If hpet_register_irq_handler() fails, cmos_do_probe() will incorrectly
return 0.
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Rob Herring <robh+dt@kernel.org>
device_driver.name is "const char *"
Cc: Alessandro Zummo <a.zummo@towertech.it>
41c7f7424259f ("rtc: Disable the alarm in the hardware (v2)") added the
functionality to disable the RTC wake alarm when shutting down the box.
However, there are at least two b0rked BIOSes we know about:
https://bugzilla.novell.com/show_bug.cgi?id=812592
https://bugzilla.novell.com/show_bug.cgi?id=805740
where, when wakeup alarm is enabled in the BIOS, the machine reboots
automatically right after shutdown, regardless of what wakeup time is
programmed.
Bisecting the issue lead to this patch so disable its functionality with
a DMI quirk only for those boxes.
Cc: Brecht Machiels <brecht@mos6581.org>
Cc: Rabin Vincent <rabin.vincent@stericsson.com>
Cc: stable <stable@vger.kernel.org>
[jstultz: Changed variable name for clarity, added extra dmi entry]
Tested-by: Brecht Machiels <brecht@mos6581.org>
Tested-by: Borislav Petkov <bp@suse.de>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly. This is a cosmetic change to make
the code simpler and enhance the readability.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Driver core sets the driver data to NULL upon device_release or on probe
failure.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Jingoo Han <jg1.han@samsung.com>
Convert drivers/rtc/rtc-cmos to use dev_pm_ops instead of legacy pm_ops.
This patch depends on pnp driver bus ops change to invoke pnp_driver
dev_pm_ops.
Signed-off-by: Shuah Khan <shuah.kh@samsung.com>
Cc: Matthew Garrett <matthew.garrett@nebula.com>
Cc: Leonidas Da Silva Barbosa <leosilva@linux.vnet.ibm.com>
Cc: Ashley Lai <ashley@ashleylai.com>
Cc: Rajiv Andrade <mail@srajiv.net>
Cc: Marcel Selhorst <tpmdd@selhorst.net>
Cc: Sirrix AG <tpmdd@sirrix.com>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Peter Hüwe <PeterHuewe@gmx.de>
The bios may clear the rtc control register when resuming the system. Since the
cmos interrupt handler may now be run before the rtc_cmos is resumed, this can
cause the interrupt handler to ignore an alarm since the alarm bit is not set in
the rtc control register. To work around this, check if the rtc_cmos is
suspended and use the stored value for the rtc control register.
Signed-off-by: Derek Basehore <dbasehore@chromium.org>
Reviewed-by: Sameer Nanda <snanda@chromium.org>
Fixes the following types of issues:
ERROR: space required after that ',' (ctx:VxV)
WARNING: please, no spaces at the start of a line
During resume, we call hpet_rtc_timer_init after masking an irq bit in
hpet. This will cause the call to hpet_disable_rtc_channel to be undone
if RTC_AIE is the only bit not masked.
Allowing the cmos interrupt handler to run before resuming caused some
issues where the timer for the alarm was not removed. This would cause
other, later timers to not be cleared, so utilities such as hwclock
would time out when waiting for the update interrupt.
[akpm@linux-foundation.org: coding-style tweak]
There's a bug where rtc alarms are ignored after the rtc cmos suspends
but before the system finishes suspend. Since hpet emulation is
disabled and it still handles the interrupts, a wake event is never
registered which is done from the rtc layer.
This patch reverts commit d1b2efa83fbf ("rtc: disable hpet emulation on
suspend") which disabled hpet emulation. To fix the problem mentioned
in that commit, hpet_rtc_timer_init() is called directly on resume.
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: <stable@vger.kernel.org>
Fix the checkpatch warning as below:
WARNING: Prefer netdev_err(netdev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ...
This eliminates having an #ifdef returning NULL for the case when OF is
disabled. Maintains consistency in cases where OF is always selected.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
If an RTC alarm fires just as suspend is happening, it is possible for
suspend to complete and the alarm to be missed.
