path: root/drivers/of/of_i2c.c
2008-12-03of/i2c: Fill the archdata for I2C devicesAnton Vorontsov
For I2C devices we just setting the node pointer in the archdata. This is needed so that the I2C devices could find their OF tree nodes. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-10-21of: Format string bug in drivers/of/of_i2c.cJon Smirl
Format string bug. Not exploitable, as this is only writable by root, but worth fixing all the same. See 326f6a5c9c9e1a62aec37bdc0c3f8d53adabe77b Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-25of: adapt of_find_i2c_driver() to be usable by SPI alsoGrant Likely
SPI has a similar problem as I2C in that it needs to determine an appropriate modalias value for each device node. This patch adapts the of_i2c of_find_i2c_driver() function to be usable by of_spi also. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-22powerpc/mpc5200: Fix wrong 'no interrupt' handling in of_i2cWolfram Sang
If an I2C device node does not specify an interrupt, the .irq member of the board_info struct was set to -1. This caused crashes on following irq_dispose_mappings. Leave it NO_IRQ as returned from irq_of_parse_and_map. (Suggesting -1 as 'i2c-no-irq' used to be a bug in linux/i2c.h.) Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Sean MacLennan <smaclennan@pikatech.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-12OpenFirmware: Include <linux/of_i2c.h> from of_i2c.c.Robert P. J. Day
drivers/of/of_i2c.c should include <linux/of_i2c.h> for the prototype for of_register_i2c_devices(). Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: Jochen Friedrich <jochen@scram.de> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-06-06rtc-ds1374: rename device to just "ds1374"Jean Delvare
Change the name of the device from "rtc-ds1374" to just "ds1374", to match what all other RTC drivers do. I seem to remember that this name was chosen to avoid possible confusion with an older ds1374 driver, but that driver was removed 3 months ago. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Kumar Gala <galak@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24[POWERPC] drivers/of/of_i2c.c: Add MODULE_LICENSEAdrian Bunk
After commit 585468e5d5962660867c269e26f0a4b89a599473 ([POWERPC] i2c: Fix build breakage introduced by OF helpers) drivers/of/of_i2c.c needs a MODULE_LICENSE. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-20[POWERPC] i2c: Fix build breakage introduced by OF helpersJochen Friedrich
Fix build breakage introduced in commit "[POWERPC] i2c: OF helpers for the i2c API". If i2c-core is compiled as a module, the helper needs to be compiled as a module, as well. Rename i2c.c to of_i2c.c to avoid name space conflict. [paulus@samba.org: Changed dependency from OF to PPC_OF to avoid sparc{32,64} allmodconfig breakage.] Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
