path: root/drivers/net
2016-09-10net/mlx5: Organize device list API in one placeMohamad Haj Yahia
Hide the exposed (external) mlx5_dev_list and mlx5_intf_mutex and expose an organized modular API to manage and manipulate mlx5 devices list. Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net/mlx5e: Restore vlan filter after seamless resetMohamad Haj Yahia
When detaching the mlx5e interface clear all the vlans rules from the vlan flow table. When attaching it back restore all the active vlans rules to the HW. Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net/mlx5e: Implement mlx5e interface attach/detach callbacksMohamad Haj Yahia
Needed to support seamless and lightweight PCI/Internal error recovery. Implement the attach/detach interface callbacks. In attach callback we only allocate HW resources. In detach callback we only deallocate HW resources. All SW/kernel objects initialzing/destroying is kept in add/remove callbacks. Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net/mlx5: Implement vports admin state backup/restoreMohamad Haj Yahia
Save the user configuration in the vport sturct. Restore saved old configuration upon vport enable. Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net/mlx5: Align sriov/eswitch modules with the new load/unload flow.Mohamad Haj Yahia
Init/cleanup sriov/eswitch in the core software context init/cleanup flows. Attach/detach sriov/eswitch in the core load/unload flows. Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net/mlx5: Implement eswitch attach/detach flowsMohamad Haj Yahia
Needed for lightweight and modular internal/pci error handling. Implement eswitch attach function which allocates/starts hw related resources. Implement eswitch detach function which releases/stops hw related resources. Init/cleanup function only handle eswitch software context allocation and destruction. Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net/mlx5: Implement SRIOV attach/detach flowsMohamad Haj Yahia
Needed for lightweight and modular internal/pci error handling. Implement sriov attach function which enables pre-saved number of vfs on the device side. Implement sriov detach function which disable the current vfs on the device side. Init/cleanup function only handles sriov software context allocation and destruction. Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net/mlx5: Split the load/unload flow into hardware and software flowsMohamad Haj Yahia
Gather all software context creating/destroying in one function and call it once in the first load and in the last unload. load/unload functions will now receive indication if we need to create/destroy the software contexts. In internal/pci error do the unload/load flows without releasing the software objects. In this way we perserve the sw core state and it help us restoring old driver state after PCI error/shutdown. Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net/mlx5: Introduce attach/detach to interface APIMohamad Haj Yahia
Add attach/detach callbacks to interface API. This is crucial for implementing seamless reset flow which releases the hardware and it's resources upon detach while keeping software structures and state (e.g netdev) then reset and reallocate the hardware needed resources upon attach. Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net/mlx5: SRIOV core code refactoringMohamad Haj Yahia
Simplify the code and makes it look modular and symmetric. Split sriov enable/disable to two levels: device level and pci level. When user enable/disable sriov (via sriov_configure driver callback) we will enable/disable both device and pci sriov. When driver load/unload we will enable/disable (on demand) only device sriov while keeping the PCI sriov enabled for next driver load. On internal/pci error, VFs will be kept enabled on PCI and the reset is done only in device level. Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net/mlx5: Skip waiting for vf pages in internal errorMohamad Haj Yahia
In case of device in internal error state there is no need to wait for vf pages since they will be reclaimed manually later in the unload flow. Signed-off-by: Mohamad Haj Yahia <mohamad@mellanox.com> Signed-off-by: Saeed Mahameed <saeedm@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net: fs_enet: make rx_copybreak value configurableChristophe Leroy
