path: root/drivers/pci/hotplug/rpaphp_pci.c
2008-10-20PCI hotplug: rpaphp: make debug var uniqueKristen Carlson Accardi
Change debug variable name to one more unique to this driver. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-20PCI: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01pci hotplug: fix rpaphp directory namingLinas Vepstas
Fix presentation of the slot number in the /sys/bus/pci/slots directory to match that used in the majority of other drivers. > Greg said: > How is anyone supposed to write sane managability tools in the > presence > of such anarchy? > > > ~ # cat /sys/bus/pci/slots/0000:00:02.2/phy_location > > U787A.001.DNZ00Z5-P1-C2 > > Right. This should look like: > > # cat /sys/bus/pci/slots/U787A.001.DNZ00Z5-P1-C2/address > 0000:00:02 This patch implements exactly what you describe. Boot tested. I assume you really mean it -- if so, then please review and ack the patch !? I have absolutely no clue if this breaks any existing IBM tools. I'm pretty sure it doesn't ... but attention Mike Strosaker! does it? Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: <strosake@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28pci hotplug: kernel-doc fixesRandy Dunlap
acpiphp.h: not using kernel-doc, so change /** to /* acpiphp_core.c: lots of kernel-doc cleanups acpiphp_glue.c: lots of kernel-doc cleanups acpiphp_ibm.c: lots of kernel-doc cleanups cpqphp_core.c: lots of kernel-doc cleanups cpqphp_ctrl.c: lots of kernel-doc cleanups fakephp.c: correct kernel-doc notation pciehp_ctrl.c: correct kernel-doc notation rpadlpar_core.c: correct function names & kernel-doc notation rpaphp_core.c: correct kernel-doc notation shpchp_ctrl.c: correct kernel-doc notation Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kristen Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02PCI: rpaphp: Rename rpaphp_register_pci_slot() to rpaphp_enable_slot()Linas Vepstas
Rename rpaphp_register_pci_slot() because its easy to confuse with rpaphp_register_slot() even though it does something completely different. Rename it to rpaphp_enable_slot() because its almost identical to enbale_slot(). Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: John Rose <johnrose@austin.ibm.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02PCI: rpaphp: refactor tail call to rpaphp_register_slot()Linas Vepstas
Eliminate the tail call to rpaphp_register_slot() by placing it in the caller. This will help later dis-entanglement. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: John Rose <johnrose@austin.ibm.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02PCI: rpaphp: remove print_slot_pci_funcs()Linas Vepstas
The debug function print_slot_pci_funcs() is a large wrapper around two debug print statements. Just invoke these directly. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: John Rose <johnrose@austin.ibm.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02PCI: rpaphp: Remove setup_pci_slot()Linas Vepstas
The setup_pci_slot() routine appears to be nothing else than a big, complicated wrapper around pcibios_add_pci_devices(). Remove the wrapping, and call pcibios_add_pci_devices() directly. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: John Rose <johnrose@austin.ibm.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02PCI: rpaphp: Remove another wrappered functionLinas Vepstas
Remove another stove-pipe; this funcion was called from two different places, with a compile-time const that is then run-time checked to perform two different things. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: John Rose <johnrose@austin.ibm.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02PCI: rpaphp: Remve another call that is a wrapperLinas Vepstas
Remove another stovepipe: a call which wraps another call, and just adds printks. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: John Rose <johnrose@austin.ibm.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02PCI: rpaphp: remove a function that does nothing but wrap debug printksLinas Vepstas
Remove a stove-pipe-- a function that is called from only one place, does nothing but wraps another function with debug printk's. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: John Rose <johnrose@austin.ibm.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02PCI: rpaphp: match up alloc and free in same routineLinas Vepstas
The routine that called an alloc should be the same routine that calles the mathcing free, if anything in the middle failed. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: John Rose <johnrose@austin.ibm.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: cleanup: add prefixlinas@austin.ibm.com
Minor cleanup. Add the prefix rpaphp_* to several generic-sounding routines. Remove rpaphp_remove_slot(), which is a one-liner. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: merge rpaphp_enable_pci_slot()linas@austin.ibm.com
Remove general baroqueness. The function rpaphp_enable_pci_slot() has a fairly simple logic structure, once all of the debug printk's are removed. Its called from only one place, and that place also has a very simple structure once he printk's are removed. Merge the two together. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: de-convolute rpaphp_unconfig_pci_adaplinas@austin.ibm.com
Remove general baroqueness. The function rpaphp_unconfig_pci_adapter() is really just three lines of code, once all the dbg printks are removed. And its called in only one place. So replace the call by the thre lines. Also, provide proper semaphore locking in the affected function disable_slot() Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: remove remove_bus_device()linas@austin.ibm.com
The function rpaphp_eeh_remove_bus_device() is a dupe of eeh_remove_bus_device(). Remove it. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: merge config_pci_adapterlinas@austin.ibm.com
Remove general baroqueness. The function rpaphp_config_pci_adapter() is really just one line of code, once all the dbg printks are removed. And its called in only one place. So replace the call by the one line. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: remove rpaphp_fixup_new_pci_devices()linas@austin.ibm.com
