git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: AMD 813x B2 devices do not need boot interrupt quirk
PCI: Enable PCIe AER only after checking firmware support
PCI: pciehp: Handle interrupts that happen during initialization.
PCI: don't enable too many HT MSI mappings
PCI: add some sysfs ABI docs
PCI quirk: enable MSI on 8132
Turns out that the new AMD 813x devices do not need the
quirk_disable_amd_813x_boot_interrupt quirk to be run on them. If it
is, no interrupts are seen on the PCI-X adapter.
Reported-by: Jamie Wellnitz <Jamie.Wellnitz@emulex.com>
Tested-by: Jamie Wellnitz <Jamie.Wellnitz@emulex.com>
Cc: stable <stable@kernel.org>
Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
* git://git.infradead.org/iommu-2.6:
intel-iommu: fix endless "Unknown DMAR structure type" loop
VT-d: handle Invalidation Queue Error to avoid system hang
intel-iommu: fix build error with INTR_REMAP=y and DMAR=n
The PCIe port driver currently sets the PCIe AER error reporting bits for
any root or switch port without first checking to see if firmware will grant
control. This patch moves setting these bits to the AER service driver
aer_enable_port routine. The bits are then set for the root port and any
downstream switch ports after the check for firmware support (aer_osc_setup)
is made. The patch also unsets the bits in a similar fashion when the AER
service driver is unloaded.
Reviewed-by: Alex Chiang <achiang@hp.com>
Signed-off-by: Andrew Patterson <andrew.patterson@hp.com>
Move the enabling of interrupts after all of the data structures
are setup so that we can safely run the interrupt handler as
soon as it is registered.
Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Tested-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
Prakash reported that his c51-mcp51 ondie sound card doesn't work with
MSI. But if he hacks out the HT-MSI quirk, MSI works fine.
So this patch reworks the nv_msi_ht_cap_quirk(). It will now only
enable ht_msi on own its root device, avoiding enabling it on devices
following that root dev.
Reported-by: Prakash Punnoor <prakash@punnoor.de>
Tested-by: Prakash Punnoor <prakash@punnoor.de>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
arch/x86/mach-default/setup.c
Semantic conflict resolution:
arch/x86/kernel/setup.c
David reported that LSI SAS doesn't work with MSI. It turns out that
his BIOS doesn't enable it, but the HT MSI 8132 does support HT MSI.
Add quirk to enable it
Cc: stable@kernel.org
Reported-by: David Lang <david@lang.hm>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
iommu: fix Intel IOMMU write-buffer flushing
futex: fix reference leak
Trivial conflicts fixed manually in drivers/pci/intel-iommu.c
PCI: Documentation: fix minor PCIe HOWTO thinko
PCI: fix missing kernel-doc and typos
PCI: fix struct pci_platform_pm_ops kernel-doc
PCI: fix rom.c kernel-doc warning
PCI/MSI: fix msi_mask() shift fix
This is the cause of the DMA faults and disk corruption that people have
been seeing. Some chipsets neglect to report the RWBF "capability" --
the flag which says that we need to flush the chipset write-buffer when
changing the DMA page tables, to ensure that the change is visible to
the IOMMU.
Override that bit on the affected chipsets, and everything is happy
again.
Thanks to Chris and Bhavesh and others for helping to debug.
Tested-by: Chris Wright <chrisw@sous-sol.org>
Reviewed-by: Bhavesh Davda <bhavesh@vmware.com>
the IOMMU.
again.
Should resolve:
https://bugzilla.redhat.com/show_bug.cgi?id=479996
http://bugzilla.kernel.org/show_bug.cgi?id=12578
Tested-and-acked-by: Chris Wright <chrisw@sous-sol.org>
I have a SuperMicro C2SBX motherboard with BIOS revision 1.0b. With vt-d
enabled in the BIOS, Linux gets into an endless loop printing
"DMAR:Unknown DMAR structure type" when booting. Here is the DMAR ACPI
table:
DMAR @ 0x7fe86dec
0000: 44 4d 41 52 98 00 00 00 01 6f 49 6e 74 65 6c 20 DMAR.....oIntel
0010: 4f 45 4d 44 4d 41 52 20 00 00 04 06 4c 4f 48 52 OEMDMAR ....LOHR
0020: 01 00 00 00 23 00 00 00 00 00 00 00 00 00 00 00 ....#...........
0030: 01 00 58 00 00 00 00 00 00 a0 e8 7f 00 00 00 00 ..X.............
0040: ff ff ef 7f 00 00 00 00 01 08 00 00 00 00 1d 00 ................
0050: 01 08 00 00 00 00 1d 01 01 08 00 00 00 00 1d 02 ................