To avoid the race, we must register the event with the PM core.
As the event is made visible to userspace through a thread which is
only scheduled by the interrupt, we need a pm_stay_awake/pm_relax
pair preventing suspend from the interrupt until the thread completes
its work.
This makes the pm_wakeup_event() call in cmos_interrupt unnecessary as
it provides suspend protection for all RTCs that use rtc_update_irq.
Signed-off-by: NeilBrown <neilb@suse.de>
When suspending the system with an important RTC wake alarm active,
it is possible that the RTC alarm will expire before the system has
gone to sleep (e.g. short alarm timer, or an unusually long suspend
routine).
If this happens, the RTC alarm should trigger a wakeup event, possibly
aborting system suspend. This condition can be detected in the form
of an RTC alarm interrupt.
Signed-off-by: Paul Fox <pgf@laptop.org>
Signed-off-by: Daniel Drake <dsd@laptop.org>
When the ACPI-driven RTC alarm wakes the system, report it as a wakeup
event. This allows userspace to determine that the reason for system
wakeup was RTC alarm.
Since commit e58aa3d2d0cc ("genirq: run irq handlers with interrupts
disabled") we run all interrupt handlers with interrupts disabled and we
even check and yell when an interrupt handler returns with interrupts
enabled - see commit b738a50a2026 ("genirq: warn when handler enables
interrupts").
So now this flag is a NOOP and can be removed.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Fix writing to NVRAM bank 2 in rtc-cmos driver. It never worked since its
introduction in 2.6.28 because of a typo.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits)
x86: Clean up apic.c and apic.h
x86: Remove superflous goal definition of tsc_sync
x86: dt: Correct local apic documentation in device tree bindings
x86: dt: Cleanup local apic setup
x86: dt: Fix OLPC=y/INTEL_CE=n build
rtc: cmos: Add OF bindings
x86: ce4100: Use OF to setup devices
x86: ioapic: Add OF bindings for IO_APIC
x86: dtb: Add generic bus probe
x86: dtb: Add support for PCI devices backed by dtb nodes
x86: dtb: Add device tree support for HPET
x86: dtb: Add early parsing of IO_APIC
x86: dtb: Add irq domain abstraction
x86: dtb: Add a device tree for CE4100
x86: Add device tree support
x86: e820: Remove conditional early mapping in parse_e820_ext
x86: OLPC: Make OLPC=n build again
x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection
x86: OLPC: Cleanup config maze completely
x86: OLPC: Hide OLPC_OPENFIRMWARE config switch
Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
Now that the generic code handles UIE mode irqs via periodic
alarm interrupts, no one calls the
rtc_class_ops->update_irq_enable() method anymore.
This patch removes the driver hooks and implementations of
update_irq_enable if no one else is calling it.
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Alessandro Zummo <a.zummo@towertech.it>
CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
CC: rtc-linux@googlegroups.com
With the generic rtc code now emulating PIE mode irqs via an
hrtimer, no one calls the rtc_class_ops->irq_set_freq call.
This patch removes the hook and deletes the driver functions
if no one else calls them.
With PIE mode interrupts now emulated in generic code via an hrtimer,
no one calls rtc_class_ops->irq_set_state(), so this patch removes it
along with driver implementations.
This allows to load the OF driver based informations from the device
tree. Systems without BIOS may need to perform some initialization.
PowerPC creates a PNP device from the OF information and performs this
kind of initialization in their private PCI quirk. This looks more
generic.
This patch also avoids registering the platform RTC driver on X86 if
we have a device tree blob. Otherwise we would setup the device based
on the hardcoded information in arch/x86 rather than the device tree
based one.
