path: root/drivers/pci/access.c
2016-03-10PCI: Sleep rather than busy-wait for VPD access completionBjorn Helgaas
Use usleep_range() instead of udelay() while waiting for a VPD access to complete. This is not a performance path, so no need to hog the CPU. Rationale for usleep_range() parameters: We clear PCI_VPD_ADDR_F for a read (or set it for a write), then wait for the device to change it. For a device that updates PCI_VPD_ADDR between our config write and subsequent config read, we won't sleep at all and can get the device's maximum rate. Sleeping a minimum of 10 usec per 4-byte access limits throughput to about 400Kbytes/second. VPD is small (32K bytes at most), and most devices use only a fraction of that. We back off exponentially up to 1024 usec per iteration. If we reach 1024, we've already waited up to 1008 usec (16 + 32 + ... + 512), so if we miss an update and wait an extra 1024 usec, we can still get about 1/2 of the device's maximum rate. Tested-by: Shane Seymour <shane.seymour@hpe.com> Tested-by: Babu Moger <babu.moger@oracle.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Hannes Reinecke <hare@suse.com>
2016-02-29PCI: Fold struct pci_vpd_pci22 into struct pci_vpdBjorn Helgaas
We only support one flavor of VPD, so there's no need to complicate things by having a "generic" struct pci_vpd and a more specific struct pci_vpd_pci22. Fold struct pci_vpd_pci22 directly into struct pci_vpd. [bhelgaas: remove NULL check before kfree of dev->vpd (per kfreeaddr.cocci)] Tested-by: Shane Seymour <shane.seymour@hpe.com> Tested-by: Babu Moger <babu.moger@oracle.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Hannes Reinecke <hare@suse.com>
2016-02-29PCI: Rename VPD symbols to remove unnecessary "pci22"Bjorn Helgaas
There's only one kind of VPD, so we don't need to qualify it as "the version described by PCI spec rev 2.2." Rename the following symbols to remove unnecessary "pci22": PCI_VPD_PCI22_SIZE -> PCI_VPD_MAX_SIZE pci_vpd_pci22_size() -> pci_vpd_size() pci_vpd_pci22_wait() -> pci_vpd_wait() pci_vpd_pci22_read() -> pci_vpd_read() pci_vpd_pci22_write() -> pci_vpd_write() pci_vpd_pci22_ops -> pci_vpd_ops pci_vpd_pci22_init() -> pci_vpd_init() Tested-by: Shane Seymour <shane.seymour@hpe.com> Tested-by: Babu Moger <babu.moger@oracle.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Hannes Reinecke <hare@suse.com>
2016-02-29PCI: Remove struct pci_vpd_ops.release function pointerBjorn Helgaas
The struct pci_vpd_ops.release function pointer is always pci_vpd_pci22_release(), so there's no need for the flexibility of a function pointer. Inline the pci_vpd_pci22_release() body into pci_vpd_release() and remove pci_vpd_pci22_release() and the struct pci_vpd_ops.release function pointer. Tested-by: Shane Seymour <shane.seymour@hpe.com> Tested-by: Babu Moger <babu.moger@oracle.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Hannes Reinecke <hare@suse.com>
2016-02-29PCI: Move pci_vpd_release() from header file to pci/access.cBjorn Helgaas
Move pci_vpd_release() so it's next to the other VPD functions. This puts it next to pci_vpd_pci22_init(), which allocates the space freed by pci_vpd_release(). Tested-by: Shane Seymour <shane.seymour@hpe.com> Tested-by: Babu Moger <babu.moger@oracle.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Hannes Reinecke <hare@suse.com>
2016-02-29PCI: Move pci_read_vpd() and pci_write_vpd() close to other VPD codeBjorn Helgaas
pci_read_vpd() and pci_write_vpd() were stranded in the middle of config accessor functions. Move them close to the other VPD code in the file. No functional change. Tested-by: Shane Seymour <shane.seymour@hpe.com> Tested-by: Babu Moger <babu.moger@oracle.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Hannes Reinecke <hare@suse.com>
2016-02-29PCI: Determine actual VPD size on first accessHannes Reinecke
PCI-2.2 VPD entries have a maximum size of 32k, but might actually be smaller than that. To figure out the actual size one has to read the VPD area until the 'end marker' is reached. Per spec, reading outside of the VPD space is "not allowed." In practice, it may cause simple read errors or even crash the card. To make matters worse not every PCI card implements this properly, leaving us with no 'end' marker or even completely invalid data. Try to determine the size of the VPD data when it's first accessed. If no valid data can be read an I/O error will be returned when reading or writing the sysfs attribute. As the amount of VPD data is unknown initially the size of the sysfs attribute will always be set to '0'. [bhelgaas: changelog, use 0/1 (not false/true) for bitfield, tweak pci_vpd_pci22_read() error checking] Tested-by: Shane Seymour <shane.seymour@hpe.com> Tested-by: Babu Moger <babu.moger@oracle.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: Alexander Duyck <alexander.duyck@gmail.com>
