commit 7612b3b28c0b900dcbcdf5e9b9747cc20a1e2455 upstream.
When a power fault occurs, the power controller sets Power Fault Detected
in the Slot Status register, and pciehp_isr() queues an INT_POWER_FAULT
event to handle it.
It also clears Power Fault Detected, but since nothing has yet changed to
correct the power fault, the power controller will likely set it again
immediately, which may cause an infinite loop when pcie_isr() rechecks
Slot Status.
Fix that by masking off Power Fault Detected from new events if the driver
hasn't seen the power fault clear from the previous handling attempt.
Fixes: fad214b0aa72 ("PCI: pciehp: Process all hotplug events before looking for new ones")
Signed-off-by: Keith Busch <keith.busch@intel.com>
[bhelgaas: changelog, pull test out and add comment]
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Mayurkumar Patel <mayurkumar.patel@intel.com>
commit 48b79a14505349a29b3e20f03619ada9b33c4b17 upstream.
An SHPC may generate MSIs to notify software about slot or controller
events (SHPC spec r1.0, sec 4.7). A PCI device can only generate an MSI if
it has bus mastering enabled.
Enable bus mastering if the bridge contains an SHPC that uses MSI for event
notifications.
Signed-off-by: Aleksandr Bezzubikov <zuban32s@gmail.com>
[bhelgaas: changelog]
Reviewed-by: Marcel Apfelbaum <marcel@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
commit d0c424971f70501ec0a0364117b9934db039c9cc upstream.
In PowerNV PCI hotplug driver, the initial PCI slot's state is set
to PNV_PHP_STATE_POPULATED if no PCI devices are connected to the
slot. The PCI devices that are hot added to the slot won't be probed
and populated because of the check in pnv_php_enable():
/* Check if the slot has been configured */
if (php_slot->state != PNV_PHP_STATE_REGISTERED)
return 0;
This fixes the issue by leaving the slot in PNV_PHP_STATE_REGISTERED
state initially if nothing is connected to the slot.
Fixes: 360aebd85a4 ("drivers/pci/hotplug: Support surprise hotplug in powernv driver")
Reported-by: Hank Chang <hankmax0000@gmail.com>
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Tested-by: Willie Liauw <williel@supermicro.com.tw>
commit d7d55536c6cd1f80295b6d7483ad0587b148bde4 upstream.
The surprise hotplug is driven by interrupt in PowerNV PCI hotplug
driver. In the interrupt handler, pnv_php_interrupt(), we bail when
pnv_pci_get_presence_state() returns zero wrongly. It causes the
presence change event is always ignored incorrectly.
This fixes the issue by bailing on error (non-zero value) returned
from pnv_pci_get_presence_state().
commit 303529d6ef1293513c2c73c9ab86489eebb37d08 upstream.
The root port or PCIe switch downstream port might have been associated
with driver other than pnv-php. The MSI or MSIx might also have been
enabled by that driver (e.g. pcieport_drv). Attempt to enable MSI incurs
below backtrace:
PowerPC PowerNV PCI Hotplug Driver version: 0.1
WARNING: CPU: 19 PID: 1004 at drivers/pci/msi.c:1071 \
__pci_enable_msi_range+0x84/0x4e0
NIP [c000000000665c34] __pci_enable_msi_range+0x84/0x4e0
LR [c000000000665c24] __pci_enable_msi_range+0x74/0x4e0
Call Trace:
[c000000384d67600] [c000000000665c24] __pci_enable_msi_range+0x74/0x4e0
[c000000384d676e0] [d00000000aa31b04] pnv_php_register+0x564/0x5a0 [pnv_php]
[c000000384d677c0] [d00000000aa31658] pnv_php_register+0xb8/0x5a0 [pnv_php]
[c000000384d678a0] [d00000000aa31658] pnv_php_register+0xb8/0x5a0 [pnv_php]
[c000000384d67980] [d00000000aa31dfc] pnv_php_init+0x60/0x98 [pnv_php]
[c000000384d679f0] [c00000000000cfdc] do_one_initcall+0x6c/0x1d0
[c000000384d67ab0] [c000000000b92354] do_init_module+0x94/0x254
[c000000384d67b40] [c00000000019719c] load_module+0x258c/0x2c60
[c000000384d67d30] [c000000000197bb0] SyS_finit_module+0xf0/0x170
[c000000384d67e30] [c00000000000b184] system_call+0x38/0xe0
This fixes the issue by skipping enabling the surprise hotplug
capability if the MSI or MSIx on the PCI slot's upstream port has
been enabled by other driver.
Fixes: 360aebd85a4c ("drivers/pci/hotplug: Support surprise hotplug in powernv driver")
Reviewed-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
Tested-by: Vaibhav Jain <vaibhav@linux.vnet.ibm.com>
commit 36c7c9da40c408a71e5e6bfe12e57dcf549a296d upstream.
The WARN_ON() causes unnecessary backtrace when putting the parent
slot, which is likely to be NULL.