[ tglx: Changed "int of_have_populated_dt()" to bool as recommended by
Grant ]
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
Cc: sodaville@linutronix.de
Cc: devicetree-discuss@lists.ozlabs.org
Cc: rtc-linux@googlegroups.com
LKML-Reference: <1298405266-1624-12-git-send-email-bigeasy@linutronix.de>
rtc-cmos was setting suspend/resume hooks at the device_driver level.
However, the platform bus code (drivers/base/platform.c) only looks for
resume hooks at the dev_pm_ops level, or within the platform_driver.
Switch rtc_cmos to use dev_pm_ops so that suspend/resume code is executed
again.
Paul said:
: The user visible symptom in our (XO laptop) case was that rtcwake would
: fail to wake the laptop. The RTC alarm would expire, but the wakeup
: wasn't unmasked.
: As for severity, the impact may have been reduced because if I recall
: correctly, the bug only affected platforms with CONFIG_PNP disabled.
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Cc: <stable@kernel.org> [2.6.37.x]
The following warning is seen while compilation of PowerPC kernel:
CC drivers/rtc/rtc-cmos.o
drivers/rtc/rtc-cmos.c:697:2: warning: #warning Assuming 128 bytes
of RTC+NVRAM address space, not 64 bytes.
Fix it by adding defined(__powerpc__).
Signed-off-by: Srikanth Krishnakar <skrishna@mvista.com>
Because CONFIG_PM is a precondition to CONFIG_ACPI, the ifdef CONFIG_PM
within ifdef CONFIG_ACPI is redundant.
Signed-off-by: Christian Dietrich <qy03fugy@stud.informatik.uni-erlangen.de>
The bug is an oops when dev_get_drvdata() returned null in
cmos_update_irq_enable(). The call tree looks like this:
rtc_dev_ioctl()
=> rtc_update_irq_enable()
=> cmos_update_irq_enable()
It's caused by a race condition in the module initialization. It is
rtc_device_register() which makes the ioctl operations live so I moved
the call to dev_set_drvdata() before the call to rtc_device_register().
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=15963
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
Cc: Malte Schroder <maltesch@gmx.de>
Cc: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
As a follow-up to the thread about RTC support for some Loongson 2E/2F
boards, this patch tries to address the "REVISIT"/"FIXME" comments about
rtc binary mode handling and allow rtc to work with rtc in binary mode.
I've also raised the message about 24-h mode not supported to warning
otherwise, one may end up with no rtc without any message in the kernel
log.
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
To: linux-mips@linux-mips.org
To: rtc-linux@googlegroups.com
Cc: david-b@pacbell.net
Cc: a.zummo@towertech.it
Cc: akpm@linux-foundation.org
Patchwork: http://patchwork.linux-mips.org/patch/1158/
This allows bin_attr->read,write,mmap callbacks to check file specific data
(such as inode owner) as part of any privilege validation.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
commit abd6633c67925f90775bb74755f9c547e30f1f20 ("pnp: add a shutdown
method to pnp drivers") adds shutdown method to bus driver blindly. With
it, driver->shutdown is no longer valid.
Use pnp_driver->shutdown instead.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14889
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Reported-by: Malte Schröder <maltesch@gmx.de>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: David Hardeman <david@hardeman.nu>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: <stable@kernel.org> [2.6.32.x]
This patch fixes the following warning with RTC_LIB on MIPS:
drivers/rtc/rtc-cmos.c:697:2: warning: #warning Assuming 128 bytes of
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
Cc: Arnaud Patard <apatard@mandriva.com>
Cc: linux-mips@linux-mips.org
Patchwork: http://patchwork.linux-mips.org/patch/570/
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Drop ioctl function that handles RTC_AIE/RTC_UIE, and use instead the
rtc subsystem API (alarm_irq_enable/update_irq_enable callbacks).
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
Cc: David Brownell <david-b@pacbell.net>
I noticed that rtc wont generate interrupts after a resume from disk.
Here hpet rtc emulation is used.
Problem is that rtc hpet comparator, isn't reinitialized after resume.