2016-02-29PCI: Use bitfield instead of bool for struct pci_vpd_pci22.busyBjorn Helgaas
Make struct pci_vpd_pci22.busy a 1-bit field instead of a bool. We intend to add another flag, and two bitfields are cheaper than two bools. Tested-by: Shane Seymour <shane.seymour@hpe.com> Tested-by: Babu Moger <babu.moger@oracle.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Hannes Reinecke <hare@suse.com>
2016-01-08PCI: Fix all whitespace issuesBogicevic Sasa
Fix all whitespace issues (missing or needed whitespace) in all files in drivers/pci. Code is compiled with allyesconfig before and after code changes and objects are recorded and checked with objdiff and they are not changed after this commit. Signed-off-by: Bogicevic Sasa <brutallesale@gmail.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2015-09-24PCI: Use function 0 VPD for identical functions, regular VPD for othersAlex Williamson
932c435caba8 ("PCI: Add dev_flags bit to access VPD through function 0") added PCI_DEV_FLAGS_VPD_REF_F0. Previously, we set the flag on every non-zero function of quirked devices. If a function turned out to be different from function 0, i.e., it had a different class, vendor ID, or device ID, the flag remained set but we didn't make VPD accessible at all. Flip this around so we only set PCI_DEV_FLAGS_VPD_REF_F0 for functions that are identical to function 0, and allow regular VPD access for any other functions. [bhelgaas: changelog, stable tag] Fixes: 932c435caba8 ("PCI: Add dev_flags bit to access VPD through function 0") Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <helgaas@kernel.org> Acked-by: Myron Stowe <myron.stowe@redhat.com> Acked-by: Mark Rustad <mark.d.rustad@intel.com> CC: stable@vger.kernel.org
2015-09-24PCI: Fix devfn for VPD access through function 0Alex Williamson
Commit 932c435caba8 ("PCI: Add dev_flags bit to access VPD through function 0") passes PCI_SLOT(devfn) for the devfn parameter of pci_get_slot(). Generally this works because we're fairly well guaranteed that a PCIe device is at slot address 0, but for the general case, including conventional PCI, it's incorrect. We need to get the slot and then convert it back into a devfn. Fixes: 932c435caba8 ("PCI: Add dev_flags bit to access VPD through function 0") Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <helgaas@kernel.org> Acked-by: Myron Stowe <myron.stowe@redhat.com> Acked-by: Mark Rustad <mark.d.rustad@intel.com> CC: stable@vger.kernel.org
2015-07-21PCI: Add dev_flags bit to access VPD through function 0Mark Rustad
Add a dev_flags bit, PCI_DEV_FLAGS_VPD_REF_F0, to access VPD through function 0 to provide VPD access on other functions. This is for hardware devices that provide copies of the same VPD capability registers in multiple functions. Because the kernel expects that each function has its own registers, both the locking and the state tracking are affected by VPD accesses to different functions. On such devices for example, if a VPD write is performed on function 0, *any* later attempt to read VPD from any other function of that device will hang. This has to do with how the kernel tracks the expected value of the F bit per function. Concurrent accesses to different functions of the same device can not only hang but also corrupt both read and write VPD data. When hangs occur, typically the error message: vpd r/w failed. This is likely a firmware bug on this device. will be seen. Never set this bit on function 0 or there will be an infinite recursion. Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Alexander Duyck <alexander.h.duyck@redhat.com> CC: stable@vger.kernel.org
2015-07-14PCI: Add pcie_downstream_port() (true for Root and Switch Downstream Ports)Bjorn Helgaas
