path: root/drivers/net
2016-05-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix negative error code usage in ATM layer, from Stefan Hajnoczi. 2) If CONFIG_SYSCTL is disabled, the default TTL is not initialized properly. From Ezequiel Garcia. 3) Missing spinlock init in mvneta driver, from Gregory CLEMENT. 4) Missing unlocks in hwmb error paths, also from Gregory CLEMENT. 5) Fix deadlock on team->lock when propagating features, from Ivan Vecera. 6) Work around buffer offset hw bug in alx chips, from Feng Tang. 7) Fix double listing of SCTP entries in sctp_diag dumps, from Xin Long. 8) Various statistics bug fixes in mlx4 from Eric Dumazet. 9) Fix some randconfig build errors wrt fou ipv6 from Arnd Bergmann. 10) All of l2tp was namespace aware, but the ipv6 support code was not doing so. From Shmulik Ladkani. 11) Handle on-stack hrtimers properly in pktgen, from Guenter Roeck. 12) Propagate MAC changes properly through VLAN devices, from Mike Manning. 13) Fix memory leak in bnx2x_init_one(), from Vitaly Kuznetsov. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (62 commits) sfc: Track RPS flow IDs per channel instead of per function usbnet: smsc95xx: fix link detection for disabled autonegotiation virtio_net: fix virtnet_open and virtnet_probe competing for try_fill_recv bnx2x: avoid leaking memory on bnx2x_init_one() failures fou: fix IPv6 Kconfig options openvswitch: update checksum in {push,pop}_mpls sctp: sctp_diag should dump sctp socket type net: fec: update dirty_tx even if no skb vlan: Propagate MAC address to VLANs atm: iphase: off by one in rx_pkt() atm: firestream: add more reserved strings vxlan: Accept user specified MTU value when create new vxlan link net: pktgen: Call destroy_hrtimer_on_stack() timer: Export destroy_hrtimer_on_stack() net: l2tp: Make l2tp_ip6 namespace aware Documentation: ip-sysctl.txt: clarify secure_redirects sfc: use flow dissector helpers for aRFS ieee802154: fix logic error in ieee802154_llsec_parse_dev_addr net: nps_enet: Disable interrupts before napi reschedule net/lapb: tuse %*ph to dump buffers ...
2016-05-31sfc: Track RPS flow IDs per channel instead of per functionJon Cooper
Otherwise we get confused when two flows on different channels get the same flow ID. Signed-off-by: Edward Cree <ecree@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-31usbnet: smsc95xx: fix link detection for disabled autonegotiationChristoph Fritz
To detect link status up/down for connections where autonegotiation is explicitly disabled, we don't get an irq but need to poll the status register for link up/down detection. This patch adds a workqueue to poll for link status. Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-31virtio_net: fix virtnet_open and virtnet_probe competing for try_fill_recvwangyunjian
In function virtnet_open() and virtnet_probe(), func try_fill_recv() may be executed at the same time. VQ in virtqueue_add() has not been protected well and BUG_ON will be triggered when virito_net.ko being removed. Signed-off-by: Yunjian Wang <wangyunjian@huawei.com> Acked-by: Jason Wang <jasowang@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-31bnx2x: avoid leaking memory on bnx2x_init_one() failuresVitaly Kuznetsov
bnx2x_init_bp() allocates memory with bnx2x_alloc_mem_bp() so if we fail later in bnx2x_init_one() we need to free this memory with bnx2x_free_mem_bp() to avoid leakages. E.g. I'm observing memory leaks reported by kmemleak when a failure (unrelated) happens in bnx2x_vfpf_acquire(). Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com> Acked-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-31net: fec: update dirty_tx even if no skbTroy Kisky
If dirty_tx isn't updated, then dma_unmap_single can be called twice. This fixes a [ 58.420980] ------------[ cut here ]------------ [ 58.425667] WARNING: CPU: 0 PID: 377 at /home/schurig/d/mkarm/linux-4.5/lib/dma-debug.c:1096 check_unmap+0x9d0/0xab8() [ 58.436405] fec 2188000.ethernet: DMA-API: device driver tries to free DMA memory it has not allocated [device address=0x0000000000000000] [size=66 bytes] encountered by Holger Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Tested-by: <holgerschurig@gmail.com> Acked-by: Fugang Duan <fugang.duan@nxp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-31vxlan: Accept user specified MTU value when create new vxlan linkChen Haiquan
