path: root/drivers/pci/quirks.c
2013-08-12Merge branch 'pci/vipul-chelsio-reset-v2' into nextBjorn Helgaas
* pci/vipul-chelsio-reset-v2: PCI: Use pci_wait_for_pending_transaction() instead of for loop bnx2x: Use pci_wait_for_pending_transaction() instead of for loop PCI: Chelsio quirk: Enable Bus Master during Function-Level Reset PCI: Add pci_wait_for_pending_transaction()
2013-08-12PCI: Use pci_wait_for_pending_transaction() instead of for loopCasey Leedom
New routine has been added to avoid duplication of code to wait for pending PCI transactions to complete. This makes use of that function. Signed-off-by: Casey Leedom <leedom@chelsio.com> Signed-off-by: Vipul Pandya <vipul@chelsio.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-08-12PCI: Chelsio quirk: Enable Bus Master during Function-Level ResetCasey Leedom
T4 can wedge if there are DMAs in flight within the chip and Bus Master has been disabled. We need to have it on till the Function Level Reset completes. T4 can also suffer a Head Of Line blocking problem if MSI-X interrupts are disabled before the FLR has completed. Signed-off-by: Casey Leedom <leedom@chelsio.com> Signed-off-by: Vipul Pandya <vipul@chelsio.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-25PCI: Claim ACS support for AMD southbridge devicesAlex Williamson
AMD confirmed that peer-to-peer between these devices is not possible. We can therefore claim that they support a subset of ACS. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Donald Dutile <ddutile@redhat.com>
2013-06-26Merge branch 'pci/misc' into nextBjorn Helgaas
* pci/misc: MAINTAINERS: Add ACPI folks for ACPI-related things under drivers/pci PCI: Add CircuitCo vendor ID and subsystem ID PCI: Use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM)
2013-06-18PCI: Use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM)Yijing Wang
PCI PM cap register offset has been saved in pci_pm_init(), so we can use pdev->pm_cap instead of using pci_find_capability(..) here. Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-06-04Merge branch 'pci/shane-amd-ahci-i2c' into nextBjorn Helgaas
* pci/shane-amd-ahci-i2c: i2c-piix4: Add AMD CZ SMBus device ID ahci: Add AMD CZ SATA device ID PCI: Put Hudson-2 device IDs together
2013-06-03ahci: Add AMD CZ SATA device IDShane Huang
To add AMD CZ SATA controller device ID of IDE mode. [bhelgaas: drop pci_ids.h update] Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2013-05-15PCI: Work around Ivytown NTB BAR size issueJon Mason
Certain NTB devices have a hardware erratum where, regardless of pre-configured value, reading the BAR size returns 4096. To work around this issue, add a PCI quirk to read the appropriate values from an alternative register in PCI config space and move the resource endpoints to the appropriate location. Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-04-15PCI: Clean up quirk_io_regionYinghai Lu
Before every call of quirk_io_region(), pci_read_config_word() is called. We can fold that call into quirk_io_region() to make code more readable. [bhelgaas: changelog, fill bus_region directly rather than copying from res] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-04-04PCI: Add MSI INTX_DISABLE quirks for AR8161/AR8162/AR8171/AR8172/E210XXiong Huang
The following PCIe devices with revision lower than 0x18 have this bug: AR8161(1091)/AR8162(1090)/AR8171(10A1)/AR8172(10A0)/E210X(E091). Signed-off-by: Huang,Xiong <xiong@qca.qualcomm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Wei Yang <weiyang@linux.vnet.ibm.com>
2012-12-26PCI: Reduce Ricoh 0xe822 SD card reader base clock frequency to 50MHzAndy Lutomirski
Otherwise it fails like this on cards like the Transcend 16GB SDHC card: mmc0: new SDHC card at address b368 mmcblk0: mmc0:b368 SDC 15.0 GiB mmcblk0: error -110 sending status command, retrying mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb0 Tested on my Lenovo x200 laptop. [bhelgaas: changelog] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Chris Ball <cjb@laptop.org> CC: Manoj Iyer <manoj.iyer@canonical.com> CC: stable@vger.kernel.org
2012-12-13Merge tag 'for-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pciLinus Torvalds
