path: root/drivers/pci/pci-acpi.c
2017-10-05ACPI / PCI: Bail early in acpi_pci_add_bus() if there is no ACPI handleVitaly Kuznetsov
Hyper-V instances support PCI pass-through which is implemented through PV pci-hyperv driver. When a device is passed through, a new root PCI bus is created in the guest. The bus sits on top of VMBus and has no associated information in ACPI. acpi_pci_add_bus() in this case proceeds all the way to acpi_evaluate_dsm(), which reports ACPI: \: failed to evaluate _DSM (0x1001) While acpi_pci_slot_enumerate() and acpiphp_enumerate_slots() are protected against ACPI_HANDLE() being NULL and do nothing, acpi_evaluate_dsm() is not and gives us the error. It seems the correct fix is to not do anything in acpi_pci_add_bus() in such cases. Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2017-08-01ACPI / PCI / PM: Rework acpi_pci_propagate_wakeup()Rafael J. Wysocki
The acpi_pci_propagate_wakeup() routine is there to handle cases in which PCI bridges (or PCIe ports) are expected to signal wakeup for devices below them, but currently it doesn't do that correctly. The problem is that acpi_pci_propagate_wakeup() uses acpi_pm_set_device_wakeup() for bridges and if that routine is called for multiple times to disable wakeup for the same device, it will disable it on the first invocation and the next calls will have no effect (it works analogously when called to enable wakeup, but that is not a problem). Now, say acpi_pci_propagate_wakeup() has been called for two different devices under the same bridge and it has called acpi_pm_set_device_wakeup() for that bridge each time. The bridge is now enabled to generate wakeup signals. Next, suppose that one of the devices below it resumes and acpi_pci_propagate_wakeup() is called to disable wakeup for that device. It will then call acpi_pm_set_device_wakeup() for the bridge and that will effectively disable remote wakeup for all devices under it even though some of them may still be suspended and remote wakeup may be expected to work for them. To address this (arguably theoretical) issue, allow wakeup.enable_count under struct acpi_device to grow beyond 1 in certain situations. In particular, allow that to happen in acpi_pci_propagate_wakeup() when wakeup is enabled or disabled for PCI bridges, so that wakeup is actually disabled for the bridge when all devices under it resume and not when just one of them does that. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2017-06-28PM / core: Drop run_wake flag from struct dev_pm_infoRafael J. Wysocki
The run_wake flag in struct dev_pm_info is used to indicate whether or not the device is capable of generating remote wakeup signals at run time (or in the system working state), but the distinction between runtime remote wakeup and system wakeup signaling has always been rather artificial. The only practical reason for it to exist at the core level was that ACPI and PCI treated those two cases differently, but that's not the case any more after recent changes. For this reason, get rid of the run_wake flag and, when applicable, use device_set_wakeup_capable() and device_can_wakeup() instead of device_set_run_wake() and device_run_wake(), respectively. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2017-06-28PCI / PM: Simplify device wakeup settings codeRafael J. Wysocki
After previous changes it is not necessary to distinguish between device wakeup for run time and device wakeup from system sleep states any more, so rework the PCI device wakeup settings code accordingly. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2017-06-28PCI / PM: Drop pme_interrupt flag from struct pci_devRafael J. Wysocki
The pme_interrupt flag in struct pci_dev is set when PMEs generated by the device are going to be signaled via root port PME interrupts. Ironically enough, that information is only used by the code setting up device wakeup through ACPI which returns as soon as it sees the pme_interrupt flag set while setting up "remote runtime wakeup". That is questionable, however, because in theory there may be PCIe devices using out-of-band PME signaling under root ports handled by the native PME code or devices requiring wakeup power setup to be carried out by AML. For such devices, ACPI wakeup should be invoked regardless of whether or not native PME signaling is used in general. For this reason, drop the pme_interrupt flag and rework the code using it which then allows the ACPI-based device wakeup handling in PCI to be consolidated to use one code path for both "runtime remote wakeup" and system wakeup (from sleep states). Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2017-06-28ACPI / PM: Consolidate device wakeup settings codeRafael J. Wysocki
Currently, there are two separate ways of handling device wakeup settings in the ACPI core, depending on whether this is runtime wakeup or system wakeup (from sleep states). However, after the previous commit eliminating the run_wake ACPI device wakeup flag, there is no difference between the two any more at the ACPI level, so they can be combined. For this reason, introduce acpi_pm_set_device_wakeup() to replace both acpi_pm_device_run_wake() and acpi_pm_device_sleep_wake() and make it check the ACPI device object's wakeup.valid flag to determine whether or not the device can be set up to generate wakeup signals. Also notice that zpodd_enable/disable_run_wake() only call device_set_run_wake() because acpi_pm_device_run_wake() called device_run_wake(), which is not done by acpi_pm_set_device_wakeup(), so drop the now redundant device_set_run_wake() calls from there. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2017-06-28ACPI / PM: Drop run_wake from struct acpi_device_wakeup_flagsRafael J. Wysocki
The run_wake flag in struct acpi_device_wakeup_flags stores the information on whether or not the device can generate wakeup signals at run time, but in ACPI that really is equivalent to being able to generate wakeup signals at all. In fact, run_wake will always be set after successful executeion of acpi_setup_gpe_for_wake(), but if that fails, the device will not be able to use a wakeup GPE at all, so it won't be able to wake up the systems from sleep states too. Hence, run_wake actually means that the device is capable of triggering wakeup and so it is equivalent to the valid flag. For this reason, drop run_wake from struct acpi_device_wakeup_flags and make sure that the valid flag is only set if acpi_setup_gpe_for_wake() has been successful. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2017-06-22Merge branch 'uuid-types'Rafael J. Wysocki
Merge branch 'uuid-types' from git://git.infradead.org/users/hch/uuid.git to satisfy dependencies.