WARNING: CPU: 2 PID: 1071 at drivers/pci/hotplug/pnv_php.c:85 \
pnv_php_release+0xcc/0x150 [pnv_php]
Call Trace:
[c0000003bc007c10] [d00000000ad613c4] pnv_php_release+0x144/0x150 [pnv_php]
[c0000003bc007c40] [c0000000006641d8] pci_hp_deregister+0x238/0x330
[c0000003bc007cd0] [d00000000ad61440] pnv_php_unregister_one+0x70/0xa0 [pnv_php]
[c0000003bc007d10] [d00000000ad614c0] pnv_php_unregister+0x50/0x80 [pnv_php]
[c0000003bc007d40] [d00000000ad61e84] pnv_php_exit+0x50/0xcb4 [pnv_php]
[c0000003bc007d70] [c00000000019499c] SyS_delete_module+0x1fc/0x2a0
[c0000003bc007e30] [c00000000000b184] system_call+0x38/0xe0
Fixes: 66725152fb9f ("PCI/hotplug: PowerPC PowerNV PCI hotplug driver")
commit 49f4b08e61547a5ccd2db551d994c4503efe5666 upstream.
pnv_php_disable_irq() can be called in two paths: Bailing path in
pnv_php_enable_irq() or releasing slot. The MSI (or MSIx) interrupts
is disabled unconditionally in pnv_php_disable_irq(). It's wrong
because that might be enabled by drivers other than pnv-php.
This disables MSI (or MSIx) interrupts and the PCI device only if
it was enabled by pnv-php. In the error path of pnv_php_enable_irq(),
we rely on the newly added parameter @disable_device. In the path
of releasing slot, @pnv_php->irq is checked.
commit 99e5cde5eae78bef95bfe7c16ccda87fb070149b upstream.
Make sure to drop any device reference taken by vio_find_node() when
adding and removing virtual I/O slots.
Fixes: 5eeb8c63a38f ("[PATCH] PCI Hotplug: rpaphp: Move VIO registration")
Signed-off-by: Johan Hovold <johan@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Highlights:
- Major rework of Book3S 64-bit exception vectors (Nicholas Piggin)
- Use gas sections for arranging exception vectors et. al.
- Large set of TM cleanups and selftests (Cyril Bur)
- Enable transactional memory (TM) lazily for userspace (Cyril Bur)
- Support for XZ compression in the zImage wrapper (Oliver
O'Halloran)
- Add support for bpf constant blinding (Naveen N. Rao)
- Beginnings of upstream support for PA Semi Nemo motherboards
(Darren Stevens)
Fixes:
- Ensure .mem(init|exit).text are within _stext/_etext (Michael
Ellerman)
- xmon: Don't use ld on 32-bit (Michael Ellerman)
- vdso64: Use double word compare on pointers (Anton Blanchard)
- powerpc/nvram: Fix an incorrect partition merge (Pan Xinhui)
- powerpc: Fix usage of _PAGE_RO in hugepage (Christophe Leroy)
- powerpc/mm: Update FORCE_MAX_ZONEORDER range to allow hugetlb w/4K
(Aneesh Kumar K.V)
- Fix memory leak in queue_hotplug_event() error path (Andrew
Donnellan)
- Replay hypervisor maintenance interrupt first (Nicholas Piggin)
Various performance optimisations (Anton Blanchard):
- Align hot loops of memset() and backwards_memcpy()
- During context switch, check before setting mm_cpumask
- Remove static branch prediction in atomic{, 64}_add_unless
- Only disable HAVE_EFFICIENT_UNALIGNED_ACCESS on POWER7 little
endian
- Set default CPU type to POWER8 for little endian builds
Cleanups & features:
- Sparse fixes/cleanups (Daniel Axtens)
- Preserve CFAR value on SLB miss caused by access to bogus address
(Paul Mackerras)
- Radix MMU fixups for POWER9 (Aneesh Kumar K.V)
- Support for setting used_(vsr|vr|spe) in sigreturn path (for CRIU)
(Simon Guo)
- Optimise syscall entry for virtual, relocatable case (Nicholas
Piggin)
- Optimise MSR handling in exception handling (Nicholas Piggin)
- Support for kexec with Radix MMU (Benjamin Herrenschmidt)
- powernv EEH fixes (Russell Currey)
- Suprise PCI hotplug support for powernv (Gavin Shan)
- Endian/sparse fixes for powernv PCI (Gavin Shan)
- Defconfig updates (Anton Blanchard)
- KVM: PPC: Book3S HV: Migrate pinned pages out of CMA (Balbir Singh)
- cxl: Flush PSL cache before resetting the adapter (Frederic Barrat)
- cxl: replace loop with for_each_child_of_node(), remove unneeded
of_node_put() (Andrew Donnellan)
- Fix HV facility unavailable to use correct handler (Nicholas
Piggin)
- Remove unnecessary syscall trampoline (Nicholas Piggin)
- fadump: Fix build break when CONFIG_PROC_VMCORE=n (Michael
Ellerman)
- Quieten EEH message when no adapters are found (Anton Blanchard)
- powernv: Add PHB register dump debugfs handle (Russell Currey)
- Use kprobe blacklist for exception handlers & asm functions
(Nicholas Piggin)
- Document the syscall ABI (Nicholas Piggin)
- MAINTAINERS: Update cxl maintainers (Michael Neuling)
- powerpc: Remove all usages of NO_IRQ (Michael Ellerman)
Minor cleanups:
- Andrew Donnellan, Christophe Leroy, Colin Ian King, Cyril Bur,
Frederic Barrat, Pan Xinhui, PrasannaKumar Muralidharan, Rui Teng,
Simon Guo"
* tag 'powerpc-4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (156 commits)
