path: root/drivers/platform
2014-06-09thinkpad-acpi: fix issuing duplicated key events for brightness up/downAlex Hung
commit ff413195e830541afeae469fc866ecd0319abd7e upstream. The tp_features.bright_acpimode will not be set correctly for brightness control because ACPI_VIDEO_HID will not be located in ACPI. As a result, a duplicated key event will always be sent. acpi_video_backlight_support() is sufficient to detect standard ACPI brightness control. Signed-off-by: Alex Hung <alex.hung@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-04-02hp_accel: Add a new PnP ID HPQ6007 for new HP laptopsTakashi Iwai
commit b0ad4ff35d479a46a3b995a299db9aeb097acfce upstream. The DriveGuard chips on the new HP laptops are with a new PnP ID "HPQ6007". It should be compatible with older chips. Acked-by: Éric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-06-19thinkpad-acpi: recognize latest V-Series using DMI_BIOS_VENDORManoj Iyer
commit a4f46bb9fa84642e356898ee44b670989622f8bb upstream. In the latest V-series bios DMI_PRODUCT_VERSION does not contain the string Lenovo or Thinkpad, but is set to the model number, this causes the thinkpad_acpi module to fail to load. Recognize laptop as Lenovo using DMI_BIOS_VENDOR instead, which is set to Lenovo. Test on V490u ============= == After the patch == [ 1350.295757] thinkpad_acpi: ThinkPad ACPI Extras v0.24 [ 1350.295760] thinkpad_acpi: http://ibm-acpi.sf.net/ [ 1350.295761] thinkpad_acpi: ThinkPad BIOS H7ET21WW (1.00 ), EC unknown [ 1350.295763] thinkpad_acpi: Lenovo LENOVO, model LV5DXXX [ 1350.296086] thinkpad_acpi: detected a 8-level brightness capable ThinkPad [ 1350.296694] thinkpad_acpi: radio switch found; radios are enabled [ 1350.296703] thinkpad_acpi: possible tablet mode switch found; ThinkPad in laptop mode [ 1350.306466] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked [ 1350.307082] Registered led device: tpacpi::thinklight [ 1350.307215] Registered led device: tpacpi::power [ 1350.307255] Registered led device: tpacpi::standby [ 1350.307294] Registered led device: tpacpi::thinkvantage [ 1350.308160] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one [ 1350.308333] thinkpad_acpi: Console audio control enabled, mode: monitor (read only) [ 1350.312287] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input14 == Before the patch == sudo modprobe thinkpad_acpi FATAL: Error inserting thinkpad_acpi (/lib/modules/3.2.0-27-generic/kernel/drivers/platform/x86/thinkpad_acpi.ko): No such device Test on B485 ============= This patch was also test in a B485 where the thinkpad_acpi module does not have any issues loading. But, I tested it to make sure this patch does not break on already functioning models of Lenovo products. [13486.746359] thinkpad_acpi: ThinkPad ACPI Extras v0.24 [13486.746364] thinkpad_acpi: http://ibm-acpi.sf.net/ [13486.746368] thinkpad_acpi: ThinkPad BIOS HJET15WW(1.01), EC unknown [13486.746373] thinkpad_acpi: Lenovo Lenovo LB485, model 814TR01 [13486.747300] thinkpad_acpi: detected a 8-level brightness capable ThinkPad [13486.752435] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked [13486.752883] Registered led device: tpacpi::thinklight [13486.752915] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one [13486.753216] thinkpad_acpi: Console audio control enabled, mode: monitor (read only) [13486.757147] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input15 Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-05-30hp_accel: Ignore the error from lis3lv02d_poweron() at resumeShuah Khan
commit 7783819920ca52fc582a2782f654fe6ed373f465 upstream. The error in lis3lv02_poweron() is harmless in the resume path, so we should ignore it. It is inline with the other usages of lis3lv02_poweron() and matches the 3.0 code for this routine. This patch is in suse git and might have missed making it into the mainline. opensuse - commit id: 66ccdac87c322cf7af12bddba8c805af640b1cff Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-25msi-wmi: Fix memory leakMaxim Mikityanskiy
