path: root/drivers/pci/pci.h
2005-09-09[PATCH] PCI: Small rearrangement of PCI probing codePaul Mackerras
This patch makes some small rearrangements of the PCI probing code in order to make it possible for arch code to set up the PCI tree without needing to duplicate code from the PCI layer unnecessarily. PPC64 will use this to set up the PCI tree from the Open Firmware device tree, which we need to do on logically-partitioned pSeries systems. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-16[PATCH] PCI: fix quirk-6700-fix.patchAndrew Morton
drivers/built-in.o(.text+0x32c3): In function `quirk_pcie_pxh': /usr/src/25/drivers/pci/quirks.c:1312: undefined reference to `disable_msi_mode' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-16[PATCH] PCI: 6700/6702PXH quirkKristen Accardi
On the 6700/6702 PXH part, a MSI may get corrupted if an ACPI hotplug driver and SHPC driver in MSI mode are used together. This patch will prevent MSI from being enabled for the SHPC as part of an early pci quirk, as well as on any pci device which sets the no_msi bit. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-11[ACPI] pci_set_power_state() now callsDavid Shaohua Li
platform_pci_set_power_state() and ACPI can answer http://bugzilla.kernel.org/show_bug.cgi?id=4277 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[ACPI] PCI can now get suspend state from firmwareDavid Shaohua Li
pci_choose_state() can now call platform_pci_choose_state() and ACPI can answer http://bugzilla.kernel.org/show_bug.cgi?id=4277 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-05-17[PATCH] PCI Hotplug: remove pci_visit_devScott Murray
If my CPCI hotplug update patch is applied, then there are no longer any in tree users of the pci_visit_dev API, and it and its related code can be removed. Signed-off-by: Scott Murray <scottm@somanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
