path: root/drivers/rtc/rtc-dev.c
2012-12-17drivers/rtc/rtc-dev.c: remove unused code from rtc-dev.cSachin Kamat
This code is under #if 0 and not used. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-01rtc: Fix ioctl error path returnJohn Stultz
Bryan Henderson noticed that the "RTC: Fix rtc driver ioctl specific shortcutting" commit has a small bug: When an ioctl is called with an invalid command code and the clock driver does not have an "ioctl" method, the ioctl returns rc 0 instead of -ENOTTY. This patch fixes the issue. CC: Bryan Henderson <bryanh@giraffe-data.com> CC: Gabor Z. Papp <gzp@papp.hu> Reported-by: Bryan Henderson <bryanh@giraffe-data.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-17RTC: Re-enable UIE timer/polling emulationJohn Stultz
This patch re-enables UIE timer/polling emulation for rtc devices that do not support alarm irqs. CC: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> CC: Thomas Gleixner <tglx@linutronix.de> Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-17RTC: Revert UIE emulation removalJohn Stultz
Uwe pointed out that my alarm based UIE emulation is not sufficient to replace the older timer/polling based UIE emulation on devices where there is no alarm irq. This causes rtc devices without alarms to return -EINVAL to UIE ioctls. The fix is to re-instate the old timer/polling method for devices without alarm irqs. This patch reverts the following commits: 042620a018afcfba1d678062b62e46 - Remove UIE emulation 1daeddd5962acad1bea55e524fc0fa - Cleanup removed UIE emulation declaration b5cc8ca1c9c3a37eaddf709b2fd3e1 - Remove Kconfig symbol for UIE emulation The emulation mode will still need to be wired-in with a following patch before it will work. CC: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> CC: Thomas Gleixner <tglx@linutronix.de> Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-03RTC: Fix rtc driver ioctl specific shortcuttingJohn Stultz
Some RTC drivers enable functionality directly via their ioctl method instead of using the generic ioctl handling code. With the recent virtualization of the RTC layer, its now important that the generic layer always be used. This patch moved the rtc driver ioctl method call to after the generic ioctl processing is done. This allows hardware specific features or ioctls to still function, while relying on the generic code for handling everything else. This patch on its own may more obviously break rtc drivers that implement the alarm irq enablement via their ioctl method instead of implementing the alarm_irq_eanble method. Those drivers will be fixed in a following patch. Additionaly, those drivers are already likely to not be functioning reliably without this patch. CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: Thomas Gleixner <tglx@linutronix.de> Reported-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Tested-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Signed-off-by: John Stultz <john.stultz@linaro.org>
2010-12-10RTC: Remove UIE emulationJohn Stultz
Since we provide UIE interrupts via a rtc_timer, the old emulation code can be removed. Signed-off-by: John Stultz <john.stultz@linaro.org> LKML Reference: <1290136329-18291-5-git-send-email-john.stultz@linaro.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: Richard Cochran <richardcochran@gmail.com>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-06-19rtc: make rtc_update_irq callable with irqs enabledAtsushi Nemoto
The rtc_update_irq() might be called with irqs enabled, if a interrupt handler was registered without IRQF_DISABLED. Use spin_lock_irqsave/spin_unlock_irqrestore instead of spin_lock/spin_unlock. Also update kerneldoc and drivers which do extra work to follow the current interface spec, as suggestted by David Brownell. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04rtc: add alarm/update irq interfacesAlessandro Zummo
Add standard interfaces for alarm/update irqs enabling. Drivers are no more required to implement equivalent ioctl code as rtc-dev will provide it. UIE emulation should now be handled correctly and will work even for those RTC drivers who cannot be configured to do both UIE and AIE. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-01saner FASYNC handling on file closeAl Viro