0060: 01 08 00 00 00 00 1d 07 01 08 00 00 00 00 1a 00 ................
0070: 01 08 00 00 00 00 1a 01 01 08 00 00 00 00 1a 02 ................
0080: 01 08 00 00 00 00 1a 07 01 08 00 00 00 00 1a 07 ................
0090: c0 00 68 00 04 10 66 60 ..h...f`
Here are the messages printed by the kernel:
DMAR:Host address width 36
DMAR:RMRR base: 0x000000007fe8a000 end: 0x000000007fefffff
Although I not very familiar with ACPI, to me it looks like struct
acpi_dmar_header::length == 0x0058 is incorrect, causing
parse_dmar_table() to look at an invalid offset on the next loop. This
offset happens to have struct acpi_dmar_header::length == 0x0000, which
prevents the loop from ever terminating. This patch checks for this
condition and bails out instead of looping forever.
Signed-off-by: Tony Battersby <tonyb@cybernetics.com>
Fix pci kernel-doc parameter missing notation, correct
function name, and fix typo:
Warning(linux-2.6.28-git10//drivers/pci/pci.c:1511): No description found for parameter 'exclusive'
Fix struct pci_platform_pm_ops kernel-doc notation.
Fix PCI kernel-doc warning:
Warning(linux-2.6.29-rc4-git1/drivers/pci/rom.c:67): No description found for parameter 'pdev'
cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Hidetoshi Seto points out that commit
bffac3c593eba1f9da3efd0199e49ea6558a40ce has wrong values in the array.
Rather than correct the array, we can just use a bounds check and
perform the calculation specified in the comment. As a bonus, this will
not run off the end of the array if the device specifies an illegal
value in the MSI capability.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
'x86/debug', 'x86/defconfig', 'x86/doc', 'x86/header-fixes', 'x86/headers' and 'x86/minor-fixes' into x86/core
arch/x86/kernel/acpi/boot.c
arch/x86/mm/fault.c
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
ptrace, x86: fix the usage of ptrace_fork()
i8327: fix outb() parameter order
x86: fix math_emu register frame access
x86: math_emu info cleanup
x86: include correct %gs in a.out core dump
x86, vmi: put a missing paravirt_release_pmd in pgd_dtor
x86: find nr_irqs_gsi with mp_ioapic_routing
x86: add clflush before monitor for Intel 7400 series
x86: disable intel_iommu support by default
x86: don't apply __supported_pte_mask to non-present ptes
x86: fix grammar in user-visible BIOS warning
x86/Kconfig.cpu: make Kconfig help readable in the console
x86, 64-bit: print DMI info in the oops trace
Pawel reported:
WARNING: at arch/x86/mm/ioremap.c:616 check_early_ioremap_leak+0x52/0x67()
Hardware name:
Debug warning: early ioremap leak of 1 areas detected.
Modules linked in:
Pid: 1, comm: swapper Not tainted 2.6.29-rc4-tip #2
Reported-by: Pawel Dziekonski <dzieko@gmail.com>
When hardware detects any error with a descriptor from the invalidation
queue, it stops fetching new descriptors from the queue until software
clears the Invalidation Queue Error bit in the Fault Status register.
Following fix handles the IQE so the kernel won't be trapped in an
infinite loop.
Signed-off-by: Yu Zhao <yu.zhao@intel.com>
This fix should be safe since iommu->agaw is only used in intel-iommu.c.
And this file is only compiled with DMAR=y.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Semantic merge:
arch/x86/kernel/irqinit_32.c
Due to recurring issues with DMAR support on certain platforms.
There's a number of filesystem corruption incidents reported:
Provide a Kconfig option to change whether it is enabled by
default.
If disabled, it can still be reenabled by passing intel_iommu=on to the
kernel. Keep the .config option off by default.
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Acked-By: David Woodhouse <David.Woodhouse@intel.com>
Currently, the PM core always attempts to manage devices with drivers
that use the new PM framework. In particular, it attempts to disable
the devices (which is unnecessary), to save their state (which may be
undesirable if the driver has done that already) and to put them into
low power states (again, this may be undesirable if the driver has
already put the device into a low power state). That need not be
the right thing to do, so make the core be more careful in this
respect.
Generally, there are the following categories of devices to consider:
* bridge devices without drivers
* non-bridge devices without drivers
* bridge devices with drivers
* non-bridge devices with drivers
and each of them should be handled differently.
For bridge devices without drivers the PCI PM core will save their
state on suspend and restore it (early) during resume, after putting
them into D0 if necessary. It will not attempt to do anything else
to these devices.