powerpc/bpf: Add support for bpf constant blinding
powerpc/bpf: Implement support for tail calls
powerpc/bpf: Introduce accessors for using the tmp local stack space
powerpc/fadump: Fix build break when CONFIG_PROC_VMCORE=n
powerpc: tm: Enable transactional memory (TM) lazily for userspace
powerpc/tm: Add TM Unavailable Exception
powerpc: Remove do_load_up_transact_{fpu,altivec}
powerpc: tm: Rename transct_(*) to ck(\1)_state
powerpc: tm: Always use fp_state and vr_state to store live registers
selftests/powerpc: Add checks for transactional VSXs in signal contexts
selftests/powerpc: Add checks for transactional VMXs in signal contexts
selftests/powerpc: Add checks for transactional FPUs in signal contexts
selftests/powerpc: Add checks for transactional GPRs in signal contexts
selftests/powerpc: Check that signals always get delivered
selftests/powerpc: Add TM tcheck helpers in C
selftests/powerpc: Allow tests to extend their kill timeout
selftests/powerpc: Introduce GPR asm helper header file
selftests/powerpc: Move VMX stack frame macros to header file
selftests/powerpc: Rework FPU stack placement macros and move to header file
selftests/powerpc: Check for VSX preservation across userspace preemption
This replaces of_get_property() with of_property_read_u32() or
of_property_read_string() so that we needn't consider the endian
issue, the returned value always is in CPU-endian.
[mpe: Fold in the change to the "ibm,slot-surprise-pluggable" case]
* pci/hotplug:
x86/PCI: VMD: Request userspace control of PCIe hotplug indicators
PCI: pciehp: Allow exclusive userspace control of indicators
PCI: pciehp: Remove useless pciehp_get_latch_status() calls
PCI: pciehp: Clean up dmesg "Slot(%s)" messages
PCI: pciehp: Remove unnecessary guard
PCI: pciehp: Don't re-read Slot Status when handling surprise event
PCI: pciehp: Don't re-read Slot Status when queuing hotplug event
PCI: pciehp: Return IRQ_NONE when we can't read interrupt status
PCI: pciehp: Rename pcie_isr() locals for clarity
PCI: pciehp: Clear attention LED on device add
This supports PCI surprise hotplug. The design is highlighted as
below:
* The PCI slot's surprise hotplug capability is exposed through
device node property "ibm,slot-surprise-pluggable", meaning
PCI surprise hotplug will be disabled if skiboot doesn't support
it yet.
* The interrupt because of presence or link state change is raised
on surprise hotplug event. One event is allocated and queued to
the PCI slot for workqueue to pick it up and process in serialized
fashion. The code flow for surprise hotplug is same to that for
managed hotplug except: the affected PEs are put into frozen state
to avoid unexpected EEH error reporting in surprise hot remove path.
This removes likely() and unlikely() in pnv_php.c as the code isn't
running in hot path. Those macros to affect CPU's branch stream don't
help a lot for performance. I used them to identify the cases are
likely or unlikely to happen. No logical changes introduced.
PCIe hotplug supports optional Attention and Power Indicators, which are
used internally by pciehp. Users can't control the Power Indicator, but
they can control the Attention Indicator by writing to a sysfs "attention"
file.
The Slot Control register has two bits for each indicator, and the PCIe
spec defines the encodings for each as (Reserved/On/Blinking/Off). For
sysfs "attention" writes, pciehp_set_attention_status() maps into these
encodings, so the only useful write values are 0 (Off), 1 (On), and 2
(Blinking).
However, some platforms use all four bits for platform-specific indicators,
and they need to allow direct user control of them while preventing pciehp
from using them at all.
Add a "hotplug_user_indicators" flag to the pci_dev structure. When set,
pciehp does not use either the Attention Indicator or the Power Indicator,
and the low four bits (values 0x0 - 0xf) of sysfs "attention" write values
are written directly to the Attention Indicator Control and Power Indicator
Control fields.
[bhelgaas: changelog, rename flag and accessors to s/attention/indicator/]
Long ago, we updated a "switch_save" field based on the latch status. But
switch_save was unused, and ed6cbcf2ac70 ("[PATCH] pciehp: miscellaneous
cleanups") removed it.
We no longer use the latch status, so remove calls to
pciehp_get_latch_status(). No functional change intended.
Tested-by: Lukas Wunner <lukas@wunner.de>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Print slot name consistently as "Slot(%s)". I don't know whether that's
ideal, but we can at least do it the same way all the time. No functional
change intended.
