path: root/drivers/pwm/pwm-imx.c
2018-12-24pwm: imx: Add ipg clock operationAnson Huang
i.MX PWM module's ipg_clk_s is for PWM register access, on most of i.MX SoCs, this ipg_clk_s is from system ipg clock or perclk which is always enabled, but on i.MX7D, the ipg_clk_s is from PWM1_CLK_ROOT which is controlled by CCGR132, that means the CCGR132 MUST be enabled first before accessing PWM registers on i.MX7D. This patch adds ipg clock operation to make sure register access successfully on i.MX7D and it fixes Linux kernel boot up hang during PWM driver probe. Fixes: 4a23e6ee9f69 ("ARM: dts: imx7d-sdb: Restore pwm backlight support") Signed-off-by: Anson Huang <Anson.Huang@nxp.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2018-12-12pwm: imx: Implement get_state() function for hardware readoutMichal Vokáč
Implement the get_state() function and set the initial state to reflect real state of the hardware. This allows to keep the PWM running if it was enabled in bootloader. It is very similar to the GPIO behavior. GPIO pin set as output in bootloader keep the same setting in Linux unless it is reconfigured. If we find the PWM block enabled we need to prepare and enable its source clock otherwise the clock will be disabled late in the boot as unused. That will leave the PWM in enabled state but with disabled clock. That has a side effect that the PWM output is left at its current level at which the clock was disabled. It is totally non-deterministic and it may be LOW or HIGH. Signed-off-by: Michal Vokáč <michal.vokac@ysoft.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2018-12-12pwm: imx: Use bitops and bitfield macros to define register valuesMichal Vokáč
Use existing macros to define register fields instead of manually shifting the bit masks. Also define some more register bits. Signed-off-by: Michal Vokáč <michal.vokac@ysoft.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2018-12-12pwm: imx: Sort include filesMichal Vokáč
Sort included header files alphabetically. Signed-off-by: Michal Vokáč <michal.vokac@ysoft.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2018-07-09pwm: imx: Switch to SPDX identifierFabio Estevam
Adopt the SPDX license identifier headers to ease license compliance management. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2018-03-28pwm: imx: Let PWM be active during suspendFabio Estevam
On a imx6q-cubox-i board, which has an LED driven by PWM, when the system goes into suspend the PWM block is disabled by default, then the PWM pin goes to logic level zero and turn on the LED during suspend, which is not really the behaviour we want to see. By keeping the PWM enabled during suspend via STOPEN bit, the pwm-leds driver sets the brightness to zero in suspend and then the LED is turned off as expected. So always set the STOPEN to fix the PWM behaviour in suspend. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2017-02-10Merge branch 'for-4.11/drivers' into for-nextThierry Reding
2017-01-30pwm: imx: Add polarity inversion support to i.MX's PWMv2Lukasz Majewski
With this patch the polarity settings for i.MX's PWMv2 is now supported on top of atomic PWM setting Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2017-01-30pwm: imx: Remove redundant i.MX PWMv2 codeLukasz Majewski
The code providing functionality surpassed by the atomic PWM is not needed anymore and hence can be removed. Suggested-by: Stefan Agner <stefan@agner.ch> Suggested-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2017-01-30pwm: imx: Provide atomic PWM support for i.MX PWMv2Lukasz Majewski
This commit provides apply() callback implementation for i.MX's PWMv2. Suggested-by: Stefan Agner <stefan@agner.ch> Suggested-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2017-01-30pwm: imx: Move PWMv2 wait for fifo slot code to a separate functionLukasz Majewski
The code, which waits for fifo slot, has been extracted from imx_pwm_config_v2 function and moved to new one - imx_pwm_wait_fifo_slot(). This change reduces the overall size of imx_pwm_config_v2() and prepares it for atomic PWM operation. Suggested-by: Stefan Agner <stefan@agner.ch> Suggested-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2017-01-30pwm: imx: Move PWMv2 software reset code to a separate functionLukasz Majewski
