s3c_rtc_gettime() already returns the result of rtc_valid_tm() on the
obtained time so get rid of another call to rtc_valid_tm().
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Initialize the device time (if it is wrong) before registering RTC device
to fix following error message during rtc-s3c probe:
[ 2.215414] rtc (null): read_time: fail to read
[ 2.216322] s3c-rtc 10070000.rtc: rtc core: registered s3c as rtc1
The current functions in s3c-rtc driver execute clk_enable/disable() to
control clocks and some functions execute s3c_rtc_alarm_clk_enable()
unnecessarily. So this patch deletes the duplicate clock control and
spilts s3c_rtc_alarm_clk_enable() out as
s3c_rtc_enable_clk()/s3c_rtc_disable_clk() to improve readability.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Inki Dae <inki.dae@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Commit df9e26d093d3 ("rtc: s3c: add support for RTC of Exynos3250 SoC")
added an "rtc_src" DT property to specify the clock used as a source to
the S3C real-time clock.
Not all SoCs needs this so commit eaf3a659086e ("drivers/rtc/rtc-s3c.c:
fix initialization failure without rtc source clock") changed to check
the struct s3c_rtc_data .needs_src_clk to conditionally grab the clock.
But that commit didn't update the data for each IP version so the RTC
broke on the boards that needs a source clock. This is the case of at
least Exynos5250 and Exynos5440 which uses the s3c6410 RTC IP block.
This commit fixes the S3C rtc on the Exynos5250 Snow and Exynos5420
Peach Pit and Pi Chromebooks.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Cc: Chanwoo Choi <cw00.choi@samsung.com>
Cc: Doug Anderson <dianders@chromium.org>
Cc: Olof Johansson <olof@lixom.net>
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Tyler Baker <tyler.baker@linaro.org>
Cc: <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into driver-core-next
Remove all .owner fields from platform drivers
Fix unconditional initialization failure on non-exynos3250 SoCs.
introduced rtc source clock support, but also added initialization
failure on SoCs, which doesn't need such clock.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Add support for RTC of Exynos3250 SoC. The Exynos3250 needs source
clock(32.768KHz) for RTC block. If source clock of RTC is registerd on
clock list of common clk framework, Exynos RTC drvier have to control
this clock.
Clock list for s3c-rtc device:
- rtc : CLK_RTC of CLK_GATE_IP_PERIR is gate clock for RTC.
- rtc_src : XrtcXTI is 32.768.kHz source clock for RTC.
(XRTCXTI: Specifies a clock from 32.768 kHz crystal pad with XRTCXTI and
XRTCXTO pins. RTC uses this clock as the source of a real-time clock.)
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Add s3c_rtc_data structure to variant data according to SoC type. The
s3c_rtc_data structure includes some functions to control RTC operation
and specific data dependent on SoC type.
script
Remove warning message when checking codeing style with checkpatch script
and reduce un-necessary i2c read operation on s3c_rtc_enable.
WARNING: line over 80 characters
#406: FILE: drivers/rtc/rtc-s3c.c:406:
+ if ((readw(info->base + S3C2410_RTCCON) & S3C2410_RTCCON_RTCEN) == 0) {
#414: FILE: drivers/rtc/rtc-s3c.c:414:
+ if ((readw(info->base + S3C2410_RTCCON) & S3C2410_RTCCON_CNTSEL)) {
#422: FILE: drivers/rtc/rtc-s3c.c:422:
+ if ((readw(info->base + S3C2410_RTCCON) & S3C2410_RTCCON_CLKRST)) {
WARNING: Missing a blank line after declarations
#451: FILE: drivers/rtc/rtc-s3c.c:451:
+ struct s3c_rtc_drv_data *data;
+ if (pdev->dev.of_node) {
#453: FILE: drivers/rtc/rtc-s3c.c:453:
+ const struct of_device_id *match;
+ match = of_match_node(s3c_rtc_dt_match, pdev->dev.of_node);
WARNING: DT compatible string "samsung,s3c2416-rtc" appears un-documented -- check ./Documentation/devicetree/bindings/
#650: FILE: drivers/rtc/rtc-s3c.c:650:
+ .compatible = "samsung,s3c2416-rtc",
WARNING: DT compatible string "samsung,s3c2443-rtc" appears un-documented -- check ./Documentation/devicetree/bindings/
#653: FILE: drivers/rtc/rtc-s3c.c:653:
+ .compatible = "samsung,s3c2443-rtc",
Define s3c_rtc structure including necessary variables for S3C RTC device
instead of global variables. This patch improves the readability by
removing global variables.
NO_IRQ may be defined as '(unsigned int) -1' in some architectures (arm,
sh ...), and either may not be defined in some architectures (arm64) which
can enable RTC_DRV_S3C.
