path: root/drivers/regulator
2017-11-02regulator: fan53555: fix I2C device idsGuillaume Tucker
commit fc1111b885437f374ed54aadda44d8b241ebd2a3 upstream. The device tree nodes all correctly describe the regulators as syr827 or syr828, but the I2C device id is currently set to the wildcard value of syr82x in the driver. This causes udev to fail to match the driver module with the modalias data from sysfs. Fix this by replacing the I2C device ids with ones that match the device tree descriptions, with syr827 and syr828. Tested on Firefly rk3288 board. The syr82x id was not used anywhere. Fixes: e80c47bd738b (regulator: fan53555: Export I2C module alias information) Signed-off-by: Guillaume Tucker <guillaume.tucker@collabora.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25regulator: tps65023: Fix inverted core enable logic.Richard Cochran
commit c90722b54a4f5e21ac59301ed9a6dbaa439bdb16 upstream. Commit 43530b69d758328d3ffe6ab98fd640463e8e3667 ("regulator: Use regmap_read/write(), regmap_update_bits functions directly") intended to replace working inline helper functions with standard regmap calls. However, it also inverted the set/clear logic of the "CORE ADJ Allowed" bit. That patch was clearly never tested, since without that bit cleared, the core VDCDC1 voltage output does not react to I2C configuration changes. This patch fixes the issue by clearing the bit as in the original, correct implementation. Note for stable back porting that, due to subsequent driver churn, this patch will not apply on every kernel version. Fixes: 43530b69d758 ("regulator: Use regmap_read/write(), regmap_update_bits functions directly") Signed-off-by: Richard Cochran <rcochran@linutronix.de> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-02regulator: core: Clear the supply pointer if enabling failsJon Hunter
commit 8e5356a73604f53da6a1e0756727cb8f9f7bba17 upstream. During the resolution of a regulator's supply, we may attempt to enable the supply if the regulator itself is already enabled. If enabling the supply fails, then we will call _regulator_put() for the supply. However, the pointer to the supply has not been cleared for the regulator and this will cause a crash if we then unregister the regulator and attempt to call regulator_put() a second time for the supply. Fix this by clearing the supply pointer if enabling the supply after fails when resolving the supply for a regulator. Signed-off-by: Jon Hunter <jonathanh@nvidia.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12regulator: Fix regulator_summary for deviceless consumersLeonard Crestez
commit e42a46b6f52473661ad192f76a128a68fe301df4 upstream. It is allowed to call regulator_get with a NULL dev argument (_regulator_get explicitly checks for it) but this causes an error later when printing /sys/kernel/debug/regulator_summary. Fix this by explicitly handling "deviceless" consumers in the debugfs code. Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-09regulator: stw481x-vmmc: fix ages old enable errorLinus Walleij
commit 295070e9aa015abb9b92cccfbb1e43954e938133 upstream. The regulator has never been properly enabled, it has been dormant all the time. It's strange that MMC was working at all, but it likely worked by the signals going through the levelshifter and reaching the card anyways. Fixes: 3615a34ea1a6 ("regulator: add STw481x VMMC driver") Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28regulator: tps65910: Work around silicon erratum SWCZ010Jan Remmet
commit 8f9165c981fed187bb483de84caf9adf835aefda upstream. http://www.ti.com/lit/pdf/SWCZ010: DCDC o/p voltage can go higher than programmed value Impact: VDDI, VDD2, and VIO output programmed voltage level can go higher than expected or crash, when coming out of PFM to PWM mode or using DVFS. Description: When DCDC CLK SYNC bits are 11/01: * VIO 3-MHz oscillator is the source clock of the digital core and input clock of VDD1 and VDD2 * Turn-on of VDD1 and VDD2 HSD PFETis synchronized or at a constant phase shift * Current pulled though VCC1+VCC2 is Iload(VDD1) + Iload(VDD2) * The 3 HSD PFET will be turned-on at the same time, causing the highest possible switching noise on the application. This noise level depends on the layout, the VBAT level, and the load current. The noise level increases with improper layout. When DCDC CLK SYNC bits are 00: * VIO 3-MHz oscillator is the source clock of digital core * VDD1 and VDD2 are running on their own 3-MHz oscillator * Current pulled though VCC1+VCC2 average of Iload(VDD1) + Iload(VDD2) * The switching noise of the 3 SMPS will be randomly spread over time, causing lower overall switching noise. Workaround: Set DCDCCTRL_REG[1:0]= 00. Signed-off-by: Jan Remmet <j.remmet@phytec.de> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07regulator: qcom_smd: Fix voltage ranges for pm8x41Stephen Boyd