commit 51c94491c82c3d9029f6e87a1a153db321d88e35 upstream. Fix memory leak - don't forget to kfree ACPI object when returning from msi_wmi_notify() after suppressing key event. Signed-off-by: Maxim Mikityanskiy <maxtram95@gmail.com> Acked-by: Anisse Astier <anisse@astier.eu> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-06asus-laptop: Do not call HWRS on initBen Hutchings
commit cb7da022450cdaaebd33078b6b32fb7dd2aaf6db upstream. Since commit 8871e99f89b7 ('asus-laptop: HRWS/HWRS typo'), module initialisation is very slow on the Asus UL30A. The HWRS method takes about 12 seconds to run, and subsequent initialisation also seems to be delayed. Since we don't really need the result, don't bother calling it on init. Those who are curious can still get the result through the 'infos' device attribute. Update the comment about HWRS in show_infos(). Reported-by: ryan <draziw+deb@gmail.com> References: http://bugs.debian.org/692436 Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
2013-02-06samsung-laptop: Disable on EFI hardwareMatt Fleming
commit e0094244e41c4d0c7ad69920681972fc45d8ce34 upstream. It has been reported that running this driver on some Samsung laptops with EFI can cause those machines to become bricked as detailed in the following report, https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 There have also been reports of this driver causing Machine Check Exceptions on recent EFI-enabled Samsung laptops, https://bugzilla.kernel.org/show_bug.cgi?id=47121 So disable it if booting from EFI since this driver relies on grovelling around in the BIOS memory map which isn't going to work. Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Colin Ian King <colin.king@canonical.com> Cc: Steve Langasek <steve.langasek@canonical.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06efi: Make 'efi_enabled' a function to query EFI facilitiesMatt Fleming
commit 83e68189745ad931c2afd45d8ee3303929233e7f upstream. Originally 'efi_enabled' indicated whether a kernel was booted from EFI firmware. Over time its semantics have changed, and it now indicates whether or not we are booted on an EFI machine with bit-native firmware, e.g. 64-bit kernel with 64-bit firmware. The immediate motivation for this patch is the bug report at, https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 which details how running a platform driver on an EFI machine that is designed to run under BIOS can cause the machine to become bricked. Also, the following report, https://bugzilla.kernel.org/show_bug.cgi?id=47121 details how running said driver can also cause Machine Check Exceptions. Drivers need a new means of detecting whether they're running on an EFI machine, as sadly the expression, if (!efi_enabled) hasn't been a sufficient condition for quite some time. Users actually want to query 'efi_enabled' for different reasons - what they really want access to is the list of available EFI facilities. For instance, the x86 reboot code needs to know whether it can invoke the ResetSystem() function provided by the EFI runtime services, while the ACPI OSL code wants to know whether the EFI config tables were mapped successfully. There are also checks in some of the platform driver code to simply see if they're running on an EFI machine (which would make it a bad idea to do BIOS-y things). This patch is a prereq for the samsung-laptop fix patch. Cc: David Airlie <airlied@linux.ie> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Olof Johansson <olof@lixom.net> Cc: Peter Jones <pjones@redhat.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Steve Langasek <steve.langasek@canonical.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Konrad Rzeszutek Wilk <konrad@kernel.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> [bwh: Backported to 3.2: - Adjust context (a lot) - Add efi_is_native() function from commit 5189c2a7c776 ('x86: efi: Turn off efi_enabled after setup on mixed fw/kernel') - Make efi_init() bail out when booted non-native, as it would previously not be called in this case - Drop inapplicable changes to start_kernel()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-12-06acer-wmi: support for P key on TM8372Merlin Schumacher
