path: root/drivers/rtc/rtc-s3c.c
2008-05-22[RTC] remove unused asm/rtc.h includes from ARM RTC driversRussell King
On ARM, asm/rtc.h only contains definitions for the predecessor to the RTC class support. RTC class drivers should not be including this include. Build tested on at91sam9rl and s3c2410 configurations. Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-22[RTC] remove references to asm/mach/time.hRussell King
asm/mach/time.h is the ARM header file for setting up kernel ticker timekeeping (be that the old jiffy interrupt or the new clocksource.) RTC drivers have no business using this header file, and in fact do not require it. Build tested on at91sam9rl, omap and s3c2410 configurations. Acked-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-28rtc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11rtc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable RTC platform drivers, to re-enable module auto loading. [dbrownell@users.sourceforge.net: more drivers, minor fix] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc-s3c: Use is_power_of_2() macro for simplicity.Robert P. J. Day
Use is_power_of_2() macro for simplicity. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-30s3c-rtc: remove unused variableKrzysztof Helt
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31s3c2410: fixup after arch movesBen Dooks
Fixup the changes from moving around the arch support for s3c24xx based systems. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: suspend()/resume() restores system clockDavid Brownell
RTC class suspend/resume support, re-initializing the system clock on resume from the clock used to initialize it at boot time. - The reinit-on-resume is hooked to the existing RTC_HCTOSYS config option, on the grounds that a clock good enough for init must also be good enough for re-init. - Inlining a version of the code used by ARM, to save and restore the delta between a selected RTC and the current system wall-clock time. - Removes calls to that ARM code from AT91, OMAP1, and S3C RTCs. This means that systems using those RTCs across suspend/resume will likely want to change their kernel configs to enable RTC_HCTOSYS. If HCTOSYS isn't using a second RTC (with battery?), this changes the system's initial date from Jan 1970 to the epoch this hardware uses: 1998 for AT91, 2000 for OMAP1 (assuming no split power mode), etc. This goes on top of the patch series removing "struct class_device" usage from the RTC framework. That's all needed for class suspend()/resume(). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: rtc interfaces don't use class_deviceDavid Brownell
This patch removes class_device from the programming interface that the RTC framework exposes to the rest of the kernel. Now an rtc_device is passed, which is more type-safe and streamlines all the relevant code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] rtc framewok: rtc_wkalrm.enabled reporting updatesDavid Brownell
Fix a glitch in the procfs dumping of whether the alarm IRQ is enabled: use the traditional name (from drivers/char/rtc.c and many other places) of "alarm_IRQ", not "alrm_wakeup" (which didn't even match the efirtc code, which originated that reporting API). Also, update a few of the RTC drivers to stop providing that duplicate status, and/or to expose it properly when reporting the alarm state. We really don't want every RTC driver doing their own thing here... Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-01[PATCH] constify rtc_class_ops: update driversDavid Brownell
Update RTC framework so that drivers can constify their method tables, moving them from ".data" to ".rodata". Then update the drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] rtc-s3c.c: fix time setting checksBen Dooks
Fix the year check on setting the time with the S3C24XX RTC driver. Also move the debug to before the set to see what is going on if it does fail. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] drivers/rtc: fix rtc-s3c.cBen Dooks
In the cleanups of drivers/rtc/s3c-rtc.c, the base address for the registers got broken. This patch fixes that by ensuring the readb/writeb are all prefixed with the base returned from ioremap()ing the registers. Also fix check for valid year range, which was the wrong way around. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] RTC: class driver for Samsung S3C series SoCBen Dooks
This is a renamed and tested version of the previous S3C24XX RTC class driver. The driver has been renamed from the original s3c2410-rtc, which is now too narrow for the range of devices supported. The rtc-s3c has been chosen as there is the distinct possibility of this driver being carried forward into newer Samsung SoC silicon. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