Pull PCI update from Bjorn Helgaas: "Host bridge hotplug: - Untangle _PRT from struct pci_bus (Bjorn Helgaas) - Request _OSC control before scanning root bus (Taku Izumi) - Assign resources when adding host bridge (Yinghai Lu) - Remove root bus when removing host bridge (Yinghai Lu) - Remove _PRT during hot remove (Yinghai Lu) SRIOV - Add sysfs knobs to control numVFs (Don Dutile) Power management - Notify devices when power resource turned on (Huang Ying) Bug fixes - Work around broken _SEG on HP xw9300 (Bjorn Helgaas) - Keep runtime PM enabled for unbound PCI devices (Huang Ying) - Fix Optimus dual-GPU runtime D3 suspend issue (Dave Airlie) - Fix xen frontend shutdown issue (David Vrabel) - Work around PLX PCI 9050 BAR alignment erratum (Ian Abbott) Miscellaneous - Add GPL license for drivers/pci/ioapic (Andrew Cooks) - Add standard PCI-X, PCIe ASPM register #defines (Bjorn Helgaas) - NumaChip remote PCI support (Daniel Blueman) - Fix PCIe Link Capabilities Supported Link Speed definition (Jingoo Han) - Convert dev_printk() to dev_info(), etc (Joe Perches) - Add support for non PCI BAR ROM data (Matthew Garrett) - Add x86 support for host bridge translation offset (Mike Yoknis) - Report success only when every driver supports AER (Vijay Pandarathil)" Fix up trivial conflicts. * tag 'for-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (48 commits) PCI: Use phys_addr_t for physical ROM address x86/PCI: Add NumaChip remote PCI support ath9k: Use standard #defines for PCIe Capability ASPM fields iwlwifi: Use standard #defines for PCIe Capability ASPM fields iwlwifi: collapse wrapper for pcie_capability_read_word() iwlegacy: Use standard #defines for PCIe Capability ASPM fields iwlegacy: collapse wrapper for pcie_capability_read_word() cxgb3: Use standard #defines for PCIe Capability ASPM fields PCI: Add standard PCIe Capability Link ASPM field names PCI/portdrv: Use PCI Express Capability accessors PCI: Use standard PCIe Capability Link register field names x86: Use PCI setup data PCI: Add support for non-BAR ROMs PCI: Add pcibios_add_device EFI: Stash ROMs if they're not in the PCI BAR PCI: Add and use standard PCI-X Capability register names PCI/PM: Keep runtime PM enabled for unbound PCI devices xen-pcifront: Handle backend CLOSED without CLOSING PCI: SRIOV control and status via sysfs (documentation) PCI/AER: Report success only when every device has AER-aware driver ...
2012-11-28PCI: Remove __dev* markingsBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p, __devint, __devinitdata, __devinitconst, and _devexit are no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-07PCI: Add PLX PCI 9050 workaround for some Meilhaus DAQ cardsIan Abbott
The Meilhaus ME-2000i and ME-2600i data acquisition cards supported by the Comedi "me_daq" driver use the PLX PCI 9050 PCI Target bridge chip affected by the bug that prevents the chip's local configuration registers being read from BAR0 or BAR1 base addresses that are an odd multiple of 128 bytes. Use the PLX PCI 9050 quirk handler for these devices to re-allocate affected regions to a 256-byte boundary. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-11-07PCI: Add workaround for PLX PCI 9050 BAR alignment erratumIan Abbott
The PLX PCI 9050 PCI Target bridge controller has a bug that prevents its local configuration registers being read through BAR0 (memory) or BAR1 (i/o) if the base address lies on an odd 128-byte boundary, i.e. if bit 7 of the base address is non-zero. This bug is described in the PCI 9050 errata list, version 1.4, May 2005. It was fixed in the pin-compatible PCI 9052, which can be distinguished from the PCI 9050 by checking the revision in the PCI header, which is hard-coded for these chips. Workaround the problem by re-allocating the affected regions to a 256-byte boundary. Note that BAR0 and/or BAR1 may have been disabled (size 0) during initialization of the PCI chip when its configuration is read from a serial EEPROM. Currently, the fix-up has only been used for devices with the default vendor and device ID of the PLX PCI 9050. The PCI 9052 shares the same default device ID as the PCI 9050 but they have different PCI revision codes. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-08-23PCI: Wait for pending transactions to complete before 82599 FLRBjorn Helgaas
Before initiating an FLR, we should wait for completion of any outstanding non-posted requests. See PCIe spec r3.0, sec 6.6.2. This makes reset_intel_82599_sfp_virtfn() very similar to the generic pcie_flr(). The only difference is that the 82599 doesn't report FLR support in the VF Device Capability register. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-08-23PCI/core: Use PCI Express Capability accessorsJiang Liu
Use PCI Express Capability access functions to simplify core. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-07-24Merge tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pciLinus Torvalds