The software reset code has been extracted from imx_pwm_config_v2 function and moved to new one - imx_pwm_sw_reset(). This change reduces the overall size of imx_pwm_config_v2() and prepares it for atomic PWM operation. Suggested-by: Stefan Agner <stefan@agner.ch> Suggested-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2017-01-30pwm: imx: Rewrite v1 code to facilitate switch to atomic PWMLukasz Majewski
The code has been rewritten to remove "generic" calls to imx_pwm_{enable|disable|config}. Such approach would facilitate switch to atomic PWM (a.k.a ->apply()) implementation. Suggested-by: Stefan Agner <stefan@agner.ch> Suggested-by: Boris Brezillon <boris.brezillon@free-electrons.com> Reviewed-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2017-01-30pwm: imx: Add separate set of PWM ops for v1 and v2Lukasz Majewski
This patch provides separate set of PWM operations utilized by i.MX's v1 and v2 of the PWM hardware. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2017-01-30pwm: imx: Remove ipg clock and enable per clock when requiredSascha Hauer
The use of the ipg clock was introduced with commit 7b27c160c681 ("pwm: i.MX: fix clock lookup"). In the commit message it was claimed that the ipg clock is enabled for register accesses. This is true for the ->config() callback, but not for the ->set_enable() callback. Given that the ipg clock is not consistently enabled for all register accesses we can assume that either it is not required at all or that the current code does not work. Remove the ipg clock code for now so that it's no longer in the way of refactoring the driver. On the other hand, the i.MX 7 IP requires the peripheral clock to be enabled before accessing its registers. Since ->config() can be called when the PWM is disabled (in which case, the peripheral clock is also disabled), we need to surround the imx->config() with clk_prepare_enable(per_clk)/clk_disable_unprepare(per_clk) calls. Note that the driver was working fine for the i.MX 7 IP so far because the ipg and peripheral clock use the same hardware clock gate, which guaranteed peripheral clock activation even when ->config() was called when the PWM was disabled. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Philipp Zabel <p.zabel@pengutronix.de> Reviewed-by: Stefan Agner <stefan@agner.ch> Tested-by: Stefan Agner <stefan@agner.ch> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2017-01-19pwm: constify pwm_ops structuresBhumika Goyal
Declare pwm_ops structures as const as they are only stored in the ops field of a pwm_chip structure. This field is of type const struct pwm_ops *, so pwm_ops structures having this property can be declared as const. Done using Coccinelle: @r1 disable optional_qualifier@ identifier i; position p; @@ static struct pwm_ops i@p={...}; @ok1@ identifier r1.i; position p; struct pxa_pwm_chip pwm; struct bfin_pwm_chip bwm; struct vt8500_chip vp; struct imx_chip icp; @@ ( pwm.chip.ops=&i@p | bwm.chip.ops=&i@p | vp.chip.ops=&i@p | icp.chip.ops=&i@p ) @bad@ position p!={r1.p,ok1.p}; identifier r1.i; @@ i@p @depends on !bad disable optional_qualifier@ identifier r1.i; @@ +const struct pwm_ops i; File size details: text data bss dec hex filename 1646 328 0 1974 7b6 drivers/pwm/pwm-imx.o 1742 224 0 1966 7ae drivers/pwm/pwm-imx.o 1941 296 0 2237 8bd drivers/pwm/pwm-pxa.o 2037 192 0 2229 8b5 drivers/pwm/pwm-pxa.o 1946 296 0 2242 8c2 drivers/pwm/pwm-vt8500.o 2050 192 0 2242 8c2 drivers/pwm/pwm-vt8500.o The drivers/pwm/pwm-bfin.o file did not compile. Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2017-01-04pwm: Remove .can_sleep from struct pwm_chipThierry Reding
All PWM devices have been marked as "might sleep" since v4.5, there is no longer a need to differentiate on a per-chip basis. Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2015-07-20pwm: Make use of pwm_get_xxx() helpers where appropriateBoris Brezillon
Use the pwm_get_xxx() helpers instead of directly accessing the fields in struct pwm_device. This will allow us to smoothly move to the atomic update approach. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2015-07-20pwm: Add the pwm_is_enabled() helperBoris Brezillon
Some PWM drivers are testing the PWMF_ENABLED flag. Create a helper function to hide the logic behind enabled test. This will allow us to smoothly move from the current approach to an atomic PWM update approach. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-11-03Merge branch 'platform/remove_owner' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux into driver-core-next Remove all .owner fields from platform drivers
