path: root/drivers/pci/quirks.c
2006-06-21[PATCH] PCI: nVidia quirk to make AER PCI-E extended capability visibleBrice Goglin
The nVidia CK804 PCI-E chipset supports the AER extended capability but sometimes fails to link it (with some BIOS or after a warm reboot). It makes the AER cap invisible to pci_find_ext_capability(). The patch adds a quirk to set the missing bit that controls the linking of the capability. By the way, it removes the corresponding code in the myri10ge driver. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Loic Prylli <loic@myri.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] PCI: MSI-K8T-Neo2-Fir: run only where neededChris Wedgwood
Be more selective when running the MSI-K8T-Neo2Fir soundcard PCI quirk so as not to run this on hardware where it's probably not needed. Signed-off-by: Chris Wedgwood <cw@f00f.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] PCI Bus Parity Status-broken hardware attribute, EDAC foundationDoug Thompson
Currently, the EDAC (error detection and correction) modules that are in the kernel contain some features that need to be moved. After some good feedback on the PCI Parity detection code and interface (http://www.ussg.iu.edu/hypermail/linux/kernel/0603.1/0897.html) this patch ADDs an new attribute to the pci_dev structure: Namely the 'broken_parity_status' bit. When set this indicates that the respective hardware generates false positives of Parity errors. The EDAC "blacklist" solution was inferior and will be removed in a future patch. Also in this patch is a PCI quirk.c entry for an Infiniband PCI-X card which generates false positive parity errors. I am requesting comments on this AND on the possibility of a exposing this 'broken_parity_status' bit to userland via the PCI device sysfs directory for devices. This access would allow for enabling of this feature on new devices and for old devices that have their drivers updated. (SLES 9 SP3 did this on an ATI motherboard video device). There is a need to update such a PCI attribute between kernel releases. This patch just adds a storage place for the attribute and a quirk entry for a known bad PCI device. PCI Parity reaper/harvestor operations are in EDAC itself and will be refactored to use this PCI attribute instead of its own mechanisms (which are currently disabled) in the future. Signed-off-by: Doug Thompson <norsk5@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-15[PATCH] smbus unhiding kills thermal managementCarl-Daniel Hailfinger
Do not enable the SMBus device on Asus boards if suspend is used. We do not reenable the device on resume, leading to all sorts of undesirable effects, the worst being a total fan failure after resume on Samsung P35 laptop. Signed-off-by: Carl-Daniel Hailfinger <c-d.hailfinger.devel.2006@gmx.net> Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15[PATCH] VIA quirk fixup, additional PCI IDsChris Wedgwood
An earlier commit (75cf7456dd87335f574dcd53c4ae616a2ad71a11) changed an overly-zealous PCI quirk to only poke those VIA devices that need it. However, some PCI devices were not included in what I hope is now the full list. Consequently we're failing to run the quirk on all machines which need it, causing IRQ routing failures. This should I hope correct this. Thanks to Masoud Sharbiani <masouds@masoud.ir> for pointing this out and testing the fix. Signed-off-by: Chris Wedgwood <cw@f00f.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-27[PATCH] PCI quirk: VIA IRQ fixup should only run for VIA southbridgesChris Wedgwood
Alan Cox pointed out that the VIA 'IRQ fixup' was erroneously running on my system which has no VIA southbridge (but I do have a VIA IEEE 1394 device). This should address that. I also changed "Via IRQ" to "VIA IRQ" (initially I read Via as a capitalized via (by way/means of). Signed-off-by: Chris Wedgwood <cw@f00f.org> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-20[PATCH] MSI-K8T-Neo2-Fir OnboardSound and additional SoundcardJohannes Goecke
On the MSI-K8T-NEO2 FIR ( Athlon-64, Socket 939 with VIA-K8T800- Chipset and onboard Sound,... ) the BIOS lets you choose "DISABLED" or "AUTO" for the On-Board Sound Device. If you add another PCI-Sound-Card the BIOS disables the on-board device. So far I have a Quirk, that does set the correspondent BIT in the PCI-registers to enable the soundcard. But how to ensure that the code is executed ONLY on excactly this kind of boards (not any other with similar Chipset)? Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Lee Revell <rlrevell@joe-job.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-14[PATCH] PCI: Add PCI quirk for SMBus on the Asus A6VA notebookJean Delvare