Pull PCI changes from Bjorn Helgaas: "Host bridge hotplug: - Add MMCONFIG support for hot-added host bridges (Jiang Liu) Device hotplug: - Move fixups from __init to __devinit (Sebastian Andrzej Siewior) - Call FINAL fixups for hot-added devices, too (Myron Stowe) - Factor out generic code for P2P bridge hot-add (Yinghai Lu) - Remove all functions in a slot, not just those with _EJx (Amos Kong) Dynamic resource management: - Track bus number allocation (struct resource tree per domain) (Yinghai Lu) - Make P2P bridge 1K I/O windows work with resource reassignment (Bjorn Helgaas, Yinghai Lu) - Disable decoding while updating 64-bit BARs (Bjorn Helgaas) Power management: - Add PCIe runtime D3cold support (Huang Ying) Virtualization: - Add VFIO infrastructure (ACS, DMA source ID quirks) (Alex Williamson) - Add quirks for devices with broken INTx masking (Jan Kiszka) Miscellaneous: - Fix some PCI Express capability version issues (Myron Stowe) - Factor out some arch code with a weak, generic, pcibios_setup() (Myron Stowe)" * tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (122 commits) PCI: hotplug: ensure a consistent return value in error case PCI: fix undefined reference to 'pci_fixup_final_inited' PCI: build resource code for M68K architecture PCI: pciehp: remove unused pciehp_get_max_lnk_width(), pciehp_get_cur_lnk_width() PCI: reorder __pci_assign_resource() (no change) PCI: fix truncation of resource size to 32 bits PCI: acpiphp: merge acpiphp_debug and debug PCI: acpiphp: remove unused res_lock sparc/PCI: replace pci_cfg_fake_ranges() with pci_read_bridge_bases() PCI: call final fixups hot-added devices PCI: move final fixups from __init to __devinit x86/PCI: move final fixups from __init to __devinit MIPS/PCI: move final fixups from __init to __devinit PCI: support sizing P2P bridge I/O windows with 1K granularity PCI: reimplement P2P bridge 1K I/O windows (Intel P64H2) PCI: disable MEM decoding while updating 64-bit MEM BARs PCI: leave MEM and IO decoding disabled during 64-bit BAR sizing, too PCI: never discard enable/suspend/resume_early/resume fixups PCI: release temporary reference in __nv_msi_ht_cap_quirk() PCI: restructure 'pci_do_fixups()' ...
2012-07-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull arch/tile updates from Chris Metcalf: "These changes provide support for PCIe root complex and USB host mode for tilegx's on-chip I/Os. In addition, this pull provides the required underpinning for the on-chip networking support that was pulled into 3.5. The changes have all been through LKML (with several rounds for PCIe RC) and on linux-next." * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: updates to pci root complex from community feedback bounce: allow use of bounce pool via config option usb: add host support for the tilegx architecture arch/tile: provide kernel support for the tilegx USB shim tile pci: enable IOMMU to support DMA for legacy devices arch/tile: enable ZONE_DMA for tilegx tilegx pci: support I/O to arbitrarily-cached pages tile: remove unused header arch/tile: tilegx PCI root complex support arch/tile: provide kernel support for the tilegx TRIO shim arch/tile: break out the "csum a long" function to <asm/checksum.h> arch/tile: provide kernel support for the tilegx mPIPE shim arch/tile: common DMA code for the GXIO IORPC subsystem arch/tile: support MMIO-based readb/writeb etc. arch/tile: introduce GXIO IORPC framework for tilegx
2012-07-18arch/tile: tilegx PCI root complex supportChris Metcalf
This change implements PCIe root complex support for tilegx using the kernel support layer for accessing the TRIO hardware shim. Reviewed-by: Bjorn Helgaas <bhelgaas@google.com> [changes in 07487f3] Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2012-07-16Merge branch 'pci/myron-final-fixups-v2' into nextBjorn Helgaas
* pci/myron-final-fixups-v2: PCI: fix undefined reference to 'pci_fixup_final_inited'
2012-07-16PCI: fix undefined reference to 'pci_fixup_final_inited'Myron Stowe
My "PCI: Integrate 'pci_fixup_final' quirks into hot-plug paths" patch introduced an undefined reference to 'pci_fixup_final_inited' when CONFIG_PCI_QUIRKS is not enabled (on x86_64): drivers/built-in.o: In function `pci_bus_add_device': (.text+0x4f62): undefined reference to `pci_fixup_final_inited' This patch removes the external reference ending up with a result closer to what we ultimately want when the boot path issues described in the original patch are resolved. References: https://lkml.org/lkml/2012/7/9/542 Original, offending, patch https://lkml.org/lkml/2012/7/12/338 Randy's catch Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2012-07-10PCI: EHCI: fix crash during suspend on ASUS computersAlan Stern