Easiest way to solve this, is always mask all hpet interrupts on suspend
This is triggered, when suspending with alarm set.
Otherwise, hpet driver will think it doesn't need to reinitialize
the rtc comparator, thus rtc interrupts won't work.
This emulation isn't need for wakealarm.
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
rtc-cmos has two drivers, one PNP and one platform. When PNP has not
succeeded probing, platform is registered. However, it tries to
unregister both drivers unconditionally, instead of only unregistering
those that were successfully registered. This causes runtime warnings to
be emitted from the driver core code.
Fix this with a boolean variable for each driver indicating whether
registering was successful.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Cc: Alessandro Zummo <alessandro.zummo@towertech.it>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Greg KH <greg@kroah.com>
Cc: Ozan Caglayan <ozan@pardus.org.tr>
With no IRQ available/defined, RTC-CMOS driver prints something like:
rtc0: alarms up to one no, y3k, 114 bytes nvram
I guess the following is a bit easier to understand:
rtc0: no alarms, y3k, 114 bytes nvram
Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl>
Move the power of 2 check on frequencies down into individual rtc drivers
This is to allow for non power of 2 real time clock periodic interrupts
such as those on the pxa27x to be found in the new pxa27x-rtc driver
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
This patch fixes a bunch of irq checking misuses. Most drivers were
getting irq via platform_get_irq(), which returns -ENXIO or r->start.
rtc-cmos.c is special. It is using PNP and platform bindings. Hopefully
nobody is using PNP IRQ 0 for RTC. So the changes should be safe.
rtc-sh.c is using platform_get_irq, but was storing a result into an
unsigned type, then was checking for < 0. This is fixed now.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-By: Greg Kroah-Hartman <gregkh@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
-rtc0: alarms up to one month, y3k, 114 bytes nvram, , hpet irqs irqs
+rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
Signed-off-by: Frans Pop <elendil@planet.nl>
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs
attribute->owner unnecessary. But the field was left in the structure to
ease the merge. It's been over a year since that change and it is now
time to start killing attribute->owner along with its users - one arch at
a time!
This patch is attempt #1 to get rid of attribute->owner only for
CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on
as and when possible - avr32 will be the next since that is something I
can test. Compile (make allyesconfig / make allmodconfig / custom config)
and boot tested.
akpm: the idea is that we put the declaration of sttribute.owner inside
`#ifndef CONFIG_X86'. But that proved to be too ambitious for now because
new usages kept on turning up in subsystem trees.
[akpm: remove the ifdef for now]
Signed-off-by: Parag Warudkar <parag.lkml@gmail.com>
Cc: Tejun Heo <htejun@gmail.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Roland Dreier <rolandd@cisco.com>
Change drivers/rtc/ to use the new bcd2bin/bin2bcd functions instead of
the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Teach rtc-cmos about the second bank of registers found on most modern x86
systems, giving access to 128 bytes more NVRAM.
This version only sees that extra NVRAM when both register banks are
provided as part of *one* PNP resource. Since BIOS on some systems
presents them using two IO resources, and nothing merges them, this can't
always show all the NVRAM. (We're supposed to be able to use PNP id
PNP0b01 too, but BIOS tables doesn't often seem to use that particular
option.)
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
We shouldn't rely on "pnp_platform_devices" to tell us whether there
is a PNP RTC device.
I introduced "pnp_platform_devices", but I think it was a mistake.
All it tells us is whether we found any PNPBIOS or PNPACPI devices.
Many machines have some PNP devices, but do not describe the RTC
via PNP. On those machines, we need to do the platform driver probe
to find the RTC.
We should just register the PNP driver and see whether it claims anything.
If we don't find a PNP RTC, fall back to the platform driver probe.
