Another device using 8390 library that needs converting.
Commit bea3348eef27e6044b6161fd04c3152215f96411
"[NET]: Make NAPI polling independent of struct net_device objects."
made NAPI polling to be independent of net_device.
So e1000_adapter->polling_netdev is no longer used.
Kill it.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
Seems the ixgbe's code was copied from e1000.
The comment talks about something not exist.
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Although the hardware supports the 64bit DMA address in design,
but later found that it actually not working.
This patch reduced the rang to 32bit.
Found-by: "Ethan" <ethanhsiao@jmicron.com>
Signed-off-by: "Guo-Fu Tseng" <cooldavid@cooldavid.org>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Due to the hardware design, except the first chip on the market,
other chips needs to setup the clock source for MAC processor
implicitly through Global Host Control Register(GHC).
(Strange design huh?)
10/100M uses the PCI-E as clock source, and 1G uses GPHY.
And I reordered the code a little, to make it easier to read.
Fixed-by: "akeemting" <akeem@jmicron.com>
Simply replace netdev->priv with netdev_priv().
Bring the physical link down when the interface is down by placing the PHY
in power-down state, unless WOL is enabled. This mirrors the behavior of
other drivers including e1000 and tg3.
Without the patch, ifconfig down leaves the physical link up, which confuses
datacenter users who expect the link lights both on the NIC and the switch to
go out when they bring an interface down.
Furthermore, even though the phy is powered on, autonegotiation stops working,
so a normally gigabit link might suddenly become 100 Mbit half-duplex when the
interface goes down, and become gigabit when it comes up again.
Ayaz said:
I would not include this patch until further testing is performed. NVIDIA
MCP chips use 3rd party PHY vendors. By powering down the phy, it could
have adverse affects on certain phys.
Arthur Jones said:
I just ran across this patch. Tested on a Marvell 88E1121R (GigE PHY)
and works great. This is a very important feature for me.
Signed-off-by: Ed Swierk <eswierk@arastra.com>
Tested-by: Arthur Jones <ajones@riverbed.com>
Save an ugly ifdef.
drivers/net/ixgbe/ixgbe_main.c
drivers/net/smc91x.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
MAINTAINERS: add netdev to ATM
ATM: horizon, fix hrz_probe fail path
pppol2tp: Add missing sock_put() in pppol2tp_release()
net: Fix soft lockups/OOM issues w/ unix garbage collector
macvlan: don't broadcast PAUSE frames to macvlan devices
Phonet: fix oops in phonet_address_del() on non-Phonet device
netfilter: ctnetlink: fix GFP_KERNEL allocation under spinlock
sungem: Fix PCS_MIICTRL register write in gem_init_phy().
net: make skb_truesize_bug() call WARN()
net: hp-plus uses eip_poll
net/wireless/reg.c: fix bad WARN_ON in if statement
ath5k: disable beacon filter when station is not associated
ath5k: fix Security issue in DebugFS part of ath5k
ath9k: correct expected max RX buffer size
ath9k: Fix SW-IOMMU bounce buffer starvation
mac80211 : Fix setting ad-hoc mode and non-ibss channel
iwlagn: fix DMA sync
phylib: Add Vitesse VSC8221 SGMII PHY
rose: zero length frame filtering in af_rose.c
bridge: netfilter: fix update_pmtu crash with GRE
ssh://master.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus
Another related 8390 driver. Since this is for nubus, not sure if
anyone still has the hardware?
Fix build of ARM etherh driver with new net_device_ops.
We don't really have a max tx packet size limit, so allow configuring
the device with up to 64k tx MTU.
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/mlx4: Fix MTT leakage in resize CQ
IB/ehca: Fix problem with generated flush work completions
IB/ehca: Change misleading error message on memory hotplug
mlx4_core: Save/restore default port IB capability mask
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
powerpc: Fix system calls on Cell entered with XER.SO=1
powerpc/cell: Fix GDB watchpoints, again
powerpc/mpic: Don't reset affinity for secondary MPIC on boot
powerpc/cell/axon-msi: Retry on missing interrupt
powerpc: Fix boot freeze on machine with empty memory node
powerpc: Fix IRQ assignment for some PCIe devices
powerpc/spufs: Fix spinning in spufs_ps_fault on signal
powerpc/mpc832x_rdb: fix swapped ethernet ids
powerpc: Use generic PHY driver for Marvell 88E1111 PHY on GE Fanuc SBC610
powerpc/85xx: L2 cache size wrong in 8572DS dts
powerpc/virtex: Update defconfigs
powerpc/52xx: update defconfigs
xsysace: Fix driver to use resource_size_t instead of unsigned long
powerpc/virtex: fix various format/casting printk mismatches
powerpc/mpc5200: fix bestcomm Kconfig dependencies
powerpc/44x: Fix 460EX/460GT machine check handling
powerpc/40x: Limit allocable DRAM during early mapping
... by giving the instances' names magic suffix recognized by modpost ;-/
Their ->probe() is __devinit
a) ->probe() can be __devinit; no need to put it into .text
b) calling __init stuff from it, OTOH, is wrong
c) ->remove() is __devexit fodder
Acked-by: rmk+kernel@arm.linux.org.uk
ibmtr_resume() is calling ibmtr_probe(), which is devinit. Whether
that's the right thing to do there is a separate question, but
since it's PCMCIA and thus will never compile without HOTPLUG...
ixgbe_init_interrupt_scheme() is called from ixgbe_resume(). Build that
with CONFIG_PM and without CONFIG_HOTPLUG and you've got a problem.