In pcie_isr(), we return early if no status bits other than
PCI_EXP_SLTSTA_CC are set. This was introduced by dbd79aed1aea ("pciehp:
fix NULL dereference in interrupt handler"), but it is no longer necessary
because all the subsequent pcie_isr() code is already predicated on a
status bit being set.
Remove the unnecessary test for ~PCI_EXP_SLTSTA_CC. No functional change
intended.
Previously we read Slot Status when handling a surprise event. But Slot
Status might have changed since we identified the event, and the event_type
already tells us whether to enable or disable the slot, so there's no need
to read it again.
Remove handle_surprise_event() and queue the power work directly.
Signed-off-by: Mayurkumar Patel <mayurkumar.patel@intel.com>
Acked-by: Rajat Jain <rajatxjain@gmail.com>
Previously we read Slot Status to learn about hotplug events, then cleared
the events, then re-read Slot Status to find out what happened. But Slot
Status might have changed before the second read.
Capture the Slot Status once before clearing the events. Also capture the
Link Status if we had a link status change.
[bhelgaas: changelog, split to separate patch]
Previously we accumulated hotplug events, then processed them, essentially
like this:
events = 0
do {
status = read(Slot Status)
status &= EVENT_MASK # only look at events
events |= status # accumulate events
write(Slot Status, events) # clear events
} while (status)
process events
The problem is that as soon as we clear events in Slot Status, the hardware
may send notifications for new events, and we lose information about the
first events. For example, we might see two Presence Detect Changed
events, but lose the fact that the slot was temporarily empty:
read PCI_EXP_SLTSTA_PDC set, PCI_EXP_SLTSTA_PDS clear # slot empty
write PCI_EXP_SLTSTA_PDC # clear PDC event
read PCI_EXP_SLTSTA_PDC set, PCI_EXP_SLTSTA_PDS set # slot occupied
The current code does not process a removal; it only processes the
insertion, which fails because we didn't remove the original device.
To avoid this problem, read Slot Status once and process all the events
before reading it again, like this:
do {
read events
clear events
process events
} while (events)
[bhelgaas: changelog, add external loop around pciehp_isr()]
After 1469d17dd341 ("PCI: pciehp: Handle invalid data when reading from
non-existent devices"), we returned IRQ_HANDLED when we failed to read
interrupt status from the bridge. I think it's better to return IRQ_NONE,
as we do in other cases where there's no interrupt pending. This will
facilitate refactoring the loop in pcie_isr(): we'll be able to call the
ISR in a loop as long as it returns IRQ_HANDLED.
Return IRQ_NONE if we couldn't read interrupt status.
Rename "detected" and "intr_loc" to "status" and "events" for clarity.
"status" is the value we read from the Slot Status register; "events" is
the set of hot-plug events we need to process. No functional change
intended.
This code is not being built as a module by anyone:
obj-$(CONFIG_HOTPLUG_PCI_PCIE) += pciehp.o
pciehp-objs := pciehp_core.o \
drivers/pci/pcie/Kconfig:config HOTPLUG_PCI_PCIE
drivers/pci/pcie/Kconfig: bool "PCI Express Hotplug driver"
Remove uses of MODULE_DESCRIPTION(), MODULE_AUTHOR(), MODULE_LICENSE(),
etc., so that when reading the driver there is no doubt it is builtin-only.
The information is preserved in comments at the top of the file.
Note that for non-modular code, module_init() translates to
device_initcall(). One could argue that we should use subsys_initcall()
here, but for now we stick with runtime equivalence.
We delete module.h but we keep the moduleparam.h include, since we are
keeping the module_param() that the file has as-is for now.
CC: Kristen Carlson Accardi <kristen@linux.intel.com>
obj-$(CONFIG_HOTPLUG_PCI) += pci_hotplug.o
pci_hotplug-objs := pci_hotplug_core.o
drivers/pci/hotplug/Kconfig:menuconfig HOTPLUG_PCI
drivers/pci/hotplug/Kconfig: bool "Support for PCI Hotplug"
Remove orphaned exit function in cpci_hotplug_core.c.
We would delete module.h and just keep the moduleparam.h include (since the
file does use module_param), but there is a try_module_get and module_put
pairing that prevents us from doing that.
CC: Scott Murray <scott@spiteful.org>
Clear the LED attention status after a successful device add. It is
possible the attention LED was on from a previous power fault or link
failure, and a subsequent successful device insert insertion should clear
it.
If a PCI bridge (or PCIe port) that is runtime-suspended gets an ACPI
hotplug notification, such as a bus check, it has to be resumed before
re-scanning the devices below it, or those devices will not be
accessible and will be treated as hot-removed.
Make that happen and let the bridge suspend again after the bus below it
has been re-scanned.
This is a replacement for commit 16468c783cb4 ("ACPI / hotplug / PCI:
Runtime resume bridge before rescan") that has been reverted, because it
introduced a system resume regression (due to missing bridge->pci_dev
checks that are necessary in case the notification is targeted at the
host bridge) and it is necessary for the code added by commit
006d44e49a25 ("PCI: Add runtime PM support for PCIe ports") to work as
expected.