Measurement shows that on a MPC8xx running at 132MHz, the optimal limit is 112: * 114 bytes packets are processed in 147 TB ticks with higher copybreak * 114 bytes packets are processed in 148 TB ticks with lower copybreak * 128 bytes packets are processed in 154 TB ticks with higher copybreak * 128 bytes packets are processed in 148 TB ticks with lower copybreak * 238 bytes packets are processed in 172 TB ticks with higher copybreak * 238 bytes packets are processed in 148 TB ticks with lower copybreak However it might be different on other processors and/or frequencies. So it is useful to make it configurable. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net: fs_enet: don't unmap DMA when packet len is below copybreakChristophe Leroy
When the length of the packet is below the defined copybreak limit, the received packet is copied into a newly allocated skb in order to reuse the skb. This is only interesting if it allow us to avoid a new DMA mapping. We shall therefore not DMA unmap and remap the skb->data. Instead, we invalidate the cache with dma_sync_single_for_cpu() once the received data has been copied into the new skb. The following measures have been obtained on a mpc885 running at 132Mhz. Measurement is done using the timebase with packets sent to the target with 'ping -s 1' (packet len is 60): * Without this patch: 182 TB ticks * With this patch: 143 TB ticks As a comparison, if we set the copybreak limit to 0, then we get 148 TB ticks. It means that without this patch, duration is even worse when copying received data to a new skb instead of allocating a new skb for next packet to be received Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net: fs_enet: merge NAPI RX and NAPI TXChristophe Leroy
Initially, a NAPI TX routine has been implemented separately from NAPI RX, as done on the freescale/gianfar driver. By merging NAPI RX and NAPI TX, we reduce the amount of TX completion interrupts. Handling of the budget in association with TX interrupts is based on indications provided at https://wiki.linuxfoundation.org/networking/napi We never proceed more than the complete TX ring on a single run. At the same time, we fix an issue in the handling of fep->tx_free: It is only when fep->tx_free goes up to MAX_SKB_FRAGS that we need to wake up the queue. There is no need to call netif_wake_queue() at every packet successfully transmitted. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-10net/ip_tunnels: Introduce tunnel_id_to_key32() and key32_to_tunnel_id()Amir Vadai
Add utility functions to convert a 32 bits key into a 64 bits tunnel and vice versa. These functions will be used instead of cloning code in GRE and VXLAN, and in tc act_iptunnel which will be introduced in a following patch in this patchset. Signed-off-by: Amir Vadai <amir@vadai.me> Signed-off-by: Hadar Hen Zion <hadarh@mellanox.com> Reviewed-by: Shmulik Ladkani <shmulik.ladkani@gmail.com> Acked-by: Jiri Benc <jbenc@redhat.com> Acked-by: Jiri Pirko <jiri@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-09alx: add module parameter to enable msi-x supportTobias Regnery
msi-x support is default disabled in the alx driver. In order to test msi-x interrupts for regressions add a module parameter to the driver. Signed-off-by: Tobias Regnery <tobias.regnery@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-09alx: add msi-x supportTobias Regnery
Add msi-x support to the alx driver. This is in preparation for multi queue support. msi-x interrupts are disabled by default because without multi queue support there is no advantage over msi interrupts. The performance numbers observed with iperf stay the same. Based on information of the downstream driver at github.com/qca/alx Signed-off-by: Tobias Regnery <tobias.regnery@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-09alx: factor out part of the interrupt handlerTobias Regnery
Factor out the handling of misc interrupts into a new function. This function can be reused later for msi-x interrupts. Signed-off-by: Tobias Regnery <tobias.regnery@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-09alx: refactor msi enablement and disablementTobias Regnery
Introduce a new flag field for the advanced interrupt capatibilities and add new functions to enable and disable msi interrupts. These functions will be extended later to cover msi-x interrupts. We enable msi interrupts earlier in alx_init_intr because with msi-x and multi queue support the number of queues must be set before we allocate resources for the rx and tx paths. Signed-off-by: Tobias Regnery <tobias.regnery@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-09qed: mark symbols static where possibleBaoyou Xie
