path: root/drivers/pci/probe.c
2010-07-30PCI: disable mmio during bar sizingJacob Pan
It is a known issue that mmio decoding shall be disabled while doing PCI bar sizing. Host bridge and other devices (PCI PIC) shall be excluded for certain platforms. This patch mainly comes from Mathew Willcox's patch in http://kerneltrap.org/mailarchive/linux-kernel/2007/9/13/258969. A new flag bit "mmio_alway_on" is added to pci_dev with the intention that devices with their mmio decoding cannot be disabled during BAR sizing shall have this bit set, preferrablly in their quirks. Without this patch, Intel Moorestown platform graphics unit will be corrupted during bar sizing activities. Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-05-19ACPI, APEI, PCIE AER, use general HEST table parsing in AER firmware_first setupHuang Ying
Now, a dedicated HEST tabling parsing code is used for PCIE AER firmware_first setup. It is rebased on general HEST tabling parsing code of APEI. The firmware_first setup code is moved from PCI core to AER driver too, because it is only AER related. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-22PCI: revert broken device warningBjorn Helgaas
This reverts c519a5a7dab2d. That change added a warning about devices that didn't respond correctly when sizing BARs, which helped diagnose broken devices. But the test wasn't specific enough, so it also complained about working devices with zero-size BARs, e.g., https://bugzilla.kernel.org/show_bug.cgi?id=15822 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-03-24PCI: complain about devices that seem to be brokenBjorn Helgaas
If we can tell that a device isn't working correctly, we should tell the user to make debugging easier. Otherwise, it can take a lot of work to determine whether the problem is in the driver, PCMCIA, PCI, hardware, etc., as in http://bugzilla.kernel.org/show_bug.cgi?id=12006 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-03-24PCI: make disabled window printk style match the enabled onesBjorn Helgaas
No functional change; this just tweaks the changes from 349e1823a405 so the new printks for disabled PCI-to-PCI bridge windows match the ones for the enabled windows. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> CC: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-03-24PCI: break out primary/secondary/subordinate for readabilityBjorn Helgaas
No functional change; just add names for the primary/secondary/subordinate bus numbers read from config space rather than repeatedly masking/shifting. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-26PM: Allow PCI devices to suspend/resume asynchronouslyRafael J. Wysocki
Set power.async_suspend for all PCI devices and PCIe port services, so that they can be suspended and resumed in parallel with other devices they don't depend on in a known way (i.e. devices which are not their parents or children). This only affects the "regular" suspend and resume stages, which means in particular that the restoration of the PCI devices' standard configuration registers during resume will still be carried out synchronously (at the "early" resume stage). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-23PCI: augment bus resource table with a listBjorn Helgaas
Previously we used a table of size PCI_BUS_NUM_RESOURCES (16) for resources forwarded to a bus by its upstream bridge. We've increased this size several times when the table overflowed. But there's no good limit on the number of resources because host bridges and subtractive decode bridges can forward any number of ranges to their secondary buses. This patch reduces the table to only PCI_BRIDGE_RESOURCE_NUM (4) entries, which corresponds to the number of windows a PCI-to-PCI (3) or CardBus (4) bridge can positively decode. Any additional resources, e.g., PCI host bridge windows or subtractively-decoded regions, are kept in a list. I'd prefer a single list rather than this split table/list approach, but that requires simultaneous changes to every architecture. This approach only requires immediate changes where we set up (a) host bridges with more than four windows and (b) subtractive-decode P2P bridges, and we can incrementally change other architectures to use the list. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-23PCI: read bridge windows before filling in subtractive decode resourcesBjorn Helgaas
No functional change; this fills in the bus subtractive decode resources after reading the bridge window information rather than before. Also, print out the subtractive decode resources as we already do for the positive decode windows. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-23PCI: split up pci_read_bridge_bases()Bjorn Helgaas
No functional change; this breaks up pci_read_bridge_bases() into separate pieces for the I/O, memory, and prefetchable memory windows, similar to how Yinghai recently split up pci_setup_bridge() in 68e84ff3bdc. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22PCI: reject mmio ranges starting at 0 on pci_bridge readYinghai Lu
We already track unassigned resources in struct resource, and this prevents us from overwriting resource flags and info in the unassigned case. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22PCI: Make pci_scan_slot more robustMatthew Wilcox
Yinghai pointed out that the new pci_scan_slot() crashes when called on an ARI-capable slot that is empty. Fix this by exiting early from pci_scan_slot if there is no device in the slot. Also make next_ari_func() robust against devices not existing in case the ARI capability is corrupt. ARI also requires that the devices be listed in order, so if we find a function listed that is out of order, stop scanning to prevent loops. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22PCI: Add support for reporting PCIe 3.0 speedsMatthew Wilcox
