path: root/drivers/parisc/lba_pci.c
2006-10-04[PARISC] Move LBA and SBA register defines to the common ropes.hKyle McMartin
header. This will allow the use of more constants in the agpgart driver. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Create shared <asm/ropes.h> headerKyle McMartin
Pull out struct sba_device and struct lba_device into a common ropes.h header. Also fold the parisc portion of iosapic.h into this file. (Then delete the useless portion of iosapic.h) Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Stash the lba_device in its struct device drvdataKyle McMartin
2006-10-04[PARISC] Pretty print the name of the lba type on kernel bootKyle McMartin
(it's pretty useless telling a user they have a whole bunch of TR%d.%d LBAs) Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-30[PARISC] I/O-Space must be ioremap_nocache()'dHelge Deller
Addresses in F-space must be accessed uncached on most parisc machines. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Use kzalloc and other janitor-style cleanupsHelge Deller
Helge, o Convert a bunch of kmalloc/memset uses to kzalloc. o pci.c: Add some __read_mostly annotations. o pci.c: Move constant pci_post_reset_delay to asm/pci.h o grfioctl.h: Add A4450A to comment of CRT_ID_VISUALIZE_EG. o Add some consts to perf.c/perf_images.h Matthew, o sticore.c: Add some consts to suppress compile warnings. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Truncate overlapping PAT PDC reported rangesGrant Grundler
Deal with overlapping LBA MMIO resources, rp3440 PDC BUG: PDC reports lmmio range for the last rope that overlaps with the CPU HPA. Console output was: ... Found devices: 1. Storm Peak Fast at 0xfffffffffe798000 [152] { 0, 0x0, 0x889, 0x00004 } 2. Storm Peak Fast at 0xfffffffffe799000 [153] { 0, 0x0, 0x889, 0x00004 } ... FAILED: lba_fixup_bus() request for lmmio_space [fffffffff0000000/fffffffffecffffe] Output is now: LBA: Truncating lmmio_space [fffffffff0000000/fffffffffecffffe] to [fffffffff0000000,fffffffffe797fff] My only concern with this patch is how C8000 (PAT PDC) will report elmmio ranges when a gfx card is installed. I'll have to test this another day. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Add __read_mostly section for pariscHelge Deller
Flag a whole bunch of things as __read_mostly on parisc. Also flag a few branches as unlikely() and cleanup a bit of code. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Convert parisc_device to use struct resource for hpaMatthew Wilcox
Convert pa_dev->hpa from an unsigned long to a struct resource. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Fix up users of ->hpa to use ->hpa.start instead. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-06-27[PATCH] acpi bridge hotadd: ACPI based root bridge hot-addRajesh Shah
When you hot-plug a (root) bridge hierarchy, it may have p2p bridges and devices attached to it that have not been configured by firmware. In this case, we need to configure the devices before starting them. This patch separates device start from device scan so that we can introduce the configuration step in the middle. I kept the existing semantics for pci_scan_bus() since there are a huge number of callers to that function. Also, I have no way of testing the changes I made to the parisc files, so this needs review by those folks. Sorry for the massive cross-post, this touches files in many different places. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
