path: root/drivers/pci/iov.c
2012-02-10PCI: set pci sriov page size before reading SRIOV BARVaidyanathan Srinivasan
For an SRIOV device, PCI_SRIOV_SYS_PGSIZE should be set before the PCI_SRIOV_BAR are queried. The sys pagesize defaults to 4k, so this change is required on powerpc box with 64k base page size. This is a regression caused due to moving SRIOV init to sriov_enable(). | commit afd24ece5c76af87f6fc477f2747b83a764f161c | Author: Ram Pai <linuxram@us.ibm.com> | PCI: delay configuration of SRIOV capability | The SRIOV capability, namely page size and total_vfs of a device are | configured during enumeration phase of the device. This can potentially | interfere with the PCI operations of the platform, if the IOV capability | of the device is not enabled. Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Acked-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06PCI: delay configuration of SRIOV capabilityRam Pai
The SRIOV capability, namely page size and total_vfs of a device are configured during enumeration phase of the device. This can potentially interfere with the PCI operations of the platform, if the IOV capability of the device is not enabled. The following patch postpones the configuration of the IOV capability of the device to a later point, when the IOV capability is explicitly enabled by the device driver. The patch is tested on x86 and power platform. Tested-by: Donald Dutile <ddutile@redhat.com> Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06PCI: Rework config space blocking servicesJan Kiszka
pci_block_user_cfg_access was designed for the use case that a single context, the IPR driver, temporarily delays user space accesses to the config space via sysfs. This assumption became invalid by the time pci_dev_reset was added as locking instance. Today, if you run two loops in parallel that reset the same device via sysfs, you end up with a kernel BUG as pci_block_user_cfg_access detect the broken assumption. This reworks the pci_block_user_cfg_access to a sleeping service pci_cfg_access_lock and an atomic-compatible variant called pci_cfg_access_trylock. The former not only blocks user space access as before but also waits if access was already locked. The latter service just returns false in this case, allowing the caller to resolve the conflict instead of raising a BUG. Adaptions of the ipr driver were originally written by Brian King. Acked-by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-12-05PCI: defer enablement of SRIOV BARSRam Pai
All the PCI BARs of a device are enabled when the device is enabled using pci_enable_device(). This unnecessarily enables SRIOV BARs of the device. On some platforms, which do not support SRIOV as yet, the pci_enable_device() fails to enable the device if its SRIOV BARs are not allocated resources correctly. The following patch fixes the above problem. The SRIOV BARs are now enabled when IOV capability of the device is enabled in sriov_enable(). NOTE: Note, there is subtle change in the pci_enable_device() API. Any driver that depends on SRIOV BARS to be enabled in pci_enable_device() can fail. The patch has been touch tested on power and x86 platform. Tested-by: Michael Wang <wangyun@linux.vnet.ibm.com> Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-10-31pci: Fix files needing export.h for EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
They were implicitly getting it from device.h --> module.h but we want to clean that up. So add the minimal header for these macros. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-14PCI: Move ATS implementation into own fileJoerg Roedel
ATS does not depend on IOV support, so move the code into its own file. This file will also include support for the PRI and PASID capabilities later. Also give ATS its own Kconfig variable to allow selecting it without IOV support. Reviewed-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-04-11PCI: Move ATS declarations in seperate header fileJoerg Roedel
This patch moves the relevant declarations from the local header file in drivers/pci to a more accessible locations so that it can be used by the AMD IOMMU driver too. The file is named pci-ats.h because support for the PCI PRI capability will also be added there in a later patch-set. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-09-09PCI: fix pci_resource_alignment prototypeCam Macdonell
This fixes the prototype for both pci_resource_alignment() and pci_sriov_resource_alignment(). Patch started as debugging effort from Cam Macdonell. Cc: Cam Macdonell <cam@cs.ualberta.ca> Cc: Avi Kivity <avi@redhat.com> [chrisw: add iov bits] Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-12pci: Add SR-IOV convenience functions and macrosWilliams, Mitch A
Add and export pci_num_vf to allow other subsystems to determine how many virtual function devices are associated with an SR-IOV physical function device. Add macros dev_is_pci, dev_is_ps, and dev_num_vf to make it easier for non-PCI specific code to determine SR-IOV capabilities. Signed-off-by: Mitch Williams <mitch.a.williams@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-24PCI: use pci_is_pcie() in pci coreKenji Kaneshige
Change for PCI core to use pci_is_pcie() instead of checking pci_dev->is_pcie. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-08-30PCI SR-IOV: correct broken resource alignment calculationsChris Wright