As used in the PCIe spec, "Downstream Port" includes both Root Ports and Switch Downstream Ports. We sometimes checked for PCI_EXP_TYPE_DOWNSTREAM when we should have checked for PCI_EXP_TYPE_ROOT_PORT or PCI_EXP_TYPE_DOWNSTREAM. For a Root Port without a slot, the effect of this was that using pcie_capability_read_word() to read PCI_EXP_SLTSTA returned zero instead of showing the Presence Detect State bit hardwired to one as the PCIe Spec, r3.0, sec 7.8, requires. (This read is completed in software because previous PCIe spec versions didn't require PCI_EXP_SLTSTA to exist at all.) Nothing in the kernel currently depends on this (pciehp only reads PCI_EXP_SLTSTA on ports with slots), so this is a cleanup and not a functional change. Add a pcie_downstream_port() helper function and use it. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-01-22PCI: Add generic config accessorsRob Herring
Many PCI controllers' configuration space accesses are memory-mapped and vary only in address calculation and access checks. There are 2 main access methods: a decoded address space such as ECAM or a single address and data register similar to x86. This implementation can support both cases as well as be used in cases that need additional pre- or post-access handling. Add a new pci_ops member, map_bus, which can do access checks and any necessary setup. It returns the address to use for the configuration space access. The access types supported are 32-bit only accesses or correct byte, word, or dword sized accesses. Tested-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Thierry Reding <treding@nvidia.com>
2014-11-13PCI: Apply _HPX Link Control settings to all devices with a linkYinghai Lu
Previously we applied _HPX type 2 record Link Control register settings only to bridges with a subordinate bus. But it's better to apply them to all devices with a link because if the subordinate bus has not been allocated yet, we won't apply settings to the device. Use pcie_cap_has_lnkctl() to determine whether the device has a Link Control register instead of looking at dev->subordinate. [bhelgaas: changelog] Fixes: 6cd33649fa83 ("PCI: Add pci_configure_device() during enumeration") Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-06-10PCI: Merge multi-line quoted stringsRyan Desfosses
Merge quoted strings that are broken across lines into a single entity. The compiler merges them anyway, but checkpatch complains about it, and merging them makes it easier to grep for strings. No functional change. [bhelgaas: changelog, do the same for everything under drivers/pci] Signed-off-by: Ryan Desfosses <ryan@desfo.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-05-27PCI: Fix return value from pci_user_{read,write}_config_*()Gavin Shan
The PCI user-space config accessors pci_user_{read,write}_config_*() return negative error numbers, which were introduced by commit 34e3207205ef ("PCI: handle positive error codes"). That patch converted all positive error numbers from platform-specific PCI config accessors to -EINVAL, which means the callers don't know anything about the specific cause of the failure. The patch fixes the issue by converting the positive PCIBIOS_* error values to generic negative error numbers with pcibios_err_to_errno(). [bhelgaas: changelog] Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Greg Thelen <gthelen@google.com>
2014-01-13PCI: Remove unused pci_vpd_truncate()Stephen Hemminger
My philosophy is unused code is dead code. And dead code is subject to bit rot and is a likely source of bugs. Use it or lose it. This reverts db5679437a2b ("PCI: add interface to set visible size of VPD"), removing this interface: pci_vpd_truncate() [bhelgaas: split to separate patch, also remove prototype from pci.h] Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-08-28PCI: Remove pcie_cap_has_devctl()Bjorn Helgaas
pcie_cap_has_devctl() does nothing, so remove it. Simplicity over consistency in this case. No functional change. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-By: Jiang Liu <jiang.liu@huawei.com>
2013-08-28PCI: Support PCIe Capability Slot registers only for ports with slotsBjorn Helgaas
Previously we allowed callers to access Slot Capabilities, Status, and Control for Root Ports even if the Root Port did not implement a slot. This seems dubious because the spec only requires these registers if a slot is implemented. It's true that even Root Ports without slots must have *space* for these slot registers, because the Root Capabilities, Status, and Control registers are after the slot registers in the capability. However, for a v1 PCIe Capability, the *semantics* of the slot registers are undefined unless a slot is implemented. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-By: Jiang Liu <jiang.liu@huawei.com>
2013-08-28PCI: Remove PCIe Capability version checksBjorn Helgaas