commit 290284776bb281759b11faa287b8abccaf74bfcb upstream. The voltage ranges listed here are wrong. The correct ranges can be seen in the "native" spmi regulator driver qcom_spmi-regulator.c at pldo_ranges[], ftsmps_ranges[] and boost_ranges[] for the pldo, ftsmps, and boost type regulators. Port these ranges over to the RPM SMD regulator driver so that we list the appropriate set of supported voltages on pldos. Doing this allows us to specify a voltage like 3075000 for l24, whereas before that wasn't a supported voltage. Fixes: da65e367b67e ("regulator: Regulator driver for the Qualcomm RPM") Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Reviewed-by: Andy Gross <andy.gross@linaro.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07regulator: qcom_spmi: Update mvs1/mvs2 switches on pm8941Stephen Boyd
commit 93bfe79b03365f410aa91caf04263173c008ecdf upstream. The mvs1 and mvs2 switches are actually called 5vs1 and 5vs2 on some datasheets. Let's rename them to match the datasheets and also match the RPM based regulator driver which calls these by their 5vs names (see qcom_smd-regulator.c). There aren't any users of these regulators so far, so there aren't any concerns of DT ABI breakage here. While we're here making updates to the switches, also mandate usage of the OCP irq for these switches too. Cc: Bjorn Andersson <bjorn.andersson@linaro.org> Fixes: e92a4047419c ("regulator: Add QCOM SPMI regulator driver") Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07regulator: qcom_spmi: Add support for get_mode/set_mode on switchesStephen Boyd
commit 919163f6362ac23138d31fc8befdd52e5d7e488d upstream. The voltage switches support mode switching, so add support for these ops to those types of regulators. Cc: Bjorn Andersson <bjorn.andersson@linaro.org> Fixes: e92a4047419c ("regulator: Add QCOM SPMI regulator driver") Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07regulator: qcom_spmi: Add support for S4 supply on pm8941Stephen Boyd
commit c333dfe8dba7d3e47e97e1cee3c38123e19ae73c upstream. The S4 supply is sometimes called the boost regulator because it outputs 5V. Typically it's connected to the 5vs1 and 5vs2 switches for use in USB OTG and HDMI applications. Add support for this regulator which was mistakenly left out from the initial submission of this driver. Cc: Bjorn Andersson <bjorn.andersson@linaro.org> Fixes: e92a4047419c ("regulator: Add QCOM SPMI regulator driver") Signed-off-by: Stephen Boyd <stephen.boyd@linaro.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15regulator: anatop: allow regulator to be in bypass modeMika Båtsman
commit 8a092e682f20f193f2070dba2ea1904e95814126 upstream. Bypass support was added in commit d38018f2019c ("regulator: anatop: Add bypass support to digital LDOs"). A check for valid voltage selectors was added in commit da0607c8df5c ("regulator: anatop: Fail on invalid voltage selector") but it also discards all regulators that are in bypass mode. Add check for the bypass setting. Errors below were seen on a Variscite mx6 board. anatop_regulator 20c8000.anatop:regulator-vddcore@140: Failed to read a valid default voltage selector. anatop_regulator: probe of 20c8000.anatop:regulator-vddcore@140 failed with error -22 anatop_regulator 20c8000.anatop:regulator-vddsoc@140: Failed to read a valid default voltage selector. anatop_regulator: probe of 20c8000.anatop:regulator-vddsoc@140 failed with error -22 Fixes: da0607c8df5c ("regulator: anatop: Fail on invalid voltage selector") Signed-off-by: Mika Båtsman <mbatsman@mvista.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18regulator: axp20x: Fix axp22x ldo_io voltage rangesHans de Goede
commit a2262e5a12e05389ab4c7fc5cf60016b041dd8dc upstream. The minium voltage of 1800mV is a copy and paste error from the axp20x regulator info. The correct minimum voltage for the ldo_io regulators on the axp22x is 700mV. Fixes: 1b82b4e4f954 ("regulator: axp20x: Add support for AXP22X regulators") Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18regulator: s2mps11: Fix invalid selector mask and voltages for buck9Krzysztof Kozlowski
