path: root/drivers/rtc/interface.c
2011-03-09RTC: Initialize kernel state from RTCJohn Stultz
Mark Brown pointed out a corner case: that RTC alarms should be allowed to be persistent across reboots if the hardware supported it. The rework of the generic layer to virtualize the RTC alarm virtualized much of the alarm handling, and removed the code used to read the alarm time from the hardware. Mark noted if we want the alarm to be persistent across reboots, we need to re-read the alarm value into the virtualized generic layer at boot up, so that the generic layer properly exposes that value. This patch restores much of the earlier removed rtc_read_alarm code and wires it in so that we set the kernel's alarm value to what we find in the hardware at boot time. NOTE: Not all hardware supports persistent RTC alarm state across system reset. rtc-cmos for example will keep the alarm time, but disables the AIE mode irq. Applications should not expect the RTC alarm to be valid after a system reset. We will preserve what we can, to represent the hardware state at boot, but its not guarenteed. Further, in the future, with multiplexed RTC alarms, the soonest alarm to fire may not be the one set via the /dev/rt ioctls. So an application may set the alarm with RTC_ALM_SET, but after a reset find that RTC_ALM_READ returns an earlier time. Again, we preserve what we can, but applications should not expect the RTC alarm state to persist across a system reset. Big thanks to Mark for pointing out the issue! Thanks also to Marcelo for helping think through the solution. CC: Mark Brown <broonie@opensource.wolfsonmicro.com> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: rtc-linux@googlegroups.com Reported-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-17RTC: Re-enable UIE timer/polling emulationJohn Stultz
This patch re-enables UIE timer/polling emulation for rtc devices that do not support alarm irqs. CC: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> CC: Thomas Gleixner <tglx@linutronix.de> Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-17RTC: Release mutex in error path of rtc_alarm_irq_enableUwe Kleine-König
On hardware that doesn't support alarm interrupts, rtc_alarm_irq_enable could return without releasing the ops_lock mutex. This was introduced in aa0be0f (RTC: Propagate error handling via rtc_timer_enqueue properly) This patch corrects the issue by only returning once the mutex is released. [john.stultz: Reworded the commit log] Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-03RTC: Prevents a division by zero in kernel code.Marcelo Roberto Jimenez
This patch prevents a user space program from calling the RTC_IRQP_SET ioctl with a negative value of frequency. Also, if this call is make with a zero value of frequency, there would be a division by zero in the kernel code. [jstultz: Also initialize irq_freq to 1 to catch other divbyzero issues] CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-01-21RTC: Properly handle rtc_read_alarm error propagation and fix bugJohn Stultz
In reviewing cases where the virtualized interfaces didn't propagate errors properly, I noticed rtc_read_alarm needed fixing. In doing so I noticed my RTC rework dropped a memset and that the behavior of rtc_read_alarm shouldn't be conditionalized on the alarm.enabled flag (as the alarm may be set, but the irqs may be disabled). So those were corrected as well. CC: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org> LKML-Reference: <1295565973-14358-2-git-send-email-john.stultz@linaro.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-21RTC: Propagate error handling via rtc_timer_enqueue properlyJohn Stultz
In cases where RTC hardware does not support alarms, the virtualized RTC interfaces did not have a way to propagate the error up to userland. This patch extends rtc_timer_enqueue so it catches errors from the hardware and returns them upwards to the virtualized interfaces. To simplify error handling, it also internalizes the management of the timer->enabled bit into rtc_timer_enqueue and rtc_timer_remove. Also makes rtc_timer_enqueue and rtc_timer_remove static. Reported-by: David Daney <ddaney@caviumnetworks.com> Reported-by: Andreas Schwab <schwab@linux-m68k.org> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Diagnosed-by: David Daney <ddaney@caviumnetworks.com> Tested-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: John Stultz <john.stultz@linaro.org> LKML-Reference: <1295565973-14358-1-git-send-email-john.stultz@linaro.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-12-13rtc: Namespace fixupThomas Gleixner
rtctimer_* is already occupied by sound/core/rtctimer.c. Instead of fiddling with that, rename the new functions to rtc_timer_* which reads nicer anyway. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <johnstul@us.ibm.com>
2010-12-10RTC: Rework RTC code to use timerqueue for eventsJohn Stultz