Quite a few ASUS computers experience a nasty problem, related to the EHCI controllers, when going into system suspend. It was observed that the problem didn't occur if the controllers were not put into the D3 power state before starting the suspend, and commit 151b61284776be2d6f02d48c23c3625678960b97 (USB: EHCI: fix crash during suspend on ASUS computers) was created to do this. It turned out this approach messed up other computers that didn't have the problem -- it prevented USB wakeup from working. Consequently commit c2fb8a3fa25513de8fedb38509b1f15a5bbee47b (USB: add NO_D3_DURING_SLEEP flag and revert 151b61284776be2) was merged; it reverted the earlier commit and added a whitelist of known good board names. Now we know the actual cause of the problem. Thanks to AceLan Kao for tracking it down. According to him, an engineer at ASUS explained that some of their BIOSes contain a bug that was added in an attempt to work around a problem in early versions of Windows. When the computer goes into S3 suspend, the BIOS tries to verify that the EHCI controllers were first quiesced by the OS. Nothing's wrong with this, but the BIOS does it by checking that the PCI COMMAND registers contain 0 without checking the controllers' power state. If the register isn't 0, the BIOS assumes the controller needs to be quiesced and tries to do so. This involves making various MMIO accesses to the controller, which don't work very well if the controller is already in D3. The end result is a system hang or memory corruption. Since the value in the PCI COMMAND register doesn't matter once the controller has been suspended, and since the value will be restored anyway when the controller is resumed, we can work around the BIOS bug simply by setting the register to 0 during system suspend. This patch (as1590) does so and also reverts the second commit mentioned above, which is now unnecessary. In theory we could do this for every PCI device. However to avoid introducing new problems, the patch restricts itself to EHCI host controllers. Finally the affected systems can suspend with USB wakeup working properly. Reference: https://bugzilla.kernel.org/show_bug.cgi?id=37632 Reference: https://bugzilla.kernel.org/show_bug.cgi?id=42728 Based-on-patch-by: AceLan Kao <acelan.kao@canonical.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Dâniel Fraga <fragabr@gmail.com> Tested-by: Javier Marcet <jmarcet@gmail.com> Tested-by: Andrey Rahmatullin <wrar@wrar.name> Tested-by: Oleksij Rempel <bug-track@fisher-privat.net> Tested-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Cc: stable <stable@vger.kernel.org> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-10Merge branch 'pci/bjorn-p2p-bridge-windows' into nextBjorn Helgaas
* pci/bjorn-p2p-bridge-windows: sparc/PCI: replace pci_cfg_fake_ranges() with pci_read_bridge_bases() PCI: support sizing P2P bridge I/O windows with 1K granularity PCI: reimplement P2P bridge 1K I/O windows (Intel P64H2) PCI: allow P2P bridge windows starting at PCI bus address zero Conflicts: drivers/pci/probe.c include/linux/pci.h
2012-07-09Merge branch 'pci/myron-final-fixups-v2' into nextBjorn Helgaas
* pci/myron-final-fixups-v2: PCI: call final fixups hot-added devices PCI: move final fixups from __init to __devinit x86/PCI: move final fixups from __init to __devinit MIPS/PCI: move final fixups from __init to __devinit PCI: never discard enable/suspend/resume_early/resume fixups PCI: release temporary reference in __nv_msi_ht_cap_quirk() PCI: restructure 'pci_do_fixups()'
2012-07-09PCI: call final fixups hot-added devicesMyron Stowe
Final fixups are currently applied only at boot-time by pci_apply_final_quirks(), which is an fs_initcall(). Hot-added devices don't get these fixups, so they may not be completely initialized. This patch makes us run final fixups for hot-added devices in pci_bus_add_device() just before the new device becomes eligible for driver binding. This patch keeps the fs_initcall() for devices present at boot because we do resource assignment between pci_bus_add_device and the fs_initcall(), and we don't want to break any fixups that depend on that assignment. This is a design issue that may be addressed in the future -- any resource assignment should be done *before* device_add(). [bhelgaas: changelog] Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-07-09PCI: move final fixups from __init to __devinitMyron Stowe
Final fixups are executed during device enumeration. If we support hotplug, this may be after boot, so final fixups cannot be __init. [bhelgaas: changelog] Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-07-09PCI: reimplement P2P bridge 1K I/O windows (Intel P64H2)Bjorn Helgaas