2017-06-15ACPI / PM: Run wakeup notify handlers synchronouslyRafael J. Wysocki
The work functions provided by the users of acpi_add_pm_notifier() should be run synchronously before re-enabling the wakeup GPE in case they are used to clear the status and/or disable the wakeup signaling at the source. Otherwise, which is the case currently in the PCI bus type code, the same wakeup event may be signaled for multiple times while the execution of the work function in response to it has already been queued up. Fortunately, acpi_add_pm_notifier() is only used by PCI and by ACPI device PM code internally, so the change is relatively straightforward to make. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2017-06-07ACPI: Switch to use generic guid_t in acpi_evaluate_dsm()Andy Shevchenko
acpi_evaluate_dsm() and friends take a pointer to a raw buffer of 16 bytes. Instead we convert them to use guid_t type. At the same time we convert current users. acpi_str_to_uuid() becomes useless after the conversion and it's safe to get rid of it. Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Borislav Petkov <bp@suse.de> Acked-by: Dan Williams <dan.j.williams@intel.com> Cc: Amir Goldstein <amir73il@gmail.com> Reviewed-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Acked-by: Jani Nikula <jani.nikula@intel.com> Cc: Ben Skeggs <bskeggs@redhat.com> Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Acked-by: Joerg Roedel <jroedel@suse.de> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Yisen Zhuang <yisen.zhuang@huawei.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com> Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com> Reviewed-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Acked-by: Mark Brown <broonie@kernel.org> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2016-12-12Merge branch 'pci/pm' into nextBjorn Helgaas
* pci/pm: x86/platform/intel-mid: Constify mid_pci_platform_pm PCI: pciehp: Add runtime PM support for PCIe hotplug ports ACPI / hotplug / PCI: Make device_is_managed_by_native_pciehp() public ACPI / hotplug / PCI: Use cached copy of PCI_EXP_SLTCAP_HPC bit PCI: Unfold conditions to block runtime PM on PCIe ports PCI: Consolidate conditions to allow runtime PM on PCIe ports PCI: Activate runtime PM on a PCIe port only if it can suspend PCI: Speed up algorithm in pci_bridge_d3_update() PCI: Autosense device removal in pci_bridge_d3_update() PCI: Don't acquire ref on parent in pci_bridge_d3_update() USB: UHCI: report non-PME wakeup signalling for Intel hardware PCI: Check for PME in targeted sleep state
2016-12-06PCI/ACPI: Provide acpi_get_rc_resources() for ARM64 platformDongdong Liu
The acpi_get_rc_resources() is used to get the RC register address that can not be described in MCFG. It takes the _HID & segment to look for and outputs the RC address resource. Use PNP0C02 devices to describe such RC address resource. Use _UID to match segment to tell which root bus the PNP0C02 resource belongs to. [bhelgaas: add dev argument, wrap in #ifdef CONFIG_PCI_QUIRKS] Signed-off-by: Dongdong Liu <liudongdong3@huawei.com> Signed-off-by: Tomasz Nowicki <tn@semihalf.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2016-11-17ACPI / hotplug / PCI: Make device_is_managed_by_native_pciehp() publicLukas Wunner
We're about to add runtime PM of hotplug ports, but we need to restrict it to ports that are handled natively by the OS: If they're handled by the firmware (which is the case for Thunderbolt on non-Macs), things would break if the OS put the ports into D3hot behind the firmware's back. To determine if a hotplug port is handled natively, one has to walk up from the port to the root bridge and check the cached _OSC Control Field for the value of the "PCI Express Native Hot Plug control" bit. There's already a function to do that, device_is_managed_by_native_pciehp(), but it's private to drivers/pci/hotplug/acpiphp_glue.c and only compiled in if CONFIG_HOTPLUG_PCI_ACPI is enabled. Make it public and move it to drivers/pci/pci-acpi.c, so that it is available in the more general CONFIG_ACPI case. The function contains a check if the device in question is a hotplug port and returns false if it's not. The caller we're going to add doesn't need this as it only calls the function if it actually *is* a hotplug port. Move the check out of the function into the single existing caller. Rename it to pciehp_is_native() and add some kerneldoc and polish. No functional change intended. Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Lukas Wunner <lukas@wunner.de> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-09-28PCI: Query platform firmware for device power stateLukas Wunner
Usually the most accurate way to determine a PCI device's power state is to read its PM Control & Status Register. There are two cases however when this is not an option: If the device doesn't have the PM capability at all, or if it is in D3cold (in which case its config space is inaccessible). In both cases, we can alternatively query the platform firmware for its opinion on the device's power state. To facilitate this, augment struct pci_platform_pm_ops with a ->get_power callback and implement it for acpi_pci_platform_pm (the only pci_platform_pm_ops existing so far). It is used by a forthcoming commit to let pci_update_current_state() recognize D3cold. Signed-off-by: Lukas Wunner <lukas@wunner.de> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-01-12Merge tag 'pm+acpi-4.5-rc1-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull oower management and ACPI updates from Rafael Wysocki: "As far as the number of commits goes, ACPICA takes the lead this time, followed by cpufreq and the device properties framework changes. The most significant new feature is the debugfs-based interface to the ACPICA's AML debugger added in the previous cycle and a new user space tool for accessing it. On the cpufreq front, the core is updated to handle governors more efficiently, particularly on systems where a single cpufreq policy object is shared between multiple CPUs, and there are quite a few changes in drivers (intel_pstate, cpufreq-dt etc). The device properties framework is updated to handle built-in (ie included in the kernel itself) device properties better, among other things by adding a fallback mechanism that will allow drivers to provide default properties to be used in case the plaform firmware doesn't provide the properties expected by them. The Operating Performance Points (OPP) framework gets new DT bindings and debugfs support. A new cpufreq driver for ST platforms is added and the ACPI driver for AMD SoCs will now support the APM X-Gene ACPI I2C device. The rest is mostly fixes and cleanups all over. Specifics: - Add a debugfs-based interface for interacting with the ACPICA's AML debugger introduced in the previous cycle and a new user space tool for that, fix some bugs related to the AML debugger and clean up the code in question (Lv Zheng, Dan Carpenter, Colin Ian King, Markus Elfring). - Update ACPICA to upstream revision 20151218 including a number of fixes and cleanups in the ACPICA core (Bob Moore, Lv Zheng, Labbe Corentin, Prarit Bhargava, Colin Ian King, David E Box, Rafael Wysocki). In particular, the previously added erroneous support for the _SUB object is dropped, the concatenate operator will support all ACPI objects now, the Debug Object handling is improved, the SuperName handling of parameters being control methods is fixed, the ObjectType operator handling is updated to follow ACPI 5.0A and the handling of CondRefOf and RefOf is updated accordingly, module- level code will be executed after loading each ACPI table now (instead of being run once after all tables containing AML have been loaded), the Operation Region handlers management is updated to fix some reported problems and a the ACPICA code in the kernel is more in line with the upstream now. - Update the ACPI backlight driver to provide information on whether or not it will generate key-presses for brightness