Previously we relied on the PCIe r3.0, sec 7.8, spec language that says "For Functions that do not implement the [Link, Slot, Root] registers, these spaces must be hardwired to 0b," which means that for v2 PCIe capabilities, we don't need to check the device type at all. But it's simpler if we don't need to check the capability version at all, and I think the spec is explicit enough about which registers are required for which types that we can remove the version checks. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-By: Jiang Liu <jiang.liu@huawei.com>
2013-08-28PCI: Allow PCIe Capability link-related register access for switchesBjorn Helgaas
Every PCIe device has a link, except Root Complex Integrated Endpoints and Root Complex Event Collectors. Previously we didn't give access to PCIe capability link-related registers for Upstream Ports, Downstream Ports, and Bridges, so attempts to read PCI_EXP_LNKCTL incorrectly returned zero. See PCIe spec r3.0, sec 7.8 and 1.3.2.3. Reference: http://lkml.kernel.org/r/979A8436335E3744ADCD3A9F2A2B68A52AD136BE@SJEXCHMB10.corp.ad.broadcom.com Reported-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-By: Jiang Liu <jiang.liu@huawei.com>
2013-02-15PCI: Fix PCI Express Capability accessors for PCI_EXP_FLAGSAlex Williamson
PCI_EXP_FLAGS_TYPE is a mask, not an offset. Fix it. Previously, pcie_capability_read_word(..., PCI_EXP_FLAGS, ...) would fail. [bhelgaas: tweak changelog] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.7+
2013-01-30PCI: Use PCI Express Capability accessorMyron Stowe
Use PCI Express Capability access functions to simplify device Capabilities Register usages. Signed-off-by: Myron Stowe <myron.stowe@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-08-23PCI: Add accessors for PCI Express CapabilityJiang Liu
The PCI Express Capability (PCIe spec r3.0, sec 7.8) comes in two versions, v1 and v2. In v1 Capability structures (PCIe spec r1.0 and r1.1), some fields are optional, so the structure size depends on the device type. This patch adds functions to access this capability so drivers don't have to be aware of the differences between v1 and v2. Note that these new functions apply only to the "PCI Express Capability," not to any of the other "PCI Express Extended Capabilities" (AER, VC, ACS, MFVC, etc.) Function pcie_capability_read_word/dword() reads the PCIe Capabilities register and returns the value in the reference parameter "val". If the PCIe Capabilities register is not implemented on the PCIe device, "val" is set to 0. Function pcie_capability_write_word/dword() writes the value to the specified PCIe Capability register. Function pcie_capability_clear_and_set_word/dword() sets and/or clears bits of a PCIe Capability register. [bhelgaas: changelog, drop "pci_" prefixes, don't export pcie_capability_reg_implemented()] Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-12PCI: export pci_user functions for use by other driversAlex Williamson
VFIO PCI support will make use of these for user-initiated PCI config accesses. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-01-06PCI: Introduce INTx check & mask APIJan Kiszka
These new PCI services allow to probe for 2.3-compliant INTx masking support and then use the feature from PCI interrupt handlers. The services are properly synchronized with concurrent config space access via sysfs or on device reset. This enables generic PCI device drivers like uio_pci_generic or KVM's device assignment to implement the necessary kernel-side IRQ handling without any knowledge about device-specific interrupt status and control registers. Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06PCI: Rework config space blocking servicesJan Kiszka
pci_block_user_cfg_access was designed for the use case that a single context, the IPR driver, temporarily delays user space accesses to the config space via sysfs. This assumption became invalid by the time pci_dev_reset was added as locking instance. Today, if you run two loops in parallel that reset the same device via sysfs, you end up with a kernel BUG as pci_block_user_cfg_access detect the broken assumption. This reworks the pci_block_user_cfg_access to a sleeping service pci_cfg_access_lock and an atomic-compatible variant called pci_cfg_access_trylock. The former not only blocks user space access as before but also waits if access was already locked. The latter service just returns false in this case, allowing the caller to resolve the conflict instead of raising a BUG. Adaptions of the ipr driver were originally written by Brian King. Acked-by: Brian King <brking@linux.vnet.ibm.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10PCI: handle positive error codesGreg Thelen