This (in conjunction with the arch/x86/kernel/rtc.c patch to add
a platform RTC device when PNP doesn't have one) should resolve
these issues:
http://bugzilla.kernel.org/show_bug.cgi?id=11580
https://bugzilla.redhat.com/show_bug.cgi?id=451188
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Reported-by: Rik Theys <rik.theys@esat.kuleuven.be>
Reported-by: shr_msn@yahoo.com.tw
Move rtc_wake_setup() from drivers/acpi/glue.c into the RTC driver
in drivers/rtc/rtc-cmos.c.
This removes the ordering constraint between the module_init(acpi_rtc_init)
and the cmos_do_probe() code that depends on it.
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6
arch/sparc64/kernel/pci_psycho.c
Update rtc-cmos shutdown handling to leave RTC alarms active, resolving
http://bugzilla.kernel.org/show_bug.cgi?id=11411 on several boards. There
are still some systems where the ACPI event handling doesn't cooperate.
(Possibly related to bugid 11312, reporting the spontaneous disabling of
RTC events.)
Bug 11411 reported that changes to work around some ACPI event issues
broke wake-from-S5 handling, as used for DVR applications. (They like to
power off, then wake later to record programs.)
[yakui.zhao@intel.com: add shutdown for PNP devices]
[dbrownell@users.sourceforge.net: update comments]
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Cc: Stefan Bauer <stefan.bauer@cs.tu-chemnitz.de>
Add Sparc to the Kconfig depends list.
Add __sparc___ to address_sparc = 128 ifdef.
Finally, don't be concerned about 24-hour BCD mode support if the RTC
doesn't have a valid IRQ. We won't even use the alarm code in this
case and the Sparc RTCs have this limitation.
This fixes kernel http://bugzilla.kernel.org/show_bug.cgi?id=11112 (bogus
RTC update IRQs reported) for rtc-cmos, in two ways:
- When HPET is stealing the IRQs, use the first IRQ to grab
the seconds counter which will be monitored (instead of
using whatever was previously in that memory);
- In sane IRQ handling modes, scrub out old IRQ status before
enabling IRQs.
That latter is done by tightening up IRQ handling for rtc-cmos everywhere,
also ensuring that when HPET is used it's the only thing triggering IRQ
reports to userspace; net object shrink.
Also fix a bogus HPET message related to its RTC emulation.
Report-by: W Unruh <unruh@physics.ubc.ca>
Cc: Andrew Victor <avictor.za@gmail.com>
Resolve http://bugzilla.kernel.org/show_bug.cgi?id=11051 and other bugs
related to the way the HPET glue code in rtc-cmos was incomplete and
inconsistent:
* Switch the approach so that the basic driver code flow isn't
changed by having HPET ... instead, just have HPET shadow the
RTC_CONTROL irq enables and RTC_FREQ_SELECT data. It's only
coping with IRQ thievery, after all.
* Do that consistently (!!) to avoid problems when the HPET code
is out of sync with the real RTC intent. Examples include:
- cmos_procfs(), which now reports correct data
- cmos_irq_set_state() ... also removing the previous PIE_{ON,OFF}
ioctl support so only one code path manages "periodic" IRQs
- cmos_do_shutdown() ... currently a "just in case" change.
- cmos_suspend() and cmos_resume() ... also handling a bug that
was specific to HPET's IRQ thievery, where the alarm wasn't
disabled after waking the system
* Always call that HPET code under the RTC spinlock (it doesn't do
its own locking)
Also clean up the HPET glue:
* Add some comments explaining what's going on.
* Switch to having just one #ifdef for the HPET glue, and inline
functions (not #defines) to avoid some compiler warnings.
* Have the probe message also report when HPET IRQs are involved
This still leaves various holes in the HPET glue, like the emulated update
IRQs being out of sync with the RTC, alarms never using day or month
matches, and many extra IRQs (at 64 Hz).
[akpm@linux-foundation.org: fix build]
Cc: Tomas Janousek <tomi@nomi.cz>
Cc: Bernhard Walle <bwalle@suse.de>
Cc: Carlos R. Mafra <crmafra@ift.unesp.br>