change hotkeys and update some platform drivers (dell-wmi, thinkpad_acpi) to use that information to avoid sending double key-events to users pace for these, add new ACPI backlight quirks (Hans de Goede, Aaron Lu, Adrien Schildknecht). - Improve the ACPI handling of interrupt GPIOs (Christophe Ricard). - Fix the handling of the list of device IDs of device objects found in the ACPI namespace and add a helper for checking if there is a device object for a given device ID (Lukas Wunner). - Change the logic in the ACPI namespace scanning code to create struct acpi_device objects for all ACPI device objects found in the namespace even if _STA fails for them which helps to avoid device enumeration problems on Microsoft Surface 3 (Aaron Lu). - Add support for the APM X-Gene ACPI I2C device to the ACPI driver for AMD SoCs (Loc Ho). - Fix the long-standing issue with the DMA controller on Intel SoCs where ACPI tables have no power management support for the DMA controller itself, but it can be powered off automatically when the last (other) device on the SoC is powered off via ACPI and clean up the ACPI driver for Intel SoCs (acpi-lpss) after previous attempts to fix that problem (Andy Shevchenko). - Assorted ACPI fixes and cleanups (Andy Lutomirski, Colin Ian King, Javier Martinez Canillas, Ken Xue, Mathias Krause, Rafael Wysocki, Sinan Kaya). - Update the device properties framework for better handling of built-in properties, add support for built-in properties to the platform bus type, update the MFD subsystem's handling of device properties and add support for passing default configuration data as device properties to the intel-lpss MFD drivers, convert the designware I2C driver to use the unified device properties API and add a fallback mechanism for using default built-in properties if the platform firmware fails to provide the properties as expected by drivers (Andy Shevchenko, Mika Westerberg, Heikki Krogerus, Andrew Morton). - Add new Device Tree bindings to the Operating Performance Points (OPP) framework and update the exynos4412 DT binding accordingly, introduce debugfs support for the OPP framework (Viresh Kumar, Bartlomiej Zolnierkiewicz). - Migrate the mt8173 cpufreq driver to the new OPP bindings (Pi-Cheng Chen). - Update the cpufreq core to make the handling of governors more efficient, especially on systems where policy objects are shared between multiple CPUs (Viresh Kumar, Rafael Wysocki). - Fix cpufreq governor handling on configurations with CONFIG_HZ_PERIODIC set (Chen Yu). - Clean up the cpufreq core code related to the boost sysfs knob support and update the ACPI cpufreq driver accordingly (Rafael Wysocki). - Add a new cpufreq driver for ST platforms and corresponding Device Tree bindings (Lee Jones). - Update the intel_pstate driver to allow the P-state selection algorithm used by it to depend on the CPU ID of the processor it is running on, make it use a special P-state selection algorithm (with an IO wait time compensation tweak) on Atom CPUs based on the Airmont and Silvermont cores so as to reduce their energy consumption and improve intel_pstate documentation (Philippe Longepe, Srinivas Pandruvada). - Update the cpufreq-dt driver to support registering cooling devices that use the (P * V^2 * f) dynamic power draw formula where V is the voltage, f is the frequency and P is a constant coefficient provided by Device Tree and update the arm_big_little cpufreq driver to use that support (Punit Agrawal). - Assorted cpufreq driver (cpufreq-dt, qoriq, pcc-cpufreq, blackfin-cpufreq) updates (Andrzej Hajda, Hongtao Jia, Jacob Tanenbaum, Markus Elfring). - cpuidle core tweaks related to polling and measured_us calculation (Rik van Riel). - Removal of modularity from a few cpuidle drivers (clps711x, ux500, exynos) that cannot be built as modules in practice (Paul Gortmaker). - PM core update to prevent devices from being probed during system suspend/resume which is generally problematic and may lead to inconsistent behavior (Grygorii Strashko). - Assorted updates of the PM core and related code (Julia Lawall, Manuel Pégourié-Gonnard, Maruthi Bayyavarapu, Rafael Wysocki, Ulf Hansson). - PNP bus type updates (Christophe Le Roy, Heiner Kallweit). - PCI PM code cleanups (Jarkko Nikula, Julia Lawall). - cpupower tool updates (Jacob Tanenbaum, Thomas Renninger)" * tag 'pm+acpi-4.5-rc1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (177 commits) PM / clk: don't leave clocks enabled when driver not bound i2c: dw: Add APM X-Gene ACPI I2C device support ACPI / APD: Add APM X-Gene ACPI I2C device support ACPI / LPSS: change 'does not have' to 'has' in comment Revert "dmaengine: dw: platform: provide platform data for Intel" dmaengine: dw: return immediately from IRQ when DMA isn't in use dmaengine: dw: platform: power on device on shutdown ACPI / LPSS: override power state for LPSS DMA device PM / OPP: Use snprintf() instead of sprintf() Documentation: cpufreq: intel_pstate: enhance documentation ACPI, PCI, irq: remove redundant check for null string pointer ACPI / video: driver must be registered before checking for keypresses cpufreq-dt: fix handling regulator_get_voltage() result cpufreq: governor: Fix negative idle_time when configured with CONFIG_HZ_PERIODIC PM / sleep: Add support for read-only sysfs attributes ACPI: Fix white space in a structure definition ACPI / SBS: fix inconsistent indenting inside if statement PNP: respect PNP_DRIVER_RES_DO_NOT_CHANGE when detaching ACPI / PNP: constify device IDs ACPI / PCI: Simplify acpi_penalize_isa_irq() ...
2015-12-21acpi: pci: Setup MSI domain for ACPI based pci devicesSuravee Suthikulpanit
This patch introduces pci_msi_register_fwnode_provider() for irqchip to register a callback, to provide a way to determine appropriate MSI domain for a pci device. It also introduces pci_host_bridge_acpi_msi_domain(), which returns the MSI domain of the specified PCI host bridge with DOMAIN_BUS_PCI_MSI bus token. Then, it is assigned to pci device. Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rjw@rjwysocki.net> Signed-off-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-12-09PCI / PM: constify pci_platform_pm_ops structureJulia Lawall
The pci_platform_pm_ops structure is never modified, so declare it as const. Done with the help of Coccinelle. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-15PCI / ACPI: Fix pci_acpi_optimize_delay() commentSrinidhi Kasagar
The function takes ACPI handle, not the device itself. Fix the comment Signed-off-by: Srinidhi Kasagar <srinidhi.kasagar@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2015-05-16ACPI / PM: Rework device power management to follow ACPI 6Rafael J. Wysocki
The ACPI 6 specification has made some changes in the device power management area. In particular: * The D3hot power state is now supposed to be always available (instead of D3cold) and D3cold is only regarded as valid if the _PR3 object is present for the given device. * The required ordering of transitions into power states deeper than D0 is now such that for a transition into state Dx the _PSx method is supposed to be executed first, if present, and the states of the power resources the device depends on are supposed to be changed after that. * It is now explicitly forbidden to transition devices from lower-power (deeper) into higher-power (shallower) power states other than D0. Those changes have been made so the specification reflects the Windows' device power management code that the vast majority of systems using ACPI is validated against. To avoid artificial differences in ACPI device power management between Windows and Linux, modify the ACPI device power management code to follow the new specification. Add comments explaining the code flow in some unclear places. This only may affect some real corner cases in which the OS behavior expected by the firmware is different from the Windows one, but that's quite unlikely. The transition ordering change affects transitions to D1 and D2 which are rarely used (if at all) and into D3hot and D3cold for devices actually having _PR3, but those are likely to be validated against Windows anyway. The other changes may affect code calling acpi_device_get_power() or acpi_device_update_power() where ACPI_STATE_D3_HOT may be returned instead of ACPI_STATE_D3_COLD (that's why the ACPI fan driver needs to be updated too) and since transitions into ACPI_STATE_D3_HOT may remove power now, it is better to avoid this one in acpi_pm_device_sleep_state() if the "no power off" PM QoS flag is set. The only existing user of acpi_device_can_poweroff() really cares about the case when _PR3 is present, so the change in that function should not cause any problems to happen too. A plus is that PCI_D3hot can be mapped to ACPI_STATE_D3_HOT now and the compatibility with older systems should be covered automatically. In any case, if any real problems result from this, it still will be better to follow the Windows' behavior (which now is reflected by the specification too) in general and handle the cases when it doesn't work via quirks. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-04-13Merge tag 'pci-v4.1-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "Enumeration - Read capability list as dwords, not bytes (Sean O. Stalley) Resource management - Don't check for PNP overlaps with unassigned PCI BARs (Bjorn Helgaas) - Mark invalid BARs as unassigned (Bjorn Helgaas) - Show driver, BAR#, and resource on pci_ioremap_bar() failure (Bjorn Helgaas) - Fail pci_ioremap_bar() on unassigned resources (Bjorn Helgaas) - Assign resources before drivers claim devices (Yijing Wang) - Claim bus resources before pci_bus_add_devices() (Yijing Wang) Power management - Optimize device state transition delays (Aaron Lu) - Don't clear ASPM bits when the FADT declares it's unsupported (Matthew Garrett) Virtualization - Add ACS quirks for Intel 1G NICs (Alex Williamson) IOMMU - Add ptr to OF node arg to of_iommu_configure() (Murali Karicheri) - Move of_dma_configure() to device.c to help re-use (Murali Karicheri) - Fix size when dma-range is not used (Murali Karicheri) - Add helper functions pci_get[put]_host_bridge_device() (Murali Karicheri) - Add of_pci_dma_configure() to update DMA configuration (Murali Karicheri) - Update DMA configuration from DT (Murali Karicheri) - dma-mapping: limit IOMMU mapping size (Murali Karicheri) - Calculate device DMA masks based on DT dma-range size (Murali Karicheri) ARM Versatile host bridge driver - Check for devm_ioremap_resource() failures (Jisheng Zhang) Broadcom iProc host bridge driver - Add Broadcom iProc PCIe driver (Ray Jui) Marvell MVEBU host bridge driver - Add suspend/resume support (Thomas Petazzoni) Renesas R-Car host bridge driver - Fix position of MSI enable bit (Nobuhiro Iwamatsu) - Write zeroes to reserved PCIEPARL bits (Nobuhiro Iwamatsu) - Change PCIEPARL and PCIEPARH to PCIEPALR and PCIEPAUR (Nobuhiro Iwamatsu) - Verify that mem_res is 64K-aligned (Nobuhiro Iwamatsu) Samsung Exynos host bridge driver - Fix INTx enablement statement termination error (Jaehoon Chung) Miscellaneous - Make a shareable UUID for PCI firmware ACPI _DSM (Aaron Lu) - Clarify policy for vendor IDs in pci.txt (Michael S. Tsirkin)" * tag 'pci-v4.1-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (36 commits) PCI: Read capability list as dwords, not bytes PCI: layerscape: Simplify platform_get_resource_byname() failure checking PCI: keystone: Don't dereference possible NULL pointer PCI: versatile: Check for devm_ioremap_resource() failures PCI: Don't clear ASPM bits when the FADT declares it's unsupported PCI: Clarify policy for vendor IDs in pci.txt PCI/ACPI: Optimize device state transition delays PCI: Export pci_find_host_bridge() for use inside PCI core PCI: Make a shareable UUID for PCI firmware ACPI _DSM PCI: Fix typo in Thunderbolt kernel message PCI: exynos: Fix INTx enablement statement termination error PCI: iproc: Add Broadcom iProc PCIe support PCI: iproc: Add DT docs for Broadcom iProc PCIe driver PCI: Export symbols required for loadable host driver modules PCI: Add ACS quirks for Intel 1G NICs PCI: mvebu: Add suspend/resume support PCI: Cleanup control flow sparc/PCI: Claim bus resources before pci_bus_add_devices() PCI: Assign resources before drivers claim devices (pci_scan_root_bus()) PCI: Fail pci_ioremap_bar() on unassigned resources ...
2015-04-08PCI/ACPI: Optimize device state transition delaysAaron Lu
The PCI "ACPI additions for FW latency optimizations" ECN (link below) defines two functions in the PCI _DSM: Function 8, "Reset Delay," applies to the entire hierarchy below a PCI host bridge. If it returns one, the OS may assume that all devices in the hierarchy have already completed power-on reset delays. Function 9, "Device Readiness Durations," applies only to the object where it is located. It returns delay durations required after various events if the device requires less time than the spec requires. Delays from this function take precedence over the Reset Delay function. Add support for Reset Delay and part of Device Readiness Durations. [bhelgaas: changelog, comments] Link: https://www.pcisig.com/specifications/conventional/pci_firmware/ECN_fw_latency_optimization_final.pdf Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2015-04-08PCI: Make a shareable UUID for PCI firmware ACPI _DSMAaron Lu
The PCI Firmware Specification, r3.0, sec 4.6.4.1.3, defines a single UUID for an ACPI _DSM method to provide device-specific control functions. This _DSM method support several functions, including PCI Express Slot Information, PCI Express Slot Number, PCI Bus Capabilities, etc. Move the UUID definition from pci/pci-label.c, where it could be used only for one function, to pci/pci-acpi.c where it can be shared for all these functions. [bhelgaas: changelog] Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-04-08PCI: Don't look for ACPI hotplug parameters if ACPI is disabledBjorn Helgaas
Booting a v3.18 or newer Xen domU kernel with PCI devices passed through results in an oops (this is a 32-bit 3.13.11 dom0 with a 64-bit 4.4.0 hypervisor and 32-bit domU): BUG: unable to handle kernel paging request at 0030303e IP: [<c06ed0e6>] acpi_ns_validate_handle+0x12/0x1a Call Trace: [<c06eda4d>] ? acpi_evaluate_object+0x31/0x1fc [<c06b78e1>] ? pci_get_hp_params+0x111/0x4e0 [<c0407bc7>] ? xen_force_evtchn_callback+0x17/0x30 [<c04085fb>] ? xen_restore_fl_direct_reloc+0x4/0x4 [<c0699d34>] ? pci_device_add+0x24/0x450 Don't look for ACPI configuration information if ACPI has been disabled. I don't think this is the best fix, because we can boot plain Linux (no Xen) with "acpi=off", and we don't need this check in pci_get_hp_params(). There should be a better fix that would make Xen domU work the same way. The domU kernel has ACPI support but it has no AML. There should be a way to initialize the ACPI data structures so things fail gracefully rather than oopsing. This is an interim fix to address the regression. Fixes: 6cd33649fa83 ("PCI: Add pci_configure_device() during enumeration") Link: https://bugzilla.kernel.org/show_bug.cgi?id=96301 Reported-by: Michael D Labriola <mlabriol@gdeb.com> Tested-by: Michael D Labriola <mlabriol@gdeb.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.18+
2015-01-23PCI / PM: Avoid resuming PCI devices during system suspendRafael J. Wysocki
Commit f25c0ae2b4c4 (ACPI / PM: Avoid resuming devices in ACPI PM domain during system suspend) modified the ACPI PM domain's system suspend callbacks to allow devices attached to it to be left in the runtime-suspended state during system suspend so as to optimize the suspend process. This was based on the general mechanism introduced by commit aae4518b3124 (PM / sleep: Mechanism to avoid resuming runtime-suspended devices unnecessarily). Extend that approach to PCI devices by modifying the PCI bus type's ->prepare callback to return 1 for devices that are runtime-suspended when it is being executed and that are in a suitable power state and need not be resumed going forward. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2014-11-10PCI: Delete unnecessary NULL pointer checksMarkus Elfring