commit 67e1d34cd54cbf33f093f1dd53e7bda1124eb972 upstream. BugLink: http://launchpad.net/bugs/865807 There is no entry for P key on TM8372, so when P key is pressed, only "acer_wmi: Unknown key number - 0x29" in dmesg. Signed-off-by: Merlin Schumacher <merlin.schumacher@gmail.com> Signed-off-by: Ike Panhc <ike.pan@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-10-30samsung-laptop: make the dmi check less strict (part 2)Ben Hutchings
commit 3be324a94df0c3f032178d04549dbfbf6cccb09a upstream. These are the hunks that I dropped when backporting for 3.2.24, which are applicable now that we also have commit f34cd9ca ('samsung-laptop: don't handle backlight if handled by acpi/video'). Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-10-30samsung-laptop: don't handle backlight if handled by acpi/videoCorentin Chary
commit f34cd9ca9320876e9c12764f052004628a03ba2d upstream. samsung-laptop is not at all related to ACPI, but since this interface is not documented at all, and the driver has to use it at load to understand how it works on the laptop, I think it's a good idea to disable it if a better solution is available. Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Matthew Garrett <mjg@redhat.com> [bwh: Backported to 3.2: - Adjust context, and change return to goto, since we do not have commit 5dea7a2 ('samsung-laptop: move code into init/exit functions') - Use static variable since we do not have commit a6df489 ('samsung-laptop: put all local variables in a single structure')] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-10-10asus-laptop: HRWS/HWRS typoCorentin Chary
commit 8871e99f89b7d7b1ea99de550eea2a56273f42ab upstream. Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=24222 Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-09-12asus-nb-wmi: add some video toggle keysAceLan Kao
commit 3766054fff4af1b58a1440a284907887f4d2e8be upstream. There are some new video switch keys that used by newer machines. 0xA0 - SDSP HDMI only 0xA1 - SDSP LCD + HDMI 0xA2 - SDSP CRT + HDMI 0xA3 - SDSP TV + HDMI But in Linux, there is no suitable userspace application to handle this, so, mapping them all to KEY_SWITCHVIDEOMODE. Signed-off-by: AceLan Kao <acelan.kao@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-08-10asus-wmi: use ASUS_WMI_METHODID_DSTS2 as default DSTS ID.Alex Hung
commit 63a78bb1051b240417daad3a3fa9c1bb10646dca upstream. According to responses from the BIOS team, ASUS_WMI_METHODID_DSTS2 (0x53545344) will be used as future DSTS ID. In addition, calling asus_wmi_evaluate_method(ASUS_WMI_METHODID_DSTS2, 0, 0, NULL) returns ASUS_WMI_UNSUPPORTED_METHOD in new ASUS laptop PCs. This patch fixes no DSTS ID will be assigned in this case. Signed-off-by: Alex Hung <alex.hung@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-07-25intel_ips: blacklist HP ProBook laptopsTakashi Iwai
commit 88ca518b0bb4161e5f20f8a1d9cc477cae294e54 upstream. intel_ips driver spews the warning message "ME failed to update for more than 1s, likely hung" at each second endlessly on HP ProBook laptops with IronLake. As this has never worked, better to blacklist the driver for now. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-07-25samsung-laptop: make the dmi check less strictCorentin Chary
commit 3be324a94df0c3f032178d04549dbfbf6cccb09a upstream. This enable the driver for everything that look like a laptop and is from vendor "SAMSUNG ELECTRONICS CO., LTD.". Note that laptop supported by samsung-q10 seem to have a different vendor strict. Also remove every log output until we know that we have a SABI interface (except if the driver is forced to load, or debug is enabled). Keeping a whitelist of laptop with a model granularity is something that can't work without close vendor cooperation (and we don't have that). Signed-off-by: Corentin Chary <corentincj@iksaif.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com> [bwh: Backported to 3.2: - Adjust context - Drop changes relating to ACPI video] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31sony-laptop: Enable keyboard backlight by defaultJosh Boyer