Also since platform_get_irq returns err-code in case of any error, we do
not need to intialize s3c_rtc_alarmno and s3c_rtc_tickno.
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
for TYPE_S3C64XX
On exynos5250, exynos5420 and exynos5260 it was observed that, after 1
cycle of S2R, the rtc-tick occurs at a very fast rate as compared to the
rtc-tick occuring before S2R.
This patch fixes the above issue by correcting the wrong way of
save/restore of S3C2410_TICNT for TYPE_S3C64XX.
Signed-off-by: Vikas Sajjan <vikas.sajjan@samsung.com>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
The driver core clears the driver data to NULL after device_release or
on probe failure, since commit 0998d063100 ("device-core: Ensure drvdata
= NULL when no driver is bound"). Thus, it is not needed to manually
clear the device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
devm_ioremap_resource does sanity checks on the given resource. No need to
duplicate this in the driver.
Pull ARM SoC multiplatform updates from Olof Johansson:
"More multiplatform enablement for ARM platforms. The ones converted
in this branch are:
- bcm2835
- cns3xxx
- sirf
- nomadik
- msx
- spear
- tegra
- ux500
We're getting close to having most of them converted!
One of the larger platforms remaining is Samsung Exynos, and there are
a bunch of supporting patches in this merge window for it. There was
a patch in this branch to a early version of multiplatform conversion,
but it ended up being reverted due to need of more bake time. The
revert commit is part of the branch since it would have required
rebasing multiple dependent branches and they were stable by then"
* tag 'multiplatform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (70 commits)
mmc: sdhci-s3c: Fix operation on non-single image Samsung platforms
clocksource: nomadik-mtu: fix up clocksource/timer
Revert "ARM: exynos: enable multiplatform support"
ARM: SPEAr13xx: Fix typo "ARCH_HAVE_CPUFREQ"
rtc: s3c: make header file local
mtd: onenand/samsung: make regs-onenand.h file local
thermal/exynos: remove unnecessary header inclusions
mmc: sdhci-s3c: remove platform dependencies
ARM: samsung: move mfc device definition to s5p-dev-mfc.c
ARM: exynos: move debug-macro.S to include/debug/
ARM: exynos: prepare for sparse IRQ
ARM: exynos: introduce EXYNOS_ATAGS symbol
ARM: tegra: build assembly files with -march=armv7-a
ARM: Push selects for TWD/SCU into machine entries
ARM: ux500: build hotplug.o for ARMv7-a
ARM: ux500: move to multiplatform
ARM: ux500: make remaining headers local
ARM: ux500: make irqs.h local to platform
ARM: ux500: get rid of <mach/[hardware|db8500-regs].h>
Convert clk_enable/clk_disable to clk_prepare_enable/clk_disable_unprepare
calls as required by common clock framework.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Reviewed-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Instead of using legacy suspend/resume methods, using newer dev_pm_ops
structure allows better control over power management. Also, 'wake_en'
variable is moved, because it is only used when CONFIG_PM_SLEEP is
enabled.
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Rob Herring <rob.herring@calxeda.com>
devm_rtc_device_register() is device managed and makes cleanup
paths simpler.
Nothing outside of the rtc driver includes plat/regs-rtc.h,
so we can simply move the file into the same directory,
which allows us to build the file as platform-independent
code.
Cc: rtc-linux@googlegroups.com
Merge misc patches from Andrew Morton:
- Florian has vanished so I appear to have become fbdev maintainer
again :(
- Joel and Mark are distracted to welcome to the new OCFS2 maintainer
- The backlight queue
- Small core kernel changes
- lib/ updates
- The rtc queue
- Various random bits
* akpm: (164 commits)
rtc: rtc-davinci: use devm_*() functions
rtc: rtc-max8997: use devm_request_threaded_irq()
rtc: rtc-max8907: use devm_request_threaded_irq()
rtc: rtc-da9052: use devm_request_threaded_irq()
rtc: rtc-wm831x: use devm_request_threaded_irq()
rtc: rtc-tps80031: use devm_request_threaded_irq()
rtc: rtc-lp8788: use devm_request_threaded_irq()
rtc: rtc-coh901331: use devm_clk_get()
rtc: rtc-vt8500: use devm_*() functions
rtc: rtc-tps6586x: use devm_request_threaded_irq()
rtc: rtc-imxdi: use devm_clk_get()
rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug()
rtc: rtc-pcf8583: use dev_warn() instead of printk()
rtc: rtc-sun4v: use pr_warn() instead of printk()
rtc: rtc-vr41xx: use dev_info() instead of printk()
rtc: rtc-rs5c313: use pr_err() instead of printk()
rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug()
rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug()
rtc: rtc-ds2404: use dev_err() instead of printk()
rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk()
Use dev_dbg() instaed of pr_debug() to be consistent.
