path: root/drivers/rtc/rtc-efi.c
2014-10-03Merge branch 'next' into efi-next-mergeMatt Fleming
Conflicts: arch/x86/boot/compressed/eboot.c
2014-10-03efi: rtc-efi: Export platform:rtc-efi as module aliasArd Biesheuvel
When the rtc-efi driver is built as a module, we already register the EFI rtc as a platform device if UEFI Runtime Services are enabled. To wire it up to udev, and let the module be loaded automatically, we need to export the 'platform:rtc-efi' alias from the module. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Mark Salter <msalter@redhat.com> Cc: Dave Young <dyoung@redhat.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-09-26drivers/rtc/rtc-efi.c: add missing module aliasPali Rohár
Without proper alias kernel module is not loaded for rtc-efi driver. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Cc: dann frazier <dannf@dannf.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08drivers/rtc/rtc-efi.c: check for invalid data coming back from UEFIJan Beulich
In particular seeing zero in eft->month is problematic, as it results in -1 (converted to unsigned int, i.e. yielding 0xffffffff) getting passed to rtc_year_days(), where the value gets used as an array index (normally resulting in a crash). This was observed with the driver enabled on x86 on some Fujitsu system (with possibly not up to date firmware, but anyway). Perhaps efi_read_alarm() should not fail if neither enabled nor pending are set, but the returned time is invalid? Signed-off-by: Jan Beulich <jbeulich@suse.com> Reported-by: Raymund Will <rw@suse.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Jingoo Han <jg1.han@samsung.com> Acked-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06drivers/rtc/rtc-efi.c: avoid subtracting day twice when computing year daysLee, Chun-Yi
Compared source code of rtc-lib.c::rtc_year_days() with efirtc.c::rtc_year_days(), found the code in rtc-efi decreases value of day twice when it computing year days. rtc-lib.c::rtc_year_days() has already decrease days and return the year days from 0 to 365. Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/rtc/rtc-efi.c: remove empty functionSachin Kamat
After the switch to devm_* functions and the removal of rtc_device_unregister(), the 'remove' function does not do anything. Delete it. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: dann frazier <dannf@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-efi: use devm_rtc_device_register()Jingoo Han
devm_rtc_device_register() is device managed and makes cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-efi: use module_platform_driver_probe()Jingoo Han
Use module_platform_driver_probe() macro which makes the code smaller and simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk()Jingoo Han
Fix the checkpatch warnings as below: WARNING: Prefer netdev_err(netdev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ... WARNING: please, no space before tabs Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-12drivers/rtc/rtc-efi.c: fix section mismatch warningJan Beulich
efi_rtc_init() uses platform_driver_probe(), so there's no need to also set efi_rtc_driver's probe member (as it won't be used anyway). This fixes a modpost section mismatch warning (as efi_rtc_probe() validly is __init). Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: Matthew Garrett <mjg@redhat.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01rtc: add platform driver for EFIdann frazier
Munge Stephane Eranian's efirtc.c code into an rtc platform driver [akpm@linux-foundation.org: use is_leap_year()] Signed-off-by: dann frazier <dannf@hp.com> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Cc: stephane eranian <eranian@googlemail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
