path: root/drivers/rtc/rtc-parisc.c
2009-04-02parisc: rtc: Rename rtc-parisc to rtc-genericGeert Uytterhoeven
The rtc-parisc driver is not PA-RISC specific at all, as it uses the existing (but deprecated) generic RTC infrastructure ([gs]et_rtc_time()). Rename the driver from rtc-parisc to rtc-generic. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-04-02parisc: rtc: Add missing module aliasGeert Uytterhoeven
Make udev autoload the driver Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-04-02parisc: rtc: platform_driver_probe() fixupsGeert Uytterhoeven
When using platform_driver_probe(), it's not needed to setup a .probe function, and .remove should be marked __exit_p(), not __devexit_p(). Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: dann frazier <dannf@hp.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-04-02parisc: rtc: get_rtc_time() returns unsigned intGeert Uytterhoeven
2009-04-01rtc-parisc: rename p pointer to rtcdann frazier
Signed-off-by: dann frazier <dannf@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01rtc-parisc: remove a couple unnecessary variablesdann frazier
Signed-off-by: dann frazier <dannf@hp.com> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01rtc-parisc: use platform_driver_probedann frazier
This isn't a hotpluggable device, so call platform_driver_probe directly in parisc_rtc_init Signed-off-by: dann frazier <dannf@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01rtc-parisc: use rtc_valid_tm() in parisc_get_timedann frazier
Use the return value of rtc_valid_tm() instead of just returning 0. Signed-off-by: dann frazier <dannf@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01rtc-parisc: remove struct parisc_rtcdann frazier
parisc_rtc now only includes an rtc_device pointer, so let's just use the rtc_device type directly. Signed-off-by: dann frazier <dannf@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01rtc-parisc: remove redundant lockingdann frazier
The RTC subsystem proides ops locking, no need to implement our own Signed-off-by: dann frazier <dannf@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01rtc-parisc: add a missing include for linux/rtc.hdann frazier
2009-01-05parisc: set_time() catch errorsRoel Kluin
set_rtc_time returns negative on error, ret should be signed to catch those Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-10-10parisc: add rtc platform driverKyle McMartin
