With the generic RTC rework, the UIE mode irqs are handled
in the generic layer, and only hardware specific ioctls
get passed down to the rtc driver layer.
So this patch removes the UIE mode ioctl handling in the rtc
driver layer, which never get used.
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Alessandro Zummo <a.zummo@towertech.it>
CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
CC: rtc-linux@googlegroups.com
Signed-off-by: John Stultz <john.stultz@linaro.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
I found the PrimeCell/AMBA Bus drivers distrusting the resource
passed in as part of the struct amba_device abstraction. This
patch removes all hard coded resource sizes found in the PrimeCell
drivers and move the responsibility of this definition back to
the platform/board device definition, which already exist and
appear to be correct for all in-tree users of these drivers.
We do this using the resource_size() inline function which was
also replicated in the only driver using the resource size, so
that has been changed too. The KMI_SIZE was left in kmi.h in case
someone likes it. Test-compiled against Versatile and Integrator
defconfigs, seems to work but I don't posess these boards and
cannot test them.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
The second argument of the probe method points to the amba_id
structure, so it's better passed with the correct type. None of the
current in-tree drivers uses the pointer, so they have only been
checked for a clean compile.
Change suggested by Russell King.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Remove NOP methods from rtc-pl030 and rtc-pl031 drivers;
this is pure wasted code.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Convert Integrator PL030 RTC driver to use the RTC class interfaces.
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
