path: root/drivers/regulator/fixed.c
2012-04-18regulator: fixed: Support for open drain gpio pinLaxman Dewangan
Adding flag on fixed regulator board configuration structure to specify whether gpio is open drain type or not. Passing this information to gpio library when requesting gpio so that gpio driver can set the pin state accordingly, for open drain type: - Pin can be set HIGH as setting as input, PULL UP on pin make this as HIGH. - Pin can be set LOW as setting it as output and drive to LOW. The non-open drain pin can be set HIGH/LOW by setting it to output and driving it to HIGH/LOW. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> cherry picked from mainline commit a4d9f179cc788b7f4b735d32c2e4a3b2562e8240 Change-Id: I2ee7789db67fdeea77c0d6ac2b44876af36c803e Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/94150 Reviewed-by: Automatic_Commit_Validation_User
2012-04-07Merge branch '3.4-rc1' into android-tegra-nv-3.3-rebasedVarun Wadekar
Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-06regulator: set constraints.apply_uV to 0 in of_get_fixed_voltage_configRichard Zhao
Fix fixed regulator using DT failed to call regulator_register. of_get_regulator_init_data set apply_uV to 1, but fixed regulator doesn't need it. Set it back to 0. Signed-off-by: Richard Zhao <richard.zhao@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-01-02regulator: pass regulator_register of_node in fixed voltage driverRichard Zhao
regulator_get needs of_node to find right regulator. Signed-off-by: Richard Zhao <richard.zhao@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-05Merge branch 'topic/dt' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator into regulator-next
2011-12-05regulator: pass device_node to of_get_regulator_init_data()Shawn Guo
It's not always true that the device_node of regulator can be found at dev->of_node at the time when of_get_regulator_init_data() is being called, because in some cases the regulator nodes in device tree do not have 'struct device' behind them until regulator_dev gets created for it by core function regulator_register(). The patch adds device_node as a new parameter to of_get_regulator_init_data(), so that caller can pass in the node of regulator directly. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-27Merge remote-tracking branch 'regulator/topic/dt' into regulator-nextMark Brown
2011-11-27regulator: Avoid potential NULL dereference in reg_fixed_voltage_probe()Axel Lin
of_get_fixed_voltage_config() may return NULL, return -ENOMEM in this case so we don't dereference NULL pointer. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-27regulator: Staticise of_get_fixed_voltage_config()Axel Lin
It is not used outside this driver so no need to make the symbol global. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-27regulator: Checking return value of of_get_regulator_init_dataAxel Lin
of_get_regulator_init_data() may return NULL, thus check the return value to avoid NULL pointer dereference. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-23Merge remote-tracking branch 'regulator/topic/dt' into regulator-nextMark Brown
2011-11-23regulator: pass additional of_node to regulator_register()Rajendra Nayak
With device tree support for regulators, its needed that the regulator_dev->dev device has the right of_node attached. To be able to do this add an additional parameter to the regulator_register() api, wherein the dt-adapted driver can then pass this additional info onto the regulator core. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-23regulator: adapt fixed regulator driver to dtRajendra Nayak
The fixed regulator driver uses of_get_fixed_voltage_config() to extract fixed_voltage_config structure contents from device tree. Also add documenation for additional bindings for fixed regulators that can be passed through dt. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-23regulator: Don't report zero volts for the fixed voltage regulatorMark Brown
If we don't know what voltage the regulator is set to return an error rather than reporting zero volts. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-31regulator: Add module.h to drivers/regulator users as requiredPaul Gortmaker
Another group of drivers that are taking advantage of the implicit presence of module.h -- and will break when we pull the carpet out from under them during a cleanup. Fix 'em now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03Regulators: fixed - annotate probe and remove methodsDmitry Torokhov
Add __devinit/__devexit markings to probe and remove methids of the driver, change types of variables containing boolean data to boolean, set up driver's owner field so we have proper sysfs link between driver and the module. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-03regulator: Convert fixed voltage regulator to use enable_time()Mark Brown
It had an open coded version in enable(). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-03regulator: Add 'start-up time' to fixed voltage regulatorsAdrian Hunter
Add a field to specify a delay for the start-up time of a fixed voltage regulator. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-11-16dereferencing freed memory regulator_fixed_voltage_remove()Dan Carpenter
Don't dereference drvdata after it has been freed. regards, dan carpenter Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator: Add GPIO enable control to fixed voltage regulator driverRoger Quadros
Now fixed regulators that have their enable pin connected to a GPIO line can use the fixed regulator driver for regulator enable/disable control. The GPIO number and polarity information is passed through platform data. GPIO enable control is achieved using gpiolib. Signed-off-by: Roger Quadros <ext-roger.quadros@nokia.com> Reviewed-by: Philipp Zabel <philipp.zabel@gmail.com> Reviewed-by: Felipe Balbi <felipe.balbi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator: More explict error reporting for fixed regulatorMark Brown
2009-06-15regulator: Set MODULE_ALIAS for regulator driversMark Brown
Several of the regulator drivers didn't have MODULE_ALIAS so couldn't be auto loaded. Add the MODULE_ALIAS in case they do get built as modules. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-06-15regulator: Support list_voltage for fixed voltage regulatorMark Brown
2009-06-15regulator: Move regulator drivers to subsys_initcall()Mark Brown
Regulators need to be available early in init in order to allow them to be available for consumers when requested. This is generally done by registering them at subsys_initcall() time but not all regulator drivers have done that. Convert these drivers to do so in order to mimimise future support. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-03-31regulator: Allow init_data to be passed to fixed voltage regulatorsMark Brown
2008-07-30regulator: add support for fixed regulators.Mark Brown
This adds supports for regulator that are not software controlable. It allows them to coexist in systems with mixed supplies. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