commit 3b672623079bb3e5685b8549e514f2dfaa564406 upstream. The buck9 regulator of S2MPS11 PMIC had incorrect vsel_mask (0xff instead of 0x1f) thus reading entire register as buck9's voltage. This effectively caused regulator core to interpret values as higher voltages than they were and then to set real voltage much lower than intended. The buck9 provides power to other regulators, including LDO13 and LDO19 which supply the MMC2 (SD card). On Odroid XU3/XU4 the lower voltage caused SD card detection errors on Odroid XU3/XU4: mmc1: card never left busy state mmc1: error -110 whilst initialising SD card During driver probe the regulator core was checking whether initial voltage matches the constraints. With incorrect vsel_mask of 0xff and default value of 0x50, the core interpreted this as 5 V which is outside of constraints (3-3.775 V). Then the regulator core was adjusting the voltage to match the constraints. With incorrect vsel_mask this new voltage mapped to a vere low voltage in the driver. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com> Tested-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04regulator: s5m8767: fix get_register() error handlingArnd Bergmann
commit e07ff9434167981c993a26d2edbbcb8e13801dbb upstream. The s5m8767_pmic_probe() function calls s5m8767_get_register() to read data without checking the return code, which produces a compile-time warning when that data is accessed: drivers/regulator/s5m8767.c: In function 's5m8767_pmic_probe': drivers/regulator/s5m8767.c:924:7: error: 'enable_reg' may be used uninitialized in this function [-Werror=maybe-uninitialized] drivers/regulator/s5m8767.c:944:30: error: 'enable_val' may be used uninitialized in this function [-Werror=maybe-uninitialized] This changes the s5m8767_get_register() function to return a -EINVAL not just for an invalid register number but also for an invalid regulator number, as both would result in returning uninitialized data. The s5m8767_pmic_probe() function is then changed accordingly to fail on a read error, as all the other callers of s5m8767_get_register() already do. In practice this probably cannot happen, as we don't call s5m8767_get_register() with invalid arguments, but the gcc warning seems valid in principle, in terms writing safe error checking. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 9c4c60554acf ("regulator: s5m8767: Convert to use regulator_[enable|disable|is_enabled]_regmap") Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04regulator: core: Fix nested locking of suppliesThierry Reding
commit 70a7fb80e85ae7f78f8e90cec3fbd862ea6a4d4b upstream. Commit fa731ac7ea04 ("regulator: core: avoid unused variable warning") introduced a subtle change in how supplies are locked. Where previously code was always locking the regulator of the current iteration, the new implementation only locks the regulator if it has a supply. For any given power tree that means that the root will never get locked. On the other hand the regulator_unlock_supply() will still release all the locks, which in turn causes the lock debugging code to warn about a mutex being unlocked which wasn't locked. Cc: Mark Brown <broonie@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Fixes: fa731ac7ea04 ("regulator: core: avoid unused variable warning") Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04regulator: core: Ensure we lock all regulatorsMark Brown
commit 49a6bb7a1c0963f260e4b0dcc2c0e56ec65a28b2 upstream. The latest workaround for the lockdep interface's not using the second argument of mutex_lock_nested() changed the loop missed locking the last regulator due to a thinko with the loop termination condition exiting one regulator too soon. Reported-by: Tyler Baker <tyler.baker@linaro.org> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04regulator: core: fix regulator_lock_supply regressionArnd Bergmann
commit bb41897e38c53458a88b271f2fbcd905ee1f9584 upstream. As noticed by Geert Uytterhoeven, my patch to avoid a harmless build warning in regulator_lock_supply() was total crap and introduced a real bug: > [ BUG: bad unlock balance detected! ] > kworker/u4:0/6 is trying to release lock (&rdev->mutex) at: > [<c0247b84>] regulator_set_voltage+0x38/0x50 we still lock the regulator supplies, but not the actual regulators, so we are missing a lock, and the unlock is unbalanced. This rectifies it by first locking the regulator device itself before using the same loop as before to lock its supplies. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 716fec9d1965 ("[SUBMITTED] regulator: core: avoid unused variable warning") Signed-off-by: Mark Brown <broonie@kernel.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04Revert "regulator: core: Fix nested locking of supplies"Greg Kroah-Hartman
This reverts commit b1999fa6e8145305a6c8bda30ea20783717708e6 which was commit 70a7fb80e85ae7f78f8e90cec3fbd862ea6a4d4b upstream. It causes run-time breakage in the 4.4-stable tree and more patches are needed to be applied first before this one in order to resolve the issue. Reported-by: Guenter Roeck <linux@roeck-us.net> Cc: Mark Brown <broonie@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Thierry Reding <treding@nvidia.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12regulator: core: Fix nested locking of suppliesThierry Reding