2014-10-20pwm: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-08-25pwm: imx: Avoid sample FIFO overflow for i.MX PWM version2Liu Ying
The i.MX PWM version2 is embedded in several i.MX SoCs, such as i.MX27, i.MX51 and i.MX6SL. There is a 4-word (16 bit) sample FIFO in this IP. Each FIFO slot determines the duty period of a PWM waveform in one full cycle. The IP spec mentions that we should not write a fourth sample because the FIFO will become full and triggers a FIFO write error (FWE) which will prevent the PWM from starting once it is enabled. In order to avoid any sample FIFO overflow issue, this patch clears all sample FIFO by doing software reset in the configuration hook when the controller is disabled or waits for a full PWM cycle to get a relinquished FIFO slot when the controller is enabled and the FIFO is fully loaded. The FIFO overflow issue can be reproduced by the following commands on the i.MX6SL EVK platform, assuming we use PWM2 for the debug LED which is driven by the pin HSIC_STROBE and the maximal brightness is 255. echo 0 > /sys/class/leds/user/brightness echo 0 > /sys/class/leds/user/brightness echo 0 > /sys/class/leds/user/brightness echo 0 > /sys/class/leds/user/brightness echo 255 > /sys/class/leds/user/brightness Here, FWE happens (PWMSR register reads 0x58) and the LED can not be lighten. Another way to reproduce the FIFO overflow issue is to run this script: while true; do echo 255 > /sys/class/leds/user/brightness; done Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Shawn Guo <shawn.guo@freescale.com> Cc: Lothar Waßmann <LW@KARO-electronics.de> Cc: linux-pwm@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Liu Ying <Ying.Liu@freescale.com> Acked-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-08-25pwm: imx: Cleanup indentation for register definitionsLiu Ying
This patch contains no logic change to cleanup indentation for register definitions only. Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Shawn Guo <shawn.guo@freescale.com> Cc: Lothar Waßmann <LW@KARO-electronics.de> Cc: linux-pwm@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Liu Ying <Ying.Liu@freescale.com> Acked-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-08-25pwm: imx: Fix the macro MX3_PWMCR_PRESCALER(x) definitionLiu Ying
This patch adds missing parentheses around the argument of the macro MX3_PWMCR_PRESCALER(x) to avoid any potential macro expansion issue. Reported-by: Lothar Waßmann <LW@KARO-electronics.de> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Shawn Guo <shawn.guo@freescale.com> Cc: Lothar Waßmann <LW@KARO-electronics.de> Cc: linux-pwm@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Liu Ying <Ying.Liu@freescale.com> Acked-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-08-07pwm: imx: set can_sleep flag for imx_pwmShawn Guo
The .config() hook imx_pwm_config() calls clk APIs like clk_prepare() and clk_get_rate(), which might sleep, so we need to set can_sleep flag on pwm_chip. Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2014-04-28pwm: i.MX: Remove unnecessary OOM messagesJingoo Han
The site-specific OOM messages are unnecessary, because they duplicate the MM subsystem generic OOM message. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-10-08pwm: imx: Remove redundant of_match_ptrSachin Kamat
The data structure of_match_ptr() protects is always compiled in. Hence of_match_ptr() is not needed. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-10-08pwm: imx: Include linux/of.h headerSachin Kamat
'of_match_ptr' is defined in linux/of.h. Include it explicitly. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-06-12pwm: Fill in missing .owner fieldsThierry Reding
Some drivers don't set the .owner fields of the struct device_driver or struct pwm_ops, which causes the module usage count to become wrong. Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
2013-05-18drivers/pwm: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Stephen Warren <swarren@nvidia.com>
2013-04-02pwm: imx: Remove enabled field from struct imx_chipAxel Lin
We can test PWMF_ENABLED bit to know if pwm is enabled or not. Thus remove enabled field from struct imx_chip. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2013-01-22pwm: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-19Merge tag 'for-3.8-rc1' of git://gitorious.org/linux-pwm/linux-pwmLinus Torvalds