When create a new vxlan link, example: ip link add vtap mtu 1440 type vxlan vni 1 dev eth0 The argument "mtu" has no effect, because it is not set to conf->mtu. The default value is used in vxlan_dev_configure function. This problem was introduced by commit 0dfbdf4102b9 (vxlan: Factor out device configuration). Fixes: 0dfbdf4102b9 (vxlan: Factor out device configuration) Signed-off-by: Chen Haiquan <oc@yunify.com> Acked-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-29sfc: use flow dissector helpers for aRFSEdward Cree
2016-05-29net: nps_enet: Disable interrupts before napi rescheduleElad Kanfi
Since NAPI works by shutting down event interrupts when theres work and turning them on when theres none, the net driver must make sure that interrupts are disabled when it reschedules polling. By calling napi_reschedule, the driver switches to polling mode, therefor there should be no interrupt interference. Any received packets will be handled in nps_enet_poll by polling the HW indication of received packet until all packets are handled. Signed-off-by: Elad Kanfi <eladkan@mellanox.com> Acked-by: Noam Camus <noamca@mellanox.com> Tested-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-27remove lots of IS_ERR_VALUE abusesArnd Bergmann
Most users of IS_ERR_VALUE() in the kernel are wrong, as they pass an 'int' into a function that takes an 'unsigned long' argument. This happens to work because the type is sign-extended on 64-bit architectures before it gets converted into an unsigned type. However, anything that passes an 'unsigned short' or 'unsigned int' argument into IS_ERR_VALUE() is guaranteed to be broken, as are 8-bit integers and types that are wider than 'unsigned long'. Andrzej Hajda has already fixed a lot of the worst abusers that were causing actual bugs, but it would be nice to prevent any users that are not passing 'unsigned long' arguments. This patch changes all users of IS_ERR_VALUE() that I could find on 32-bit ARM randconfig builds and x86 allmodconfig. For the moment, this doesn't change the definition of IS_ERR_VALUE() because there are probably still architecture specific users elsewhere. Almost all the warnings I got are for files that are better off using 'if (err)' or 'if (err < 0)'. The only legitimate user I could find that we get a warning for is the (32-bit only) freescale fman driver, so I did not remove the IS_ERR_VALUE() there but changed the type to 'unsigned long'. For 9pfs, I just worked around one user whose calling conventions are so obscure that I did not dare change the behavior. I was using this definition for testing: #define IS_ERR_VALUE(x) ((unsigned long*)NULL == (typeof (x)*)NULL && \ unlikely((unsigned long long)(x) >= (unsigned long long)(typeof(x))-MAX_ERRNO)) which ends up making all 16-bit or wider types work correctly with the most plausible interpretation of what IS_ERR_VALUE() was supposed to return according to its users, but also causes a compile-time warning for any users that do not pass an 'unsigned long' argument. I suggested this approach earlier this year, but back then we ended up deciding to just fix the users that are obviously broken. After the initial warning that caused me to get involved in the discussion (fs/gfs2/dir.c) showed up again in the mainline kernel, Linus asked me to send the whole thing again. [ Updated the 9p parts as per Al Viro - Linus ] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andrzej Hajda <a.hajda@samsung.com> Cc: Andrew Morton <akpm@linux-foundation.org> Link: https://lkml.org/lkml/2016/1/7/363 Link: https://lkml.org/lkml/2016/5/27/486 Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> # For nvmem part Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-26qed: Don't config min BW on 100g on link flapYuval Mintz
Currently 100g devices don't support minimum/maximum BW configurations, yet link flaps might cause the driver to attempt to do such a configuration. Prevent this just as we do for the maximum BW. Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-26qed: Prevent 100g from working in MSISudarsana Reddy Kalluru
Adapter can support 100g in both MSIx and INTa, but not in MSI. Signed-off-by: Sudarsana Reddy Kalluru <sudarsana.kalluru@qlogic.com> Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-26qed: Add missing 100g init modeYuval Mintz
Some of the HW configurations are currently missing for 100g devices. This can cause various classification issues, as well as prevent device from fully reaching line-rate. Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-26qed: Save min/max accross dcbx-changeYuval Mintz
