path: root/drivers/pci/hotplug/fakephp.c
2012-08-24PCI: Remove the fakephp driverBjorn Helgaas
The fakephp driver was scheduled for removal in 2011. Fakephp presented /sys/bus/pci/slots/.../power files for every PCI function. Writing "0" to one of these files logically removed the device from the system. The PCI core now provides the same functionality with /sys/bus/pci/devices/.../remove. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-27PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_deviceYinghai Lu
The old pci_remove_bus_device actually did stop and remove. Make the name reflect that to reduce confusion. This patch is done by sed scripts and changes back some incorrect __pci_remove_bus_device changes. Suggested-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-07-30PCI: use for_each_pci_dev()Kulikov Vasiliy
Use for_each_pci_dev() to simplify the code. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-26PCI: update fakephp for bus_id removalStephen Rothwell
Get rid of a new use of bus_id that snuck in. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI Hotplug: rename legacy_fakephp to fakephpAlex Chiang
We wanted to replace fakephp wholesale, so rename legacy_fakephp back to fakephp. Yes, this is a silly commit, but it produces a much easier patch to read and review. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI Hotplug: restore fakephp interface with complete reimplementationTrent Piepho
A complete re-implementation of fakephp is necessary if it is to present its former interface (pre-2.6.27, when it broke). The reason is that PCI hotplug drivers call pci_hp_register(), which enforces the rule that only one /sys/bus/pci/slots/ file may be created per physical slot. The change breaks the old fakephp's assumption that it could create a file per function. So we re-implement fakephp to avoid using the standard PCI hotplug API so that we can restore the old fakephp user interface. It puts entries in /sys/bus/pci/slots with the names of all PCI devices/functions, exactly symmetrical to what is shown in /sys/bus/pci/devices. Each slots/ entry has a "power" attribute, which works the same way as the fakephp driver's power attribute has worked. There are a few improvements over old fakephp, which couldn't handle PCI devices being added or removed via a means outside of fakephp's knowledge. If a device was added another way, old fakephp didn't notice and didn't create the fake slot for it. If a device was removed another way, old fakephp didn't delete the fake slot for it (and accessing the stale slot caused an oops). The new implementation overcomes these limitations. As a consequence, removing a bridge with other devices behind it now works as well, which is something else old fakephp couldn't do previously. This duplicates a tiny bit of the code in the PCI core that does this same function. Re-using that code ends up being more complex than duplicating it, and it makes code in the PCI core more ugly just to support this legacy fakephp interface compatibility layer. Reviewed-by: James Cameron <qz@hp.com> Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-03-20PCI: Introduce pci_rescan_bus()Alex Chiang
This API is used by the PCI core to rescan a bus and rediscover newly added devices. Over time, it is expected that the various PCI hotplug drivers will migrate to this interface and away from the old pci_do_scan_bus() interface. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI hotplug: fakephp: Allocate PCI resources before adding the deviceDarrick J. Wong
For PCI devices, pci_bus_assign_resources() must be called to set up the pci_device->resource array before pci_bus_add_devices() can be called, else attempts to load drivers results in BAR collision errors where there are none. This is not done in fakephp, so devices can be "unplugged" but scanning the parent bus won't bring the devices back due to resource unallocation. Move the pci_bus_add_device-calling logic into pci_rescan_bus and preface it with a call to pci_bus_assign_resources so that we only have to (re)allocate resources once per bus where a new device is found. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07drivers/pci/hotplug: Add missing pci_dev_getJulia Lawall
pci_get_slot does a pci_dev_get, so pci_dev_put needs to be called in an error case. An alterative would be to move the test_and_set_bit before the call to pci_get_slot. The problem was fixed using the following semantic patch. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ local idexpression *n; statement S1,S2; expression E,E1; expression *ptr != NULL; type T,T1; @@ ( if (!(n = pci_get_slot(...))) S1 | n = pci_get_slot(...) ) <... when != pci_dev_put(n) when != if (...) { <+... pci_dev_put(n) ...+> } when != true !n || ... when != n = (T)E when != E = n if (!n || ...) S2 ...> ( return \(0\|<+...n...+>\|ptr\); | + pci_dev_put(n); return ...; | pci_dev_put(n); | n = (T1)E1 | E1 = n ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-22PCI Hotplug: fakephp: add duplicate slot name debuggingAlex Chiang