As it is, all instances of ->release() for files that have ->fasync() need to remember to evict file from fasync lists; forgetting that creates a hole and we actually have a bunch that *does* forget. So let's keep our lives simple - let __fput() check FASYNC in file->f_flags and call ->fasync() there if it's been set. And lose that crap in ->release() instances - leaving it there is still valid, but we don't have to bother anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rtc: file close() consistently disables repeating irqsDavid Brownell
Make the rtc framework consistent about disabling 1/second update IRQs that may have been activated through the /dev interface, when that /dev file is closed. (It may have closed because of coredump, etc.) This was previously done only for emulated update IRQs ... now, do it always. Also comment the current policy: repeating IRQs (periodic, update) that userspace enabled will be cleanly disabled, but alarms are left alone. Such repeating IRQs are a constant and pointless system load. Update some RTC drivers to remove now-needless release() methods. Most such methods just enforce that policy. The others all seem to be buggy, and mistreat in-kernel clients of periodic or alarm IRQs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Andrew Sharp <andy.sharp@onstor.com> Cc: Angelo Castello <angelo.castello@st.com> Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Thomas Hommel <thomas.hommel@gefanuc.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-03rtc: fix kernel panic on second use of SIGIO nofiticationMarcin Slusarz
When userspace uses SIGIO notification and forgets to disable it before closing file descriptor, rtc->async_queue contains stale pointer to struct file. When user space enables again SIGIO notification in different process, kernel dereferences this (poisoned) pointer and crashes. So disable SIGIO notification on close. Kernel panic: (second run of qemu (requires echo 1024 > /sys/class/rtc/rtc0/max_user_freq)) general protection fault: 0000 [1] PREEMPT CPU 0 Modules linked in: af_packet snd_pcm_oss snd_mixer_oss snd_seq_oss snd_seq_midi_event snd_seq usbhid tuner tea5767 tda8290 tuner_xc2028 xc5000 tda9887 tuner_simple tuner_types mt20xx tea5761 tda9875 uhci_hcd ehci_hcd usbcore bttv snd_via82xx snd_ac97_codec ac97_bus snd_pcm snd_timer ir_common compat_ioctl32 snd_page_alloc videodev v4l1_compat snd_mpu401_uart snd_rawmidi v4l2_common videobuf_dma_sg videobuf_core snd_seq_device snd btcx_risc soundcore tveeprom i2c_viapro Pid: 5781, comm: qemu-system-x86 Not tainted 2.6.27-rc6 #363 RIP: 0010:[<ffffffff8024f891>] [<ffffffff8024f891>] __lock_acquire+0x3db/0x73f RSP: 0000:ffffffff80674cb8 EFLAGS: 00010002 RAX: ffff8800224c62f0 RBX: 0000000000000046 RCX: 0000000000000002 RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff8800224c62f0 RBP: ffffffff80674d08 R08: 0000000000000002 R09: 0000000000000001 R10: ffffffff80238941 R11: 0000000000000001 R12: 0000000000000000 R13: 6b6b6b6b6b6b6b6b R14: ffff88003a450080 R15: 0000000000000000 FS: 00007f98b69516f0(0000) GS:ffffffff80623200(0000) knlGS:00000000f7cc86d0 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000a87000 CR3: 0000000022598000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process qemu-system-x86 (pid: 5781, threadinfo ffff880028812000, task ffff88003a450080) Stack: ffffffff80674cf8 0000000180238440 0000000200000002 0000000000000000 ffff8800224c62f0 0000000000000046 0000000000000000 0000000000000002 0000000000000002 0000000000000000 ffffffff80674d68 ffffffff8024fc7a Call Trace: <IRQ> [<ffffffff8024fc7a>] lock_acquire+0x85/0xa9 [<ffffffff8029cb62>] ? send_sigio+0x2a/0x184 [<ffffffff80491d1f>] _read_lock+0x3e/0x4a [<ffffffff8029cb62>] ? send_sigio+0x2a/0x184 [<ffffffff8029cb62>] send_sigio+0x2a/0x184 [<ffffffff8024fb97>] ? __lock_acquire+0x6e1/0x73f [<ffffffff8029cd4d>] ? kill_fasync+0x2c/0x4e [<ffffffff8029cd10>] __kill_fasync+0x54/0x65 [<ffffffff8029cd5b>] kill_fasync+0x3a/0x4e [<ffffffff80402896>] rtc_update_irq+0x9c/0xa5 [<ffffffff80404640>] cmos_interrupt+0xae/0xc0 [<ffffffff8025d1c1>] handle_IRQ_event+0x25/0x5a [<ffffffff8025e5e4>] handle_edge_irq+0xdd/0x123 [<ffffffff8020da34>] do_IRQ+0xe4/0x144 [<ffffffff8020bad6>] ret_from_intr+0x0/0xf <EOI> [<ffffffff8026fdc2>] ? __alloc_pages_internal+0xe7/0x3ad [<ffffffff8033fe67>] ? clear_page_c+0x7/0x10 [<ffffffff8026fc10>] ? get_page_from_freelist+0x385/0x450 [<ffffffff8026fdc2>] ? __alloc_pages_internal+0xe7/0x3ad [<ffffffff80280aac>] ? anon_vma_prepare+0x2e/0xf6 [<ffffffff80279400>] ? handle_mm_fault+0x227/0x6a5 [<ffffffff80494716>] ? do_page_fault+0x494/0x83f [<ffffffff8049251d>] ? error_exit+0x0/0xa9 Code: cc 41 39 45 28 74 24 e8 5e 1d 0f 00 85 c0 0f 84 6a 03 00 00 83 3d 8f a9 aa 00 00 be 47 03 00 00 0f 84 6a 02 00 00 e9 53 03 00 00 <41> ff 85 38 01 00 00 45 8b be 90 06 00 00 41 83 ff 2f 76 24 e8 RIP [<ffffffff8024f891>] __lock_acquire+0x3db/0x73f RSP <ffffffff80674cb8> ---[ end trace 431877d860448760 ]--- Kernel panic - not syncing: Aiee, killing interrupt handler! Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-20rtc: fix double lock on UIE emulationAtsushi Nemoto