Tested-by: Linus Torvalds <torvalds@linux-foundation.org>
This reverts commit 16468c783cb4cf72475dcda23fabecb4a4bb0e17.
Bisection showed that it was the root cause for a resume hang on a
bog-standard all-Intel laptop (Sony Vaio Pro 11), and reverting fixes
the hang.
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"Highlights:
- ARM64 support for ACPI host bridges
- new drivers for Axis ARTPEC-6 and Marvell Aardvark
- new pci_alloc_irq_vectors() interface for MSI-X, MSI, legacy INTx
- pci_resource_to_user() cleanup (more to come)
Detailed summary:
Enumeration:
- Move ecam.h to linux/include/pci-ecam.h (Jayachandran C)
- Add parent device field to ECAM struct pci_config_window (Jayachandran C)
- Add generic MCFG table handling (Tomasz Nowicki)
- Refactor pci_bus_assign_domain_nr() for CONFIG_PCI_DOMAINS_GENERIC (Tomasz Nowicki)
- Factor DT-specific pci_bus_find_domain_nr() code out (Tomasz Nowicki)
Resource management:
- Add devm_request_pci_bus_resources() (Bjorn Helgaas)
- Unify pci_resource_to_user() declarations (Bjorn Helgaas)
- Implement pci_resource_to_user() with pcibios_resource_to_bus() (microblaze, powerpc, sparc) (Bjorn Helgaas)
- Request host bridge window resources (designware, iproc, rcar, xgene, xilinx, xilinx-nwl) (Bjorn Helgaas)
- Make PCI I/O space optional on ARM32 (Bjorn Helgaas)
- Ignore write combining when mapping I/O port space (Bjorn Helgaas)
- Claim bus resources on MIPS PCI_PROBE_ONLY set-ups (Bjorn Helgaas)
- Remove unicore32 pci=firmware command line parameter handling (Bjorn Helgaas)
- Support I/O resources when parsing host bridge resources (Jayachandran C)
- Add helpers to request/release memory and I/O regions (Johannes Thumshirn)
- Use pci_(request|release)_mem_regions (NVMe, lpfc, GenWQE, ethernet/intel, alx) (Johannes Thumshirn)
- Extend pci=resource_alignment to specify device/vendor IDs (Koehrer Mathias (ETAS/ESW5))
- Add generic pci_bus_claim_resources() (Lorenzo Pieralisi)
- Claim bus resources on ARM32 PCI_PROBE_ONLY set-ups (Lorenzo Pieralisi)
- Remove ARM32 and ARM64 arch-specific pcibios_enable_device() (Lorenzo Pieralisi)
- Add pci_unmap_iospace() to unmap I/O resources (Sinan Kaya)
- Remove powerpc __pci_mmap_set_pgprot() (Yinghai Lu)
PCI device hotplug:
- Allow additional bus numbers for hotplug bridges (Keith Busch)
- Ignore interrupts during D3cold (Lukas Wunner)
Power management:
- Enforce type casting for pci_power_t (Andy Shevchenko)
- Don't clear d3cold_allowed for PCIe ports (Mika Westerberg)
- Put PCIe ports into D3 during suspend (Mika Westerberg)
- Power on bridges before scanning new devices (Mika Westerberg)
- Runtime resume bridge before rescan (Mika Westerberg)
- Add runtime PM support for PCIe ports (Mika Westerberg)
- Remove redundant check of pcie_set_clkpm (Shawn Lin)
Virtualization:
- Add function 1 DMA alias quirk for Marvell 88SE9182 (Aaron Sierra)
- Add DMA alias quirk for Adaptec 3805 (Alex Williamson)
- Mark Atheros AR9485 and QCA9882 to avoid bus reset (Chris Blake)
- Add ACS quirk for Solarflare SFC9220 (Edward Cree)
MSI:
- Fix PCI_MSI dependencies (Arnd Bergmann)
- Add pci_msix_desc_addr() helper (Christoph Hellwig)
- Switch msix_program_entries() to use pci_msix_desc_addr() (Christoph Hellwig)
- Make the "entries" argument to pci_enable_msix() optional (Christoph Hellwig)
- Provide sensible IRQ vector alloc/free routines (Christoph Hellwig)
- Spread interrupt vectors in pci_alloc_irq_vectors() (Christoph Hellwig)
Error Handling:
- Bind DPC to Root Ports as well as Downstream Ports (Keith Busch)
- Remove DPC tristate module option (Keith Busch)
- Convert Downstream Port Containment driver to use devm_* functions (Mika Westerberg)
Generic host bridge driver:
- Select IRQ_DOMAIN (Arnd Bergmann)
- Claim bus resources on PCI_PROBE_ONLY set-ups (Lorenzo Pieralisi)
ACPI host bridge driver:
- Add ARM64 acpi_pci_bus_find_domain_nr() (Tomasz Nowicki)
- Add ARM64 ACPI support for legacy IRQs parsing and consolidation with DT code (Tomasz Nowicki)
- Implement ARM64 AML accessors for PCI_Config region (Tomasz Nowicki)
- Support ARM64 ACPI-based PCI host controller (Tomasz Nowicki)
Altera host bridge driver:
- Check link status before retrain link (Ley Foon Tan)
