path: root/drivers/parisc/iosapic.c
2006-10-04[PARISC] Create shared <asm/ropes.h> headerKyle McMartin
Pull out struct sba_device and struct lba_device into a common ropes.h header. Also fold the parisc portion of iosapic.h into this file. (Then delete the useless portion of iosapic.h) Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Allow nested interruptsJames Bottomley
Our prior mode of operation didn't allow nested interrupts because it makes the interrupt code much simpler. However, nested interrupts are better for latency. This code uses the EIEM register to simulate level interrupts and thus achieve nesting. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PARISC] I/O-Space must be ioremap_nocache()'dHelge Deller
Addresses in F-space must be accessed uncached on most parisc machines. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Use kzalloc and other janitor-style cleanupsHelge Deller
Helge, o Convert a bunch of kmalloc/memset uses to kzalloc. o pci.c: Add some __read_mostly annotations. o pci.c: Move constant pci_post_reset_delay to asm/pci.h o grfioctl.h: Add A4450A to comment of CRT_ID_VISUALIZE_EG. o Add some consts to perf.c/perf_images.h Matthew, o sticore.c: Add some consts to suppress compile warnings. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Add IRQ affinitiesJames Bottomley
This really only adds them for the machines I can check SMP on, which is CPU interrupts and IOSAPIC (so not any of the GSC based machines). With this patch, irqbalanced can be used to maintain irq balancing. Unfortunately, irqbalanced is a bit x86 centric, so it doesn't do an incredibly good job, but it does work. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Minor iosapic.c cleanupGrant Grundler
minor cleanup: qualify constant with "UL" Acked-by: "Hmamouche, Youssef" <youssef@ece.utexas.edu> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-09[PATCH] more SPIN_LOCK_UNLOCKED -> DEFINE_SPINLOCK conversionsIngo Molnar
This converts the final 20 DEFINE_SPINLOCK holdouts. (another 580 places are already using DEFINE_SPINLOCK). Build tested on x86. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