When DCBx re-negotiation is occurring, the PF's configurations for maximum and minimum bandwidth guarantees are currently lost. Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-26qed: Fix allocation in interrupt contextSudarsana Reddy Kalluru
Commit 39651abd2814 ("qed: add support for dcbx") is re-configuring the QM hw-block as part of its sequence. This is done in attention handling context which is non-sleepable, yet memory is allocated in this flow using GFP_KERNEL. Signed-off-by: Sudarsana Reddy Kalluru <sudarsana.kalluru@qlogic.com> Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-26qede: Don't expose self-test for VFsYuval Mintz
PFs and VFs differ in their registered ethtool operations, but they're using a common function for get_sset_count(). As a result, `ethtool -i' for a VF would indicate it supports selftest, although that's not the case. Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-26qede: Reload on GRO changesYuval Mintz
Since driver is using a FW-based GRO implementation, this has some effects on its ability to cope with GRO enablement/disablement. As a result, driver must perform an inner-reload as a result of a state change in the offload configuration of said feature. [Failure to do so means network stack would continue to receive aggregated packets even though user requested the feature to be disabled]. Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-26qede: Fix VF minimum BW settingYuval Mintz
VF is currently ignoring the minimum provided by the API, mistakenly using the maximum for minimum as well. Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-25net/mlx4_en: get rid of private net_device_statsEric Dumazet
We simply can use the standard net_device stats. We do not need to clear fields that are already 0. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Cc: Eugenia Emantayev <eugenia@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-25net/mlx4_en: get rid of ret_statsEric Dumazet
mlx4 uses a private struct net_device_stats in a vain attempt to avoid races. This is buggy because multiple cpus could call mlx4_en_get_stats() at the same time, so ret_stats can not guarantee stable results. To fix this, we need to switch to ndo_get_stats64() as this method provides per-thread storage. This allows to reduce mlx4_en_priv bloat. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Cc: Eugenia Emantayev <eugenia@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-25net/mlx4_en: clear some TX ring stats in mlx4_en_clear_stats()Eric Dumazet
mlx4_en_clear_stats() clears about everything but few TX ring fields are missing : - queue_stopped, wake_queue, tso_packets, xmit_more Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Cc: Eugenia Emantayev <eugenia@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-25net/mlx4_en: fix tx_dropped bugEric Dumazet
1) mlx4_en_xmit() can increment priv->stats.tx_dropped, but this variable is overwritten in mlx4_en_DUMP_ETH_STATS(). 2) This increment was not SMP safe, as a port might have many TX queues. Add a per TX ring tx_dropped to fix these issues. This is u32 as mlx4_en_DUMP_ETH_STATS() will add a 32bit field. So lets avoid bugs with SNMP agents having to cope with partial overwraps. (One of these agents being bond_fold_stats()) Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Willem de Bruijn <willemb@google.com> Cc: Eugenia Emantayev <eugenia@mellanox.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-25net: arc: trivial: Replace comma with a semicolonMarek Vasut
Fix a typo in the driver, replace comma with a semicolon at the end of statement. While using comma is a legal C here and probably does not even generate compiler warning, it was unlikely the intention. Signed-off-by: Marek Vasut <marex@denx.de> Cc: David S. Miller <davem@davemloft.net> Cc: Caesar Wang <wxt@rock-chips.com> Cc: Heiko Stuebner <heiko@sntech.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-25net: stmmac: Fix incorrect memcpy source memoryMarek Vasut
The memcpy() currently copies mdio_bus_data into new_bus->irq, which makes no sense, since the mdio_bus_data structure contains more than just irqs. The code was likely supposed to copy mdio_bus_data->irqs into the new_bus->irq instead, so fix this. Fixes: e7f4dc3536a4 ("mdio: Move allocation of interrupts into core") Signed-off-by: Marek Vasut <marex@denx.de> Cc: David S. Miller <davem@davemloft.net> Cc: Giuseppe Cavallaro <peppe.cavallaro@st.com> Cc: Alexandre Torgue <alexandre.torgue@st.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-25net: alx: use custom skb allocatorFeng Tang