The functions pci_dev_put(), pci_pme_wakeup_bus(), and put_device() return immediately if their argument is NULL. Thus the test before the call is not needed. Remove these unnecessary tests. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-09-12PCI: Shuffle pci-acpi.c functions to group them logicallyBjorn Helgaas
Move code around to put all the ACPI power management stuff together and all the pieces related to ACPI methods (_CBA, _HPP, _HPX) together. No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-09-12PCI: Whitespace cleanup in pci-acpi.cBjorn Helgaas
Whitespace fixes only; no functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-09-12PCI: Move pci_get_hp_params() to drivers/pci/pci-acpi.cBjorn Helgaas
Move pci_get_hp_params() and related functions from drivers/pci/hotplug/acpi_pcihp.c to drivers/pci/pci-acpi.c. Previously, pci_get_hp_params() was used only by hotplug drivers. But future changes will move this into the normal device enumeration process, so it will be used even when CONFIG_HOTPLUG_PCI is not set. No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-07-27Merge branches 'acpi-pnp' and 'acpi-pci'Rafael J. Wysocki
* acpi-pnp: ACPI / PNP: Use ACPI_COMPANION() instead of ACPI_HANDLE() ACPI / PNP: do ACPI binding directly * acpi-pci: ACPI / PCI: Use ACPI_COMPANION() instead of ACPI_HANDLE()
2014-07-24ACPI / PCI: Use ACPI_COMPANION() instead of ACPI_HANDLE()Rafael J. Wysocki
The ACPI_HANDLE() macro evaluates ACPI_COMPANION() internally to return the handle of the device's ACPI companion, so it is much more straightforward and efficient to use ACPI_COMPANION() directly to obtain the device's ACPI companion object instead of using ACPI_HANDLE() and acpi_bus_get_device() on the returned handle for the same thing. Use ACPI_COMPANION() instead of ACPI_HANDLE() in the PCI ACPI support code. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-07-23ACPI / PM: Revork the handling of ACPI device wakeup notificationsRafael J. Wysocki
Since ACPI wakeup GPEs are going to be enabled during system suspend as well as for runtime wakeup by a subsequent patch and the same notify handlers will be used in both cases, rework the ACPI device wakeup notification framework so that the part specific to physical devices is always run asynchronously from the PM workqueue. This prevents runtime resume callbacks for those devices from being run during system suspend and resume which may not be appropriate, among other things. Also make ACPI device wakeup notification handling a bit more robust agaist subsequent removal of ACPI device objects, whould that ever happen, and create a wakeup source object for each ACPI device configured for wakeup so that wakeup notifications for those devices can wake up the system from the "freeze" sleep state. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-27PCI: Use pci_is_bridge() to simplify codeYijing Wang
Use pci_is_bridge() to simplify code. No functional change. Requires: 326c1cdae741 PCI: Rename pci_is_bridge() to pci_has_subordinate() Requires: 1c86438c9423 PCI: Add new pci_is_bridge() interface Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-01-24Merge tag 'pm+acpi-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "As far as the number of commits goes, the top spot belongs to ACPI this time with cpufreq in the second position and a handful of PM core, PNP and cpuidle updates. They are fixes and cleanups mostly, as usual, with a couple of new features in the mix. The most visible change is probably that we will create struct acpi_device objects (visible in sysfs) for all devices represented in the ACPI tables regardless of their status and there will be a new sysfs attribute under those objects allowing user space to check that status via _STA. Consequently, ACPI device eject or generally hot-removal will not delete those objects, unless the table containing the corresponding namespace nodes is unloaded, which is extremely rare. Also ACPI container hotplug will be handled quite a bit differently and cpufreq will support CPU boost ("turbo") generically and not only in the acpi-cpufreq driver. Specifics: - ACPI core changes to make it create a struct acpi_device object for every device represented in the ACPI tables during all namespace scans regardless of the current status of that device. In accordance with this, ACPI hotplug operations will not delete those objects, unless the underlying ACPI tables go away. - On top of the above, new sysfs attribute for ACPI device objects allowing user space to check device status by triggering the execution of _STA for its ACPI object. From Srinivas Pandruvada. - ACPI core hotplug changes reducing code duplication, integrating the PCI root hotplug with the core and reworking container hotplug. - ACPI core simplifications making it use ACPI_COMPANION() in the code "glueing" ACPI device objects to "physical" devices. - ACPICA update to upstream version 20131218. This adds support for the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves debug facilities. From Bob Moore, Lv Zheng and Betty Dall. - Init code change to carry out the early ACPI initialization earlier. That should allow us to use ACPI during the timekeeping initialization and possibly to simplify the EFI initialization too. From Chun-Yi Lee. - Clenups of the inclusions of ACPI headers in many places all over from Lv Zheng and Rashika Kheria (work in progress). - New helper for ACPI _DSM execution and rework of the code in drivers that uses _DSM to execute it via the new helper. From Jiang Liu. - New Win8 OSI blacklist entries from Takashi Iwai. - Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava, Rashika Kheria, Tang Chen, Zhang Rui. - intel_pstate driver updates, including proper Baytrail support, from Dirk Brandewie and intel_pstate documentation from Ramkumar Ramachandra. - Generic CPU boost ("turbo") support for cpufreq from Lukasz Majewski. - powernow-k6 cpufreq driver fixes from Mikulas Patocka. - cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark Brown. - Assorted cpufreq drivers fixes and cleanups from Anson Huang, John Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh Kumar. - cpuidle cleanups from Bartlomiej Zolnierkiewicz. - Support for hibernation APM events from Bin Shi. - Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC disabled during thaw transitions from Bjørn Mork. - PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf Hansson. - PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente Kurusa, Rashika Kheria. - New tool for profiling system suspend from Todd E Brandt and a cpupower tool cleanup from One Thousand Gnomes" * tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits) thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412) cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ Documentation: cpufreq / boost: Update BOOST documentation cpufreq: exynos: Extend Exynos cpufreq driver to support boost cpufreq / boost: Kconfig: Support for software-managed BOOST acpi-cpufreq: Adjust the code to use the common boost attribute cpufreq: Add boost frequency support in core intel_pstate: Add trace point to report internal state. cpufreq: introduce cpufreq_generic_get() routine ARM: SA1100: Create dummy clk_get_rate() to avoid build failures cpufreq: stats: create sysfs entries when cpufreq_stats is a module cpufreq: stats: free table and remove sysfs entry in a single routine cpufreq: stats: remove hotplug notifiers cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly cpufreq: speedstep: remove unused speedstep_get_state platform: introduce OF style 'modalias' support for platform bus PM / tools: new tool for suspend/resume performance optimization ACPI: fix module autoloading for ACPI enumerated devices ACPI: add module autoloading support for ACPI enumerated devices ACPI: fix create_modalias() return value handling ...