Add the 8.0 GT/s speed. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22PCI: Add support for AGP in cur/max bus speedMatthew Wilcox
Take advantage of some gaps in the table to fit in support for AGP speeds. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22PCI: Add support for detection of PCIe and PCI-X bus speedsMatthew Wilcox
Both PCIe and PCI-X bridges report their secondary bus speed in their respective capabilities. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22PCI: Make current and maximum bus speeds part of the PCI coreMatthew Wilcox
Move the max_bus_speed and cur_bus_speed into the pci_bus. Expose the values through the PCI slot driver instead of the hotplug slot driver. Update all the hotplug drivers to use the pci_bus instead of their own data structures. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22PCI: Rewrite pci_scan_slotMatthew Wilcox
The Alternate Routing-ID Interpretation capability allows a single device to have up to 256 functions. They can be populated sparsely, so the current technique of scanning every eighth function is not guaranteed to find them all. By introducing a 'next_fn' function pointer, we can use the linked list of functions in the ARI capability to scan all the functions which exist. We can then speed up the pci_scan_slot by skipping the scan of subsequent devfns for PCIe devices which are the direct children of Root Ports or Downstream Ports. These devices are only permitted to implement device 0, unless they are ARI devices, in which case they'll be scanned by the ARI code above. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-01-29powerpc/pci: Add calls to set_pcie_port_type() and set_pcie_hotplug_bridge()Benjamin Herrenschmidt
We are missing these when building the pci_dev from scratch off the Open Firmware device-tree Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-12-04PCI: add pci_request_acsChris Wright
Commit ae21ee65e8bc228416bbcc8a1da01c56a847a60c "PCI: acs p2p upsteram forwarding enabling" doesn't actually enable ACS. Add a function to pci core to allow an IOMMU to request that ACS be enabled. The existing mechanism of using iommu_found() in the pci core to know when ACS should be enabled doesn't actually work due to initialization order; iommu has only been detected not initialized. Have Intel and AMD IOMMUs request ACS, and Xen does as well during early init of dom0. Cc: Allen Kay <allen.m.kay@intel.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-24PCI: use pci_pcie_cap() in pci coreKenji Kaneshige
Use pcie_cap() instead of pci_find_capability() to get PCIe capability offset in PCI core code. This avoids unnecessary search in PCI configuration space. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-06PCI: cache PCIe capability offsetKenji Kaneshige
There are a lot of codes that searches PCI express capability offset in the PCI configuration space using pci_find_capability(). Caching it in the struct pci_dev will reduce unncecessary search. This patch adds an additional 'pcie_cap' fields into struct pci_dev, which is initialized at pci device scan time (in set_pcie_port_type()). Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: improve discovery/configuration messagesBjorn Helgaas
This makes PCI resource management messages more consistent and adds a few new messages to aid debugging. Whenever we assign resources to a device, update a BAR, or change a bridge aperture, it's worth noting it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: replace pr_debug with dev_dbgBjorn Helgaas
Since we have a struct device, we might as well use dev_printk. Note that both pr_debug() and dev_dbg() are completely compiled out unless DEBUG or DYNAMIC_DEBUG is defined. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04vsprintf: use %pR, %pr instead of %pRt, %pRfBjorn Helgaas
Jesse accidentally applied v1 [1] of the patchset instead of v2 [2]. This is the diff between v1 and v2. The changes in this patch are: - tidied vsprintf stack buffer to shrink and compute size more accurately - use %pR for decoding and %pr for "raw" (with type and flags) instead of adding %pRt and %pRf [1] http://lkml.org/lkml/2009/10/6/491 [2] http://lkml.org/lkml/2009/10/13/441 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: populate subsystem vendor and device IDs for PCI bridgesGabe Black
Change to populate the subsystem vendor and subsytem device IDs for PCI-PCI bridges that implement the PCI Subsystem Vendor ID capability. Previously bridges left subsystem vendor IDs unpopulated. Signed-off-by: Gabe Black <gabe.black@ni.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: PCIe AER: honor ACPI HEST FIRMWARE FIRST modeMatt Domsch
Feedback from Hidetoshi Seto and Kenji Kaneshige incorporated. This correctly handles PCI-X bridges, PCIe root ports and endpoints, and prints debug messages when invalid/reserved types are found in the HEST. PCI devices not in domain/segment 0 are not represented in HEST, thus will be ignored. Today, the PCIe Advanced Error Reporting (AER) driver attaches itself to every PCIe root port for which BIOS reports it should, via ACPI _OSC. However, _OSC alone is insufficient for newer BIOSes. Part of ACPI 4.0 is the new APEI (ACPI Platform Error Interfaces) which is a way for OS and BIOS to handshake over which errors for which components each will handle. One table in ACPI 4.0 is the Hardware Error Source Table (HEST), where BIOS can define that errors for certain PCIe devices (or all devices), should be handled by BIOS ("Firmware First mode"), rather than be handled by the OS. Dell PowerEdge 11G server BIOS defines Firmware First mode in HEST, so that it may manage such errors, log them to the System Event Log, and possibly take other actions. The aer driver should honor this, and not attach itself to devices noted as such. Furthermore, Kenji Kaneshige reminded us to disallow changing the AER registers when respecting Firmware First mode. Platform firmware is expected to manage these, and if changes to them are allowed, it could break that firmware's behavior. The HEST parsing code may be replaced in the future by a more feature-rich implementation. This patch provides the minimum needed to prevent breakage until that implementation is available. Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: fix nit in ROM BAR size probingMichael S. Tsirkin