The Asus A6VA notebook was reported to need a PCI quirk to unhide the SMBus. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-14[PATCH] pci_ids.h: correct naming of 1022:7450 (AMD 8131 Bridge)John W. Linville
The naming of the constant defined for PCI ID 1022:7450 does not seem to match the information at http://pciids.sourceforge.net/: http://pci-ids.ucw.cz/iii/?i=1022 There 1022:7450 is listed as "AMD-8131 PCI-X Bridge" while 1022:7451 is listed as "AMD-8131 PCI-X IOAPIC". Yet, the current definition for 0x7450 is PCI_DEVICE_ID_AMD_8131_APIC. It seems to me like that name should map to 0x7451, while a name like PCI_DEVICE_ID_AMD_8131_BRIDGE should map to 0x7450. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] PCI: make MSI quirk inheritable from the pci busMichael S. Tsirkin
It turns out AMD 8131 quirk only affects MSI for devices behind the 8131 bridge. Handle this by adding a flags field in pci_bus, inherited from parent to child. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] PCI: quirk for asus a8v and a8v delux motherboardsBauke Jan Douma
On ASUS A8V and A8V Deluxe boards, the onboard AC97 audio controller and MC97 modem controller are deactivated when a second PCI soundcard is present. This patch enables them. Signed-off-by: Bauke Jan Douma <bjdouma@xs4all.nl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] PCI: SMBus unhide on HP Compaq nx6110tomek@koprowski.org
I attach a trivial patch for 2.6.15.4 that unhides SMBus controller on an HP Compaq nx6110 notebook. Signed-off-by: Tomasz Koprowski <tomek@koprowski.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] PCI: quirk for IBM Dock II cardbus controllersKristen Accardi
The IBM Dock II cardbus bridges require some extra configuration before Yenta is loaded in order to setup the Interrupts to be routed properly. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-17[PATCH] Intel ICH8 SATA: add PCI device IDsJason Gaston
Signed-off-by:  Jason Gaston <Jason.d.gaston@intel.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-09[PATCH] PCI Quirk: 1K I/O space granularity on Intel P64H2Daniel Yeisley
I've implemented a quirk to take advantage of the 1KB I/O space granularity option on the Intel P64H2 PCI Bridge. I had to change probe.c because it sets the resource start and end to be aligned on 4k boundaries (after the quirk sets them to 1k boundaries). I've tested this patch on a Unisys ES7000-600 both with and without the 1KB option enabled. I also tested this on a 2 processor Dell box that doesn't have a P64H2 to make sure there were no negative affects there. Signed-off-by: Dan Yeisley <dan.yeisley@unisys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-12-13[PATCH] add boot option to control Intel SATA/PATA combined modeJesse Barnes
Combined mode sucks. Especially when both libata and the legacy IDE drivers try to drive ports on the same device, since that makes DMA rather difficult. This patch addresses the problem by allowing the user to control which driver binds to the ports in a combined mode configuration. In many cases, they'll probably want the libata driver to control both ports since it can use DMA for talking with ATAPI devices (when libata.atapi_enabled=1 of course). It also allows the user to get old school behavior by letting the legacy IDE driver bind to both ports. But neither is forced, the patch doesn't change current behavior unless one of combined_mode=ide or combined_mode=libata is passed on the boot line. Either of those options may require you to access your devices via different device nodes (/dev/hd* in the ide case and /dev/sd* in the libata case), though of course if you have udev installed nicely you may not notice anything. :) Let me know if the documentation is too cryptic, I'd be happy to expand on it if necessary. I think most users will want to boot with 'combined_mode=libata' and add 'options libata atapi_enabled=1' to their modules.conf to get good DVD playing and disk behavior (haven't tested CD or DVD writing though). I'd much rather things behave sanely by default (i.e. DMA for devices on both ports), but apparently that's difficult given the various chip bugs and hardware configs out there (not to mention that people's drives may suddenly change from /dev/hdc to /dev/sdb), so this boot option may be the correct long term fix. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-10[PATCH] PCI: NCR 53c810 quirkIvan Kokshaysky