With commit 5ad31a575157147b43fa84ef1e21471661653878 ("rtc: remove BKL for ioctl()"), RTC_UIE_ON ioctl cause double lock on rtc->ops_lock. The ops_lock must not be held while set_uie() calls rtc_read_time() which takes the lock. Also clear_uie() does not need ops_lock. This patch fixes return value of RTC_UIE_OFF ioctl too. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12revert "rtc: cdev lock_kernel() pushdown"David Brownell
Revert commit 51a776fa7a7997e726d4a478eda0854c6f9143bd ("rtc: cdev lock_kernel() pushdown"). The RTC framework does not need BKL protection. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30rtc-dev: stop periodic interrupts on device releaseTomas Janousek
Solves http://bugzilla.kernel.org/show_bug.cgi?id=11127 The old rtc.c driver did it and some drivers (like rtc-sh) do it in their release function, though they should not -- because they should provide the irq_set_state op and the rtc framework itself should care about it. This patch makes it do so. I am aware that some drivers, like rtc-sh, handle userspace PIE sets in their ioctl op (instead of having the framework call the op), exporting the irq_set_state op at the same time. The logic in rtc_irq_set_state should make sure it doesn't matter and the driver should not need to care stopping periodic interrupts in its release routine any more. The correct way, in my opinion, should be this: 1) The driver provides the irq_set_state op and does not care closing the interrupts in its release op. 2) If the driver does not provide the op and handles PIE in the ioctl op, it's reponsible for closing them in its release op. 3) Something similar for other IRQs, like UIE -- if there's no in-kernel API like irq_set_state, handle it in ioctl and release ops. The framework will be responsible either for everything or for nothing. (This will probably change later.) Signed-off-by: Tomas Janousek <tomi@nomi.cz> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30rtc: don't return -EBUSY when mutex_lock_interruptible() failsDavid Brownell
It was pointed out that the RTC framework handles its mutex locks oddly ... returning -EBUSY when interrupted. This fixes that by returning the value of mutex_lock_interruptible() (i.e. -EINTR). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc: remove BKL for ioctl()David Brownell
Remove implicit use of BKL in ioctl() from the RTC framework. Instead, the rtc->ops_lock is used. That's the same lock that already protects the RTC operations when they're issued through the exported rtc_*() calls in drivers/rtc/interface.c ... making this a bugfix, not just a cleanup, since both ioctl calls and set_alarm() need to update IRQ enable flags and that implies a common lock (which RTC drivers as a rule do not provide on their own). A new comment at the declaration of "struct rtc_class_ops" summarizes current locking rules. It's not clear to me that the exceptions listed there should exist ... if not, those are pre-existing problems which can be fixed in a patch that doesn't relate to BKL removal. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jonathan Corbet <corbet@lwn.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20rtc: cdev lock_kernel() pushdownJonathan Corbet
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-02-06rtc-cmos alarm acts as oneshotDavid Brownell
Start making the rtc-cmos alarm act more like a oneshot alarm by disabling that alarm after its IRQ fires. (ACPI hooks are also needed.) The Linux RTC framework has previously been a bit vague in this area, but any other behavior is problematic and not very portable. RTCs with full YYYY-MM-DD HH:MM[:SS] alarms won't have a problem here. Only ones with partial match criteria, with the most visible example being the PC RTC, get confused. (Because the criteria will match repeatedly.) Update comments relating to that oneshot behavior and timezone handling. (Timezones are another issue that's mostly visible with rtc-cmos. That's because PCs often dual-boot MS-Windows, which likes its RTC to match local wall-clock time instead of UTC.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05RTC: assure proper memory ordering with respect to RTC_DEV_BUSY flagJiri Kosina