commit 70a7fb80e85ae7f78f8e90cec3fbd862ea6a4d4b upstream. Commit fa731ac7ea04 ("regulator: core: avoid unused variable warning") introduced a subtle change in how supplies are locked. Where previously code was always locking the regulator of the current iteration, the new implementation only locks the regulator if it has a supply. For any given power tree that means that the root will never get locked. On the other hand the regulator_unlock_supply() will still release all the locks, which in turn causes the lock debugging code to warn about a mutex being unlocked which wasn't locked. Cc: Mark Brown <broonie@kernel.org> Cc: Arnd Bergmann <arnd@arndb.de> Fixes: Fixes: fa731ac7ea04 ("regulator: core: avoid unused variable warning") Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12regulator: core: avoid unused variable warningArnd Bergmann
commit fa731ac7ea04a7d3a5c6d2f568132478c02a83b3 upstream. The second argument of the mutex_lock_nested() helper is only evaluated if CONFIG_DEBUG_LOCK_ALLOC is set. Otherwise we get this build warning for the new regulator_lock_supply function: drivers/regulator/core.c: In function 'regulator_lock_supply': drivers/regulator/core.c:142:6: warning: unused variable 'i' [-Wunused-variable] To avoid the warning, this restructures the code to make it both simpler and to move the 'i++' outside of the mutex_lock_nested call, where it is now always used and the variable is not flagged as unused. We had some discussion about changing mutex_lock_nested to an inline function, which would make the code do the right thing here, but in the end decided against it, in order to guarantee that mutex_lock_nested() does not introduced overhead without CONFIG_DEBUG_LOCK_ALLOC. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 9f01cd4a915 ("regulator: core: introduce function to lock regulators and its supplies") Link: http://permalink.gmane.org/gmane.linux.kernel/2068900 Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03regulator: mt6311: MT6311_REGULATOR needs to select REGMAP_I2CHenry Chen
commit aab3c3f34cc2dd8230052770712606d65de6538f upstream. This patch fix the below build error: drivers/regulator/mt6311-regulator.c:111: undefined reference to `__devm_regmap_init_i2c' Signed-off-by: Henry Chen <henryc.chen@mediatek.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03regulator: axp20x: Fix GPIO LDO enable value for AXP22xChen-Yu Tsai
commit 3cb99e2ea99a454c8837a55aac88753ef05fc1eb upstream. The enable/disable values for GPIO LDOs are reversed. It seems no one noticed as AXP22x support was introduced recently, and no one was using the GPIO LDOs, either because no designs actually use them or board support hasn't caught up. Fixes: 1b82b4e4f954 ("regulator: axp20x: Add support for AXP22X regulators") Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-05Merge tag 'spi-v4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi updates from Mark Brown: "Quite a lot of activity in SPI this cycle, almost all of it in drivers with a few minor improvements and tweaks in the core. - Updates to pxa2xx to support Intel Broxton and multiple chip selects. - Support for big endian in the bcm63xx driver. - Multiple slave support for the mt8173 - New driver for the auxiliary SPI controller in bcm2835 SoCs. - Support for Layerscale SoCs in the Freescale DSPI driver" * tag 'spi-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (87 commits) spi: pxa2xx: Rework self-initiated platform data creation for non-ACPI spi: pxa2xx: Add support for Intel Broxton spi: pxa2xx: Detect number of enabled Intel LPSS SPI chip select signals spi: pxa2xx: Add output control for multiple Intel LPSS chip selects spi: pxa2xx: Use LPSS prefix for defines that are Intel LPSS specific spi: Add DSPI support for layerscape family spi: ti-qspi: improve ->remove() callback spi/spi-xilinx: Fix race condition on last word read spi: Drop owner assignment from spi_drivers spi: Add THIS_MODULE to spi_driver in SPI core spi: Setup the master controller driver before setting the chipselect spi: dw: replace magic constant by DW_SPI_DR spi: mediatek: mt8173 spi multiple devices support spi: mediatek: handle controller_data in mtk_spi_setup spi: mediatek: remove mtk_spi_config spi: mediatek: Update document devicetree bindings to support multiple devices spi: fix kernel-doc warnings about missing return desc in spi.c spi: fix kernel-doc warnings about missing return desc in spi.h spi: pxa2xx: Align a few defines spi: pxa2xx: Save other reg_cs_ctrl bits when configuring chip select ...