Callers expect pci_user_{read,write}_config_*() to indicate errors by returning negative values. Prior to this change, the indicated routines could return positive error codes (e.g. PCIBIOS_BAD_REGISTER_NUMBER) which callers would mistakenly interpret as success. This change converts any non-zero return from the mentioned routines into unambiguous negative value return codes. Signed-off-by: Greg Thelen <gthelen@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10PCI: check pci_vpd_pci22_wait() returnGreg Thelen
pci_vpd_pci22_write() calls pci_vpd_pci22_wait() after writing PCI_VPD_DATA and PCI_VPD_ADDR to wait for the VPD operation to complete. The result pci_vpd_pci22_wait() was not checked for error. This change checks for error. Signed-off-by: Greg Thelen <gthelen@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-05-18PCI: output FW warning in pci_read/write_vpdPrarit Bhargava
pci_read/write_vpd() can fail due to a timeout. Usually the command times out because of firmware issues (incorrect vpd length, etc.) on the PCI card. Currently, the timeout occurs silently. Output a message to the user indicating that they should check with their vendor for new firmware. Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-05-11PCI: Convert pci_lock to raw_spinlockThomas Gleixner
pci_lock must be a real spinlock in preempt-rt. Convert it to raw_spinlock. No change for !RT kernels. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-16PCI: Add pci_bus_set_opsHuang Ying
pci_bus_set_ops changes pci_ops associated with a pci_bus. This can be used by debug tools such as PCIE AER error injection to fake some PCI configuration registers. Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-04-22docbooks: add/fix PCI kernel-docRandy Dunlap
Add drivers/pci/*.c source files to DocBook/kernel-api.tmpl and update those pci/*.c source files that need kernel-doc fixes. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-04-07PCI: Fix oops in pci_vpd_truncateAnton Vorontsov
pci_vpd_truncate() should check for dev->vpd->attr, otherwise this might happen: sky2 driver version 1.22 Unable to handle kernel paging request for data at address 0x0000000c Faulting instruction address: 0xc01836fc Oops: Kernel access of bad area, sig: 11 [#1] [...] NIP [c01836fc] pci_vpd_truncate+0x38/0x40 LR [c029be18] sky2_probe+0x14c/0x518 Call Trace: [ef82bde0] [c029bda4] sky2_probe+0xd8/0x518 (unreliable) [ef82be20] [c018a11c] local_pci_probe+0x24/0x34 [ef82be30] [c018a14c] pci_call_probe+0x20/0x30 [ef82be50] [c018a330] __pci_device_probe+0x64/0x78 [ef82be60] [c018a44c] pci_device_probe+0x30/0x58 [ef82be80] [c01aa270] really_probe+0x78/0x1a0 [ef82bea0] [c01aa460] __driver_attach+0xa4/0xa8 [ef82bec0] [c01a96ac] bus_for_each_dev+0x60/0x9c [ef82bef0] [c01aa0b4] driver_attach+0x24/0x34 [ef82bf00] [c01a9e08] bus_add_driver+0x12c/0x1cc [ef82bf20] [c01aa87c] driver_register+0x6c/0x110 [ef82bf30] [c018a770] __pci_register_driver+0x4c/0x9c [ef82bf50] [c03782c8] sky2_init_module+0x30/0x40 [ef82bf60] [c0001dbc] do_one_initcall+0x34/0x1a0 [ef82bfd0] [c0362240] do_initcalls+0x38/0x58 This happens with CONFIG_SKY2=y, and "ip=on" kernel command line, so pci_vpd_truncate() is called before late_initcall(pci_sysfs_init), therefore ->attr isn't yet initialized. Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07PCI: add interface to set visible size of VPDStephen Hemminger
The VPD on all devices may not be 32K. Unfortunately, there is no generic way to find the size, so this adds a simple API hook to reset it. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: revise VPD access interfaceStephen Hemminger
Change PCI VPD API which was only used by sysfs to something usable in drivers. * move iteration over multiple words to the low level * use conventional types for arguments * add exportable wrapper Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-07PCI: handle long delays in VPD accessStephen Hemminger
Accessing the VPD area can take a long time. The existing VPD access code fails consistently on my hardware. There are comments in the SysKonnect vendor driver that it can take up to 13ms per word. Change the access routines to: * use a mutex rather than spinning with IRQ's disabled and lock held * have a much longer timeout * call cond_resched while spinning Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-07-02PCI: Limit VPD read/write lengths for Broadcom 5706, 5708, 5709 rev.Benjamin Li