commit 6fe6ae56a7cebaebc2e6daa11c423e4692f9b592 upstream. When the keyboard backlight support was originally added, the commit said to default it to on with a 10 second timeout. That actually wasn't the case, as the default value is commented out for the kbd_backlight parameter. Because it is a static variable, it gets set to 0 by default without some other form of initialization. However, it seems the function to set the value wasn't actually called immediately, so whatever state the keyboard was in initially would remain. Then commit df410d522410e67660 was introduced during the 2.6.39 timeframe to immediately set whatever value was present (as well as attempt to restore/reset the state on module removal or resume). That seems to have now forced the light off immediately when the module is loaded unless the option kbd_backlight=1 is specified. Let's enable it by default again (for the first time). This should solve https://bugzilla.redhat.com/show_bug.cgi?id=728478 Signed-off-by: Josh Boyer <jwboyer@redhat.com> Acked-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-11dell-laptop: Terminate quirks list properlyMartin Nyhus
commit d62d421b071b08249361044d8e56c8b5c3ed6aa7 upstream. Add missing DMI_NONE entry to end of the quirks list so dmi_check_system() won't read past the end of the list. Signed-off-by: Martin Nyhus <martin.nyhus@gmx.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-11dell-laptop: touchpad LED should persist its status after S3AceLan Kao
commit 2d5de9e84928e35b4d9b46b4d8d5dcaac1cff1fa upstream. Touchpad LED will not turn on after S3, it will make the touchpad status doesn't consist with the LED. By adding one flag to let the LED device restore it's status. Signed-off-by: AceLan Kao <acelan.kao@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-11dell-laptop: add 3 machines that has touchpad LEDAceLan Kao
commit 2a748853ca395c48ea75baa250f7cea6f0f23dbf upstream. Add "Vostro 3555", "Inspiron N311z", and "Inspiron M5110" into quirks, so that they could have touchpad LED function work. Signed-off-by: AceLan Kao <acelan.kao@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-04-13acer-wmi: No wifi rfkill on Sony machinesLee, Chun-Yi
commit 5719b81988f3c24ff694dc3a37e35b35630a3966 upstream. The wireless rfkill should charged by sony-laptop but not acer-wmi. So, add Sony's SNY5001 acpi device to blacklist in acer-wmi. Tested on Sony Vaio Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg@redhat.com> Cc: Mattia Dongili <malattia@linux.it> Cc: Dimitris N <ddarlac@gmail.com> Tested-by: Dimitris N <ddarlac@gmail.com> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-19acer-wmi: No wifi rfkill on Lenovo machinesIke Panhc
commit 461e74377cfcfc2c0d6bbdfa8fc5fbc21b052c2a upstream. We have several reports which says acer-wmi is loaded on ideapads and register rfkill for wifi which can not be unblocked. Since ideapad-laptop also register rfkill for wifi and it works reliably, it will be fine acer-wmi is not going to register rfkill for wifi once VPC2004 is found. Also put IBM0068/LEN0068 in the list. Though thinkpad_acpi has no wifi rfkill capability, there are reports which says acer-wmi also block wireless on Thinkpad E520/E420. Signed-off-by: Ike Panhc <ike.pan@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-12-05toshiba_acpi: Fix machines that don't support HCI_SYSTEM_EVENTSeth Forshee
The Satellite C670-10V generates notifications for hotkeys but does not support HCI_SYSTEM_EVENT. As a result when a hotkey is pressed it gets stuck in an infinite loop in toshiba_acpi_notify. To fix this, detect whether or not HCI_SYSTEM_EVENT is supported up-front and don't try to read system events if it isn't supported. In addition, limit the number of retries when reading HCI_SYSTEM_EVENT fails so that this loop cannot run unbounded. Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-11-17platform/x86: fix dell-laptop function prototypesRandy Dunlap