For non-bridge devices without drivers the PCI PM core will disable
them and save their state on suspend. During resume, it will put
them into D0, if necessary, restore their state (early) and reenable
them.
For bridge devices with drivers the PCI PM core will only save
their state on suspend if the driver hasn't done that already.
Still, the core will restore their state (early) during resume,
after putting them into D0, if necessary.
For non-bridge devices with drivers the PCI PM core will only save
their state on suspend if the driver hasn't done that already. Also,
if the state of the device hasn't been saved by the driver, the core
will attempt to put the device into a low power state. During
resume the core will restore the state of the device (early), after
putting it into D0, if necessary.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
pci_restore_standard_config() unconditionally changes current_state
to PCI_D0 after attempting to change the device's power state, but
it should rather read the actual current power state from the
device.
It is a mistake to disable and enable PCI bridges and PCI Express
ports during suspend-resume, at least at the time when it is
currently done. Disabling them may lead to problems with accessing
devices behind them and they should be automatically enabled when
their standard config spaces are restored. Fix this by not attempting
to disable bridges during suspend and enable them during resume.
Simplify suspend and resume of the PCI Express port driver. It no
longer needs to save and restore the standard configuration space of the
device; this is now done by the PCI PM core layer.
This patch is reported to fix the regression tracked as
http://bugzilla.kernel.org/show_bug.cgi?id=12598
Reported-and-tested-by: Parag Warudkar <parag.lkml@gmail.com>
Make pci_legacy_suspend() save the state of the device if it is
in PCI_UNKNOWN after its suspend callback has run and warn only if
the power state of the device has been changed by its suspend
callback.
Also, use WARN_ONCE(), which is more useful, in pci_legacy_suspend(),
so that the name of the offending function is printed.
Additionally, remove the unnecessary line of code setting
pci_dev->state_saved.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Check if the standard configuration registers of a PCI device have
been saved during suspend before trying to restore them during
resume.
Reported-By: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Suspend to RAM is reported to break on some machines as a result of
attempting to put one of driverless PCI devices into a low power
state. Avoid that by not attepmting to power manage driverless
devices during suspend.
Fix up pci_pm_poweroff() after a previous incomplete fix for the same
thing during hibernation.
This patch is reported to fix the regression from 2.6.28 tracked as
http://bugzilla.kernel.org/show_bug.cgi?id=12605
Reported-and-tested-by: Eric Sesterhenn <snakebyte@gmx.de>
This patch makes the ROM reading code return an error to user space if
the size of the ROM read is equal to 0.
The patch also emits a warnings if the contents of the ROM are invalid,
and documents the effects of the "enable" file on ROM reading.
Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au>
Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com>
We only want to disable ASPM when the last function is removed from
the parent's device list. We determine this by checking to see if
the parent's device list is completely empty.
Unfortunately, we never hit that code because the parent is considered
an upstream port, and never had an ASPM link_state associated with it.
The early check for !link_state causes us to return early, we never
discover that our device list is empty, and thus we never remove the
downstream ports' link_state nodes.
Instead of checking to see if the parent's device list is empty, we can
check to see if we are the last device on the list, and if so, then we
know that we can clean up properly.
Cc: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
Some hardware exposes PCIE slots in such a way that they can be claimed
by either the acpiphp or pciehp driver. pciehp is the preferred driver
if the firmware allows the OS to claim control via the _OSC method so
should be loaded first - if it fails to bind (either due to a missing
_OSC method or the firmware refusing to hand off control) then we can
fall back to acpiphp or a vendor-specific driver.
This patch simply changes the link order to ensure that pciehp will be
initialised before acpiphp if both are statically built into the kernel.
For PCI devices, pci_bus_assign_resources() must be called to set up the
pci_device->resource array before pci_bus_add_devices() can be called, else
attempts to load drivers results in BAR collision errors where there are none.
This is not done in fakephp, so devices can be "unplugged" but scanning the
parent bus won't bring the devices back due to resource unallocation. Move the
pci_bus_add_device-calling logic into pci_rescan_bus and preface it with a call
to pci_bus_assign_resources so that we only have to (re)allocate resources once
per bus where a new device is found.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
Acked-by: Alex Chiang <achiang@hp.com>
Add an msi_mask() function which returns the correct bitmask for the
number of MSI interrupts you have. This fixes an undefined bug in
msi_capability_init().
pci_restore_standard_config() adds extra delay for PCI buses in
low power states (B2 or B3), but this is only correct for buses in
B2, because the buses in B3 are reset when they are put back into
B0. Thus we should wait for such buses to settle after the reset,
but it's not a good idea to wait that long (1.1 s) with interrupts
off.