2014-01-22Merge tag 'pci-v3.14-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for the v3.14 merge window: Resource management - Change pci_bus_region addresses to dma_addr_t (Bjorn Helgaas) - Support 64-bit AGP BARs (Bjorn Helgaas, Yinghai Lu) - Add pci_bus_address() to get bus address of a BAR (Bjorn Helgaas) - Use pci_resource_start() for CPU address of AGP BARs (Bjorn Helgaas) - Enforce bus address limits in resource allocation (Yinghai Lu) - Allocate 64-bit BARs above 4G when possible (Yinghai Lu) - Convert pcibios_resource_to_bus() to take pci_bus, not pci_dev (Yinghai Lu) PCI device hotplug - Major rescan/remove locking update (Rafael J. Wysocki) - Make ioapic builtin only (not modular) (Yinghai Lu) - Fix release/free issues (Yinghai Lu) - Clean up pciehp (Bjorn Helgaas) - Announce pciehp slot info during enumeration (Bjorn Helgaas) MSI - Add pci_msi_vec_count(), pci_msix_vec_count() (Alexander Gordeev) - Add pci_enable_msi_range(), pci_enable_msix_range() (Alexander Gordeev) - Deprecate "tri-state" interfaces: fail/success/fail+info (Alexander Gordeev) - Export MSI mode using attributes, not kobjects (Greg Kroah-Hartman) - Drop "irq" param from *_restore_msi_irqs() (DuanZhenzhong) SR-IOV - Clear NumVFs when disabling SR-IOV in sriov_init() (ethan.zhao) Virtualization - Add support for save/restore of extended capabilities (Alex Williamson) - Add Virtual Channel to save/restore support (Alex Williamson) - Never treat a VF as a multifunction device (Alex Williamson) - Add pci_try_reset_function(), et al (Alex Williamson) AER - Ignore non-PCIe error sources (Betty Dall) - Support ACPI HEST error sources for domains other than 0 (Betty Dall) - Consolidate HEST error source parsers (Bjorn Helgaas) - Add a TLP header print helper (Borislav Petkov) Freescale i.MX6 - Remove unnecessary code (Fabio Estevam) - Make reset-gpio optional (Marek Vasut) - Report "link up" only after link training completes (Marek Vasut) - Start link in Gen1 before negotiating for Gen2 mode (Marek Vasut) - Fix PCIe startup code (Richard Zhu) Marvell MVEBU - Remove duplicate of_clk_get_by_name() call (Andrew Lunn) - Drop writes to bridge Secondary Status register (Jason Gunthorpe) - Obey bridge PCI_COMMAND_MEM and PCI_COMMAND_IO bits (Jason Gunthorpe) - Support a bridge with no IO port window (Jason Gunthorpe) - Use max_t() instead of max(resource_size_t,) (Jingoo Han) - Remove redundant of_match_ptr (Sachin Kamat) - Call pci_ioremap_io() at startup instead of dynamically (Thomas Petazzoni) NVIDIA Tegra - Disable Gen2 for Tegra20 and Tegra30 (Eric Brower) Renesas R-Car - Add runtime PM support (Valentine Barshak) - Fix rcar_pci_probe() return value check (Wei Yongjun) Synopsys DesignWare - Fix crash in dw_msi_teardown_irq() (Bjørn Erik Nilsen) - Remove redundant call to pci_write_config_word() (Bjørn Erik Nilsen) - Fix missing MSI IRQs (Harro Haan) - Add dw_pcie prefix before cfg_read/write (Pratyush Anand) - Fix I/O transfers by using CPU (not realio) address (Pratyush Anand) - Whitespace cleanup (Jingoo Han) EISA - Call put_device() if device_register() fails (Levente Kurusa) - Revert EISA initialization breakage ((Bjorn Helgaas) Miscellaneous - Remove unused code, including PCIe 3.0 interfaces (Stephen Hemminger) - Prevent bus conflicts while checking for bridge apertures (Bjorn Helgaas) - Stop clearing bridge Secondary Status when setting up I/O aperture (Bjorn Helgaas) - Use dev_is_pci() to identify PCI devices (Yijing Wang) - Deprecate DEFINE_PCI_DEVICE_TABLE (Joe Perches) - Update documentation 00-INDEX (Erik Ekman)" * tag 'pci-v3.14-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (119 commits) Revert "EISA: Initialize device before its resources" Revert "EISA: Log device resources in dmesg" vfio-pci: Use pci "try" reset interface PCI: Check parent kobject in pci_destroy_dev() xen/pcifront: Use global PCI rescan-remove locking powerpc/eeh: Use global PCI rescan-remove locking PCI: Fix pci_check_and_unmask_intx() comment typos PCI: Add pci_try_reset_function(), pci_try_reset_slot(), pci_try_reset_bus() MPT / PCI: Use pci_stop_and_remove_bus_device_locked() platform / x86: Use global PCI rescan-remove locking PCI: hotplug: Use global PCI rescan-remove locking pcmcia: Use global PCI rescan-remove locking ACPI / hotplug / PCI: Use global PCI rescan-remove locking ACPI / PCI: Use global PCI rescan-remove locking in PCI root hotplug PCI: Add global pci_lock_rescan_remove() PCI: Cleanup pci.h whitespace PCI: Reorder so actual code comes before stubs PCI/AER: Support ACPI HEST AER error sources for PCI domains other than 0 ACPICA: Add helper macros to extract bus/segment numbers from HEST table. PCI: Make local functions static ...