We must make sure that the RTC_DEV_BUSY flag has proper lock semantics, i.e. that the RTC_DEV_BUSY stores clearing the flag don't get reordered before the preceeding stores and loads and vice versa. Spotted by Nick Piggin. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: David Brownell <david-b@pacbell.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29RTC: convert mutex to bitfieldJiri Kosina
RTC code is using mutex to assure exclusive access to /dev/rtc. This is however wrong usage, as it leaves the mutex locked when returning into userspace, which is unacceptable. Convert rtc->char_lock into bit operation. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16rtc: allow validated RTC_PIE_ON for non-rootBryan Kadzban
drivers/char/rtc.c allowed RTC_PIE_ON ioctls for non-root users, as long as the current interval (set via RTC_IRQP_SET) is <= max_user_freq. Allow RTC_PIE_ON under the same conditions when /dev/rtc* is handled by the rtc subsystem. Signed-off-by: Bryan Kadzban <bryan@kdzbn.homelinux.net> Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16rtc-dev: no need to convert file->private_data to rtc deviceMark Zhan
In rtc-dev.c, when a rtc device is opened, file->private_data is already attached with the rtc device pointer, so there is no need to call to_rtc_device() to convert file->private_data to a rtc device pointer. Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Mark Zhan <rongkai.zhan@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16RTC: periodic irq fixAlessandro Zummo
Add kernel/kernel and kernel/user locking for the periodic irq feature of the rtc class. PIE ioctls are also supported. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31rtc-dev: Make RTC driver return ENOTTY instead of ENOIOCTLCMDThomas Hommel
Prevent the RTC driver from returning ENOIOCTLCMD to userspace. Signed-off-by: Thomas Hommel <thomas.hommel@gefanuc.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17rtc-dev: return -ENOTTY in ioctl if irq_set_freq is not implemented by driverHans-Christian Egtvedt
Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove "RTC_ALM_SET mode" bugsDavid Brownell
This fixes a common glitch in how RTC drivers handle two "set alarm" modes, by getting rid of the surprising/hidden one that was rarely implemented correctly (and which could expose nonportable hardware-specific behavior). The glitch comes from the /dev/rtcX logic implementing the legacy RTC_ALM_SET (limited to 24 hours, needing RTC_AIE_ON) ioctl on top of the RTC driver call providing access to the newer RTC_WKALM_SET (without those limitations) by initializing the day/month/year fields to be invalid ... that second mode. Now, since few RTC drivers check those fields, and most hardware misbehaves when faced with invalid date fields, many RTC drivers will set bogus alarm times on those RTC_ALM_SET code paths. (Several in-tree drivers have that issue, and I also noticed it with code reviews on several new RTC drivers.) This patch ensures that RTC drivers never see such invalid alarm fields, by moving some logic out of rtc-omap into the RTC_ALM_SET code and adding an explicit check (which will prevent the issue on other code paths). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: update to class device removal patchesDavid Brownell
Fix a goof in the revised classdev support for RTCs: make sure the /dev node info is ready before the device is registered, not after. Otherwise the /sys/class/rtc/rtcN/dev attribute won't be created and then udev won't have the information it needs to create the /dev/rtcN node. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove rest of class_deviceDavid Brownell
Finish converting the RTC framework so it no longer uses class_device. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: rtc interfaces don't use class_deviceDavid Brownell
This patch removes class_device from the programming interface that the RTC framework exposes to the rest of the kernel. Now an rtc_device is passed, which is more type-safe and streamlines all the relevant code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove /sys/class/rtc-dev/*David Brownell