9d265124d051 and 15a260d53f7c added quirks for P2P bridges that support I/O windows that start/end at 1K boundaries, not just the 4K boundaries defined by the PCI spec. For details, see the IOBL_ADR register and the EN1K bit in the CNF register in the Intel 82870P2 (P64H2). These quirks complicate the code that reads P2P bridge windows (pci_read_bridge_io() and pci_cfg_fake_ranges()) because the bridge I/O resource is updated in the HEADER quirk, in pci_read_bridge_io(), in pci_setup_bridge(), and again in the FINAL quirk. This is confusing and makes it impossible to reassign the bridge windows after FINAL quirks are run. This patch adds support for 1K windows in the generic paths, so the HEADER quirk only has to enable this support. The FINAL quirk, which used to undo damage done by pci_setup_bridge(), is no longer needed. This removes "if (!res->start) res->start = ..." from pci_read_bridge_io(); that was part of 9d265124d051 to avoid overwriting the resource filled in by the quirk. Since pci_read_bridge_io() itself now knows about granularity, the quirk no longer updates the resource and this test is no longer needed. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-07-09PCI: never discard enable/suspend/resume_early/resume fixupsMyron Stowe
The enable/suspend/resume_early/resume fixups can be called at any time, so they can't be __init or __devinit. [bhelgaas: changelog] Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-07-09PCI: release temporary reference in __nv_msi_ht_cap_quirk()Myron Stowe
__nv_msi_ht_cap_quirk() acquires a temporary reference via 'pci_get_bus_and_slot()' that is never released. This patch releases the temporary reference. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-07-09PCI: restructure 'pci_do_fixups()'Myron Stowe
This patch restructures pci_do_fixups()'s quirk invocations in the style of initcall_debug_start() and initcall_debug_report(), so we have only one call site for the quirk. [bhelgaas: changelog] Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-18Merge branch 'topic/jan-intx-masking' into nextBjorn Helgaas
* topic/jan-intx-masking: PCI: add Ralink RT2800 broken INTx masking quirk PCI: add Chelsio T310 10GbE NIC broken INTx masking quirk PCI: add infrastructure for devices with broken INTx masking
2012-06-18Merge branch 'topic/sebastian-devinit-fixups' into nextBjorn Helgaas
* topic/sebastian-devinit-fixups: scripts/modpost: check for bad references in .pci.fixups area sh/PCI: move fixup hooks from __init to __devinit powerpc/PCI: move fixup hooks from __init to __devinit frv/PCI: move fixup hooks from __init to __devinit arm/PCI: move fixup hooks from __init to __devinit alpha/PCI: move fixup hooks from __init to __devinit PCI: move fixup hooks from __init to __devinit x86/PCI: move fixup hooks from __init to __devinit
2012-06-18PCI: add Ralink RT2800 broken INTx masking quirkAlex Williamson
Passes pci_intx_mask_supported test but continues to send interrupts as discovered through VFIO-based device assignment. http://www.spinics.net/lists/kvm/msg73738.html [bhelgaas: use HEADER, not FINAL, which is currently broken for hotplug] Tested-by: Andreas Hartmann <andihartmann@01019freenet.de> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-18PCI: add Chelsio T310 10GbE NIC broken INTx masking quirkJan Kiszka
According to http://thread.gmane.org/gmane.comp.emulators.kvm.devel/91388 the T310 does not properly support INTx masking as it fails to keep the PCI_STATUS_INTERRUPT bit updated once the interrupt is masked. Mark this adapter as broken so that pci_intx_mask_supported won't report it as compatible. [bhelgaas: use HEADER, not FINAL, which is currently broken for hotplug] Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-16PCI: add infrastructure for devices with broken INTx maskingBjorn Helgaas
pci_intx_mask_supported() assumes INTx masking is supported if the PCI_COMMAND_INTX_DISABLE bit is writable. But when that bit is set, some devices don't actually mask INTx or update PCI_STATUS_INTERRUPT as we expect. This patch adds a way for quirks to identify these broken devices. [bhelgaas: split out from Chelsio quirk addition] Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-13USB: add NO_D3_DURING_SLEEP flag and revert 151b61284776be2Alan Stern
This patch (as1558) fixes a problem affecting several ASUS computers: The machine crashes or corrupts memory when going into suspend if the ehci-hcd driver is bound to any controllers. Users have been forced to unbind or unload ehci-hcd before putting their systems to sleep. After extensive testing, it was determined that the machines don't like going into suspend when any EHCI controllers are in the PCI D3 power state. Presumably this is a firmware bug, but there's nothing we can do about it except to avoid putting the controllers in D3 during system sleep. The patch adds a new flag to indicate whether the problem is present, and avoids changing the controller's power state if the flag is set. Runtime suspend is unaffected; this matters only for system suspend. However as a side effect, the controller will not respond to remote wakeup requests while the system is asleep. Hence USB wakeup is not functional -- but of course, this is already true in the current state of affairs. A similar patch has already been applied as commit 151b61284776be2d6f02d48c23c3625678960b97 (USB: EHCI: fix crash during suspend on ASUS computers). The patch supersedes that one and reverts it. There are two differences: The old patch added the flag at the USB level; this patch adds it at the PCI level. The old patch applied to all chipsets with the same vendor, subsystem vendor, and product IDs; this patch makes an exception for a known-good system (based on DMI information). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Dâniel Fraga <fragabr@gmail.com> Tested-by: Andrey Rahmatullin <wrar@wrar.name> Tested-by: Steven Rostedt <rostedt@goodmis.org> Cc: stable <stable@vger.kernel.org> Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-12PCI: add ACS validation utilityAlex Williamson
In a PCI environment, transactions aren't always required to reach the root bus before being re-routed. Intermediate switches between an endpoint and the root bus can redirect DMA back downstream before things like IOMMUs have a chance to intervene. Legacy PCI is always susceptible to this as it operates on a shared bus. PCIe added a new capability to describe and control this behavior, Access Control Services, or ACS. The utility function pci_acs_enabled() allows us to test the ACS capabilities of an individual devices against a set of flags while pci_acs_path_enabled() tests a complete path from a given downstream device up to the specified upstream device. We also include the ability to add device specific tests as it's likely we'll see devices that do not implement ACS, but want to indicate support for various capabilities in this space. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-12PCI: move fixup hooks from __init to __devinitSebastian Andrzej Siewior
The fixups are executed once the pci-device is found which is during boot process so __init seems fine as long as the platform does not support hotplug. However it is possible to remove the PCI bus at run time and have it rediscovered again via "echo 1 > /sys/bus/pci/rescan" and this will call the fixups again. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-11PCI: add PCI DMA source ID quirkAlex Williamson
DMA transactions are tagged with the source ID of the device making the request. Occasionally hardware screws this up and uses the source ID of a different device (often the wrong function number of a multifunction device). A specific Ricoh multifunction device is a prime example of this problem and included in this patch. Given a pci_dev, this function returns the pci_dev to use as the source ID for DMA. When hardware works correctly, this returns the input device. For the components of the Ricoh multifunction device, it returns the pci_dev for function 0. This will be used by IOMMU drivers for determining the boundaries of IOMMU groups as multiple devices using the same source ID must be contained within the same group. This can also be used by existing streaming DMA paths for the same purpose. [bhelgaas: fold in pci_dev_get() for !CONFIG_PCI] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-05-21Merge tag 'pci-for-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: - Host bridge cleanups from Yinghai - Disable Bus Master bit on PCI device shutdown (kexec-related) - Stratus ftServer fix - pci_dev_reset() locking fix - IvyBridge graphics erratum workaround * tag 'pci-for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (21 commits) microblaze/PCI: fix "io_offset undeclared" error x86/PCI: only check for spinlock being held in SMP kernels resources: add resource_overlaps() PCI: fix uninitialized variable 'cap_mask' MAINTAINERS: update PCI git tree and patchwork PCI: disable Bus Master on PCI device shutdown PCI: work around IvyBridge internal graphics FLR erratum x86/PCI: fix unused variable warning in amd_bus.c PCI: move mutex locking out of pci_dev_reset function PCI: work around Stratus ftServer broken PCIe hierarchy x86/PCI: merge pcibios_scan_root() and pci_scan_bus_on_node() x86/PCI: dynamically allocate pci_root_info for native host bridge drivers x86/PCI: embed pci_sysdata into pci_root_info on ACPI path x86/PCI: embed name into pci_root_info struct x86/PCI: add host bridge resource release for _CRS path x86/PCI: refactor get_current_resources() PCI: add host bridge release support PCI: add generic device into pci_host_bridge struct PCI: rename pci_host_bridge() to find_pci_root_bridge() x86/PCI: fix memleak with get_current_resources() ...
