Convert all uses of devm_request_and_ioremap() to the newly introduced
devm_ioremap_resource() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Linus Walleij <linus.walleij@linaro.org>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Barry Song <baohua.song@csr.com>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Andrew Lunn <andrew@lunn.ch>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg Kroah-Hartman:
"Here's the large driver core updates for 3.8-rc1.
The biggest thing here is the various __dev* marking removals. This
is going to be a pain for the merge with different subsystem trees, I
know, but all of the patches included here have been ACKed by their
various subsystem maintainers, as they wanted them to go through here.
If this is too much of a pain, I can pull all of them out of this tree
and just send you one with the other fixes/updates and then, after
3.8-rc1 is out, do the rest of the removals to ensure we catch them
all, it's up to you. The merges should all be trivial, and Stephen
has been doing them all in linux-next for a few weeks now quite
easily.
Other than the __dev* marking removals, there's nothing major here,
some firmware loading updates and other minor things in the driver
core.
All of these have (much to Stephen's annoyance), been in linux-next
for a while.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio
update.
* tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits)
modpost.c: Stop checking __dev* section mismatches
init.h: Remove __dev* sections from the kernel
acpi: remove use of __devinit
PCI: Remove __dev* markings
PCI: Always build setup-bus when PCI is enabled
PCI: Move pci_uevent into pci-driver.c
PCI: Remove CONFIG_HOTPLUG ifdefs
unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs
sh/PCI: Remove CONFIG_HOTPLUG ifdefs
powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs
mips/PCI: Remove CONFIG_HOTPLUG ifdefs
microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs
dma: remove use of __devinit
dma: remove use of __devexit_p
firewire: remove use of __devinitdata
leds: remove use of __devexit
leds: remove use of __devinit
leds: remove use of __devexit_p
mmc: remove use of __devexit
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Instead of having the pinctrl driver register the GPIO range
for the gpio_chip, making it necessary to instantiate the
pin controller from the GPIO driver and pass the GPIO chip as
platform data, now let the GPIO chip driver register it's own
ranges and have the pinctrl driver look up the GPIO chip from
the pinctrl core as necessary.
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Staticize u300_pin_config_get() and u300_pin_config_set() functions.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
This converts the U300 pin controller to use managed resources
(devm_*) for it's memory region.
the allocated memory will be destroyed at the driver unload time,
automatically if driver uses the devm_ functions, so no need of
doing devm_kfree at the error path
Signed-off-by: Devendra Naga <develkernel412222@gmail.com>
The "i" variable was left after the GPIO range cleanup
moved to core.
The gpio ranges will be automatically removed when the pinctrl
driver is unregistered.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org>
This is some leftover from earlier development, let's get rid
of it.
the memory allocated by devm_kzalloc is automatically
freed at the driver detach side, so no neeed of calling
devm_kfree
Signed-off-by: Devendra Naga <devendra.aaru@gmail.com>
Most of the SoC drivers implement list_groups() and list_functions()
routines for pinctrl and pinmux. These routines continue returning
zero until the selector argument is greater than total count of
available groups or functions.
This patch replaces these list_*() routines with get_*_count()
routines, which returns the number of available selection for SoC
driver. pinctrl layer will use this value to check the range it can
choose.
This patch fixes all user drivers for this change. There are other
routines in user drivers, which have checks to check validity of
selector passed to them. It is also no more required and hence
removed.
Documentation updated as well.
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
[Folded in fix and fixed a minor merge artifact manually]
This adds pin configuration support for the U300 driver pair,
we can now read out the biasing and drive mode in debugfs and
configure it using the new configuration API.
ChangeLog v1->v2:
- Migrate to pin config and generic pin config changes.
ChangeLog v2->v3:
- Adjust to generic pin config changes in v7 patch set.
This solves the riddle on how the U300 pin controller shall be
able to reference the struct gpio_chip even though these are
two separate drivers: spawn the pinctrl child from the GPIO
driver and pass in the struct gpio_chip as platform data.
In the process we rename the U300 "pinmux-u300" to
"pinctrl-u300" so as not to confuse.
This patch removes maxpin member in the pin control descriptor
because we don't need this value as we enumerate a pin space
using offset.
Signed-off-by: Chanho Park <chanho61.park@samsung.com>
For stringent order, rename the pinmux-* pin controllers to
pinctrl-* and also rename the Kconfig symbols and in-kernel
users.
Cc: Rongjun Ying <Rongjun.Ying@csr.com>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