We get a few warnings when building kernel with W=1: drivers/net/ethernet/qlogic/qed/qed_l2.c:112:5: warning: no previous prototype for 'qed_sp_vport_start' [-Wmissing-prototypes] drivers/net/ethernet/qlogic/qed/qed_sriov.c:110:6: warning: no previous prototype for 'qed_iov_is_valid_vfid' [-Wmissing-prototypes] drivers/net/ethernet/qlogic/qed/qed_sriov.c:188:5: warning: no previous prototype for 'qed_iov_post_vf_bulletin' [-Wmissing-prototypes] drivers/net/ethernet/qlogic/qed/qed_sriov.c:578:6: warning: no previous prototype for 'qed_iov_set_vfs_to_disable' [-Wmissing-prototypes] drivers/net/ethernet/qlogic/qed/qed_sriov.c:1135:28: warning: no previous prototype for 'qed_iov_get_public_vf_info' [-Wmissing-prototypes] drivers/net/ethernet/qlogic/qed/qed_sriov.c:1148:6: warning: no previous prototype for 'qed_iov_clean_vf' [-Wmissing-prototypes] drivers/net/ethernet/qlogic/qed/qed_sriov.c:2444:5: warning: no previous prototype for 'qed_iov_chk_ucast' [-Wmissing-prototypes] drivers/net/ethernet/qlogic/qed/qed_sriov.c:2762:5: warning: no previous prototype for 'qed_iov_vf_flr_cleanup' [-Wmissing-prototypes] .... In fact, these functions are only used in the file in which they are declared and don't need a declaration, but can be made static. so this patch marks these functions with 'static'. Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-09via-velocity: remove null pointer check on array tdinfo->skb_dmaColin Ian King
tdinfo->skb_dma is a 7 element array of dma_addr_t hence cannot be null, so the pull pointer check on tdinfo->skb_dma is redundant. Remove it. Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-09qede: mark qede_set_features() staticBaoyou Xie
We get 1 warning when building kernel with W=1: drivers/net/ethernet/qlogic/qede/qede_main.c:2113:5: warning: no previous prototype for 'qede_set_features' [-Wmissing-prototypes] In fact, this function is only used in the file in which it is declared and don't need a declaration, but can be made static. so this patch marks this function with 'static'. Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org> Acked-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-09net: phy: Fixed checkpatch errors for Microsemi PHYs.Raju Lakkaraju
The existing VSC85xx PHY driver did not follow the coding style and caused "checkpatch" to complain. This commit fixes this. Signed-off-by: Raju Lakkaraju <Raju.Lakkaraju@microsemi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-09macsec: set network devtypestephen hemminger
The netdevice type structure for macsec was being defined but never used. To set the network device type the macro SET_NETDEV_DEVTYPE must be called. Compile tested only, I don't use macsec. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Acked-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-08net: ethernet: xilinx: Enable emaclite for MIPSZubair Lutfullah Kakakhel
The MIPS based xilfpga platform uses this driver. Enable it for MIPS Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-07be2net: Update the driver version to 11.1.0.0Sriharsha Basavapatna
Signed-off-by: Sriharsha Basavapatna <sriharsha.basavapatna@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-07be2net: Fix mac address collision in some configurationsSuresh Reddy
If the device mac address is updated using ndo_set_mac_address(), while the same mac address is already programmed, the driver does not detect this condition if its netdev->dev_addr has been changed. The driver tries to add the same mac address resulting in mac address collision error. This has been observed in bonding mode-5 configuration. To fix this, store the mac address configured in HW in the adapter structure. Use this to compare against the new address being updated to avoid collision. Signed-off-by: Suresh Reddy <Suresh.Reddy@broadcom.com> Signed-off-by: Sathya Perla <sathya.perla@broadcom.com> Signed-off-by: Sriharsha Basavapatna <sriharsha.basavapatna@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-07be2net: Avoid redundant addition of mac address in HWSuresh Reddy
If a mac address is added to the uc_list and later the same mac address is added via ndo_set_mac_address() or vice versa, the driver does not detect this condition and tries to add it again. This results in a mac address collision error when the FW rejects it. Fix this by checking if the given mac address is present in uc_list while setting the device mac address and vice versa. Similarly skip deletion if the address is still in use in the other form. Signed-off-by: Suresh Reddy <Suresh.Reddy@broadcom.com> Signed-off-by: Sathya Perla <sathya.perla@broadcom.com> Signed-off-by: Sriharsha Basavapatna <sriharsha.basavapatna@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-07be2net: Add privilege level check for OPCODE_COMMON_GET_EXT_FAT_CAPABILITIES ↵Somnath Kotur