The PCI core now manages slot names on behalf of slot detection and slot hotplug drivers, including the handling of duplicate slot names. We can use the fakephp driver to help test the new functionality. Add a 'dup_slots' module param to force fakephp to create multiple slots with the same name. We can then verify that the PCI core correctly renamed the slots. sapphire:/sys/bus/pci/slots # modprobe fakephp dup_slots sapphire:/sys/bus/pci/slots # ls fake fake-10 fake-3 fake-5 fake-7 fake-9 fake-1 fake-2 fake-4 fake-6 fake-8 Cc: kristen.c.accardi@intel.com Cc: matthew@wil.cx Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-22PCI: fakephp: remove 'name' parameterAlex Chiang
Remove 'name' from fakephp's struct dummy_slot, as the PCI core will now manage our slot name for us. Cc: jbarnes@virtuousgeek.org Cc: kristen.c.accardi@intel.com Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-22PCI Hotplug core: add 'name' param pci_hp_register interfaceAlex Chiang
Update pci_hp_register() to take a const char *name parameter. The motivation for this is to clean up the individual hotplug drivers so that each one does not have to manage its own name. The PCI core should be the place where we manage the name. We update the interface and all callsites first, in a "no functional change" manner, and clean up the drivers later. Cc: kristen.c.accardi@intel.com Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-09-09PCI Hotplug: fakephp: fix deadlock... againAlex Chiang
Commit fe99740cac117f208707488c03f3789cf4904957 (construct one fakephp slot per PCI slot) introduced a regression, causing a deadlock when removing a PCI device. We also never actually removed the device from the PCI core. So we: - remove the device from the PCI core - do not directly call remove_slot() to prevent deadlock Yu Zhao reported and diagnosed this defect. Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Yu Zhao <yu.zhao@intel.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-06-10PCI: introduce pci_slotAlex Chiang
Currently, /sys/bus/pci/slots/ only exposes hotplug attributes when a hotplug driver is loaded, but PCI slots have attributes such as address, speed, width, etc. that are not related to hotplug at all. Introduce pci_slot as the primary data structure and kobject model. Hotplug attributes described in hotplug_slot become a secondary structure associated with the pci_slot. This patch only creates the infrastructure that allows the separation of PCI slot attributes and hotplug attributes. In this patch, the PCI hotplug core remains the only user of this infrastructure, and thus, /sys/bus/pci/slots/ will still only become populated when a hotplug driver is loaded. A later patch in this series will add a second user of this new infrastructure and demonstrate splitting the task of exposing pci_slot attributes from hotplug_slot attributes. - Make pci_slot the primary sysfs entity. hotplug_slot becomes a subsidiary structure. o pci_create_slot() creates and registers a slot with the PCI core o pci_slot_add_hotplug() gives it hotplug capability - Change the prototype of pci_hp_register() to take the bus and slot number (on parent bus) as parameters. - Remove all the ->get_address methods since this functionality is now handled by pci_slot directly. [achiang@hp.com: rpaphp-correctly-pci_hp_register-for-empty-pci-slots] Tested-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: make headers_check happy] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: fix typo in #include] Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Matthew Wilcox <matthew@wil.cx> Cc: Greg KH <greg@kroah.com> Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: Len Brown <lenb@kernel.org> Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-06-10PCI: construct one fakephp slot per PCI slotAlex Chiang
Register one slot per slot, rather than one slot per function. Change the name of the slot to fake%d instead of the pci address. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Matthew Wilcox <matthew@wil.cx> Cc: Greg KH <greg@kroah.com> Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-20PCI: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-20PCI: Hotplug: fakephp: Return success, not ENODEV, when bus rescan is triggeredTrent Piepho