The function rpaphp_fixup_new_pci_devices() has been migrated to pcibios_fixup_new_pci_devices() in arch/powerpc/platforms/pseries/pci_dlpar.c This patch removes the old version. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] powerpc/PCI hotplug: remove rpaphp_find_bus()linas@austin.ibm.com
The function rpaphp_find_pci_bus() has been migrated to pcibios_find_pci_bus() in arch/powerpc/platforms/pseries/pci_dlpar.c This patch removes the old version. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI: Reduce nr of ptr derefs in drivers/pci/hotplug/rpaphp_pci.cJesper Juhl
Here's a small patch to reduce the nr. of pointer dereferences in drivers/pci/hotplug/rpaphp_pci.c Benefits: - micro speed optimization due to fewer pointer derefs - generated code should be slightly smaller - better readability note: due to lack of both hardware and cross-compile tools this patch is, unfortunately, completely untested. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI Hotplug/powerpc: more removal of duplicated codelinas@austin.ibm.com
The RPAPHP code contains two routines that appear to be gratuitous copies of very similar pci code. In particular, rpaphp_claim_resource ~~ pci_claim_resource (there is a minor, non-functional difference) rpadlpar_claim_one_bus == pcibios_claim_one_bus (the code is identical) This patch removes the rpaphp versions of the code. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] PCI Hotplug/powerpc: remove duplicated codelinas@austin.ibm.com
The RPAPHP code contains a routine that duplicates some existing code. This patch removes the rpaphp version of the code. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Acked-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-13[PATCH] rpaphp_pci build fixakpm@osdl.org
(akpm: _machine is some ppc64 thing - this is a powerpc-only driver) Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-10[PATCH] dlpar regression for ppc64 - probe changeJohn Rose
This patch contains the driver bits for enabling DLPAR and PCI Hotplug for the new OF-based PCI probe. This functionality was regressed when the new PCI approach was introduced. Please apply if appropriate. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] ppc64 PCI Hotplug: cleanup unsymmetric API routineslinas
This is a minor patch to the ppc64 PCI hotplug code; it makes the call to rpaphp_unconfig_pci_adapter() symmetric with respect to the call to rpaphp_config_pci_adapter(). I discussed this with John Rose, who had provided the last round of changes for these functions; he appearently had this patch but somehow failed to mail it out. Tested. (added/removed device). Signed-off-by: Linas Vepstas <linas@austin.ibm.com> drivers/pci/hotplug/rpaphp.h | 3 ++- drivers/pci/hotplug/rpaphp_core.c | 5 ++++- drivers/pci/hotplug/rpaphp_pci.c | 11 +++-------- 3 files changed, 9 insertions(+), 10 deletions(-)
2005-09-09[PATCH] Separate pci bits out of struct device_nodePaul Mackerras
This patch pulls the PCI-related junk out of struct device_node and puts it in a separate structure, struct pci_dn. The device_node now just has a void * pointer in it, which points to a struct pci_dn for nodes that represent PCI devices. It could potentially be used in future for device-specific data for other sorts of devices, such as virtual I/O devices. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-09-08[PATCH] PCI Hotplug: rpaphp: Purify hotplugJohn Rose
Currently rpaphp registers the following bus types as hotplug slots: 1) Actual PCI Hotplug slots 2) Embedded/Internal PCI slots 3) PCI Host Bridges The second and third bus types are not actually direct parents of removable adapters. As such, the rpaphp has special case code to fake results for attributes like power, adapter status, etc. This patch removes types 2 and 3 from the rpaphp module. This patch also changes the DLPAR module so that slots can be DLPAR-added/removed without having been designated as hotplug-capable. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] PCI Hotplug: rpaphp: Export slot enableJohn Rose
This patch exports rpaphp_config_pci_adapter() for use by the rpadlpar module. It also changes this function by removing any dependencies on struct slot. The patch also changes the RPA DLPAR-add path to enable newly-added slots in a separate step from that which registers them as hotplug slots. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] PCI Hotplug: rpaphp: Remove rpaphp_find_pciJohn Rose
The rpaphp module currently uses a fragile method to find a pci device by its device node. This function is unnecessary, so this patch scraps it. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] PCI Hotplug: rpaphp: Change slot pci referenceJohn Rose
The slot structure in the rpaphp module currently references the PCI contents of the slot using the PCI device of the parent bridge. This is unnecessary, since the module is actually interested in the subordinate bus of the bridge. The dependency on a PCI bridge device also prohibits the module from registering hotplug slots that have a root bridge as a parent, since root bridges on PPC64 don't have PCI devices. This patch changes struct slot to reference the PCI subsystem using a pci_bus rather than a pci_dev. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] PCI Hotplug: rpaphp: Move VIO registrationJohn Rose
Currently, rpaphp registers Virtual I/O slots as hotplug slots. The only purpose of this registration is to ensure that the VIO subsystem is notified of new VIO buses during DLPAR adds. Similarly, rpaphp notifies the VIO subsystem when a VIO bus is DLPAR-removed. The rpaphp module has special case code to fake results for attributes like power, adapter status, etc. The VIO register/unregister functions could just as easily be made from the DLPAR module. This patch moves the VIO registration calls to the DLPAR module, and removes the VIO fluff from rpaphp altogether. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] PCI Hotplug: rpaphp: Remove unused stuffJohn Rose
Subject line says it all :) Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