This patch reworks a large portion of the generic RTC code to in-effect virtualize the rtc interrupt code. The current RTC interface is very much a raw hardware interface. Via the proc, /dev/, or sysfs interfaces, applciations can set the hardware to trigger interrupts in one of three modes: AIE: Alarm interrupt UIE: Update interrupt (ie: once per second) PIE: Periodic interrupt (sub-second irqs) The problem with this interface is that it limits the RTC hardware so it can only be used by one application at a time. The purpose of this patch is to extend the RTC code so that we can multiplex multiple applications event needs onto a single RTC device. This is done by utilizing the timerqueue infrastructure to manage a list of events, which cause the RTC hardware to be programmed to fire an interrupt for the next event in the list. In order to preserve the functionality of the exsting proc,/dev/ and sysfs interfaces, we emulate the different interrupt modes as follows: AIE: We create a rtc_timer dedicated to AIE mode interrupts. There is only one per device, so we don't change existing interface semantics. UIE: Again, a dedicated rtc_timer, set for periodic mode, is used to emulate UIE interrupts. Again, only one per device. PIE: Since PIE mode interrupts fire faster then the RTC's clock read granularity, we emulate PIE mode interrupts using a hrtimer. Again, one per device. With this patch, the rtctest.c application in Documentation/rtc.txt passes fine on x86 hardware. However, there may very well still be bugs, so greatly I'd appreciate any feedback or testing! Signed-off-by: John Stultz <john.stultz@linaro.org> LKML Reference: <1290136329-18291-4-git-send-email-john.stultz@linaro.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: Richard Cochran <richardcochran@gmail.com>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-06-19rtc: make rtc_update_irq callable with irqs enabledAtsushi Nemoto
The rtc_update_irq() might be called with irqs enabled, if a interrupt handler was registered without IRQF_DISABLED. Use spin_lock_irqsave/spin_unlock_irqrestore instead of spin_lock/spin_unlock. Also update kerneldoc and drivers which do extra work to follow the current interface spec, as suggestted by David Brownell. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: use set_mmss when set_time is not availableAlessandro Zummo
Drivers should only need to implement either set_mmss (counter based RTCs) or set_time (most RTCs). The RTC subsystem will handle them appropriately. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: David Brownell <david-b@pacbell.net> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: move power of 2 periodic frequency check down into driversJonathan Cameron
Move the power of 2 check on frequencies down into individual rtc drivers This is to allow for non power of 2 real time clock periodic interrupts such as those on the pxa27x to be found in the new pxa27x-rtc driver Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: struct device: replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Alessandro Zummo <a.zummo@towertech.it> Acked-By: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04rtc: add alarm/update irq interfacesAlessandro Zummo
Add standard interfaces for alarm/update irqs enabling. Drivers are no more required to implement equivalent ioctl code as rtc-dev will provide it. UIE emulation should now be handled correctly and will work even for those RTC drivers who cannot be configured to do both UIE and AIE. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06rtc: fix handling of missing tm_year data when reading alarmsMark Brown
When fixing up invalid years rtc_read_alarm() was calling rtc_valid_tm() as a boolean but rtc_valid_tm() returns zero on success or a negative number if the time is not valid so the test was inverted. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30rtc: don't return -EBUSY when mutex_lock_interruptible() failsDavid Brownell
It was pointed out that the RTC framework handles its mutex locks oddly ... returning -EBUSY when interrupted. This fixes that by returning the value of mutex_lock_interruptible() (i.e. -EINTR). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21Driver Core: add ability for class_find_device to start in middle of listGreg Kroah-Hartman
This mirrors the functionality that driver_find_device has as well. We add a start variable, and all callers of the function are fixed up at the same time. The block layer will be using this new functionality in a follow-on patch. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-04rtc: rtc_read_alarm() handles wraparoundDavid Brownell
While 0e36a9a4a788e4e92407774df76c545910810d35 ("rtc: fix readback from /sys/class/rtc/rtc?/wakealarm") made sure that active alarms were never returned with invalid "wildcard" fields (negative), it can still report (wrongly) that the alarm triggers in the past. Example, if it's now 10am, an alarm firing at 5am will be triggered TOMORROW not today. (Which may also be next month or next year...) This updates that alarm handling in three ways: * Handle alarm rollover in the common cases of RTCs that don't support matching on all date fields. * Skip the invalid-field logic when it's not needed. * Minor bugfix ... tm_isdst should be ignored, it's one of the fields Linux doesn't maintain. A warning is emitted for some of the unhandled rollover cases, but the possible combinations are a bit too numerous to handle every bit of potential hardware and firmware braindamage. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Mark Lord <lkml@rtr.ca> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-24rtc: use class iteration apiDave Young
Convert to use the class iteration api. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-05RTC: assure proper memory ordering with respect to RTC_DEV_BUSY flagJiri Kosina
We must make sure that the RTC_DEV_BUSY flag has proper lock semantics, i.e. that the RTC_DEV_BUSY stores clearing the flag don't get reordered before the preceeding stores and loads and vice versa. Spotted by Nick Piggin. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: David Brownell <david-b@pacbell.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29RTC: convert mutex to bitfieldJiri Kosina