This patch follows Eric Dumazet's commit 7b70176421 for Atheros atl1c driver to fix one exactly same bug in alx driver, that the network link will be lost in 1-5 minutes after the device is up. My laptop Lenovo Y580 with Atheros AR8161 ethernet device hit the same problem with kernel 4.4, and it will be cured by Jarod Wilson's commit c406700c for alx driver which get merged in 4.5. But there are still some alx devices can't function well even with Jarod's patch, while this patch could make them work fine. More details on https://bugzilla.kernel.org/show_bug.cgi?id=70761 The debug shows the issue is very likely to be related with the RX DMA address, specifically 0x...f80, if RX buffer get 0x...f80 several times, their will be RX overflow error and device will stop working. For kernel 4.5.0 with Jarod's patch which works fine with my AR8161/Lennov Y580, if I made some change to the __netdev_alloc_skb --> __alloc_page_frag() to make the allocated buffer can get an address with 0x...f80, then the same error happens. If I make it to 0x...f40 or 0x....fc0, everything will be still fine. So I tend to believe that the 0x..f80 address cause the silicon to behave abnormally. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=70761 Cc: Eric Dumazet <edumazet@google.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Jarod Wilson <jarod@redhat.com> Signed-off-by: Feng Tang <feng.tang@intel.com> Tested-by: Ole Lukoie <olelukoie@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-25team: don't call netdev_change_features under team->lockIvan Vecera
The team_device_event() notifier calls team_compute_features() to fix vlan_features under team->lock to protect team->port_list. The problem is that subsequent __team_compute_features() calls netdev_change_features() to propagate vlan_features to upper vlan devices while team->lock is still taken. This can lead to deadlock when NETIF_F_LRO is modified on lower devices or team device itself. Example: The team0 as active backup with eth0 and eth1 NICs. Both eth0 & eth1 are LRO capable and LRO is enabled. Thus LRO is also enabled on team0. The command 'ethtool -K team0 lro off' now hangs due to this deadlock: dev_ethtool() -> ethtool_set_features() -> __netdev_update_features(team) -> netdev_sync_lower_features() -> netdev_update_features(lower_1) -> __netdev_update_features(lower_1) -> netdev_features_change(lower_1) -> call_netdevice_notifiers(...) -> team_device_event(lower_1) -> team_compute_features(team) [TAKES team->lock] -> netdev_change_features(team) -> __netdev_update_features(team) -> netdev_sync_lower_features() -> netdev_update_features(lower_2) -> __netdev_update_features(lower_2) -> netdev_features_change(lower_2) -> call_netdevice_notifiers(...) -> team_device_event(lower_2) -> team_compute_features(team) [DEADLOCK] The bug is present in team from the beginning but it appeared after the commit fd867d5 (net/core: generic support for disabling netdev features down stack) that adds synchronization of features with lower devices. Fixes: fd867d5 (net/core: generic support for disabling netdev features down stack) Cc: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Ivan Vecera <ivecera@redhat.com> Signed-off-by: Jiri Pirko <jiri@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-25sfc: on MC reset, clear PIO buffer linkage in TXQsEdward Cree
Otherwise, if we fail to allocate new PIO buffers, our TXQs will try to use the old ones, which aren't there any more. Fixes: 183233bec810 "sfc: Allocate and link PIO buffers; map them with write-combining" Signed-off-by: Edward Cree <ecree@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-25net: mvneta: Fix lacking spinlock initializationGregory CLEMENT
The spinlock used by the hwbm functions must be initialized by the network driver. This commit fixes this lack and the following erros when lockdep is enabled: INFO: trying to register non-static key. the code is fine but needs lockdep annotation. turning off the locking correctness validator. [<c010ff80>] (unwind_backtrace) from [<c010bd08>] (show_stack+0x10/0x14) [<c010bd08>] (show_stack) from [<c032913c>] (dump_stack+0xb4/0xe0) [<c032913c>] (dump_stack) from [<c01670e4>] (__lock_acquire+0x1f58/0x2060) [<c01670e4>] (__lock_acquire) from [<c0167dec>] (lock_acquire+0xa4/0xd0) [<c0167dec>] (lock_acquire) from [<c06f6650>] (_raw_spin_lock_irqsave+0x54/0x68) [<c06f6650>] (_raw_spin_lock_irqsave) from [<c058e830>] (hwbm_pool_add+0x1c/0xdc) [<c058e830>] (hwbm_pool_add) from [<c043f4e8>] (mvneta_bm_pool_use+0x338/0x490) [<c043f4e8>] (mvneta_bm_pool_use) from [<c0443198>] (mvneta_probe+0x654/0x1284) [<c0443198>] (mvneta_probe) from [<c03b894c>] (platform_drv_probe+0x4c/0xb0) [<c03b894c>] (platform_drv_probe) from [<c03b7158>] (driver_probe_device+0x214/0x2c0) [<c03b7158>] (driver_probe_device) from [<c03b72c4>] (__driver_attach+0xc0/0xc4) [<c03b72c4>] (__driver_attach) from [<c03b5440>] (bus_for_each_dev+0x68/0x9c) [<c03b5440>] (bus_for_each_dev) from [<c03b65b8>] (bus_add_driver+0x1a0/0x218) [<c03b65b8>] (bus_add_driver) from [<c03b79cc>] (driver_register+0x78/0xf8) [<c03b79cc>] (driver_register) from [<c01018f4>] (do_one_initcall+0x90/0x1dc) [<c01018f4>] (do_one_initcall) from [<c0900de4>] (kernel_init_freeable+0x15c/0x1fc) [<c0900de4>] (kernel_init_freeable) from [<c06eed90>] (kernel_init+0x8/0x114) [<c06eed90>] (kernel_init) from [<c0107910>] (ret_from_fork+0x14/0x24) Fixes: baa11ebc0c76 ("net: mvneta: Use the new hwbm framework") Reported-by: Russell King <rmk+kernel@armlinux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-25qed: Reset the enable flag for eth protocol.Sudarsana Reddy Kalluru
This patch fixes the coding error in determining the enable flag for the application/protocol. The enable flag should be set for all protocols but the eth. Signed-off-by: Sudarsana Reddy Kalluru <sudarsana.kalluru@qlogic.com> Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-24net/qlge: Avoids recursive EEH errorGavin Shan
One timer, whose handler keeps reading on MMIO register for EEH core to detect error in time, is started when the PCI device driver is loaded. MMIO register can't be accessed during PE reset in EEH recovery. Otherwise, the unexpected recursive error is triggered. The timer isn't closed that time if the interface isn't brought up. So the unexpected recursive error is seen during EEH recovery when the interface is down. This avoids the unexpected recursive EEH error by closing the timer in qlge_io_error_detected() before EEH PE reset unconditionally. The timer is started unconditionally after EEH PE reset in qlge_io_resume(). Also, the timer should be closed unconditionally when the device is removed from the system permanently in qlge_io_error_detected(). Reported-by: Shriya R. Kulkarni <shriyakul@in.ibm.com> Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-23qed: signedness bug in qed_dcbx_process_tlv()Dan Carpenter
"priority" needs to be signed for the error handling to work. Fixes: 39651abd2814 ('qed: add support for dcbx.') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-23net: hns: avoid null pointer dereferencexypron.glpk@gmx.de
In the statement assert(priv || priv->ae_handle); the right side of || is only evaluated if priv is null. v2: As suggested by David Leight and David Miller the assert statements are removed. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-23net: pegasus: simplify logical constraintxypron.glpk@gmx.de
If !count is true, count < 4 is also true. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc updates from David Miller: "Some 32-bit kgdb cleanups from Sam Ravnborg, and a hugepage TLB flush overhead fix on 64-bit from Nitin Gupta" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Reduce TLB flushes during hugepte changes aeroflex/greth: fix warning about unused variable openprom: fix warning sparc32: drop superfluous cast in calls to __nocache_pa() sparc32: fix build with STRICT_MM_TYPECHECKS sparc32: use proper prototype for trapbase sparc32: drop local prototype in kgdb_32 sparc32: drop hardcoding trap_level in kgdb_trap
2016-05-20Merge tag 'driver-core-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here's the "big" driver core update for 4.7-rc1. Mostly just debugfs changes, the long-known and messy races with removing debugfs files should be fixed thanks to the great work of Nicolai Stange. We also have some isa updates in here (the x86 maintainers told me to take it through this tree), a new warning when we run out of dynamic char major numbers, and a few other assorted changes, details in the shortlog. All have been in linux-next for some time with no reported issues" * tag 'driver-core-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (32 commits) Revert "base: dd: don't remove driver_data in -EPROBE_DEFER case" gpio: ws16c48: Utilize the ISA bus driver gpio: 104-idio-16: Utilize the ISA bus driver gpio: 104-idi-48: Utilize the ISA bus driver gpio: 104-dio-48e: Utilize the ISA bus driver watchdog: ebc-c384_wdt: Utilize the ISA bus driver iio: stx104: Utilize