one calls the rtc_class_ops->irq_set_freq call. This patch removes the hook and deletes the driver functions if no one else calls them. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_stateJohn Stultz
With PIE mode interrupts now emulated in generic code via an hrtimer, no one calls rtc_class_ops->irq_set_state(), so this patch removes it along with driver implementations. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-04drivers/rtc/rtc-s3c.c: fix prototype for s3c_rtc_setaie()Axel Lin
Fix s3c_rtc_setaie() prototype to eliminate the following compile warning: drivers/rtc/rtc-s3c.c:383: warning: initialization from incompatible pointer type (akpm: the rtc_class_ops.alarm_irq_enable() handler is being passed two arguments where it expects just one, presumably with undesired effects) Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rtc: rtc-s3c: add rtc_valid_tm in s3c_rtc_gettime()Kukjin Kim
Add "rtc_valid_tm" in s3c_rtc_gettime() as per Wan ZongShun's suggestion. Suggested-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rtc: rtc-s3c: fix RTC initialization methodChanghwan Youn
Change RTC initialization method in probe(). The 'rtc_valid_tm(tm)' can check whether RTC BCD is valid or not. And change the method of checking because the previous method cannot validate RTC BCD registers properly. Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rtc: rtc-s3c: Fix debug message format on RTCKukjin Kim
Fix debug message format. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rtc: rtc-s3c: fix on support RTC AlarmChanghwan Youn
The alarm_irq_enable function should be implemented to support RTC alarm. And fix tabs instead of white space around the proc field. Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rtc: rtc-s3c: fix setting missing field of getalarmChanghwan Youn
Current s3c_rtc_getalarm() sets missing field of alarm time with 0xff. But this value should be -1 according to drivers/rtc/interface.c. Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27rtc: rtc-s3c: fix access unit from byte to word on RTCCONChanghwan Youn
S3C2410_RTCCON of TYPE_S3C64XX RTC should be read/written by readw and writew, because TYPE_S3C64XX RTC uses bit 8 and 9. And TYPE_S3C2410 RTC also can access it by readw and writew. [atul.dahiya@samsung.com: tested on smdk2416] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Tested-by: Atul Dahiya <atul.dahiya@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22rtc: s3c: balance state changes of wakeup flagVladimir Zapolskiy
This change resolves a problem about unbalanced calls of enable_irq_wakeup() and disable_irq_wakeup() for alarm interrupt. Bug reproduction: root@eb600:~# echo 0 > /sys/class/rtc/rtc0/wakealarm WARNING: at kernel/irq/manage.c:361 set_irq_wake+0x7c/0xe4() Unbalanced IRQ 46 wake disable Modules linked in: [<c0025708>] (unwind_backtrace+0x0/0xd8) from [<c003358c>] (warn_slowpath_common+0x44/0x5c) [<c003358c>] (warn_slowpath_common+0x44/0x5c) from [<c00335dc>] (warn_slowpath_fmt+0x24/0x30) [<c00335dc>] (warn_slowpath_fmt+0x24/0x30) from [<c0058c20>] (set_irq_wake+0x7c/0xe4) [<c0058c20>] (set_irq_wake+0x7c/0xe4) from [<c01b5e80>] (s3c_rtc_setalarm+0xa8/0xb8) [<c01b5e80>] (s3c_rtc_setalarm+0xa8/0xb8) from [<c01b47a0>] (rtc_set_alarm+0x60/0x74) [<c01b47a0>] (rtc_set_alarm+0x60/0x74) from [<c01b5a98>] (rtc_sysfs_set_wakealarm+0xc8/0xd8) [<c01b5a98>] (rtc_sysfs_set_wakealarm+0xc8/0xd8) from [<c01891ec>] (dev_attr_store+0x20/0x24) [<c01891ec>] (dev_attr_store+0x20/0x24) from [<c00be934>] (sysfs_write_file+0x104/0x13c) [<c00be934>] (sysfs_write_file+0x104/0x13c) from [<c0080e7c>] (vfs_write+0xb0/0x158) [<c0080e7c>] (vfs_write+0xb0/0x158) from [<c0080fcc>] (sys_write+0x3c/0x68) [<c0080fcc>] (sys_write+0x3c/0x68) from [<c0020ec0>] (ret_fast_syscall+0x0/0x28) Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ben Dooks <ben@fluff.org.uk> Cc: Atul Dahiya <atul.dahiya@samsung.com> Cc: Taekgyun Ko <taeggyun.ko@samsung.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05rtc: rtc-s3c: Add BCD register initialization codesTaekgyun Ko
RTC needs to be initialized when BCD registers have invalid value. Signed-off-by: Taekgyun Ko <taeggyun.ko@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it>
2010-08-05rtc: rtc-s3c: Updates driver for S3C64XX and newer SoCsAtul Dahiya
This Patch does followings. 1) Enables support for alarm and time tick pending register for periodic interrupt generation. 2) Changes writeb to writew beacuse the macro S3C64XX_RTCCON_TICEN (Tick Timer Enable) is 9th bit of register. 3) Changes writeb to writel as max_user_freq used in s3c64xx is 32768 and requires 15 bits to update the Tick Count Register. Signed-off-by: Atul Dahiya <atul.dahiya@samsung.com> Signed-off-by: Taekgyun Ko <taeggyun.ko@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org>
2010-08-05rtc: rtc-s3c: Updates RTC driver for clock enabling supportAtul Dahiya
This Patch updates existing Samsung RTC driver for clock enabling support. Signed-off-by: Atul Dahiya <atul.dahiya@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com>
2010-06-04rtc: s3c: initialize s3c_rtc_cpu_type before using itMaurus Cuelenaere
Make sure s3c_rtc_cpu_type is initialised _before_ it's used in an if() check. Reported-by: Jiri Pinkava <jiri.pinkava@vscht.cz> Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Maurus Cuelenaere <mcuelenaere@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-04rtc: s3c: initialize driver data before using itMaurus Cuelenaere
s3c_rtc_setfreq() uses the platform driver data to derive struct rtc_device, so make sure drvdata is set _before_ s3c_rtc_setfreq() is called. Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Maurus Cuelenaere <mcuelenaere@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25s3c rtc driver: add support for S3C64xxMaurus Cuelenaere