RTC code is using mutex to assure exclusive access to /dev/rtc. This is however wrong usage, as it leaves the mutex locked when returning into userspace, which is unacceptable. Convert rtc->char_lock into bit operation. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16rtc: fix readback from /sys/class/rtc/rtc?/wakealarmMark Lord
Fix readback of RTC alarms on platforms which return -1 in non-hardware-supported RTC alarm fields. To fill in the missing (-1) values, we grab an RTC timestamp along with the RTC alarm value, and use the timestamp fields to populate the missing alarm fields. To counter field-wrap races (since the timestamp and alarm are not read together atomically), we read the RTC timestamp both before and after reading the RTC alarm value, and then check for wrapped fields --> if any have wrapped, we know we have a possible inconsistency, so we loop and reread the timestamp and alarm again. Wrapped fields in the RTC timestamps are an issue because rtc-cmos.c, for example, also gets/uses an RTC timestamp internally while fetching the RTC alarm. If our timestamp here wasn't the same (minutes and higher) as what was used internally there, then we might end up populating the -1 fields with inconsistent values. This fixes readbacks from /sys/class/rtc/rtc?/wakealarm, as well as other code paths which call rtc_read_alarm(). Signed-off-by: Mark Lord <mlord@pobox.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16rtc_irq_set_freq() requires power-of-two and associated kerneldocDavid Brownell
RTC periodic IRQs are only defined to work for 2^N Hz values. This patch moves that validity check into the infrastructure, so drivers don't need to check it; and adds kerneldoc for the two interface functions related to periodic IRQs. (One of which was quite mysterious until its first use was recently checked in!) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16RTC: periodic irq fixAlessandro Zummo
Add kernel/kernel and kernel/user locking for the periodic irq feature of the rtc class. PIE ioctls are also supported. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove "RTC_ALM_SET mode" bugsDavid Brownell
This fixes a common glitch in how RTC drivers handle two "set alarm" modes, by getting rid of the surprising/hidden one that was rarely implemented correctly (and which could expose nonportable hardware-specific behavior). The glitch comes from the /dev/rtcX logic implementing the legacy RTC_ALM_SET (limited to 24 hours, needing RTC_AIE_ON) ioctl on top of the RTC driver call providing access to the newer RTC_WKALM_SET (without those limitations) by initializing the day/month/year fields to be invalid ... that second mode. Now, since few RTC drivers check those fields, and most hardware misbehaves when faced with invalid date fields, many RTC drivers will set bogus alarm times on those RTC_ALM_SET code paths. (Several in-tree drivers have that issue, and I also noticed it with code reviews on several new RTC drivers.) This patch ensures that RTC drivers never see such invalid alarm fields, by moving some logic out of rtc-omap into the RTC_ALM_SET code and adding an explicit check (which will prevent the issue on other code paths). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove rest of class_deviceDavid Brownell
Finish converting the RTC framework so it no longer uses class_device. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: rtc interfaces don't use class_deviceDavid Brownell
This patch removes class_device from the programming interface that the RTC framework exposes to the rest of the kernel. Now an rtc_device is passed, which is more type-safe and streamlines all the relevant code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] rtc_cmos oops fixDavid Brownell
Fix an oops on the rtc_device_unregister() path by waiting until the last moment before nulling the rtc->ops vector. Fix some potential oopses by having the rtc_class_open()/rtc_class_close() interface increase the RTC's reference count while an RTC handle is available outside the RTC framework. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-25[PATCH] rtc class locking bugfixesDavid Brownell
I got a lockdep warning when running "rtctest" so I though it'd be good to see what was up. - The warning was for rtc->irq_task_lock, gotten from rtc_update_irq() by irq handlerss ... but in a handful of other cases, grabbed without blocking IRQs. - Some callers to rtc_update_irq() were not ensuring IRQs were blocked, yet the routine expects that; make sure all callers block IRQs. It would appear that RTC API tests haven't been part of anyone's kernel regression test suite recently, at least not with lockdep running. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] rtc framework handles periodic irqsDavid Brownell
The RTC framework has an irq_set_freq() method that should be used to manage the periodic IRQ frequency, but the current ioctl logic doesn't know how to do that. This patch teaches it how. This means that drivers implementing irq_set_freq() will automatically support RTC_IRQP_{READ,SET} ioctls; that logic doesn't need duplication within the driver. [akpm@osdl.org: export rtc_irq_set_freq] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] rtc subsystem, fix capability checks in kernel interfaceAlessandro Zummo
Remove commented capability checks and add some others. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC subsystem: classAlessandro Zummo
Add the basic RTC subsystem infrastructure to the kernel. rtc/class.c - registration facilities for RTC drivers rtc/interface.c - kernel/rtc interface functions rtc/hctosys.c - snippet of code that copies hw clock to sw clock at bootup, if configured to do so. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