Fix build warnings: drivers/platform/x86/dell-laptop.c:592:13: warning: function declaration isn't a prototype drivers/platform/x86/dell-laptop.c:599:13: warning: function declaration isn't a prototype Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-08x86 platform drivers: add POWER_SUPPLY to selected drivers for DellLinus Torvalds
The Kconfig loop detection goes crazy without this. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-08x86 platform drivers: make Dell laptop driver select needed LED supportLinus Torvalds
Otherwise we get compile errors like this: ERROR: "led_classdev_unregister" [drivers/platform/x86/dell-laptop.ko] undefined! ERROR: "led_classdev_register" [drivers/platform/x86/dell-laptop.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 when the dell-laptop support is enabled without the necessary LED support being enabled. Reported-by: Alessandro Suardi <alessandro.suardi@gmail.com> Acked-by: Matthew Garrett <mjg59@srcf.ucam.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31Merge branch 'akpm' (Andrew's incoming)Linus Torvalds
Quoth Andrew: - Most of MM. Still waiting for the poweroc guys to get off their butts and review some threaded hugepages patches. - alpha - vfs bits - drivers/misc - a few core kerenl tweaks - printk() features - MAINTAINERS updates - backlight merge - leds merge - various lib/ updates - checkpatch updates * akpm: (127 commits) epoll: fix spurious lockdep warnings checkpatch: add a --strict check for utf-8 in commit logs kernel.h/checkpatch: mark strict_strto<foo> and simple_strto<foo> as obsolete llist-return-whether-list-is-empty-before-adding-in-llist_add-fix wireless: at76c50x: follow rename pack_hex_byte to hex_byte_pack fat: follow rename pack_hex_byte() to hex_byte_pack() security: follow rename pack_hex_byte() to hex_byte_pack() kgdb: follow rename pack_hex_byte() to hex_byte_pack() lib: rename pack_hex_byte() to hex_byte_pack() lib/string.c: fix strim() semantics for strings that have only blanks lib/idr.c: fix comment for ida_get_new_above() lib/percpu_counter.c: enclose hotplug only variables in hotplug ifdef lib/bitmap.c: quiet sparse noise about address space lib/spinlock_debug.c: print owner on spinlock lockup lib/kstrtox: common code between kstrto*() and simple_strto*() functions drivers/leds/leds-lp5521.c: check if reset is successful leds: turn the blink_timer off before starting to blink leds: save the delay values after a successful call to blink_set() drivers/leds/leds-gpio.c: use gpio_get_value_cansleep() when initializing drivers/leds/leds-lm3530.c: add __devexit_p where needed ...
2011-10-31lis3: change exported function to use passed parameterÉric Piel
Change exported functions to use the device given as parameter instead of the global one. Signed-off-by: Ilkka Koskinen <ilkka.koskinen@nokia.com> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Matthew Garrett <mjg@redhat.com> Cc: Witold Pilat <witold.pilat@gmail.com> Cc: Lyall Pearce <lyall.pearce@hp.com> Cc: Malte Starostik <m-starostik@versanet.de> Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31hp_accel: add HP ProBook 655xÉric Piel
Add axis correction for HP ProBook 6555b. Signed-off-by: Malte Starostik <m-starostik@versanet.de> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Matthew Garrett <mjg@redhat.com> Cc: Witold Pilat <witold.pilat@gmail.com> Cc: Lyall Pearce <lyall.pearce@hp.com> Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lis3: add support for HP EliteBook 8540wÉric Piel
Add axis correction for HP EliteBook 8540w. Reported-by: Lyall Pearce <lyall.pearce@hp.com> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Matthew Garrett <mjg@redhat.com> Cc: Witold Pilat <witold.pilat@gmail.com> Cc: Malte Starostik <m-starostik@versanet.de> Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lis3: add support for HP EliteBook 2730pÉric Piel
Add axis correction for HP EliteBook 2730p. Tested-by: Witold Pilat <witold.pilat@gmail.com> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Matthew Garrett <mjg@redhat.com> Cc: Lyall Pearce <lyall.pearce@hp.com> Cc: Malte Starostik <m-starostik@versanet.de> Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31lis3lv02d: avoid divide by zero due to uncheckedÉric Piel