Move the PPC fixup for old NCR 810 controllers to generic quirks - it's needed for Alpha, x86 and other architectures that use setup-bus.c. Thanks to Jay Estabrook for pointing out the issue. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] PCI: Fix VIA 686 PCI quirk namesMeelis Roos
The quirk names for VIA 686 are mistyped in 2.6.14 (686 vs 868). S3 868 influence? :) Here is a patch to correct them. Signed-off-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-30Fix PIIX4 SMB region sizeLinus Torvalds
Petr Vandrovec correctly points out that the SMB region of the PIIX4 is just 16 bytes, not 32. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] USB: move handoff codeDavid Brownell
This moves the PCI quirk handling for USB host controllers from the PCI directory to the USB directory. Follow-on patches will need to: (a) merge these copies with the originals in the HCD reset methods. they don't wholly agree, despite doing the very same thing; and (b) eventually change it so "usb-handoff" is the default, to help get more robust USB/BIOS/input/... interactions. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/Makefile | 2 drivers/pci/quirks.c | 253 --------------------------------------- drivers/usb/Makefile | 1 drivers/usb/host/Makefile | 5 drivers/usb/host/pci-quirks.c | 272 ++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 280 insertions(+), 253 deletions(-)
2005-10-28[PATCH] PCI: Add quirk for SMBus on HP D530Jean Delvare
One more SMBus unhiding quirk, this time for the HP D530. Requested and successfully tested by Ben Cranston. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] unhide ICH6 SMBus - take 2R.Marek@sh.cvut.cz
This patch unhides hidden SMBus on ICH6 chipset installed in Asus M6V notebook. I would like to thank Michal Mleczko for testing and help. Signed-Off-By: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/pci/quirks.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
2005-10-28[PATCH] PCI: ICH6 ACPI and GPIO quirkR.Marek@sh.cvut.cz
This patch just adds ACPI and GPIO regions to its LPC bridge, similar way as ICH4 did. I would like to thank Michal Mleczko for testing. Signed-off-by: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/pci/quirks.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
2005-10-25PCI: be more verbose about resource quirksLinus Torvalds
When reserving an PCI quirk, note that in the kernel bootup messages. Also, parse the strange PIIX4 device resources - they should get their own PCI resource quirks, but for now just print out what it finds to verify that the code does the right thing. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-17[PATCH] Fix and clean up quirk_intel_ide_combined() configurationJeff Garzik
This change makes quirk_intel_ide_combined() dependent on the precise conditions under which it is needed: * IDE is built in * IDE SATA option is not set * ata_piix or ahci drivers are enabled This fixes an issue where some modular configurations would not cause the quirk to be enabled. Signed-off-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Linus torvalds <torvalds@osdl.org>
2005-09-09[PATCH] PCI: Unhide SMBus on Compaq Evo N620cRumen Ivanov Zarev
Trivial patch against 2.6.13 to unhide SMBus on Compaq Evo N620c laptop using Intel 82855PM chipset. Signed-off-by: Rumen Zarev <rzarev@caltech.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] Make sparc64 use setup-res.cDavid S. Miller
There were three changes necessary in order to allow sparc64 to use setup-res.c: 1) Sparc64 roots the PCI I/O and MEM address space using parent resources contained in the PCI controller structure. I'm actually surprised no other platforms do this, especially ones like Alpha and PPC{,64}. These resources get linked into the iomem/ioport tree when PCI controllers are probed. So the hierarchy looks like this: iomem --| PCI controller 1 MEM space --| device 1 device 2 etc. PCI controller 2 MEM space --| ... ioport --| PCI controller 1 IO space --| ... PCI controller 2 IO space --| ... You get the idea. The drivers/pci/setup-res.c code allocates using plain iomem_space and ioport_space as the root, so that wouldn't work with the above setup. So I added a pcibios_select_root() that is used to handle this. It uses the PCI controller struct's io_space and mem_space on sparc64, and io{port,mem}_resource on every other platform to keep current behavior. 