Convert all uses of devm_request_and_ioremap() to the newly introduced
devm_ioremap_resource() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
This eliminates having an #ifdef returning NULL for the case when OF is
disabled.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
rtc-s3c driver is modified to use devm_request_and_ioremap() (combining
request_mem_region and ioremap), devm_clk_get() and devm_request_irq()
APIs. Since this removes the necessity of freeing the related resources
the return path is also simplified.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
err_nores label redirects to a simple return statement. Move the return
statement to caller location and remove the label.
"Whether" is misspelled in various comments across the tree; this
fixes them. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Return the value returned by platform_get_irq() instead of -ENOENT;
Fixes the following checkpatch warnings:
WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h>
WARNING: Use #include <linux/io.h> instead of <asm/io.h>
rtc-s3c.c:673:32: warning: `s3c_rtc_drv_data_array' defined but not used [-Wunused-variable]
Driver data field is a pointer, hence assigning that to an integer results
in compilation warnings.
Fixes following compilation warnings:
drivers/rtc/rtc-s3c.c: In function `s3c_rtc_get_driver_data':
drivers/rtc/rtc-s3c.c:452:3: warning: return makes integer from pointer without a cast [enabled by default]
drivers/rtc/rtc-s3c.c: At top level:
drivers/rtc/rtc-s3c.c:674:3: warning: initialization makes pointer from integer without a cast [enabled by default]
drivers/rtc/rtc-s3c.c:674:3: warning: (near initialization for `s3c_rtc_dt_match[1].data') [enabled by default]
drivers/rtc/rtc-s3c.c:677:3: warning: initialization makes pointer from integer without a cast [enabled by default]
drivers/rtc/rtc-s3c.c:677:3: warning: (near initialization for `s3c_rtc_dt_match[2].data') [enabled by default]
drivers/rtc/rtc-s3c.c:680:3: warning: initialization makes pointer from integer without a cast [enabled by default]
drivers/rtc/rtc-s3c.c:680:3: warning: (near initialization for `s3c_rtc_dt_match[3].data') [enabled by default]
Cc: Heiko Stuebner <heiko@sntech.de>
Fix this error:
drivers/rtc/rtc-s3c.c:671:3: error: request for member `data' in something not a structure or union
drivers/rtc/rtc-s3c.c:674:3: error: request for member `data' in something not a structure or union
drivers/rtc/rtc-s3c.c:677:3: error: request for member `data' in something not a structure or union
drivers/rtc/rtc-s3c.c:680:3: error: request for member `data' in something not a structure or union
Pull "ARM: driver specific updates" from Arnd Bergmann:
"These are all specific to some driver. They are typically the
platform side of a change in the drivers directory, such as adding a
new driver or extending the interface to the platform. In cases where
there is no maintainer for the driver, or the maintainer prefers to
have the platform changes in the same branch as the driver changes,
the patches to the drivers are included as well.
A much smaller set of driver updates that depend on other branches
getting merged first will be sent later.
The new export of tegra_chip_uid conflicts with other changes in
fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED
conflicts with the cleanup of the interrupt handling of that driver.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fixed up aforementioned trivial conflicts.
* tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits)
ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci
mmc: sdhci-s3c: add platform data for the second capability
ARM: SAMSUNG: support the second capability for samsung-soc
ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC
ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1
ARM: EXYNOS: Enable MDMA driver
regulator: Remove bq24022 regulator driver
rtc: sa1100: add OF support
pxa: magician/hx4700: Convert to gpio-regulator from bq24022
ARM: OMAP3+: SmartReflex: fix error handling
ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API
ARM: OMAP3+: SmartReflex: micro-optimization for sanity check
ARM: OMAP3+: SmartReflex: misc cleanups
ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument
ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata()
ARM: OMAP3+: hwmod: add SmartReflex IRQs
ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need
ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register
ARM: OMAP3+: SmartReflex: Add a shutdown hook
ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP
arch/arm/mach-tegra/Makefile
arch/arm/mach-tegra/fuse.c
drivers/rtc/rtc-sa1100.c
Since commit e58aa3d2d0cc ("genirq: run irq handlers with interrupts
disabled") we run all interrupt handlers with interrupts disabled and we
even check and yell when an interrupt handler returns with interrupts
enabled - see commit b738a50a2026 ("genirq: warn when handler enables
interrupts").
So now this flag is a NOOP and can be removed.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Especially the TICNT registers are different from the two rtc
types that currently exists.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Use the data field of of_device_id to hold the type for
s3c_cpu_type.