2014-01-12Merge branch 'acpi-hotplug'Rafael J. Wysocki
* acpi-hotplug: ACPI / scan: ACPI device object sysfs attribute for _STA evaluation ACPI / hotplug / driver core: Handle containers in a special way ACPI / hotplug: Add demand_offline hotplug profile flag ACPI / bind: Move acpi_get_child() to drivers/ide/ide-acpi.c ACPI / bind: Pass struct acpi_device pointer to acpi_bind_one() ACPI / bind: Rework struct acpi_bus_type ACPI / bind: Redefine acpi_preset_companion() ACPI / bind: Redefine acpi_get_child() PCI / ACPI: Use acpi_find_child_device() for child devices lookup ACPI / bind: Simplify child device lookups ACPI / scan: Use direct recurrence for device hierarchy walks ACPI: Introduce acpi_set_device_status() ACPI / hotplug: Drop unfinished global notification handling routines ACPI / hotplug: Rework generic code to handle suprise removals ACPI / hotplug: Move container-specific code out of the core ACPI / hotplug: Make ACPI PCI root hotplug use common hotplug code ACPI / hotplug: Introduce common hotplug function acpi_device_hotplug() ACPI / hotplug: Do not fail bus and device checks for disabled hotplug ACPI / scan: Add acpi_device objects for all device nodes in the namespace ACPI / scan: Define non-empty device removal handler
2014-01-12Merge branch 'acpi-cleanup'Rafael J. Wysocki
* acpi-cleanup: (22 commits) ACPI / tables: Return proper error codes from acpi_table_parse() and fix comment. ACPI / tables: Check if id is NULL in acpi_table_parse() ACPI / proc: Include appropriate header file in proc.c ACPI / EC: Remove unused functions and add prototype declaration in internal.h ACPI / dock: Include appropriate header file in dock.c ACPI / PCI: Include appropriate header file in pci_link.c ACPI / PCI: Include appropriate header file in pci_slot.c ACPI / EC: Mark the function acpi_ec_add_debugfs() as static in ec_sys.c ACPI / NVS: Include appropriate header file in nvs.c ACPI / OSL: Mark the function acpi_table_checksum() as static ACPI / processor: initialize a variable to silence compiler warning ACPI / processor: use ACPI_COMPANION() to get ACPI device ACPI: correct minor typos ACPI / sleep: Drop redundant acpi_disabled check ACPI / dock: Drop redundant acpi_disabled check ACPI / table: Replace '1' with specific error return values ACPI: remove trailing whitespace ACPI / IBFT: Fix incorrect <acpi/acpi.h> inclusion in iSCSI boot firmware module ACPI / i915: Fix incorrect <acpi/acpi.h> inclusions via <linux/acpi_io.h> SFI / ACPI: Fix warnings reported during builds with W=1 ... Conflicts: drivers/acpi/nvs.c drivers/hwmon/asus_atk0110.c
2013-12-29PCI / ACPI: Install wakeup notify handlers for all PCI devs with ACPIRafael J. Wysocki
It turns out that some BIOSes don't report wakeup GPEs through _PRW, but use them for signaling wakeup anyway, which causes GPE storms to occur on some systems after resume from system suspend. This issue has been uncovered by commit d2e5f0c16ad6 (ACPI / PCI: Rework the setup and cleanup of device wakeup) during the 3.9 development cycle. Work around the problem by installing wakeup notify handlers for all PCI devices with ACPI support (i.e. having ACPI companions) regardless of whether or not the BIOS reports ACPI wakeup support for them. The presence of the wakeup notify handlers alone is not harmful in any way if there are no events for them to handle (they are simply never executed then), but on some systems they are needed to take care of spurious events. Fixes: d2e5f0c16ad6 (ACPI / PCI: Rework the setup and cleanup of device wakeup) References: https://bugzilla.kernel.org/show_bug.cgi?id=63021 Reported-and-tested-by: Agustin Barto <abarto@gmail.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-12-09PCI: Use dev_is_pci() to identify PCI devicesYijing Wang
Use dev_is_pci() instead of checking bus type directly. Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-12-07ACPI / bind: Rework struct acpi_bus_typeRafael J. Wysocki
Replace the .find_device function pointer in struct acpi_bus_type with a new one, .find_companion, that is supposed to point to a function returning struct acpi_device pointer (instead of an int) and takes one argument (instead of two). This way the role of this callback is more clear and the implementation of it can be more straightforward. Update all of the users of struct acpi_bus_type (PCI, PNP/ACPI and USB) to reflect the structure change. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Tested-by: Lan Tianyu <tianyu.lan@intel.com> # for USB/ACPI
2013-12-07PCI / ACPI: Use acpi_find_child_device() for child devices lookupRafael J. Wysocki
It is much more efficient to use acpi_find_child_device() for child devices lookup in acpi_pci_find_device() and pass ACPI_COMPANION(dev->parent) to it directly instead of obtaining ACPI_HANDLE() of ACPI_COMPANION(dev->parent) and passing it to acpi_find_child() which has to run acpi_bus_get_device() to obtain ACPI_COMPANION(dev->parent) from that again. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reviewed-by: Aaron Lu <aaron.lu@intel.com>
2013-12-07ACPI: Clean up inclusions of ACPI header filesLv Zheng
Replace direct inclusions of <acpi/acpi.h>, <acpi/acpi_bus.h> and <acpi/acpi_drivers.h>, which are incorrect, with <linux/acpi.h> inclusions and remove some inclusions of those files that aren't necessary. First of all, <acpi/acpi.h>, <acpi/acpi_bus.h> and <acpi/acpi_drivers.h> should not be included directly from any files that are built for CONFIG_ACPI unset, because that generally leads to build warnings about undefined symbols in !CONFIG_ACPI builds. For CONFIG_ACPI set, <linux/acpi.h> includes those files and for CONFIG_ACPI unset it provides stub ACPI symbols to be used in that case. Second, there are ordering dependencies between those files that always have to be met. Namely, it is required that <acpi/acpi_bus.h> be included prior to <acpi/acpi_drivers.h> so that the acpi_pci_root declarations the latter depends on are always there. And <acpi/acpi.h> which provides basic ACPICA type declarations should always be included prior to any other ACPI headers in CONFIG_ACPI builds. That also is taken care of including <linux/acpi.h> as appropriate. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Tony Luck <tony.luck@intel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> (drivers/pci stuff) Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> (Xen stuff) Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-11-22Merge tag 'pci-v3.13-fixes-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "Miscellaneous - Remove duplicate disable from pcie_portdrv_remove() (Yinghai Lu) - Fix whitespace, capitalization, and spelling errors (Bjorn Helgaas)" * tag 'pci-v3.13-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: Remove duplicate pci_disable_device() from pcie_portdrv_remove() PCI: Fix whitespace, capitalization, and spelling errors
2013-11-14ACPI: Eliminate the DEVICE_ACPI_HANDLE() macroRafael J. Wysocki
Since DEVICE_ACPI_HANDLE() is now literally identical to ACPI_HANDLE(), replace it with the latter everywhere and drop its definition from include/acpi.h. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-14PCI: Fix whitespace, capitalization, and spelling errorsBjorn Helgaas
Fix whitespace, capitalization, and spelling errors. No functional change. I know "busses" is not an error, but "buses" was more common, so I used it consistently. Signed-off-by: Marta Rybczynska <rybczynska@gmail.com> (pci_reset_bridge_secondary_bus()) Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-24pci-acpi: convert acpi_get_handle() to acpi_has_method()Zhang Rui