On the other hand, we have never waited for buses in B2 and B3
during resume and it seems reasonable to go back to this well
tested behaviour.
Devices that have MSI-X enabled before suspend to RAM or hibernation
and that are in a low power state during resume will not be handled
correctly by pci_restore_standard_config(). Namely, it first calls
pci_restore_state() which calls pci_restore_msi_state(), which in turn
executes __pci_restore_msix_state() that accesses the device's memory
space to restore the contents of the MSI-X table. However, if the
device is in a low power state at this point, it's memory space is
not accessible.
The easiest way to fix this potential problem is to make
pci_restore_standard_config() call pci_restore_state() after
it has put the device into the full power state, D0. Fortunately,
all of this is done with interrupts off, so the change of ordering
should not cause any trouble.
Hibernation breaks on EeePC 701 as a result of attempting to put one
of its (driverless) devices into a low power state. Avoid that by
not attepmting to power manage driverless devices during hibernation.
Reported-and-tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk>
If one of device drivers refuses to suspend by returning error code
from its ->suspend() callback, the devices that have already been
suspended are resumed by executing their drivers' ->resume()
callbacks. Some of these callbacks expect the device's
configuration space to be restored if the device has been put into
D3 before they are called. Unfortunately, this mechanism has been
broken by recent changes moving the restoration of config spaces
of some devices (most importantly, USB controllers and HDA Intel)
into the resume callbacks executed with interrupts off. Obviously,
these callbacks are not invoked in the suspend error path and, as a
result, the system cannot be successfully brought back into the
working state in case of a suspend error. The same thing happens
in the hibernation error path right before putting the system into
S4.
Similarly, the suspend testing facility associated with the
/sys/power/pm_test file is broken, because it uses the very same
mechanism that is used in the suspend and hibernation error paths.
Fix the breakage by making the PCI core restore the configuration
spaces of PCI devices that haven't been restored already before
pci_pm_resume() is called for those devices by the PM core.
arch/x86/kernel/setup_percpu.c
PCI hotplug: fix lock imbalance in pciehp
PCI PM: Restore standard config registers of all devices early
PCI/MSI: bugfix/utilize for msi_capability_init()
arch/x86/mm/fault.c
set_lock_status omits mutex_unlock in fail path. Add the omitted
unlock.
As a result a lockup caused by this can be triggered from userspace
by writing 1 to /sys/bus/pci/slots/.../lock often enough.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
There is a problem in our handling of suspend-resume of PCI devices that
many of them have their standard config registers restored with
interrupts enabled and they are put into the full power state with
interrupts enabled as well. This may lead to the following scenario:
* an interrupt vector is shared between two or more devices
* one device is resumed earlier and generates an interrupt
* the interrupt handler of another device tries to handle it and
attempts to access the device the config space of which hasn't been
restored yet and/or which still is in a low power state
* the system crashes as a result
To prevent this from happening we should restore the standard
configuration registers of all devices with interrupts disabled and we
should put them into the D0 power state right after that.
Unfortunately, this cannot be done using the existing
pci_set_power_state(), because it can sleep. Also, to do it we have to
make sure that the config spaces of all devices were actually saved
during suspend.
This patch fix a following bug and does a cleanup.
bug:
commit 5993760f7fc75b77e4701f1e56dc84c0d6cf18d5
had a wrong change (since is_64 is boolean[0|1]):
- pci_write_config_dword(dev,
- msi_mask_bits_reg(pos, is_64bit_address(control)),
- maskbits);
+ pci_write_config_dword(dev, entry->msi_attrib.is_64, maskbits);
utilize:
Unify separated if (entry->msi_attrib.maskbit) statements.
Acked-by: "Jike Song" <albcamus@gmail.com>
Cc: stable@vger.kernel.org
ACPI hotplug panic with current git head
http://lkml.org/lkml/2009/1/10/136
Rather than reverting the entire commit that causes the crash:
e8c331e963c58b83db24b7d0e39e8c07f687dbc6
"PCI hotplug: introduce functions for ACPI slot detection"
simply harden against it while the changes to
the hotplug code on this particularl machine are understood.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Len Brown <len.brown@intel.com>
This reverts commit 98e6e286d7b01deb7453b717aa38ebb69d6cefc0, as Yinghai
Lu reports that it breaks kexec with at least the e1000 and e1000e
drivers. The reason is that the shutdown sequence puts the hardware
into D3 sleep, and the commit causes us to claim that it then is in D0
(running) state just because we don't understand the PM capabilities.
Which then later makes "pci_set_power_state()" not do anything, and the
device never wakes up properly and just returns 0xff to everything.
Reported-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: From: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Jesse Barnes <jesse.barnes@intel.com>