For Broadcom 5706, 5708, 5709 rev. A nics, any read beyond the VPD end tag will hang the device. This problem was initially observed when a vpd entry was created in sysfs ('/sys/bus/pci/devices/<id>/vpd'). A read to this sysfs entry will dump 32k of data. Reading a full 32k will cause an access beyond the VPD end tag causing the device to hang. Once the device is hung, the bnx2 driver will not be able to reset the device. We believe that it is legal to read beyond the end tag and therefore the solution is to limit the read/write length. A majority of this patch is from Matthew Wilcox who gave code for reworking the PCI vpd size information. A PCI quirk added for the Broadcom NIC's to limit the read/write's. Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-20PCI: Expose PCI VPD through sysfsBen Hutchings
Vital Product Data (VPD) may be exposed by PCI devices in several ways. It is generally unsafe to read this information through the existing interfaces to user-land because of stateful interfaces. This adds: - abstract operations for VPD access (struct pci_vpd_ops) - VPD state information in struct pci_dev (struct pci_vpd) - an implementation of the VPD access method specified in PCI 2.2 (in access.c) - a 'vpd' binary file in sysfs directories for PCI devices with VPD operations defined It adds a probe for PCI 2.2 VPD in pci_scan_device() and release of VPD state in pci_release_dev(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-04[PATCH] severing module.h->sched.hAl Viro
2006-12-01PCI: Block on access to temporarily unavailable pci deviceMatthew Wilcox
The existing implementation of pci_block_user_cfg_access() was recently criticised for providing out of date information and for returning errors on write, which applications won't be expecting. This reimplementation uses a global wait queue and a bit per device. I've open-coded prepare_to_wait() / finish_wait() as I could optimise it significantly by knowing that the pci_lock protected us at all points. It looked a bit funny to be doing a spin_unlock_irqsave(); schedule(), so I used spin_lock_irq() for the _user versions of pci_read_config and pci_write_config. Not carrying a flags pointer around made the code much less nasty. Attempts to block an already blocked device hit a BUG() and attempts to unblock an already unblocked device hit a WARN(). If we need to block access to a device from userspace, it's because it's unsafe for even another bit of the kernel to access the device. An attempt to block a device for a second time means we're about to access the device to perform some other operation, which could provoke undefined behaviour from the device. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Acked-by: Adam Belay <abelay@novell.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] PCI: drivers/pci/: small cleanupsAdrian Bunk
This patch contains the following cleanups: - access.c should #include "pci.h" for getting the prototypes of it's global functions - hotplug/shpchp_pci.c: make the needlessly global function program_fw_provided_values() static Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] PCI: Block config access during BISTBrian King
Some PCI adapters (eg. ipr scsi adapters) have an exposure today in that they issue BIST to the adapter to reset the card. If, during the time it takes to complete BIST, userspace attempts to access PCI config space, the host bus bridge will master abort the access since the ipr adapter does not respond on the PCI bus for a brief period of time when running BIST. On PPC64 hardware, this master abort results in the host PCI bridge isolating that PCI device from the rest of the system, making the device unusable until Linux is rebooted. This patch is an attempt to close that exposure by introducing some blocking code in the PCI code. When blocked, writes will be humored and reads will return the cached value. Ben Herrenschmidt has also mentioned that he plans to use this in PPC power management. Signed-off-by: Brian King <brking@us.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/pci/access.c | 89 ++++++++++++++++++++++++++++++++++++++++++++++++ drivers/pci/pci-sysfs.c | 20 +++++----- drivers/pci/pci.h | 7 +++ drivers/pci/proc.c | 28 +++++++-------- drivers/pci/syscall.c | 14 +++---- include/linux/pci.h | 7 +++ 6 files changed, 134 insertions(+), 31 deletions(-)