The 'power' attribute of the fakephp driver originally only let one turn a slot off. If one tried to turn a slot on (echo 1 > .../power), it would return ENODEV, as fakephp did not support this function. An old (pre-git) patch changed this: 2004/11/11 16:33:31-08:00 jdittmer [PATCH] fakephp: add pci bus rescan ability http://article.gmane.org/gmane.linux.kernel/251183 Now writing "1" to the power attribute has the effect of triggering a bus rescan, but it still returns ENODEV, probably an oversight in the above patch. Using the BusyBox echo will not produce an error message, but will trigger *two* bus rescans (and return an exit code of 1): ~ # strace echo -n 1 > /sys/bus/pci/slots/0000:00:00.0/power ... write(1, "1", 1) = -1 ENODEV (No such device) write(1, "1", 1) = -1 ENODEV (No such device) exit(1) = ? Using cp gives a write error, even though the write did happen and a rescan was triggered: ~ # echo -n 1 > tmp ; cp tmp /sys/bus/pci/slots/0000:00:00.0/power cp: Write Error: No such device It seems much better to return success instead of failure. The actual status of the bus rescan is hard to return. It happens asynchronously in a work thread, so the sysfs store functions returns before any status is ready (the whole point of the work queue). And even if it didn't do this, the rescan doesn't have any clear status to return. Signed-off-by: Trent Piepho <tpiepho@freescale.com> CC: Jan Dittmer <jdittmer@ppp0.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI: Fix fakephp deadlockIan Abbott
If the fakephp driver is used to emulate removal of a PCI device by writing text string "0" to the "power" sysfs attribute file, this causes its parent directory and its contents (including the "power" file) to be deleted before the write operation returns. Unfortunately, it ends up in a deadlock waiting for itself to complete. The deadlock is as follows: sysfs_write_file calls flush_write_buffer which calls sysfs_get_active_two before calling power_write_file in pci_hotplug_core.c via the sysfs store operation. The power_write_file function calls disable_slot in fakephp.c via the slot operation. The disable_slot function calls remove_slot which calls pci_hp_deregister (back in pci_hotplug_core.c) which calls fs_remove_slot which calls sysfs_remove_file to remove the "power" file. The sysfs_remove_file function calls sysfs_hash_and_remove which calls sysfs_addrm_finish which calls sysfs_deactivate. The sysfs_deactivate function sees that something has an active reference on the sysfs_dirent (from the previous call to sysfs_get_active_two back up the call stack somewhere) so waits for the active reference to go away, which is of course impossible. The problem has been present since 2.6.21. This patch breaks the deadlock by queuing work queue items on a single- threaded work queue to remove a slot from sysfs, and to rescan the PCI buses. There is also some protection against disabling a slot that is already being removed. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Cc: Kristen Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28pci hotplug: kernel-doc fixesRandy Dunlap
acpiphp.h: not using kernel-doc, so change /** to /* acpiphp_core.c: lots of kernel-doc cleanups acpiphp_glue.c: lots of kernel-doc cleanups acpiphp_ibm.c: lots of kernel-doc cleanups cpqphp_core.c: lots of kernel-doc cleanups cpqphp_ctrl.c: lots of kernel-doc cleanups fakephp.c: correct kernel-doc notation pciehp_ctrl.c: correct kernel-doc notation rpadlpar_core.c: correct function names & kernel-doc notation rpaphp_core.c: correct kernel-doc notation shpchp_ctrl.c: correct kernel-doc notation Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kristen Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02PCI: Convert to alloc_pci_dev()Michael Ellerman
Convert code that allocs a struct pci_dev to use alloc_pci_dev(). Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18PCI Hotplug: move pci_hotplug.h to include/linux/Greg Kroah-Hartman
This makes it possible to build pci hotplug drivers outside of the main kernel tree, and Sam keeps telling me to move local header files to their proper places... Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18pci: Stamp out pci_find_* usage in fakephpAlan Cox
pci_find is not hotplug safe, so it really doesn't want to be in an actual hotplug driver either. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26PCI: fix __must_check warningsGreg Kroah-Hartman
2006-03-23[PATCH] PCI: kzalloc() conversion in drivers/pciEric Sesterhenn
this patch converts drivers/pci to kzalloc usage. Compile tested with allyes config. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
