path: root/drivers/parisc/superio.c
2009-12-16parisc: Fixup last users of irq_chip->typenameThomas Gleixner
The typename member of struct irq_chip was kept for migration purposes and is obsolete since more than 2 years. Fix up the leftovers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-07-03parisc: superio: fix build breakageAlexander Beregalov
Usage of parport_pc_probe_port was changed in 28783eb52 (parport: Fix various uses of parport_pc). It introduced this build error: drivers/parisc/superio.c: In function 'superio_parport_init': drivers/parisc/superio.c:437: error: too few arguments to function 'parport_pc_probe_port' Fix it. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-07-03parisc: remove obsolete hw_interrupt_typeThomas Gleixner
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have been kept around for migration reasons. After more than two years it's time to remove them finally. This patch cleans up one of the remaining users. When all such patches hit mainline we can remove the defines and typedefs finally. Impact: cleanup Convert the last remaining users to struct irq_chip and remove the define. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-04-14parport: Fix various uses of parport_pcAlan Cox
These got overlooked first time around. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-13fix early_serial_setup() regressionHelge Deller
Commit b430428a188e8a434325e251d0704af4b88b4711 ("8250: Don't clobber spinlocks.") introduced a regression on the parisc architecture, which broke the handover to the serial port at boottime. early_serial_setup() was changed to only copy a subset of the uart_port fields, and sadly the "type" and "line" fields were forgotten and thus the serial port was not initialized and could not be used for a handover. This patch fixes this by copying the missing fields. As this change to early_serial_setup() doesn't need an initialized spinlock in the uart_port struct any longer, we can drop the spinlock initialization in the superio driver. Cc: David Daney <ddaney@caviumnetworks.com> Cc: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Cc: linux-parisc@vger.kernel.org Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16generic: sparse irqs: use irq_desc() together with dyn_array, instead of ↵Yinghai Lu
irq_desc[] add CONFIG_HAVE_SPARSE_IRQ to for use condensed array. Get rid of irq_desc[] array assumptions. Preallocate 32 irq_desc, and irq_desc() will try to get more. ( No change in functionality is expected anywhere, except the odd build failure where we missed a code site or where a crossing commit itroduces new irq_desc[] usage. ) v2: according to Eric, change get_irq_desc() to irq_desc() Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-18[PARISC] Squelch pci_enable_device __must_check warning in superioKyle McMartin
If we have a SuckyIO, and pci_enable_device fails, we'll be in a world of hurt anyways, so we might as well BUG_ON. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-07-18serial: add early_serial_setup() back to header fileYinghai Lu
early_serial_setup was removed from serial.h, but forgot to put in serial_8250.h Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-27[PARISC] fix section mismatch in superio serial driversHelge Deller
This patch fixes two section mismatches in superio serial setup: WARNING: drivers/built-in.o(.text.superio_serial_init+0x78): Section mismatch: reference to .init.text:early_serial_setup (after 'superio_serial_init') WARNING: drivers/built-in.o(.text.superio_serial_init+0xa4): Section mismatch: reference to .init.text:early_serial_setup (after 'superio_serial_init') Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: PARISC: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-21[PARISC] Misc. janitorial workHelge Deller
Fix a spelling mistake, add a KERN_INFO flag, and fix some whitespace uglies. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-30[PARISC] I/O-Space must be ioremap_nocache()'dHelge Deller
Addresses in F-space must be accessed uncached on most parisc machines. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-24BUG_ON() Conversion in drivers/parisc/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-22[PARISC] Clean up printk in superio.cKyle McMartin
Clean up some of the messages printed by the superio driver by defining a prefix instead of duplicating it in every message. Also some small coding style cleanups. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Make superio.c initialize before any driver needs itKyle McMartin
Convert superio_init to use PCI_FIXUP_FINAL as ohci_pci being called before superio_probe really makes a mess. superio_init will then fail to register irq 20 (the "SuperIO" irq) and BUG() because ohci_pci has stolen it before superio_fixup_irq can be moved USB to irq 1. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Initialize serial spinlocks in superio.cKyle McMartin
git commit 976ecd12b8144d066a23fe97c6fbfc1ac8470af7 changed our locking characteristics, and put the onus of spin_lock_init on superio.c. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