2015-11-04Merge remote-tracking branches 'regulator/topic/supply', ↵Mark Brown
'regulator/topic/tps6105x' and 'regulator/topic/tps65023' into regulator-next
2015-11-04Merge remote-tracking branches 'regulator/topic/load', ↵Mark Brown
'regulator/topic/max77802', 'regulator/topic/pwm', 'regulator/topic/qcom-smd' and 'regulator/topic/stw481x' into regulator-next
2015-11-04Merge remote-tracking branches 'regulator/topic/da9053' and ↵Mark Brown
'regulator/topic/da9063' into regulator-next
2015-11-04Merge remote-tracking branches 'regulator/topic/act8865', ↵Mark Brown
'regulator/topic/anatop', 'regulator/topic/arizona', 'regulator/topic/axp20x' and 'regulator/topic/bcm590xx' into regulator-next
2015-11-04Merge remote-tracking branch 'regulator/topic/list' into regulator-nextMark Brown
2015-11-04Merge remote-tracking branch 'regulator/topic/core' into regulator-nextMark Brown
2015-11-04Merge remote-tracking branches 'spi/topic/omap-100k', ↵Mark Brown
'spi/topic/omap-uwire', 'spi/topic/owner', 'spi/topic/pxa' and 'spi/topic/pxa2xx' into spi-next
2015-11-04regulator: Use regulator_lock_supply() for get_voltage() tooMark Brown
Since we need to read voltages of parents as part of setting supply voltages we need to be able to do get_voltage() internally without taking locks so reorganize the locking to take locks on the full tree on entry rather than as we recurse when called externally. Reported-by: John Stultz <john.stultz@linaro.org> Tested-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-28spi: Drop owner assignment from spi_driversAndrew F. Davis
An spi_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-23regulator: stw481x: compile on COMPILE_TESTLuis de Bethencourt
The driver depends on MFD_STW481X but there isn't a build dependency so it's a good idea to allow the driver to always be built when the COMPILE_TEST option is enabled. That way, the driver can be built with a config generated by make allyesconfig and check if a patch would break the build. Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-22regulator: qcom-smd: Correct set_load() unitBjorn Andersson
The set_load() op deals with uA while the SMD packets used mA, so convert as we're building the packet. Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-22regulator: core: Propagate voltage changes to supply regulatorsSascha Hauer
Until now changing the voltage of a regulator only ever effected the regulator itself, but never its supplies. It's a common pattern though to put LDO regulators behind switching regulators. The switching regulators efficiently drop the input voltage but have a high ripple on their output. The output is then cleaned up by the LDOs. For higher energy efficiency the voltage drop at the LDOs should be minimized. For this scenario we need to propagate the voltage change to the supply regulators. Another scenario where voltage propagation is desired is a regulator which only consists of a switch and thus cannot regulate voltages itself. In this case we can pass setting voltages to the supply. This patch adds support for voltage propagation. We do voltage propagation when the current regulator has a minimum dropout voltage specified or if the current regulator lacks a get_voltage operation (indicating it's a switch and not a regulator). Changing the supply voltage must be done carefully. When we are increasing the current regulators output we must first increase the supply voltage and then the regulator itself. When we are decreasing the current regulators voltage we must decrease the supply voltage after changing the current regulators voltage. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-20regulator: core: Factor out regulator_map_voltageSascha Hauer
_regulator_call_set_voltage has code to translate a minimum/maximum voltage pair into a selector. This code is useful for others aswell, so create a regulator_map_voltage function. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-16regulator: i.MX anatop: Allow supply regulatorSascha Hauer
The anatop regulators are SoC internal LDO regulators usually supplied by an external PMIC. This patch adds support for specifying the supply from the device tree using the vin-supply property. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-16regulator: core: create unlocked version of regulator_set_voltageSascha Hauer
The unlocked version will be needed when we start propagating voltage changes to the supply regulators. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-16regulator: arizona-ldo1: Fix handling of GPIO 0Charles Keepax