When probing for ROM BAR size, we should not change bits 1:10 in this BAR, because these bits are marked as "reserved for future use" in PCI spec, so changing them might have side effects. No such issue for I/O or memory, as there is an implementation note in PCI spec which explicitly allows writing 0xfffffffff there. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: add xen dom0 checking before ACS initializationAllen Kay
This patch is predicated on Jeremy's patch in include/xen/xen.h. It'll prevent ACS init unless the platform has both an IOMMU and we're running as dom0. Signed-off-by: Allen Kay <allen.m.kay@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: acs p2p upsteram forwarding enablingAllen Kay
Note: dom0 checking in v4 has been separated out into 2/2. This patch enables P2P upstream forwarding in ACS capable PCIe switches. It solves two potential problems in virtualization environment where a PCIe device is assigned to a guest domain using a HW iommu such as VT-d: 1) Unintentional failure caused by guest physical address programmed into the device's DMA that happens to match the memory address range of other downstream ports in the same PCIe switch. This causes the PCI transaction to go to the matching downstream port instead of go to the root complex to get translated by VT-d as it should be. 2) Malicious guest software intentionally attacks another downstream PCIe device by programming the DMA address into the assigned device that matches memory address range of the downstream PCIe port. We are in process of implementing device filtering software in KVM/XEN management software to allow device assignment of PCIe devices behind a PCIe switch only if it has ACS capability and with the P2P upstream forwarding bits enabled. This patch is intended to work for both KVM and Xen environments. Signed-off-by: Allen Kay <allen.m.kay@intel.com> Reviewed-by: Mathew Wilcox <willy@linux.intel.com> Reviewed-by: Chris Wright <chris@sous-sol.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PCI: print resources consistently with %pRtBjorn Helgaas
This uses %pRt to print additional resource information (type, size, prefetchability, etc.) consistently. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-14PCI: Clear saved_state after the state has been restoredRafael J. Wysocki
Some PCI devices fail if their standard configuration registers are restored twice in a row. Prevent this from happening by making pci_restore_state() clear the saved_state flag of the device right after the device's standard configuration registers have been populated with the previously saved values. Simplify PCI PM callbacks by removing the direct clearing of state_saved from them, as it shouldn't be necessary any more (except in pci_pm_thaw(), where it has to be cleared, so that the values saved during the "freeze" phase of hibernation are not used later by mistake). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI: pcie: Ensure hotplug ports have a minimum number of resourcesEric W. Biederman
In general a BIOS may goof or we may hotplug in a hotplug controller. In either case the kernel needs to reserve resources for plugging in more devices in the future instead of creating a minimal resource assignment. We already do this for cardbus bridges I am just adding a variant for pcie bridges. v2: Make testing for pcie hotplug bridges based on a flag. So far we only set the flag for pcie but a header_quirk could easily be added for the non-standard pci hotplug bridges. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI: print out pref if mmio is prefetchableYinghai Lu
We already print it out for pci bridges, so also print it out for pci devices. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09PCI: remove pcibios_scan_all_fns()Alex Chiang
This was #define'd as 0 on all platforms, so let's get rid of it. This change makes pci_scan_slot() slightly easier to read. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Russell King <linux@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-16PCI: use pci_is_root_bus() in pci_read_bridge_bases()Kenji Kaneshige
Use pci_is_root_bus() in pci_read_bridge_bases() to check if the pci bus is root, for code consistency. Reviewed-by: Alex Chiang <achiang@hp.com> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-11PCI/x86: don't assume prefetchable ranges are 64bitYinghai Lu
We should not assign 64bit ranges to PCI devices that only take 32bit prefetchable addresses. Try to set IORESOURCE_MEM_64 in 64bit resource of pci_device/pci_bridge and make the bus resource only have that bit set when all devices under it support 64bit prefetchable memory. Use that flag to allocate resources from that range. Reported-by: Yannick <yannick.roehlly@free.fr> Reviewed-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-04PCI: use fixed-up device class when configuring deviceYu Zhao