Reviewed-by: Thomas Abraham <thomas.abraham@linaro.org>
This patch converts the drivers in drivers/rtc/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Ben Dooks <ben@simtec.co.uk>
Cc: John Stultz <john.stultz@linaro.org>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Add device tree based discovery support for Samsung's rtc controller.
Cc: Ben Dooks <ben-linux@fluff.org>
If an error occurs after the clock is enabled, the enable/disable state
can become unbalanced.
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
The driver does not generate an alarm interrupt even though a time for
an alarm is set.
This results from disabling rtc_clk after setting the alarm time.
To generate an alarm interrupt the driver should maintain its enabled
state for rtc_clk the until alarm interrupt occurs. This patch permits
generation of an alarm interrupt.
[akpm@linux-foundation.org: make s3c_rtc_alarm_clk_lock local to s3c_rtc_alarm_clk_enable()]
Signed-off-by: Donggeun Kim <dg77.kim@samsung.com>
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
have irq.
The previous rtc-s3c had two issues related with its IRQ.
1. Users cannot open rtc multiple times because an open operation
calls request_irq on the same IRQ. (e.g., two user processes wants to
open and read RTC time from rtc-s3c at the same time)
2. If alarm is set and no one has the rtc opened with filesystem
(either the alarm is set by kernel/boot-loader or user set an alarm and
closed rtc dev file), the pending bit is not cleared and no further
interrupt is invoked. When the alarm is used by the system itself such
as a resume from suspend-to-RAM or other Low-power modes/idle, this is
a critical issue.
This patch mitigates these issues by calling request_irq at probe and
free_irq at remove.
Cc: Changhwan Youn <chaos.youn@samsung.com>
RTC-S3C used to print out debug messages incorrectly. This patch
corrects incorrect outputs. (undecoded bcd numbers, incorrectly decoded
register values)
This patch affects the pr-debug messages only.
* Merge akpm patch series: (122 commits)
drivers/connector/cn_proc.c: remove unused local
Documentation/SubmitChecklist: add RCU debug config options
reiserfs: use hweight_long()
reiserfs: use proper little-endian bitops
pnpacpi: register disabled resources
drivers/rtc/rtc-tegra.c: properly initialize spinlock
drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time()
drivers/rtc: add support for Qualcomm PMIC8xxx RTC
drivers/rtc/rtc-s3c.c: support clock gating
drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200
init: skip calibration delay if previously done
misc/eeprom: add eeprom access driver for digsy_mtc board
misc/eeprom: add driver for microwire 93xx46 EEPROMs
checkpatch.pl: update $logFunctions
checkpatch: make utf-8 test --strict
checkpatch.pl: add ability to ignore various messages
checkpatch: add a "prefer __aligned" check
checkpatch: validate signature styles and To: and Cc: lines
checkpatch: add __rcu as a sparse modifier
checkpatch: suggest using min_t or max_t
Did this as a merge because of (trivial) conflicts in
- Documentation/feature-removal-schedule.txt
- arch/xtensa/include/asm/uaccess.h
that were just easier to fix up in the merge than in the patch series.
Add support for clock gating. Power consumption can be reduced by setting
rtc_clk disabled state except for when RTC related registers are accessed.
Signed-off-by: KyungMin Park <kyungmin.park@samsung.com>
Cc: Ben Dooks <ben@fluff.org>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
The driver is not balancing set_irq and disable_irq_wake() calls, so
ensure that it keeps track of whether the wake is enabled.
The fixes the following error on S3C6410 devices:
WARNING: at kernel/irq/manage.c:382 set_irq_wake+0x84/0xec()
Unbalanced IRQ 92 wake disable
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Cc: <stable@kernel.org>
s3c_rtc_setpie was removed, and it resulted in compiler error:
drivers/rtc/rtc-s3c.c: In function s3c_rtc_release
drivers/rtc/rtc-s3c.c:339:2: error: implicit declaration of function
s3c_rtc_setpie
Fix it by removing s3c_rtc_release calls.
[jstultz: An identical fix was also sent in by Jiri Pinkava
<jiri.pinkava@vscht.cz>]
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Alessandro Zummo <a.zummo@towertech.it>
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
With the generic rtc code now emulating PIE mode irqs via an
hrtimer, no one calls the rtc_class_ops->irq_set_freq call.
This patch removes the hook and deletes the driver functions
if no one else calls them.
CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
CC: rtc-linux@googlegroups.com
With PIE mode interrupts now emulated in generic code via an hrtimer,
no one calls rtc_class_ops->irq_set_state(), so this patch removes it
along with driver implementations.