SLI cmd. Driver issues OPCODE_COMMON_GET_EXT_FAT_CAPABILITIES cmd during init which when issued by VFs results in the logging of a cmd failure message since they don't have the required privilege for this cmd. Fix by checking privilege before issuing the cmd. Also fixed typo in CAPABILITIES. Signed-off-by: Somnath Kotur <somnath.kotur@broadcom.com> Signed-off-by: Sriharsha Basavapatna <sriharsha.basavapatna@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-07be2net: Issue COMMON_RESET_FUNCTION cmd during driver unloadSomnath Kotur
As per SLI guideline, drivers need to issue COMMON_RESET_FUNCTION SLI cmd during driver unload to clean up any non-persistent state information. Issue this cmd only if VFs are not assigned to VMs as it is possible for PF driver to unload while it\'s VF remains functional and assigned to a VM. Signed-off-by: Somnath Kotur <somnath.kotur@broadcom.com> Signed-off-by: Sriharsha Basavapatna <sriharsha.basavapatna@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-07be2net: Support UE recovery in BEx/Skyhawk adaptersSriharsha Basavapatna
This patch supports recovery from UEs caused due to Transient Parity Errors (TPE), in BE2, BE3 and Skyhawk adapters. This change avoids system reboot when such errors occur. The driver recovers from these errors such that the adapter resumes full operational status as prior to the UE. Following is the list of changes in the driver to support this: o The driver registers its UE recoverable capability with ARM FW at init time. This also allows the driver to know if the feature is supported in the FW. o As the UE recovery requires precise time bound processing, the driver creates its own error recovery work queue with a single worker thread (per module, shared across functions). o Each function runs an error detection task at an interval of 1 second as required by the FW. The error detection logic already exists for BEx/SH, but it now runs in the context of a separate worker thread. o When an error is detected by the task, if it is recoverable, the PF0 driver instance initiates a soft reset, while other PF driver instances wait for the reset to complete and the chip to become ready. Once the chip is ready, all driver instances including PF0, resume to reinitialize the respective functions. o The PF0 driver checks for some recovery criteria, to determine if the recovery can be initiated. If the criteria is not met, the PF0 driver does not initiate a soft reset, it retains the existing behavior to stop further processing and requires a reboot to get the chip to operational state again. o To allow each function to share the workq, while also making progress in its recovery process, a per-function recovery state machine is used. The per-function tasks avoid blocking operations like msleep() while in this state machine (until reinit state) and instead reschedule for the required delay. o With these changes, the existing error recovery code for Lancer also runs in the context of the new worker thread. Signed-off-by: Sriharsha Basavapatna <sriharsha.basavapatna@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-07net: smsc911x: request and deassert optional RESET GPIOLinus Walleij
On some systems (such as the Qualcomm APQ8060 Dragonboard) the RESET signal of the SMSC911x is not pulled up by a resistor (or the internal pull-up that will pull it up if the pin is not even connected) but instead connected to a GPIO line, so that the operating system must explicitly deassert RESET before use. Support this in the SMSC911x driver so this ethernet connector can be used on such targets. Notice that we request the line to go logical low (deassert) whilst the line on the actual component is active low. This is managed in the respective hardware description when specifying the GPIO line with e.g. device tree or ACPI. With device tree it looks like this in one case: reset-gpios = <&tlmm 30 GPIO_ACTIVE_LOW>; Which means that logically requesting the RESET line to be deasserted will result in the line being driven high, taking the device out of reset. Cc: Jeremy Linton <jeremy.linton@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Jeremy Linton <jeremy.linton@arm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-07qed*: Add support for the ethtool get_regs operationTomer Tayar
