path: root/drivers/oprofile/cpu_buffer.c
2008-07-26x86/oprofile: add IBS support for AMD CPUs, IBS buffer handling routinesBarry Kasindorf
This patchset supports the new profiling hardware available in the latest AMD CPUs in the oProfile driver. Signed-off-by: Barry Kasindorf <barry.kasindorf@amd.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Cc: oprofile-list <oprofile-list@lists.sourceforge.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-14oprofile: don't request cache line alignment for cpu_bufferEric Dumazet
Alignment was previously requested because cpu_buffer was an [NR_CPUS] array, to avoid cache line sharing between CPUS. After commit 608dfddd845da5ab6accef70154c8910529699f7 (oprofile: change cpu_buffer from array to per_cpu variable ), we dont need to force an alignement anymore since cpu_buffer sits in per_cpu zone. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Mike Travis <travis@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28oprofile: change cpu_buffer from array to per_cpu variableMike Travis
Change cpu_buffer from array to per_cpu variable in oprofile functions. [akpm@linux-foundation.org: coding-style fixes] Cc: Philippe Elie <phil.el@wanadoo.fr> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14oProfile: oops when profile_pc() returns ~0LUPhilippe Elie
Instruction pointer returned by profile_pc() can be a random value. This break the assumption than we can safely set struct op_sample.eip field to a magic value to signal to the per-cpu buffer reader side special event like task switch ending up in a segfault in get_task_mm() when profile_pc() return ~0UL. Fixed by sanitizing the sampled eip and reject/log invalid eip. Problem reported by Sami Farin, patch tested by him. Signed-off-by: Philippe Elie <phil.el@wanadoo.fr> Tested-by: Sami Farin <safari-kernel@safari.iki.fi> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-03-28[PATCH] Add oprofile_add_ext_sampleBrian Rogan
On ppc64 we look at a profiling register to work out the sample address and if it was in userspace or kernel. The backtrace interface oprofile_add_sample does not allow this. Create oprofile_add_ext_sample and make oprofile_add_sample use it too. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: John Levon <levon@movementarian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] more for_each_cpu() conversionsAndrew Morton
When we stop allocating percpu memory for not-possible CPUs we must not touch the percpu data for not-possible CPUs at all. The correct way of doing this is to test cpu_possible() or to use for_each_cpu(). This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very few instances of this bug, if any. But the patch converts lots of open-coded test to use the preferred helper macros. Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Cc: Christian Zankel <chris@zankel.net> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: Nathan Scott <nathans@sgi.com> Cc: Jens Axboe <axboe@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] oprofile: Use vmalloc_node() in alloc_cpu_buffers()Eric Dumazet
Make oprofile alloc_cpu_buffers() function NUMA aware, allocating each CPU local buffer in its memory node if possible. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: John Levon <levon@movementarian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