acpi_has_method() is a new ACPI API introduced to check the existence of an ACPI control method. It can be used to replace acpi_get_handle() in the case that 1. the calling function doesn't need the ACPI handle of the control method. and 2. the calling function doesn't care the reason why the method is unavailable. Convert acpi_get_handle() to acpi_has_method() in drivers/pci/pci-acpi.c in this patch. Signed-off-by: Zhang Rui <rui.zhang@intel.com> CC: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-09-20PCI / ACPI / PM: Clear pme_poll for devices in D3cold on wakeupRafael J. Wysocki
Commit 448bd85 (PCI/PM: add PCIe runtime D3cold support) added a piece of code to pci_acpi_wake_dev() causing that function to behave in a special way for devices in D3cold (so that their configuration registers are not accessed before those devices are resumed). However, it didn't take the clearing of the pme_poll flag into account. That has to be done for all devices, even if they are in D3cold, or pci_pme_list_scan() will not know that wakeup has been signaled for the device and will poll its PME Status bit unnecessarily. Fix the problem by moving the clearing of the pme_poll flag in pci_acpi_wake_dev() before the code introduced by commit 448bd85. Reported-and-tested-by: David E. Box <david.e.box@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Cc: 3.6+ <stable@vger.kernel.org> # 3.6+
2013-08-27Merge branch 'acpi-pci-hotplug'Rafael J. Wysocki
* acpi-pci-hotplug: (34 commits) ACPI / PM: Hold acpi_scan_lock over system PM transitions ACPI / hotplug / PCI: Fix NULL pointer dereference in cleanup_bridge() PCI / ACPI: Use dev_dbg() instead of dev_info() in acpi_pci_set_power_state() ACPI / hotplug / PCI: Get rid of check_sub_bridges() ACPI / hotplug / PCI: Clean up bridge_mutex usage ACPI / hotplug / PCI: Redefine enable_device() and disable_device() ACPI / hotplug / PCI: Sanitize acpiphp_get_(latch)|(adapter)_status() ACPI / hotplug / PCI: Get rid of unused constants in acpiphp.h ACPI / hotplug / PCI: Check for new devices on enabled slots ACPI / hotplug / PCI: Allow slots without new devices to be rescanned ACPI / hotplug / PCI: Do not check SLOT_ENABLED in enable_device() ACPI / hotplug / PCI: Do not exectute _PS0 and _PS3 directly ACPI / hotplug / PCI: Do not queue up event handling work items in vain ACPI / hotplug / PCI: Consolidate slot disabling and ejecting ACPI / hotplug / PCI: Drop redundant checks from check_hotplug_bridge() ACPI / hotplug / PCI: Rework namespace scanning and trimming routines ACPI / hotplug / PCI: Store parent in functions and bus in slots ACPI / hotplug / PCI: Drop handle field from struct acpiphp_bridge ACPI / hotplug / PCI: Drop handle field from struct acpiphp_func ACPI / hotplug / PCI: Embed function struct into struct acpiphp_context ...
2013-08-07ACPI: Try harder to resolve _ADR collisions for bridgesRafael J. Wysocki
In theory, under a given ACPI namespace node there should be only one child device object with _ADR whose value matches a given bus address exactly. In practice, however, there are systems in which multiple child device objects under a given parent have _ADR matching exactly the same address. In those cases we use _STA to determine which of the multiple matching devices is enabled, since some systems are known to indicate which ACPI device object to associate with the given physical (usually PCI) device this way. Unfortunately, as it turns out, there are systems in which many device objects under the same parent have _ADR matching exactly the same bus address and none of them has _STA, in which case they all should be regarded as enabled according to the spec. Still, if those device objects are supposed to represent bridges (e.g. this is the case for device objects corresponding to PCIe ports), we can try harder and skip the ones that have no child device objects in the ACPI namespace. With luck, we can avoid using device objects that we are not expected to use this way. Although this only works for bridges whose children also have ACPI namespace representation, it is sufficient to address graphics adapter detection issues on some systems, so rework the code finding a matching device ACPI handle for a given bus address to implement this idea. Introduce a new function, acpi_find_child(), taking three arguments: the ACPI handle of the device's parent, a bus address suitable for the device's bus type and a bool indicating if the device is a bridge and make it work as outlined above. Reimplement the function currently used for this purpose, acpi_get_child(), as a call to acpi_find_child() with the last argument set to 'false' and make the PCI subsystem use acpi_find_child() with the bridge information passed as the last argument to it. [Lan Tianyu notices that it is not sufficient to use pci_is_bridge() for that, because the device's subordinate pointer hasn't been set yet at this point, so use hdr_type instead.] This change fixes a regression introduced inadvertently by commit 33f767d (ACPI: Rework acpi_get_child() to be more efficient) which overlooked the fact that for acpi_walk_namespace() "post-order" means "after all children have been visited" rather than "on the way back", so for device objects without children and for namespace walks of depth 1, as in the acpi_get_child() case, the "post-order" callbacks ordering is actually the same as the ordering of "pre-order" ones. Since that commit changed the namespace walk in acpi_get_child() to terminate after finding the first matching object instead of going through all of them and returning the last one, it effectively changed the result returned by that function in some rare cases and that led to problems (the switch from a "pre-order" to a "post-order" callback was supposed to prevent that from happening, but it was ineffective). As it turns out, the systems where the change made by commit 33f767d actually matters are those where there are multiple ACPI device objects representing the same PCIe port (which effectively is a bridge). Moreover, only one of them, and the one we are expected to use, has child device objects in the ACPI namespace, so the regression can be addressed as described above. References: https://bugzilla.kernel.org/show_bug.cgi?id=60561 Reported-by: Peter Wu <lekensteyn@gmail.com> Tested-by: Vladimir Lalov <mail@vlalov.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Cc: 3.9+ <stable@vger.kernel.org> # 3.9+
2013-08-01PCI / ACPI: Use dev_dbg() instead of dev_info() in acpi_pci_set_power_state()Lan Tianyu
acpi_pci_set_power_state() uses dev_info() to print diagnostic messages regarding ACPI power state changes of devices, but that results in too much not really interesting output into the kernel log in some cases. For this reason, change it to use dev_dbg() instead and prevent kernel log from being spammed. [rjw: Changelog] References: https://bugzilla.kernel.org/show_bug.cgi?id=60636 Suggested-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-23ACPI / PCI: Make bus registration and unregistration symmetricRafael J. Wysocki
Since acpi_pci_slot_enumerate() and acpiphp_enumerate_slots() can get the ACPI device handle they need from bus->bridge, it is not necessary to pass that handle to them as an argument. Drop the second argument of acpi_pci_slot_enumerate() and acpiphp_enumerate_slots(), rework them to obtain the ACPI handle from bus->bridge and make acpi_pci_add_bus() and acpi_pci_remove_bus() entirely symmetrical. Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Yinghai Lu <yinghai@kernel.org>