- Poll for link up status after retraining the link (Ley Foon Tan)
Axis ARTPEC-6 host bridge driver:
- Add PCI_MSI_IRQ_DOMAIN dependency (Arnd Bergmann)
- Add DT binding for Axis ARTPEC-6 PCIe controller (Niklas Cassel)
- Add Axis ARTPEC-6 PCIe controller driver (Niklas Cassel)
Intel VMD host bridge driver:
- Use lock save/restore in interrupt enable path (Jon Derrick)
- Select device dma ops to override (Keith Busch)
- Initialize list item in IRQ disable (Keith Busch)
- Use x86_vector_domain as parent domain (Keith Busch)
- Separate MSI and MSI-X vector sharing (Keith Busch)
Marvell Aardvark host bridge driver:
- Add DT binding for the Aardvark PCIe controller (Thomas Petazzoni)
- Add Aardvark PCI host controller driver (Thomas Petazzoni)
- Add Aardvark PCIe support for Armada 3700 (Thomas Petazzoni)
Microsoft Hyper-V host bridge driver:
- Fix interrupt cleanup path (Cathy Avery)
- Don't leak buffer in hv_pci_onchannelcallback() (Vitaly Kuznetsov)
- Handle all pending messages in hv_pci_onchannelcallback() (Vitaly Kuznetsov)
NVIDIA Tegra host bridge driver:
- Program PADS_REFCLK_CFG* always, not just on legacy SoCs (Stephen Warren)
- Program PADS_REFCLK_CFG* registers with per-SoC values (Stephen Warren)
- Use lower-case hex consistently for register definitions (Thierry Reding)
- Use generic pci_remap_iospace() rather than ARM32-specific one (Thierry Reding)
- Stop setting pcibios_min_mem (Thierry Reding)
Renesas R-Car host bridge driver:
- Drop gen2 dummy I/O port region (Bjorn Helgaas)
TI DRA7xx host bridge driver:
- Fix return value in case of error (Christophe JAILLET)
Xilinx AXI host bridge driver:
Miscellaneous:
- Make bus_attr_resource_alignment static (Ben Dooks)
- Include <asm/dma.h> for isa_dma_bridge_buggy (Ben Dooks)
- MAINTAINERS: Add file patterns for PCI device tree bindings (Geert Uytterhoeven)
- Make host bridge drivers explicitly non-modular (Paul Gortmaker)"
* tag 'pci-v4.8-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (125 commits)
PCI: xgene: Make explicitly non-modular
PCI: thunder-pem: Make explicitly non-modular
PCI: thunder-ecam: Make explicitly non-modular
PCI: tegra: Make explicitly non-modular
PCI: rcar-gen2: Make explicitly non-modular
PCI: rcar: Make explicitly non-modular
PCI: mvebu: Make explicitly non-modular
PCI: layerscape: Make explicitly non-modular
PCI: keystone: Make explicitly non-modular
PCI: hisi: Make explicitly non-modular
PCI: generic: Make explicitly non-modular
PCI: designware-plat: Make it explicitly non-modular
PCI: artpec6: Make explicitly non-modular
PCI: armada8k: Make explicitly non-modular
PCI: artpec: Add PCI_MSI_IRQ_DOMAIN dependency
PCI: Add ACS quirk for Solarflare SFC9220
arm64: dts: marvell: Add Aardvark PCIe support for Armada 3700
PCI: aardvark: Add Aardvark PCI host controller driver
dt-bindings: add DT binding for the Aardvark PCIe controller
PCI: tegra: Program PADS_REFCLK_CFG* registers with per-SoC values
The underlying slot hotplug registration code assumed multiple slots, but
the actual implementation is broken for multiple slots.
This went unnoticed for years do to the fact that PowerVM seems to only
ever provide a single hotplug slot per PHB.
Under qemu/kvm the hotplug slot model aligns more with x86 where
multiple slots are presented under a single PHB. As seen in the
following each additional slot after the first fails to register due to
each slot always being compared against the first child node of the PHB
in the device tree.
rpaphp: RPA HOT Plug PCI Controller Driver version: 0.1
rpaphp: Slot [Slot 0] registered
rpaphp: pci_hp_register failed with error -16
The registration logic is fixed so that each slot is compared
against the existing child devices of the PHB in the device tree to
determine present slots vs empty slots.
rpaphp: Slot [C0] registered
rpaphp: Slot [C1] registered
rpaphp: Slot [C2] registered
rpaphp: Slot [C3] registered
rpaphp: Slot [C4] registered
Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
Reviewed-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
[mpe: Massage changelog]
When calling pnv_php_set_slot_power_state() with state ==
OPAL_PCI_SLOT_OFFLINE, remove devices from the device tree as if we're
dealing with OPAL_PCI_SLOT_POWER_OFF.