Several helpers called by it also are misannotated __devinit.
pppol2tp_sock_to_session() do sock_hold() if the session to release is
not NULL.
Signed-off-by: Frédéric Moulins <frederic.moulins@alsatis.com>
The function is_pure_response() does "ntohl(var) & const" and then
essentially just tests whether the result is 0 or not; this can be done
more efficiently by computing "var & htonl(const)" instead and doing the
byte swap at compile time instead of run time.
This change slightly shrinks the compiled code; eg on x86-64 we save a
couple of bswapl instructions:
add/remove: 0/0 grow/shrink: 0/1 up/down: 0/-8 (-8)
function old new delta
t3_sge_intr_msix_napi 544 536 -8
and this also has the pleasant side effect of fixing a sparse warning:
drivers/net/cxgb3/sge.c:2313:15: warning: restricted degrades to integer
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Commit 7ff93f8b ("mlx4_core: Multiple port type support") introduced
support for different port types. As part of that support, SET_PORT
is invoked to set the port type during driver startup. However, as a
side-effect, for IB ports the invocation of this command also sets the
port's capability mask to zero (losing the default value set by FW).
To fix this, get the default ib port capabilities (via a MAD_IFC Port
Info query) during driver startup, and save them for use in the
mlx4_SET_PORT command when setting the port-type to Infiniband.
This patch fixes problems with subnet manager (SM) failover such as
<https://bugs.openfabrics.org/show_bug.cgi?id=1183>, which occurred
because the IsTrapSupported bit in the capability mask was zeroed.
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
This patch adds the STMicroelectronics ste10xp PHY device driver.
It supports both the ste100p and the ste101p devices.
Suspend/resume alredy added.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
This patch adds the power management support into the physical
abstraction layer.
Suspend and resume functions respectively turns on/off the bit 11
into the PHY Basic mode control register.
Generic PHY device starts supporting PM.
In order to support the wake-on LAN and avoid to put in power down
the PHY device, the MDIO is aware of what the Ethernet device wants to do.
Voluntary, no CONFIG_PM defines were added into the sources.
Also generic suspend/resume functions are exported to allow
other drivers use them (such as genphy_config_aneg etc.).
Within the phy_driver_register function, we need to remove the
memset. It overrides the device driver owner and it is not good.
This patch adds the PHY device driver for the National Semiconductor
DP83865 Gig PHYTER.
These warning originate from 50014f1 (ne2: convert to
net_device_ops) which did drop those functions.
drivers/net/ne2.c:140: warning: 'ne_open' declared 'static' but never defined
drivers/net/ne2.c:141: warning: 'ne_close' declared 'static' but never defined
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Add the calls necessary to enable advanced error reporting for igb on
systems with AER enabled.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
The system log messages created on a link status change need to follow a
specific format to work with tools some customers use. This also makes
the messages consistant with other Intel driver link messages.
drivers/net/hp-plus.c
drivers/net/wireless/ath5k/base.c
drivers/net/wireless/ath9k/recv.c
net/wireless/reg.c
Update FW loading path to accomodate in-kernel images location
Signed-off-by: Divy Le Ray <divy@chelsio.com>
Add consistency in alloc_ring() parameter checking
to avoid potential memory leaks.
alloc_ring() callers are correct fo far.
Fix t3_eth_xmit() missing into the netdev_ops structure.
PAUSE frames are only relevant for the real device, broadcasting them
to all macvlan devices can cause a significant load increase.
Reported-by: Ben Greear <greearb@candelatech.com>
Tested-by: Ben Greear <greearb@candelatech.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Some print_mac -> %pM conversions got lost in some merge or another...
This patch fixes a regression (introduced by
"p54: more definitions form lmac_longbow.h and pda.h")
It turned out that the "ret" variable wasn't initialized and
this caused the following warnings/errors to appear:
wmaster1: failed to set TX queue parameters for queue 2
wmaster1: failed to set TX queue parameters for queue 3
wmaster1: failed to set TX queue parameters for queue 1
wmaster1: failed to set TX queue parameters for queue 0
Signed-off-by: Christian Lamparter <chunkeey@web.de>
The TX channel width of the BSS can be obtained only after association.
In all cases, default to HT20 if HT is enabled, and set
chan width to HT40 only if the BSS supports it.
Signed-off-by: Sujith <Sujith.Manoharan@atheros.com>
Merge core.c and base.c
Remove Antenna Diversity (unused now).
Remove unused chainmask handling code.
Comment, indentation scrub.
Make firmware caching on startup optional, and make it default.
When the option is not selected and PM_SLEEP is configured, then
cache firmware in the suspend pm_notifier. This configuration saves
about 64k RAM in normal use, but can lead to a situation where the
driver is configured to use a different firmware.
Signed-off by: David Kilroy <kilroyd@googlemail.com>
Retrieval of external firmware has been resolved, and should work with
the standard orinoco resume algorithm.
This fixes an issue where priv->hw_unavailable indicates the card is
ready when firmware has not been loaded.