After an "unexpected" reboot, I found this Oops in my logs: divide error: 0000 [#1] PREEMPT SMP=20 CPU 0=20 Modules linked in: lis3lv02d hp_wmi input_polldev [...] Pid: 390, comm: modprobe Tainted: G C 2.6.39-rc7-wl+=20 RIP: 0010:[<ffffffffa014b427>] [<ffffffffa014b427>] lis3lv02d_poweron+0x4e/0x94 [lis3lv02d] RSP: 0018:ffff8801d6407cf8 EFLAGS: 00010246 RAX: 0000000000000bb8 RBX: ffffffffa014e000 RCX: 0000000000000000 RDX: 0000000000000000 RSI: ffffea00066e4708 RDI: ffff8801df002700 RBP: ffff8801d6407d18 R08: ffffea00066c5a30 R09: ffffffff812498c9 R10: ffff8801d7bfcea0 R11: ffff8801d7bfce10 R12: 0000000000000bb8 R13: 00000000ffffffda R14: ffffffffa0154120 R15: ffffffffa0154030 =46S: 00007fc0705db700(0000) GS:ffff8801dfa00000(0000) knlGS:0 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00007f33549174f0 CR3: 00000001d65c9000 CR4: 00000000000406f0 Process modprobe (pid: 390, threadinfo ffff8801d6406000, task ffff8801d6b40= 000) Stack: ffffffffa0154120 62ffffffa0154030 ffffffffa014e000 00000000ffffffea ffff8801d6407d58 ffffffffa014bcc1 0000000000000000 0000000000000048 ffff8801d8bae800 00000000ffffffea 00000000ffffffda ffffffffa0154120 Call Trace: [<ffffffffa014bcc1>] lis3lv02d_init_device+0x1ce/0x496 [lis3lv02d] [<ffffffffa01522ff>] lis3lv02d_add+0x10f/0x17c [hp_accel] [<ffffffff81233e11>] acpi_device_probe+0x49/0x117 [...] Code: 3a 75 06 80 4d ef 50 eb 04 80 4d ef 40 0f b6 55 ef be 21 00 00 00 48 89 df ff 53 18 44 8b 63 6c e8 3e fc ff ff 89 c1 44 89 e0 99 <f7> f9 89 c7 e8 93 82 ef e0 48 83 7b 30 00 74 2d 45 31 e4 80 7b=20 RIP [<ffffffffa014b427>] lis3lv02d_poweron+0x4e/0x94 [lis3lv02d] RSP <ffff8801d6407cf8> >From my POV, it looks like the hardware is not working as expected and returns a bogus data rate. The driver doesn't check the result and directly uses it as some sort of divisor in some places: msleep(lis3->pwron_delay / lis3lv02d_get_odr()); Under this circumstances, this could very well cause the "divide by zero" exception from above. For now, I fixed it the easiest and most obvious way: Check if the result is sane and if it isn't use a sane default instead. I went for "100" in the latter case, simply because /sys/devices/platform/lis3lv02d/rate returns it on a successful boot. Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Cc: Matthew Garrett <mjg@redhat.com> Cc: Witold Pilat <witold.pilat@gmail.com> Cc: Lyall Pearce <lyall.pearce@hp.com> Cc: Malte Starostik <m-starostik@versanet.de> Cc: Ilkka Koskinen <ilkka.koskinen@nokia.com> Cc: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31x86: fix up files really needing to include module.hPaul Gortmaker
These files aren't just exporting symbols -- they are also defining a MODULE_LICENSE etc. so give them the full module.h file. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
* 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: (45 commits) acer-wmi: replaced the hard coded bitmap by the communication devices bitmap from SMBIOS acer-wmi: check the existence of internal wireless device when set capability acer-wmi: add ACER_WMID_v2 interface flag to represent new notebooks sony-laptop:irq: Remove IRQF_DISABLED asus-laptop: Add rfkill support for Pegatron Lucid tablet asus-laptop: pega_accel - Report accelerometer orientation change through udev asus-laptop: fix module description asus-laptop: hide leds on Pegatron Lucid asus-laptop: Pegatron Lucid accelerometer asus-laptop: allow boot time control of Pegatron ALS sensor Platform: samsung_laptop: add support for X520 machines. platform: samsung_laptop: add dmi information for Samsung R700 laptops hp_accel: Add axis-mapping for HP ProBook / EliteBook hp_accel: Add a new PNP id WMI: properly cleanup devices to avoid crashes ideapad: remove sysfs node for cfg ideapad: add debugfs support ideapad: add event for Novo key ideapad: change parameter of ideapad_sync_rfk_state ideapad: define vpc commands ...