An SR-IOV capable device includes an SR-IOV PCIe capability which describes the Virtual Function (VF) BAR requirements. A typical SR-IOV device can support multiple VFs whose BARs must be in a contiguous region, effectively an array of VF BARs. The BAR reports the size requirement for a single VF. We calculate the full range needed by simply multiplying the VF BAR size with the number of possible VFs and create a resource spanning the full range. This all seems sane enough except it artificially inflates the alignment requirement for the VF BAR. The VF BAR need only be aligned to the size of a single BAR not the contiguous range of VF BARs. This can cause us to fail to allocate resources for the BAR despite the fact that we actually have enough space. This patch adds a thin PCI specific layer over the generic resource_alignment() function which is aware of the special nature of VF BARs and does sorting and allocation based on the smaller alignment requirement. I recognize that while resource_alignment is generic, it's basically a PCI helper. An alternative to this patch is to add PCI VF BAR specific information to struct resource. I opted for the extra layer rather than adding such PCI specific information to struct resource. This does have the slight downside that we don't cache the BAR size and re-read for each alignment query (happens a small handful of times during boot for each VF BAR). Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Yu Zhao <yu.zhao@intel.com> Cc: stable@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-22Merge git://git.infradead.org/~dwmw2/iommu-2.6.31Linus Torvalds
* git://git.infradead.org/~dwmw2/iommu-2.6.31: intel-iommu: Fix one last ia64 build problem in Pass Through Support VT-d: support the device IOTLB VT-d: cleanup iommu_flush_iotlb_psi and flush_unmaps VT-d: add device IOTLB invalidation support VT-d: parse ATSR in DMA Remapping Reporting Structure PCI: handle Virtual Function ATS enabling PCI: support the ATS capability intel-iommu: dmar_set_interrupt return error value intel-iommu: Tidy up iommu->gcmd handling intel-iommu: Fix tiny theoretical race in write-buffer flush. intel-iommu: Clean up handling of "caching mode" vs. IOTLB flushing. intel-iommu: Clean up handling of "caching mode" vs. context flushing. VT-d: fix invalid domain id for KVM context flush Fix !CONFIG_DMAR build failure introduced by Intel IOMMU Pass Through Support Intel IOMMU Pass Through Support Fix up trivial conflicts in drivers/pci/{intel-iommu.c,intr_remapping.c}
2009-06-16PCI: cleanup Function Level ResetYu Zhao
This patch enhances the FLR functions: 1) remove disable_irq() so the shared IRQ won't be disabled. 2) replace the 1s wait with 100, 200 and 400ms wait intervals for the Pending Transaction. 3) replace mdelay() with msleep(). 4) add might_sleep(). 5) lock the device to prevent PM suspend from accessing the CSRs during the reset. 6) coding style fixes. Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-06-11PCI: fix SR-IOV function dependency link problemYu Zhao
PCIe root complex integrated endpoint does not implement ARI, so this kind of endpoint uses 3-bit function number. The function dependency link of the integrated endpoint should be calculated using the device number plus the value from function dependency link register. Normal endpoint always implements ARI and the function dependency link register contains 8-bit function number (i.e. `devfn' from software's perspective). Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-05-18PCI: handle Virtual Function ATS enablingYu Zhao
The SR-IOV spec requires that the Smallest Translation Unit and the Invalidate Queue Depth fields in the Virtual Function ATS capability are hardwired to 0. If a function is a Virtual Function, then and set its Physical Function's STU before enabling the ATS. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-05-18PCI: support the ATS capabilityYu Zhao
The PCIe ATS capability makes the Endpoint be able to request the DMA address translation from the IOMMU and cache the translation in the device side, thus alleviate IOMMU pressure and improve the hardware performance in the I/O virtualization environment. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06PCI-IOV: fix missing kernel-docRandy Dunlap
Fix PCI iov kernel-doc warning: Warning(drivers/pci/iov.c:638): No description found for parameter 'nr_virtfn' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: handle SR-IOV Virtual Function MigrationYu Zhao
Add or remove a Virtual Function after receiving a Migrate In or Out Request. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: add SR-IOV API for Physical Function driverYu Zhao
Add or remove the Virtual Function when the SR-IOV is enabled or disabled by the device driver. This can happen anytime rather than only at the device probe stage. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: reserve bus range for SR-IOV deviceYu Zhao
Reserve the bus number range used by the Virtual Function when pcibios_assign_all_busses() returns true. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: restore saved SR-IOV stateYu Zhao
Restore the volatile registers in the SR-IOV capability after the D3->D0 transition. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: initialize and release SR-IOV capabilityYu Zhao
If a device has the SR-IOV capability, initialize it (set the ARI Capable Hierarchy in the lowest numbered PF if necessary; calculate the System Page Size for the VF MMIO, probe the VF Offset, Stride and BARs). A lock for the VF bus allocation is also initialized if a PF is the lowest numbered PF. Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