Cc: Gavin Shan <gwshan@linux.vnet.ibm.com>
Cc: linux-pci@vger.kernel.org
Cc: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
Acked-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
The cxl driver will use infrastructure from pnv_php to handle device tree
updates when switching bi-modal CAPI cards into CAPI mode.
To enable this, export pnv_php_find_slot() and
pnv_php_set_slot_power_state(), and add corresponding declarations, as well
as the definition of struct pnv_php_slot, to asm/pnv-pci.h.
This adds standalone driver to support PCI hotplug for PowerPC PowerNV
platform that runs on top of skiboot firmware. The firmware identifies
hotpluggable slots and marked their device tree node with proper
"ibm,slot-pluggable" and "ibm,reset-by-firmware". The driver scans
device tree nodes to create/register PCI hotplug slot accordingly.
The PCI slots are organized in fashion of tree, which means one
PCI slot might have parent PCI slot and parent PCI slot possibly
contains multiple child PCI slots. At the plugging time, the parent
PCI slot is populated before its children. The child PCI slots are
removed before their parent PCI slot can be removed from the system.
If the skiboot firmware doesn't support slot status retrieval, the PCI
slot device node shouldn't have property "ibm,reset-by-firmware". In
that case, none of valid PCI slots will be detected from device tree.
The skiboot firmware doesn't export the capability to access attention
LEDs yet and it's something for TBD.
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
If a hotplug port is suspended to D3cold, its slot status register cannot
be read. If that hotplug port happens to share its IRQ with other devices,
whenever an interrupt occurs for one of these devices, pciehp logs a
"no response from device" message and tries to read the PCI_EXP_SLTSTA
register, even though we know that will fail.
Ignore interrupts while we're in D3cold.
Signed-off-by: Lukas Wunner <lukas@wunner.de>
If a PCI bridge (or PCIe port) that is runtime suspended gets an ACPI
hotplug event, such as BUS_CHECK we need to make sure it is resumed before
devices below the bridge are re-scanned. Otherwise the devices behind the
port are not accessible and will be treated as hot-unplugged.
To fix this, resume PCI bridges from runtime suspend while rescanning.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
"Highlights:
- Support for Power ISA 3.0 (Power9) Radix Tree MMU from Aneesh Kumar K.V
- Live patching support for ppc64le (also merged via livepatching.git)
Various cleanups & minor fixes from:
- Aaro Koskinen, Alexey Kardashevskiy, Andrew Donnellan, Aneesh Kumar K.V,
Chris Smart, Daniel Axtens, Frederic Barrat, Gavin Shan, Ian Munsie,
Lennart Sorensen, Madhavan Srinivasan, Mahesh Salgaonkar, Markus Elfring,
Michael Ellerman, Oliver O'Halloran, Paul Gortmaker, Paul Mackerras,
Rashmica Gupta, Russell Currey, Suraj Jitindar Singh, Thiago Jung
Bauermann, Valentin Rothberg, Vipin K Parashar.
General:
- Update LMB associativity index during DLPAR add/remove from Nathan
Fontenot
- Fix branching to OOL handlers in relocatable kernel from Hari Bathini
- Add support for userspace Power9 copy/paste from Chris Smart
- Always use STRICT_MM_TYPECHECKS from Michael Ellerman
- Add mask of possible MMU features from Michael Ellerman
PCI:
- Enable pass through of NVLink to guests from Alexey Kardashevskiy
- Cleanups in preparation for powernv PCI hotplug from Gavin Shan
- Don't report error in eeh_pe_reset_and_recover() from Gavin Shan
- Restore initial state in eeh_pe_reset_and_recover() from Gavin Shan
- Revert "powerpc/eeh: Fix crash in eeh_add_device_early() on Cell"
from Guilherme G Piccoli
- Remove the dependency on EEH struct in DDW mechanism from Guilherme
G Piccoli
selftests:
- Test cp_abort during context switch from Chris Smart
- Add several tests for transactional memory support from Rashmica
Gupta
perf:
- Add support for sampling interrupt register state from Anju T
- Add support for unwinding perf-stackdump from Chandan Kumar
cxl:
- Configure the PSL for two CAPI ports on POWER8NVL from Philippe
Bergheaud
- Allow initialization on timebase sync failures from Frederic Barrat
- Increase timeout for detection of AFU mmio hang from Frederic
Barrat
- Handle num_of_processes larger than can fit in the SPA from Ian
Munsie
- Ensure PSL interrupt is configured for contexts with no AFU IRQs
from Ian Munsie
- Add kernel API to allow a context to operate with relocate disabled
from Ian Munsie
- Check periodically the coherent platform function's state from
Christophe Lombard
Freescale:
- Updates from Scott: "Contains 86xx fixes, minor device tree fixes,
an erratum workaround, and a kconfig dependency fix."