the module_isa_driver and max_num_isa_dev macros iio: stx104: Add X86 dependency to STX104 Kconfig option Documentation: Add ISA bus driver documentation isa: Implement the max_num_isa_dev macro isa: Implement the module_isa_driver macro pnp: pnpbios: Add explicit X86_32 dependency to PNPBIOS isa: Decouple X86_32 dependency from the ISA Kconfig option driver-core: use 'dev' argument in dev_dbg_ratelimited stub base: dd: don't remove driver_data in -EPROBE_DEFER case kernfs: Move faulting copy_user operations outside of the mutex devcoredump: add scatterlist support debugfs: unproxify files created through debugfs_create_u32_array() debugfs: unproxify files created through debugfs_create_blob() debugfs: unproxify files created through debugfs_create_bool() ...
2016-05-20Merge tag 'tty-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty and serial driver updates from Greg KH: "Here's the large TTY and Serial driver update for 4.7-rc1. A few new serial drivers are added here, and Peter has fixed a bunch of long-standing bugs in the tty layer and serial drivers as normal. Full details in the shortlog. All of these have been in linux-next for a while with no reported issues" * tag 'tty-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (88 commits) MAINTAINERS: 8250: remove website reference serial: core: Fix port mutex assert if lockdep disabled serial: 8250_dw: fix wrong logic in dw8250_check_lcr() tty: vt, finish looping on duplicate tty: vt, return error when con_startup fails QE-UART: add "fsl,t1040-ucc-uart" to of_device_id serial: mctrl_gpio: Drop support for out1-gpios and out2-gpios serial: 8250dw: Add device HID for future AMD UART controller Fix OpenSSH pty regression on close serial: mctrl_gpio: add IRQ locking serial: 8250: Integrate Fintek into 8250_base serial: mps2-uart: add support for early console serial: mps2-uart: add MPS2 UART driver dt-bindings: document the MPS2 UART bindings serial: sirf: Use generic uart-has-rtscts DT property serial: sirf: Introduce helper variable struct device_node *np serial: mxs-auart: Use generic uart-has-rtscts DT property serial: imx: Use generic uart-has-rtscts DT property doc: DT: Add Generic Serial Device Tree Bindings serial: 8250: of: Make tegra_serial_handle_break() static ...
2016-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes and more updates from David Miller: 1) Tunneling fixes from Tom Herbert and Alexander Duyck. 2) AF_UNIX updates some struct sock bit fields with the socket lock, whereas setsockopt() sets overlapping ones with locking. Seperate out the synchronized vs. the AF_UNIX unsynchronized ones to avoid corruption. From Andrey Ryabinin. 3) Mount BPF filesystem with mount_nodev rather than mount_ns, from Eric Biederman. 4) A couple kmemdup conversions, from Muhammad Falak R Wani. 5) BPF verifier fixes from Alexei Starovoitov. 6) Don't let tunneled UDP packets get stuck in socket queues, if something goes wrong during the encapsulation just drop the packet rather than signalling an error up the call stack. From Hannes Frederic Sowa. 7) SKB ref after free in batman-adv, from Florian Westphal. 8) TCP iSCSI, ocfs2, rds, and tipc have to disable BH in it's TCP callbacks since the TCP stack runs pre-emptibly now. From Eric Dumazet. 9) Fix crash in fixed_phy_add, from Rabin Vincent. 10) Fix length checks in xen-netback, from Paul Durrant. 11) Fix mixup in KEY vs KEYID macsec attributes, from Sabrina Dubroca. 12) RDS connection spamming bug fixes from Sowmini Varadhan * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (152 commits) net: suppress warnings on dev_alloc_skb uapi glibc compat: fix compilation when !__USE_MISC in glibc udp: prevent skbs lingering in tunnel socket queues bpf: teach verifier to recognize imm += ptr pattern bpf: support decreasing order in direct packet access net: usb: ch9200: use kmemdup ps3_gelic: use kmemdup net:liquidio: use kmemdup bpf: Use mount_nodev not mount_ns to mount the bpf filesystem net: cdc_ncm: update datagram size after changing mtu tuntap: correctly wake up process during uninit intel: Add support for IPv6 IP-in-IP offload ip6_gre: Do not allow segmentation offloads GRE_CSUM is enabled with FOU/GUE RDS: TCP: Avoid rds connection churn from rogue SYNs RDS: TCP: rds_tcp_accept_worker() must exit gracefully when terminating rds-tcp net: sock: move ->sk_shutdown out of bitfields. ipv6: Don't reset inner headers in ip6_tnl_xmit ip4ip6: Support for GSO/GRO ip6ip6: Support for GSO/GRO ipv6: Set features for IPv6 tunnels ...