2011-10-24acer-wmi: replaced the hard coded bitmap by the communication devices bitmap ↵Lee, Chun-Yi
from SMBIOS Before set communication devices state, we need query out all devices state to set the states bitmap. That will be better use the devices bitmap in SMBIOS type Aah instead of hardcode in driver. Tested on Acer Travelmate 8572. Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg@redhat.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24acer-wmi: check the existence of internal wireless device when set capabilityLee, Chun-Yi
That will be better to check the existence of internal wireless device when we set wireless capability and generate killswitch for it. It can avoid userland access wireless rfkill but the machine doesn't have internal wireless device. Tested on Acer Travelmate 8572 Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg@redhat.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24acer-wmi: add ACER_WMID_v2 interface flag to represent new notebooksLee, Chun-Yi
There have new acer notebooks' BIOS provide new WMID_GUID3 and ACERWMID_EVENT_GUID methods. Some of machines still keep the old WMID_GUID1 method but more and more machines were already removed old wmi methods from DSDT. So, this patch add a new ACER_WMID_v2 interface flag to represent new acer notebooks, the following is definition: + ACER_WMID: It means this machine only provides WMID_GUID1/2 methods. + ACER_WMID_v2: It means this machine provide new WMID_GUID3 and WMID_EVENT_GUID methods. Some ACER_WMID_v2 machines also provide old WMID_GUID1/2 methods, but we still query/set communication device's state by new WMID_GUID3 method. Tested on Acer Travelmate 8572 Tested on Acer Aspire 4739Z Tested-by: AceLan Kao <acelan.kao@canonical.com> Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg@redhat.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24sony-laptop:irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24asus-laptop: Add rfkill support for Pegatron Lucid tabletAnisse Astier
Add three new rfkill switches in this driver that are specific to Pegatron Lucid tablet. Please note that you might not need all three switches. For example if you don't have a 3G module inside your tablet. Also, on my device, the gpio for the wifi/bt module is connected to the bluetooth line. Therefore to activate your wireless lan interface, you need to use the "pega-bt" rfkill switch. Finally, the rfkill switch only works before the wireless module is loaded the first time. Unloading ath9k doesn't help, a reboot is necessary. Signed-off-by: Anisse Astier <anisse@astier.eu> Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24asus-laptop: pega_accel - Report accelerometer orientation change through udevAnisse Astier
Signed-off-by: Anisse Astier <anisse@astier.eu> Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24asus-laptop: fix module descriptionCorentin Chary
2011-10-24asus-laptop: hide leds on Pegatron LucidCorentin Chary
2011-10-24asus-laptop: Pegatron Lucid accelerometerAndy Ross
Support the built-in accelerometer on the Lucid tablets as a standard 3-axis input device. Signed-off-by: Andy Ross <andy.ross@windriver.com> Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24asus-laptop: allow boot time control of Pegatron ALS sensorAndy Ross
2011-10-24Platform: samsung_laptop: add support for X520 machines.Tommaso Massimi
my samsung laptop would be very happy if you add these lines to the file drivers/platform/x86/samsung-laptop.c Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24platform: samsung_laptop: add dmi information for Samsung R700 laptopsStefan Beller
My DMI model is this: >dmesg |grep DMI [ 0.000000] DMI present. [ 0.000000] DMI: SAMSUNG ELECTRONICS CO., LTD. SR700/SR700, BIOS 04SR 02/20/2008 adding dmi information of Samsung R700 laptops This adds the dmi information of Samsungs R700 laptops. Signed-off-by: Stefan Beller <stefanbeller@googlemail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24hp_accel: Add axis-mapping for HP ProBook / EliteBookTakashi Iwai
Add the corrected axis-mapping for some HP laptops. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24hp_accel: Add a new PNP idTakashi Iwai
New HP laptops assign a new PNP id "HPQ6000" for DriveGuard. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-10-24WMI: properly cleanup devices to avoid crashesDmitry Torokhov
We need to remove devices that we destroy from the list, otherwise we'll crash if there are more than one "_WDG" methods in DSDT. This fixes https://bugzilla.kernel.org/show_bug.cgi?id=32052 Tested-by: Ilya Tumaykin <librarian_rus@yahoo.com> Cc: stable@kernel.org Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Matthew Garrett <mjg@redhat.com>