The device class may be changed after the fixup, so re-read the class value from pci_dev when configuring the device. Otherwise some devices such as JMicron SATA controller won't work. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Tested-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-04-22x86/PCI: Move set_pci_bus_resources_arch_default into arch/x86Matthew Wilcox
Commit 30a18d6c3f1e774de656ebd8ff219d53e2ba4029 introduced a new function to set the PCI bus resources. Unfortunately, neither the author, nor the committers seemed to know that we already have somewhere to do that -- pcibios_fixup_bus(). This patch moves the hook (used only by the K8 code) into x86-specific code where it should have been in the first place. Cc: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-04-06PCI: annotate pci_rescan_bus as __ref, not __devinitAlex Chiang
pci_rescan_bus was annotated as __devinit, which is wrong, because it will never be part of device initialization. Howevever, we can't simply drop the annotation, because then we get section warnings about calling pci_scan_child_bus (which is correctly marked as __devinit). pci_rescan_bus will only get built when CONFIG_HOTPLUG is set, meaning that __devinit is a nop, so we know that pci_scan_child_bus has not been freed. Annotate as __ref to silence modpost. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-26PCI: fix conflict between SR-IOV and config space sizingYu Zhao
New pci_cfg_space_size() needs invalid pdev->class, put it in the right place in the pci_setup_device(). Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: Introduce /sys/bus/pci/rescanAlex Chiang
This interface allows the user to force a rescan of all PCI buses in system, and rediscover devices that have been removed earlier. pci_bus_attrs implementation from Trent Piepho. Thanks to Vegard Nossum for discovering locking issues with the sysfs interface. Cc: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: Introduce pci_rescan_bus()Alex Chiang
This API is used by the PCI core to rescan a bus and rediscover newly added devices. Over time, it is expected that the various PCI hotplug drivers will migrate to this interface and away from the old pci_do_scan_bus() interface. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: always scan child busesAlex Chiang
While scanning bridges, we stop our scan if we encounter a bus that we've seen before, to work around some buggy chipsets. This is a good idea, but prevents us from fully scanning the PCI bus at a future time (to find newly hot-added devices, for example). Change the logic so that we skip _re-adding_ an existing bus that we've seen before, but also allow the scan to descend to all child buses. Now that we're potentially scanning our child buses again, we also need to be sure not to attempt re-initializing their BARs so we avoid that. This patch lays the groundwork to allow the user to issue a rescan of the PCI bus at any time. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: pci_scan_slot() returns newly found devicesTrent Piepho
pci_scan_slot() has been rewritten to be less complex and will now return the number of *new* devices found. Existing callers need not worry because they already assume that they can't call pci_scan_slot() on an already-scanned slot. Thus, there is no semantic change for existing callers: returning newly found devices (this patch) is exactly equal to returning all found devices (before this patch). This patch adds some more groundwork to allow us to rescan the PCI bus during runtime to discover newly added devices. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: don't scan existing devicesTrent Piepho
pci_scan_single_device is supposed to add newly discovered devices to pci_bus->devices, but doesn't check to see if the device has already been added. This can cause problems if we ever want to use this interface to rescan the PCI bus. If the device is already added, just return it. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: centralize device setup codeYu Zhao
Move the device setup stuff into pci_setup_device() which will be used to setup the Virtual Function later. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: reserve bus range for SR-IOV deviceYu Zhao
Reserve the bus number range used by the Virtual Function when pcibios_assign_all_busses() returns true. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: initialize and release SR-IOV capabilityYu Zhao
If a device has the SR-IOV capability, initialize it (set the ARI Capable Hierarchy in the lowest numbered PF if necessary; calculate the System Page Size for the VF MMIO, probe the VF Offset, Stride and BARs). A lock for the VF bus allocation is also initialized if a PF is the lowest numbered PF. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI/x86: detect host bridge config space size w/o using quirksYinghai Lu
Many host bridges support a 4k config space, so check them directy instead of using quirks to add them. We only need to do this extra check for host bridges at this point, because only host bridges are known to have extended address space without also having a PCI-X/PCI-E caps. Other devices with this property could be done with quirks (if there are any). As a bonus, we can remove the quirks for AMD host bridges with family 10h and 11h since they're not needed any more. With this patch, we can get correct pci cfg size of new Intel CPUs/IOHs with host bridges. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Cc: <stable@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: Use kzalloc() in pci_create_bus()Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