2016-05-20aeroflex/greth: fix warning about unused variableSam Ravnborg
Fix following warning: aeroflex/greth.c:1326:11: warning: unused variable 'phy' [-Wunused-variable] The variable was unused - remove it. It looks like this warning has been there forever - was found by an allyesconfig build of sparc32. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Kristoffer Glembo <kristoffer@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-20udp: prevent skbs lingering in tunnel socket queuesHannes Frederic Sowa
In case we find a socket with encapsulation enabled we should call the encap_recv function even if just a udp header without payload is available. The callbacks are responsible for correctly verifying and dropping the packets. Also, in case the header validation fails for geneve and vxlan we shouldn't put the skb back into the socket queue, no one will pick them up there. Instead we can simply discard them in the respective encap_recv functions. Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-20net: usb: ch9200: use kmemdupMuhammad Falak R Wani
Use kmemdup when some other buffer is immediately copied into allocated region. It replaces call to allocation followed by memcpy, by a single call to kmemdup. Signed-off-by: Muhammad Falak R Wani <falakreyaz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-20ps3_gelic: use kmemdupMuhammad Falak R Wani
2016-05-20net:liquidio: use kmemdupMuhammad Falak R Wani
2016-05-20Merge tag 'wireless-drivers-next-for-davem-2016-05-13' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers-next Kalle Valo says: ==================== wireless-drivers patches for 4.7 Major changes: iwlwifi * remove IWLWIFI_DEBUG_EXPERIMENTAL_UCODE kconfig option * work for RX multiqueue continues * dynamic queue allocation work continues * add Luca as maintainer * a bunch of fixes and improvements all over brcmfmac * add 4356 sdio support ath6kl * add ability to set debug uart baud rate with a module parameter wil6210 * add debugfs file to configure firmware led functionality ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-20net: cdc_ncm: update datagram size after changing mtuRafal Redzimski
Current implementation updates the mtu size and notify cdc_ncm device using USB_CDC_SET_MAX_DATAGRAM_SIZE request about datagram size change instead of changing rx_urb_size. Whenever mtu is being changed, datagram size should also be updated. Also updating maxmtu formula so it takes max_datagram_size with use of cdc_ncm_max_dgram_size() and not ctx. Signed-off-by: Robert Dobrowolski <robert.dobrowolski@linux.intel.com> Signed-off-by: Rafal Redzimski <rafal.f.redzimski@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-20tuntap: correctly wake up process during uninitJason Wang
We used to check dev->reg_state against NETREG_REGISTERED after each time we are woke up. But after commit 9e641bdcfa4e ("net-tun: restructure tun_do_read for better sleep/wakeup efficiency"), it uses skb_recv_datagram() which does not check dev->reg_state. This will result if we delete a tun/tap device after a process is blocked in the reading. The device will wait for the reference count which was held by that process for ever. Fixes this by using RCV_SHUTDOWN which will be checked during sk_recv_datagram() before trying to wake up the process during uninit. Fixes: 9e641bdcfa4e ("net-tun: restructure tun_do_read for better sleep/wakeup efficiency") Cc: Eric Dumazet <edumazet@google.com> Cc: Xi Wang <xii@google.com> Cc: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Eric Dumazet <edumazet@google.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-20intel: Add support for IPv6 IP-in-IP offloadAlexander Duyck