2) quirk_io_region() is buggy. It takes in raw BUS view addresses and tries to use them as a PCI resource. pci_claim_resource() expects the resource to be fully formed when it gets called. The sparc64 implementation would do the translation but that's absolutely wrong, because if the same resource gets released then re-claimed we'll adjust things twice. So I fixed up quirk_io_region() to do the proper pcibios_bus_to_resource() conversion before passing it on to pci_claim_resource(). 3) I was mistakedly __init'ing the function methods the PCI controller drivers provide on sparc64 to implement some parts of these routines. This was, of course, easy to fix. So we end up with the following, and that nasty SPARC64 makefile ifdef in drivers/pci/Makefile is finally zapped. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] via vt8237 apic bypass deassertion quirkKarsten Wiese
The VIA VT8237's IOAPIC sends 'APIC De-Assert Messages' by default, causing another CPU interrupt when the IRQ pin is de-asserted. This feature is switched off by the patch to get rid of doubled ioapic level interrupt rates. Signed-off-by: Karsten Wiese <annabellesgarden@yahoo.de> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-16[PATCH] PCI: 6700/6702PXH quirkKristen Accardi
On the 6700/6702 PXH part, a MSI may get corrupted if an ACPI hotplug driver and SHPC driver in MSI mode are used together. This patch will prevent MSI from being enabled for the SHPC as part of an early pci quirk, as well as on any pci device which sets the no_msi bit. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-08[PATCH] VIA VT8235 PCI quirkIvan Kokshaysky
Like many other southbridges from different manufacturers, VIA VT8235 chip has two non-standard BARs for power management and SMBus registers (see the datasheet at http://www.via.com.tw). This new quirk routine fixes boot problem with 2.6.13-rc2/rc6 kernels on Targa Visionary 811 Athlon64 laptop, as reported by Mikael Pettersson <mikpe@csd.uu.se>. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-29[PATCH] PCI: Hidden SMBus bridge on Toshiba Tecra M2Daniele Gaffuri
Patch against 2.6.12 to unhide SMBus on Toshiba Centrino laptops using Intel 82855PM chipset. Tested on Toshiba Tecra M2. Signed-off-by: Daniele Gaffuri <d.gaffuri@reply.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-01[PATCH] PCI: Add PCI quirk for SMBus on the Asus P4B-LXJean Delvare
One more Asus motherboard requiring the SMBus quirk (P4B-LX). Original patch from Salah Coronya. Signed-off-by: Salah Coronya <salahx@yahoo.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-09[PATCH] PCI: MSI functionality broken on Serverworks GC chipsetNarendra Sankar
MSI functionality is broken on the GC_LE x86 chipset that Serverworks developed and that is being used in various platforms today. Broadcom is going to push out to the kernel MSI enabled Gigabit drivers (in the very near future), and we would like to make sure that MSI does not get enabled on any platforms using the GC_LE chipset (device id 0x17). Following the AMD 8131 example, I am including a patch to disable MSI functionality when a GCNB_LE is detected. Please let me know if there are any issues with this. This is a permanent fix for this chipset, as the hardware will not be updated. Signed-off-by: Narendra Sankar <nsankar@broadcom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-07[PATCH] PCI: do VIA IRQ fixup always, not just in PIC modeBjorn Helgaas
At least some VIA chipsets require the fixup even in IO-APIC mode. This was found and debugged with the patient assistance of Stian Jordet <liste@jordet.nu> on an Asus CUV266-DLS motherboard. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-27[PATCH] Fixup VIA IRQ quirkAlexander Nyberg
quirk_via_irqpic can't be __devinit for swsuspend Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-27[PATCH] VIA IRQ quirkLen Brown
Delete quirk_via_bridge(), restore quirk_via_irqpic() -- but now improved to be invoked upon device ENABLE, and now only for VIA devices -- not all devices behind VIA bridges. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-03[PATCH] PCI: Rapid Hance quirkR.Marek@sh.cvut.cz
This patch just adds Intel's Hance Rapid south bridge IDs to ICH4 region quirk. Patch was successfuly tested by Chunhao Huang from Winbond. Signed-Off-By: Rudolf Marek <r.marek@sh.cvut.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-03[PATCH] PCI: Clean up a lot of sparse "Should it be static?" warnings.Greg KH
2005-04-16[PATCH] ata_piix: IDE mode SATA patch for Intel ESB2Jason Gaston
This patch adds the Intel ESB2 DID's to the ata_piix.c and quirks.c file for IDE mode SATA support. Signed-off-by: Jason Gaston <Jason.d.gaston@intel.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