* tag 'powerpc-4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (192 commits)
powerpc/86xx: Fix PCI interrupt map definition
powerpc/86xx: Move pci1 definition to the include file
powerpc/fsl: Fix build of the dtb embedded kernel images
powerpc/fsl: Fix rcpm compatible string
powerpc/fsl: Remove FSL_SOC dependency from FSL_LBC
powerpc/fsl-pci: Add a workaround for PCI 5 errata
powerpc/fsl: Fix SPI compatible on t208xrdb and t1040rdb
powerpc/powernv/npu: Add PE to PHB's list
powerpc/powernv: Fix insufficient memory allocation
powerpc/iommu: Remove the dependency on EEH struct in DDW mechanism
powerpc/eeh: Drop unnecessary label in eeh_pe_change_owner()
powerpc/eeh: Ignore handlers in eeh_pe_reset_and_recover()
powerpc/eeh: Restore initial state in eeh_pe_reset_and_recover()
powerpc/eeh: Don't report error in eeh_pe_reset_and_recover()
Revert "powerpc/powernv: Exclude root bus in pnv_pci_reset_secondary_bus()"
powerpc/powernv/npu: Enable NVLink pass through
powerpc/powernv/npu: Rework TCE Kill handling
powerpc/powernv/npu: Add set/unset window helpers
powerpc/powernv/ioda2: Export debug helper pe_level_printk()
This renames pcibios_find_pci_bus() to pci_find_bus_by_node() to
avoid conflicts with those PCI subsystem weak function names, which
have prefix "pcibios". No logical changes introduced.
Reviewed-by: Alexey Kardashevskiy <aik@ozlabs.ru>
This renames pcibios_{add,remove}_pci_devices() to avoid conflicts
with names of the weak functions in PCI subsystem, which have the
Reviewed-By: Alistair Popple <alistair@popple.id.au>
If ibm_get_table_from_acpi() fails then "table" isn't initialized. Check
for failure so we don't reference "table" unless it's been initialized.
For each PCI function we need to maintain arch specific data in
struct zpci_dev which also contains a pointer to struct pci_dev.
When a function is registered or deregistered (which is triggered by PCI
common code) we need to adjust that pointer which could interfere with
the machine check handler (triggered by FW) using zpci_dev->pdev.
Since multiple instances of the same pdev could exist at a time this can't
be solved with locking.
Fix that by ditching the pdev pointer and use a bus walk to reach
struct pci_dev (only one instance of a pdev can be registered at the bus
at a time).
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
* acpi-video:
ACPI: Revert "ACPI / video: Add Dell Inspiron 5737 to the blacklist"
* acpi-hotplug:
ACPI / PCI / hotplug: unlock in error path in acpiphp_enable_slot()
In acpiphp_enable_slot(), there is a missing unlock path
when error occurred. It needs to be unlocked before returning
an error.
Signed-off-by: Insu Yun <wuninsu@gmail.com>
Cc: All applicable <stable@vger.kernel.org>
* pci/trivial:
PCI: shpchp: Constify hpc_ops structure
PCI: Use kobj_to_dev() instead of open-coding it
PCI: Use to_pci_dev() instead of open-coding it
PCI: Fix all whitespace issues
PCI/MSI: Fix typos in <linux/msi.h>
* pci/hotplug:
PCI: ibmphp: Remove unneeded NULL test
PCI: hotplug: Use list_for_each_entry() to simplify code
PCI: acpiphp_ibm: Fix null dereferences on null ibm_slot
* pci/resource:
PCI: Avoid iterating through memory outside the resource window
PCI: Fix minimum allocation address overwrite
Remove unneeded NULL test. The index variable of list_for_each_entry is
never NULL, as it is the structure that contains the list pointer.
Generated by: scripts/coccinelle/iterators/itnull.cocci
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Julia Lawall <julia.lawall@lip6.fr>
CC: Geliang Tang <geliangtang@163.com>
Use list_for_each_entry() instead of list_for_each() to simplify the code.
Signed-off-by: Geliang Tang <geliangtang@163.com>
ibm_slot_from_id() can return null if the des header signature is not
"aPCI" or if the kmalloc() for the return ACPI descriptor fails, causing
potential null pointer dereferences on the return null descriptor.
Handle the null case with appropriate check and error return.
The hpc_ops structure is never modified, so declare it as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Use to_pci_dev() instead of open-coding it.
Fix all whitespace issues (missing or needed whitespace) in all files in
drivers/pci. Code is compiled with allyesconfig before and after code
changes and objects are recorded and checked with objdiff and they are not
changed after this commit.
Signed-off-by: Bogicevic Sasa <brutallesale@gmail.com>
* pci/aspm:
PCI/ASPM: Make sysfs link_state_store() consistent with link_state_show()
* pci/hotplug:
PCI: pciehp: Always protect pciehp_disable_slot() with hotplug mutex
* pci/misc:
x86/PCI: Simplify pci_bios_{read,write}
PCI: Simplify config space size computation
PCI: Limit config space size for Netronome NFP6000 family
PCI: Add Netronome vendor and device IDs
PCI: Support PCIe devices with short cfg_size
x86/PCI: Clarify AMD Fam10h config access restrictions comment
PCI: Print warnings for all invalid expansion ROM headers
PCI: Check for PCI_HEADER_TYPE_BRIDGE equality, not bitmask
* pci/msi:
PCI/MSI: Remove empty pci_msi_init_pci_dev()
PCI/MSI: Initialize MSI capability for all architectures