This patch adds support for offloading IPXIP6 type packets that represent either IPv4 or IPv6 encapsulated inside of an IPv6 outer IP header. In addition with this change we should also be able to support FOU encapsulated traffic with outer IPv6 headers. Signed-off-by: Alexander Duyck <aduyck@mirantis.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-20net: define gso types for IPx over IPv4 and IPv6Tom Herbert
This patch defines two new GSO definitions SKB_GSO_IPXIP4 and SKB_GSO_IPXIP6 along with corresponding NETIF_F_GSO_IPXIP4 and NETIF_F_GSO_IPXIP6. These are used to described IP in IP tunnel and what the outer protocol is. The inner protocol can be deduced from other GSO types (e.g. SKB_GSO_TCPV4 and SKB_GSO_TCPV6). The GSO types of SKB_GSO_IPIP and SKB_GSO_SIT are removed (these are both instances of SKB_GSO_IPXIP4). SKB_GSO_IPXIP6 will be used when support for GSO with IP encapsulation over IPv6 is added. Signed-off-by: Tom Herbert <tom@herbertland.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-20Revert "phy: add support for a reset-gpio specification"Fabio Estevam
Commit da47b4572056 ("phy: add support for a reset-gpio specification") causes the following xtensa qemu crash according to Guenter Roeck: [ 9.366256] libphy: ethoc-mdio: probed [ 9.367389] (null): could not attach to PHY [ 9.368555] (null): failed to probe MDIO bus [ 9.371540] Unable to handle kernel paging request at virtual address 0000001c [ 9.371540] pc = d0320926, ra = 903209d1 [ 9.375358] Oops: sig: 11 [#1] This reverts commit da47b4572056487fd7941c26f73b3e8815ff712a. Reported-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-20xen-netback: only deinitialized hash if it was initializedPaul Durrant
A domain with a frontend that does not implement a control ring has been seen to cause a crash during domain save. This was apparently because the call to xenvif_deinit_hash() in xenvif_disconnect_ctrl() is made regardless of whether a control ring was connected, and hence xenvif_hash_init() was called. This patch brings the call to xenvif_deinit_hash() in xenvif_disconnect_ctrl() inside the if clause that checks whether the control ring event channel was connected. This is sufficient to ensure it is only called if xenvif_init_hash() was called previously. Signed-off-by: Paul Durrant <paul.durrant@citrix.com> Reported-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Tested-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Wei Liu <wei.liu2@citrix.com> Acked-by: Wei Liu <wei.liu2@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-20Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma updates from Doug Ledford: "Primary 4.7 merge window changes - Updates to the new Intel X722 iWARP driver - Updates to the hfi1 driver - Fixes for the iw_cxgb4 driver - Misc core fixes - Generic RDMA READ/WRITE API addition - SRP updates - Misc ipoib updates - Minor mlx5 updates" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (148 commits) IB/mlx5: Fire the CQ completion handler from tasklet net/mlx5_core: Use tasklet for user-space CQ completion events IB/core: Do not require CAP_NET_ADMIN for packet sniffing IB/mlx4: Fix unaligned access in send_reply_to_slave IB/mlx5: Report Scatter FCS device capability when supported IB/mlx5: Add Scatter FCS support for Raw Packet QP IB/core: Add Scatter FCS create flag IB/core: Add Raw Scatter FCS device capability IB/core: Add extended device capability flags i40iw: pass hw_stats by reference rather than by value i40iw: Remove unnecessary synchronize_irq() before free_irq() i40iw: constify i40iw_vf_cqp_ops structure IB/mlx5: Add UARs write-combining and non-cached mapping IB/mlx5: Allow mapping the free running counter on PROT_EXEC IB/mlx4: Use list_for_each_entry_safe IB/SA: Use correct free function IB/core: Fix a potential array overrun in CMA and SA agent IB/core: Remove unnecessary check in ibnl_rcv_msg IB/IWPM: Fix a potential skb leak RDMA/nes: replace custom print_hex_dump() ...