Pull pwm changes from Thierry Reding: "A new driver has been added for the SPEAr platform and the TWL4030/6030 driver has been replaced by two drivers that control the regular PWMs and the PWM driven LEDs provided by the chips. The vt8500, tiecap, tiehrpwm, i.MX, LPC32xx and Samsung drivers have all been improved and the device tree bindings now support the PWM signal polarity." Fix up trivial conflicts due to __devinit/exit removal. * tag 'for-3.8-rc1' of git://gitorious.org/linux-pwm/linux-pwm: (21 commits) pwm: samsung: add missing s3c->pwm_id assignment pwm: lpc32xx: Set the chip base for dynamic allocation pwm: lpc32xx: Properly disable the clock on device removal pwm: lpc32xx: Fix the PWM polarity pwm: i.MX: eliminate build warning pwm: Export of_pwm_xlate_with_flags() pwm: Remove pwm-twl6030 driver pwm: New driver to support PWM driven LEDs on TWL4030/6030 series of PMICs pwm: New driver to support PWMs on TWL4030/6030 series of PMICs pwm: pwm-tiehrpwm: pinctrl support pwm: tiehrpwm: Add device-tree binding pwm: pwm-tiehrpwm: Adding TBCLK gating support. pwm: pwm-tiecap: pinctrl support pwm: tiecap: Add device-tree binding pwm: Add TI PWM subsystem driver pwm: Device tree support for PWM polarity pwm: vt8500: Ensure PWM clock is enabled during pwm_config pwm: vt8500: Fix build error pwm: spear: Staticize spear_pwm_config() pwm: Add SPEAr PWM chip driver support ...
2012-12-06pwm: i.MX: eliminate build warningLothar Waßmann
compiling the i.MX pwm driver produces the following warning: |drivers/pwm/pwm-imx.c: In function 'imx_pwm_probe': |drivers/pwm/pwm-imx.c:281:7: warning: assignment discards qualifiers from pointer target type Apply a 'const' attribute to the affected variable declaration. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-11-28pwm: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pwm: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28pwm: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-12pwm: i.MX: fix clock lookupPhilipp Zabel
The i.MX PWM core has two clocks: The ipg clock and the ipg highfreq (peripheral) clock. The ipg clock has to be enabled for this hardware to work. The actual PWM output can either be driven by the ipg clock or the ipg highfreq. The ipg highfreq has the advantage that it runs even when the SoC is in low power modes. This patch requests both clocks and enables the ipg clock for accessing registers and the peripheral clock to actually turn on the PWM. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-09-12pwm: i.MX: use per clock unconditionallySascha Hauer
The i.MX PWM module has two clocks: The ipg clock and the ipg highfreq (peripheral) clock. The ipg clock has to be enabled for this hardware to work. The actual PWM output can either be driven by the ipg clock or the ipg highfreq. The ipg highfreq has the advantage that it runs even when the SoC is in low power modes. Use the always running clock also on i.MX25. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-09-12pwm: i.MX: add devicetree supportPhilipp Zabel
At the same time remove platform based support. No user for this driver has made it into mainline so far, so all we break is out of tree stuff. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-09-12pwm: i.MX: Use module_platform_driverSascha Hauer
2012-09-12pwm: i.MX: add functions to enable/disable pwm.Sascha Hauer
We used to enable/disable the PWM only by switching the clock on or off. Instead, use the dedicated register bits. These differ on different SoCs, so introduce a SoC specific function for this. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-09-12pwm: i.MX: remove unnecessary if in pwm_[en|dis]ableSascha Hauer
The PWM core makes sure that pwm_enable/disable are called only once. Still keep the enabled state since we will need it in pwm_config. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-09-12pwm: i.MX: factor out SoC specific functionsSascha Hauer
To cleanup the code and to make it easier to support different SoCs. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Reviewed-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-07-23pwm: Convert pwm-imx to use devm_* APIsAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-07-02ARM i.MX: Move i.MX pwm driver to pwm frameworkSascha Hauer
Move the driver to drivers/pwm/ and convert it to use the framework. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> [eric@eukrea.com: set chip.dev to prevent probe failure] [eric@eukrea.com: fix pwmchip_add return code test] Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