This simplifies the /dev support by removing a superfluous class_device (the /sys/class/rtc-dev stuff) and the class_interface that hooks it into the rtc core. Accordingly, if it's configured then /dev support is now part of the RTC core, and is never a separate module. It's another step towards being able to remove "struct class_device". [bunk@stusta.de: drivers/rtc/rtc-dev.c should #include "rtc-core.h"] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 5Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[PATCH] trivial __user annotations - rtc-devAl Viro
2006-12-13[PATCH] rtc: remove syslog spam on registrationDavid Brownell
This removes some syslog spam as RTC drivers register; debug messages shouldn't come out at "info" level. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-25[PATCH] rtc class locking bugfixesDavid Brownell
I got a lockdep warning when running "rtctest" so I though it'd be good to see what was up. - The warning was for rtc->irq_task_lock, gotten from rtc_update_irq() by irq handlerss ... but in a handful of other cases, grabbed without blocking IRQs. - Some callers to rtc_update_irq() were not ensuring IRQs were blocked, yet the routine expects that; make sure all callers block IRQs. It would appear that RTC API tests haven't been part of anyone's kernel regression test suite recently, at least not with lockdep running. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] rtc framework handles periodic irqsDavid Brownell
The RTC framework has an irq_set_freq() method that should be used to manage the periodic IRQ frequency, but the current ioctl logic doesn't know how to do that. This patch teaches it how. This means that drivers implementing irq_set_freq() will automatically support RTC_IRQP_{READ,SET} ioctls; that logic doesn't need duplication within the driver. [akpm@osdl.org: export rtc_irq_set_freq] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-01[PATCH] constify rtc_class_ops: update driversDavid Brownell
Update RTC framework so that drivers can constify their method tables, moving them from ".data" to ".rodata". Then update the drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] RTC class uses subsys_initDavid Brownell
This makes RTC core components use "subsys_init" instead of "module_init", as appropriate for subsystem infrastructure. This is mostly useful for statically linking drivers in other parts of the tree that may provide an RTC interface as a secondary functionality (e.g. part of a multifunction chip); they won't need to worry so much about drivers/Makefile link order. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] rtc: remove superfluous call to call to cdev_del()Rolf Eike Beer
If cdev_add() fails there is no good reason to call cdev_del(). Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] rtc subsystem: add capability checksAlessandro Zummo
Centralize CAP_SYS_XXX checks to avoid duplicate code and missing checks in the drivers. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] RTC: rtc-dev UIE emulationAtsushi Nemoto
Import genrtc's RTC UIE emulation (CONFIG_GEN_RTC_X) to rtc-dev driver with slight adjustments/refinements. This makes UIE-less rtc drivers work better with programs doing read/poll on /dev/rtc, such as hwclock. This emulation should not harm rtc drivers with UIE support, since rtc_dev_ioctl() calls underlaying rtc driver's ioctl() first. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] rtc subsystem: use ENOIOCTLCMD and ENOTTY where appropriateAlessandro Zummo
Appropriately use -ENOIOCTLCMD and -ENOTTY when the ioctl is not implemented by a driver. (akpm: we're not allowed to return -ENOIOCTLCMD to userspace. This patch does the right thing). Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] RTC: rtc-dev tweak for 64-bit kernelAtsushi Nemoto
Make rtc-dev work well on 64-bit platforms with 32-bit userland. On those platforms, users might try to read 32-bit integer value. This patch make rtc-dev's read() work well for both "int" and "long" size. This tweak is came from genrtc driver. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC subsystem: dev interfaceAlessandro Zummo
Add the dev interface to the RTC subsystem. Each RTC will be available under /dev/rtcX . A symlink from /dev/rtc0 to /dev/rtc cab be obtained with the following udev rule: KERNEL=="rtc0", SYMLINK+="rtc" Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