Signed-off-by: Tomer Tayar <Tomer.Tayar@qlogic.com> Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-07qed: Add support for debug data collectionTomer Tayar
This patch adds the support for dumping and formatting the HW/FW debug data. Signed-off-by: Tomer Tayar <Tomer.Tayar@qlogic.com> Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-07kaweth: remove obsolete debugging statementsOliver Neukum
SOme statements in the driver only served to inform which functions were entered. Ftrace can do that just as good without needing memory. Remove the statements. Signed-off-by: Oliver Neukum <oneukum@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-07qed: add missing header dependenciesBaoyou Xie
We get 4 warnings when building kernel with W=1: drivers/net/ethernet/qlogic/qed/qed_selftest.c:6:5: warning: no previous prototype for 'qed_selftest_memory' [-Wmissing-prototypes] drivers/net/ethernet/qlogic/qed/qed_selftest.c:19:5: warning: no previous prototype for 'qed_selftest_interrupt' [-Wmissing-prototypes] drivers/net/ethernet/qlogic/qed/qed_selftest.c:32:5: warning: no previous prototype for 'qed_selftest_register' [-Wmissing-prototypes] drivers/net/ethernet/qlogic/qed/qed_selftest.c:55:5: warning: no previous prototype for 'qed_selftest_clock' [-Wmissing-prototypes] In fact, these functions are declared in qed_selftest.h, so this patch add missing header dependencies. Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org> Acked-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06sfc: check MTU against minimum thresholdBert Kenward
Reported-by: Ma Yuying <yuma@redhat.com> Suggested-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Bert Kenward <bkenward@solarflare.com> Reviewed-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06net: arc_emac: mark arc_mdio_reset() staticBaoyou Xie
We get 1 warning when building kernel with W=1: drivers/net/ethernet/arc/emac_mdio.c:107:5: warning: no previous prototype for 'arc_mdio_reset' [-Wmissing-prototypes] In fact, this function is only used in the file in which it is declared and don't need a declaration, but can be made static. so this patch marks this function with 'static'. Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06lan78xx: mark symbols static where possibleBaoyou Xie
We get a few warnings when building kernel with W=1: drivers/net/usb/lan78xx.c:1182:6: warning: no previous prototype for 'lan78xx_defer_kevent' [-Wmissing-prototypes] drivers/net/usb/lan78xx.c:1409:5: warning: no previous prototype for 'lan78xx_nway_reset' [-Wmissing-prototypes] drivers/net/usb/lan78xx.c:2000:5: warning: no previous prototype for 'lan78xx_set_mac_addr' [-Wmissing-prototypes] .... In fact, these functions are only used in the file in which they are declared and don't need a declaration, but can be made static. so this patch marks these functions with 'static'. Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06qed: Add infrastructure for debug data collectionTomer Tayar
Adds support for several infrastructure operations that are done as part of debug data collection. Signed-off-by: Tomer Tayar <Tomer.Tayar@qlogic.com> Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06bnx2x: Add support for segmentation of tunnels with outer checksumsAlexander Duyck
Signed-off-by: Alexander Duyck <aduyck@mirantis.com> Tested-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06qed: Remove OOM messagesJoe Perches
These messages are unnecessary as OOM allocation failures already do a dump_stack() giving more or less the same information. $ size drivers/net/ethernet/qlogic/qed/built-in.o* (defconfig x86-64) text data bss dec hex filename 127817 27969 32800 188586 2e0aa drivers/net/ethernet/qlogic/qed/built-in.o.new 132474 27969 32800 193243 2f2db drivers/net/ethernet/qlogic/qed/built-in.o.old Miscellanea: o Change allocs to the generally preferred forms where possible. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06vxlan: Update tx_errors statistics if vxlan_build_skb return err.Haishuang Yan
If vxlan_build_skb return err < 0, tx_errors should be also increased. Signed-off-by: Haishuang Yan <yanhaishuang@cmss.chinamobile.com> Acked-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06net/mlx4_en: protect ring->xdp_prog with rcu_read_lockBrenden Blanco