Add support for the S3C64xx SoC to the generic S3C RTC driver. Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Cc: Frans Pop <elendil@planet.nl> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-01-06rtc: move power of 2 periodic frequency check down into driversJonathan Cameron
Move the power of 2 check on frequencies down into individual rtc drivers This is to allow for non power of 2 real time clock periodic interrupts such as those on the pxa27x to be found in the new pxa27x-rtc driver Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-03Merge branch 'master' of ↵Ben Dooks
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into s3c-moves2
2008-10-30rtc S3C: add device_init_wakeup() invokationYauhen Kharuzhy
tAdd adds device_init_wakeup() ivokation to probe function of s3c2410_rtc_driver. Without of this wakealarm sysfs attribute does not initialise. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Acked-by: Ben Dooks <ben-linux@fluff.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30rtc-s3c: fix section mismatch warningsYauhen Kharuzhy
Warnings was appeared when compile rtc-s3c.c because platform_driver structure s3c2410_rtcdrv has wrong name. Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30[ARM] S3C: Move regs-rtc.h to arch/arm/plat-s3c/include/platBen Dooks
Move regs-rtc.h to arch/arm/plat-s3c/include/plat ready to clean out old include directories. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-10-20drivers/rtc/: use bcd2bin/bin2bcdAdrian Bunk
Change drivers/rtc/ to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-24rtc: rtc-s3c: update IRQ handlingBen Dooks
The rtc-s3c.c driver has been using its own ioctl() handling to deal with alarm and periodic interrupts to handle what should now be done with the rtc core code. Change to using the .irq_set_freq and .irq_set_state driver entries and remove the .ioctl handling. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc: rtc-s3c: add __devexit and __devinit markersBen Dooks
Add the relevant __devinit and __devexit attributes to the rtc-s3c driver. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-22[RTC] remove unused asm/rtc.h includes from ARM RTC driversRussell King
On ARM, asm/rtc.h only contains definitions for the predecessor to the RTC class support. RTC class drivers should not be including this include. Build tested on at91sam9rl and s3c2410 configurations. Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-22[RTC] remove references to asm/mach/time.hRussell King
asm/mach/time.h is the ARM header file for setting up kernel ticker timekeeping (be that the old jiffy interrupt or the new clocksource.) RTC drivers have no business using this header file, and in fact do not require it. Build tested on at91sam9rl, omap and s3c2410 configurations. Acked-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-28rtc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11rtc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable RTC platform drivers, to re-enable module auto loading. [dbrownell@users.sourceforge.net: more drivers, minor fix] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc-s3c: Use is_power_of_2() macro for simplicity.Robert P. J. Day
Use is_power_of_2() macro for simplicity. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-30s3c-rtc: remove unused variableKrzysztof Helt
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31s3c2410: fixup after arch movesBen Dooks
Fixup the changes from moving around the arch support for s3c24xx based systems. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: suspend()/resume() restores system clockDavid Brownell
RTC class suspend/resume support, re-initializing the system clock on resume from the clock used to initialize it at boot time. - The reinit-on-resume is hooked to the existing RTC_HCTOSYS config option, on the grounds that a clock good enough for init must also be good enough for re-init. - Inlining a version of the code used by ARM, to save and restore the delta between a selected RTC and the current system wall-clock time. - Removes calls to that ARM code from AT91, OMAP1, and S3C RTCs. This means that systems using those RTCs across suspend/resume will likely want to change their kernel configs to enable RTC_HCTOSYS. If HCTOSYS isn't using a second RTC (with battery?), this changes the system's initial date from Jan 1970 to the epoch this hardware uses: 1998 for AT91, 2000 for OMAP1 (assuming no split power mode), etc. This goes on top of the patch series removing "struct class_device" usage from the RTC framework. That's all needed for class suspend()/resume(). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: rtc interfaces don't use class_deviceDavid Brownell
This patch removes class_device from the programming interface that the RTC framework exposes to the rest of the kernel. Now an rtc_device is passed, which is more type-safe and streamlines all the relevant code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] rtc framewok: rtc_wkalrm.enabled reporting updatesDavid Brownell
Fix a glitch in the procfs dumping of whether the alarm IRQ is enabled: use the traditional name (from drivers/char/rtc.c and many other places) of "alarm_IRQ", not "alrm_wakeup" (which didn't even match the efirtc code, which originated that reporting API). Also, update a few of the RTC drivers to stop providing that duplicate status, and/or to expose it properly when reporting the alarm state. We really don't want every RTC driver doing their own thing here... Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-01[PATCH] constify rtc_class_ops: update driversDavid Brownell
Update RTC framework so that drivers can constify their method tables, moving them from ".data" to ".rodata". Then update the drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] rtc-s3c.c: fix time setting checksBen Dooks
Fix the year check on setting the time with the S3C24XX RTC driver. Also move the debug to before the set to see what is going on if it does fail. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