2012-05-02PCI: work around IvyBridge internal graphics FLR erratumXudong Hao
For IvyBridge Mobile platform, a system hang may occur if a FLR (Function Level Reset) is asserted to internal graphics. This quirk is a workaround for the IVB FLR errata issue. We are disabling the FLR reset handshake between the PCH and CPU display, then manually powering down the panel power sequencing and resetting the PCH display. Signed-off-by: Xudong Hao <xudong.hao@intel.com> Signed-off-by: Kay, Allen M <allen.m.kay@intel.com> Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-04-30atl1c: add workaround for issue of bit INTX-disable for MSI interruptHuang, Xiong
All supported devices have one issue that msi interrupt doesn't assert if pci command register bit (PCI_COMMAND_INTX_DISABLE) is set. Add workaround in drivers/pci/quirks.c Signed-off-by: xiong <xiong@qca.qualcomm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci Pull PCI changes (including maintainer change) from Jesse Barnes: "This pull has some good cleanups from Bjorn and Yinghai, as well as some more code from Yinghai to better handle resource re-allocation when enabled. There's also a new initcall_debug feature from Arjan which will print out quirk timing information to help identify slow quirks for fixing or refinement (Yinghai sent in a few patches to do just that once the new debug code landed). Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas. He's been a core PCI and Linux contributor for some time now, and has kindly volunteered to take over. I just don't feel I have the time for PCI review and work that it deserves lately (I've taken on some other projects), and haven't been as responsive lately as I'd like, so I approached Bjorn asking if he'd like to manage things. He's going to give it a try, and I'm confident he'll do at least as well as I have in keeping the tree managed, patches flowing, and keeping things stable." Fix up some fairly trivial conflicts due to other cleanups (mips device resource fixup cleanups clashing with list handling cleanup, ppc iseries removal clashing with pci_probe_only cleanup etc) * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits) PCI: Bjorn gets PCI hotplug too PCI: hand PCI maintenance over to Bjorn Helgaas unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h sparc/PCI: convert devtree and arch-probed bus addresses to resource powerpc/PCI: allow reallocation on PA Semi powerpc/PCI: convert devtree bus addresses to resource powerpc/PCI: compute I/O space bus-to-resource offset consistently arm/PCI: don't export pci_flags PCI: fix bridge I/O window bus-to-resource conversion x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()' PCI / PCIe: Introduce command line option to disable ARI PCI: make acpihp use __pci_remove_bus_device instead PCI: export __pci_remove_bus_device PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device PCI: print out PCI device info along with duration PCI: Move "pci reassigndev resource alignment" out of quirks.c PCI: Use class for quirk for usb host controller fixup PCI: Use class for quirk for ti816x class fixup PCI: Use class for quirk for intel e100 interrupt fixup ...
2012-03-04tg3: Recode PCI MRRS adjustment as a PCI quirkMatt Carlson
This patch recodes the MRRS cap for 5719 A0 devices as a PCI quirk. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-24PCI: print out PCI device info along with durationYinghai Lu
Makes it a little easier to figure out which device may have caused a slow quirk. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-02-24PCI: Move "pci reassigndev resource alignment" out of quirks.cYinghai Lu
This isn't really a quirk; calling it directly from pci_add_device makes more sense. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-02-24PCI: Use class for quirk for ti816x class fixupYinghai Lu
2012-02-24PCI: Use class for quirk for intel e100 interrupt fixupYinghai Lu