Depending on the preempt mode, the bpf_prog stored in xdp_prog may be freed despite the use of call_rcu inside bpf_prog_put. The situation is possible when running in PREEMPT_RCU=y mode, for instance, since the rcu callback for destroying the bpf prog can run even during the bh handling in the mlx4 rx path. Several options were considered before this patch was settled on: Add a napi_synchronize loop in mlx4_xdp_set, which would occur after all of the rings are updated with the new program. This approach has the disadvantage that as the number of rings increases, the speed of update will slow down significantly due to napi_synchronize's msleep(1). Add a new rcu_head in bpf_prog_aux, to be used by a new bpf_prog_put_bh. The action of the bpf_prog_put_bh would be to then call bpf_prog_put later. Those drivers that consume a bpf prog in a bh context (like mlx4) would then use the bpf_prog_put_bh instead when the ring is up. This has the problem of complexity, in maintaining proper refcnts and rcu lists, and would likely be harder to review. In addition, this approach to freeing must be exclusive with other frees of the bpf prog, for instance a _bh prog must not be referenced from a prog array that is consumed by a non-_bh prog. The placement of rcu_read_lock in this patch is functionally the same as putting an rcu_read_lock in napi_poll. Actually doing so could be a potentially controversial change, but would bring the implementation in line with sk_busy_loop (though of course the nature of those two paths is substantially different), and would also avoid future copy/paste problems with future supporters of XDP. Still, this patch does not take that opinionated option. Testing was done with kernels in either PREEMPT_RCU=y or CONFIG_PREEMPT_VOLUNTARY=y+PREEMPT_RCU=n modes, with neither exhibiting any drawback. With PREEMPT_RCU=n, the extra call to rcu_read_lock did not show up in the perf report whatsoever, and with PREEMPT_RCU=y the overhead of rcu_read_lock (according to perf) was the same before/after. In the rx path, rcu_read_lock is eventually called for every packet from netif_receive_skb_internal, so the napi poll call's rcu_read_lock is easily amortized. v2: Remove extra rcu_read_lock in mlx4_en_process_rx_cq body Annotate xdp_prog with __rcu, and convert all usages to rcu_assign or rcu_dereference[_protected] as appropriate. Add explicit mutex lock around rcu_assign instead of xchg loop. Fixes: d576acf0a22 ("net/mlx4_en: add page recycle to prepare rx ring for tx support") Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <alexei.starovoitov@gmail.com> Signed-off-by: Brenden Blanco <bblanco@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06net: ethernet: mediatek: enhance RX path by aggregating more SKBs into NAPISean Wang
The patch adds support for aggregating more SKBs feed into NAPI in order to get more benefits from generic receive offload (GRO) by peeking at the RX ring status and moving more packets right before returning from NAPI RX polling handler if NAPI budgets are still available and some packets already present in hardware. Signed-off-by: Sean Wang <sean.wang@mediatek.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06net: ethernet: mediatek: enhance RX path by reducing the frequency of the ↵Sean Wang
memory barrier used The patch makes move wmb() to outside the loop that could help RX path handling more faster although that RX descriptors aren't freed for DMA to use as soon as possible, but based on my experiment and the result shows it still can reach about 943Mbpis without performance drop that is tested based on the setup with one port using Giga PHY and 256 RX descriptors for DMA to move. Signed-off-by: Sean Wang <sean.wang@mediatek.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06hso: Convert printk to pr_<level>Joe Perches
Use a more common logging style Miscellanea: o Add pr_fmt to prefix each output message o Realign arguments Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06hso: Use a more common logging styleJoe Perches
Macros that end in an underscore are just odd. Add hso_dbg(level, fmt, ...) and use it everwhere instead. Several uses had additional unnecessary newlines as the macro added a newline. Remove the newline from the macro and add newlines to each use as appropriate. Remove now unused D<digit> macros. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06smsc95xx: Add mdix control via ethtoolWoojung Huh
Add mdix control through ethtool. Signed-off-by: Woojung Huh <Woojung.huh@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-06smsc95xx: Add register defineWoojung Huh
Add STRAP_STATUS defines. Signed-off-by: Woojung Huh <Woojung.huh@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