The LDO1 driver is using the arizona_of_get_named_gpio helper function which will return 0 if an error was encountered whilst parsing the GPIO, as under the pdata scheme 0 was not being treated as a valid GPIO. However, since the regulator framework was expanded to allow the use of GPIO 0 this causes us to attempt to register GPIO 0 when we encountered an error parsing the device tree. This patch uses of_get_named_gpio directly and sets the ena_gpio_initialized flag based on the return value. Fixes: 1de3821ace82 ("regulator: Set ena_gpio_initialized in regulator drivers") Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-16regulator: da9053: Update regulator for DA9053 BC silicon supportSteve Twiss
Provide an additional case entry for DA9053_BC in the find_regulator_info() function in order to support BC type silicon for the DA9053 device. Signed-off-by: Steve Twiss <stwiss.opensource@diasemi.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-06Merge remote-tracking branch 'regulator/fix/axp20x' into regulator-linusMark Brown
2015-10-05regulator: axp20x: set supply names for AXP22X DC1SW/DC5LDO internallyChen-Yu Tsai
The DC1SW and DC5LDO regulators in the AXP22X are internally chained to DCDC1 and DCDC5, hence the names. The original bindings used the parent regulator names for the supply regulator property. Since they are internally connected, the relationship should not be represented in the device tree, but handled internally by the driver. This patch has the driver remember the regulator names for the parent DCDC1/DCDC5, and use them as supply names for DC1SW/DC5LDO. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-05mfd: tps6105x: Use i2c regmap to access registersGrigoryev Denis
This patch modifies tps6105x and associated function driver to use regmap instead of operating directly on i2c. Signed-off-by: Denis Grigoryev <grigoryev@fastwel.ru> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-10-02regulator: act8865: support output voltage by VSET2[] bitsWenyou Yang
For the step-down DC/DC regulators, the output voltage is selectable by setting VSEL pin that when VSEL is low, output voltage is programmed by VSET1[] bits, and when VSEL is high, output voltage is programmed by VSET2[] bits. The DT property "active-semi,vsel-high" is used to specify the VSEL pin at high on the board. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-02regulator: arizona: add support for WM8998 and WM1814Richard Fitzgerald
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com> Acked-by: Mark Brown <broonie@kernel.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-01regulator: core: create unlocked version of regulator_list_voltageSascha Hauer
2015-10-01regulator: core: introduce function to lock regulators and its suppliesSascha Hauer
Each regulator_dev is locked with its own mutex. This is fine as long as only one regulator_dev is locked, but makes lockdep unhappy when we have to walk up the supply chain like it can happen in regulator_get_voltage: regulator_get_voltage -> mutex_lock(&regulator->rdev->mutex) -> _regulator_get_voltage(regulator->rdev) -> regulator_get_voltage(rdev->supply) -> mutex_lock(&regulator->rdev->mutex); This causes lockdep to issue a possible deadlock warning. There are at least two ways to work around this: - We can always lock the whole supply chain using the functions introduced with this patch. - We could store the current voltage in struct regulator_rdev so that we do not have to walk up the supply chain for the _regulator_get_voltage case. Anyway, regulator_lock_supply/regulator_unlock_supply will be needed once we allow regulator_set_voltage to optimize the supply voltages. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-01regulator: core: Handle probe deferral from DT when resolving suppliesMark Brown
When resolving regulator-regulator supplies we ignore probe deferral returns from regulator_dev_lookup() (such as are generated for DT when we can see a supply is registered) and just fall back to the dummy regulator if there are full constraints (as is the case for DT). This means that probe deferral is broken for DT systems, fix that by paying attention to -EPROBE_DEFER return codes like we do -ENODEV. A further patch will simplify this further, this is a minimal fix for the specific issue. Fixes: 9f7e25edb1575a6d2 (regulator: core: Handle full constraints systems when resolving supplies) Reported-by: Sascha Hauer <s.hauer@pengutronix.de> Tested-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mark Brown <broonnie@kernel.org> Cc: stable@vger.kernel.org
2015-09-29regulator: axp20x: Fix enable bit indexes for DCDC4 and DCDC5Chen-Yu Tsai
The enable bit indexes for DCDC4 and DCDC5 regulators are off by 1. We haven't run into any problems with this since either the regulators aren't defined in the DT and aren't used, or all the DCDC regulators have the "always-on" property set, as they are almost always used for system critical loads. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2015-09-21Merge remote-tracking branches 'regulator/fix/anatop', 'regulator/fix/gpio', ↵Mark Brown
'regulator/fix/pbias', 'regulator/fix/tpx65218' and 'regulator/fix/vexpress' into regulator-linus
