path: root/drivers/net
2011-05-30virtio_net: delay TX callbacksMichael S. Tsirkin
Ask for delayed callbacks on TX ring full, to give the other side more of a chance to make progress. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-05-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (97 commits) mtd: kill CONFIG_MTD_PARTITIONS mtd: remove add_mtd_partitions, add_mtd_device and friends mtd: convert remaining users to mtd_device_register() mtd: samsung onenand: convert to mtd_device_register() mtd: omap2 onenand: convert to mtd_device_register() mtd: txx9ndfmc: convert to mtd_device_register() mtd: tmio_nand: convert to mtd_device_register() mtd: socrates_nand: convert to mtd_device_register() mtd: sharpsl: convert to mtd_device_register() mtd: s3c2410 nand: convert to mtd_device_register() mtd: ppchameleonevb: convert to mtd_device_register() mtd: orion_nand: convert to mtd_device_register() mtd: omap2: convert to mtd_device_register() mtd: nomadik_nand: convert to mtd_device_register() mtd: ndfc: convert to mtd_device_register() mtd: mxc_nand: convert to mtd_device_register() mtd: mpc5121_nfc: convert to mtd_device_register() mtd: jz4740_nand: convert to mtd_device_register() mtd: h1910: convert to mtd_device_register() mtd: fsmc_nand: convert to mtd_device_register() ... Fixed up trivial conflicts in - drivers/mtd/maps/integrator-flash.c: removed in ARM tree - drivers/mtd/maps/physmap.c: addition of afs partition probe type clashing with removal of CONFIG_MTD_PARTITIONS
2011-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: Kill ratelimit.h dependency in linux/net.h net: Add linux/sysctl.h includes where needed. net: Kill ether_table[] declaration. inetpeer: fix race in unused_list manipulations atm: expose ATM device index in sysfs IPVS: bug in ip_vs_ftp, same list heaad used in all netns. bug.h: Move ratelimit warn interfaces to ratelimit.h bonding: cleanup module option descriptions net:8021q:vlan.c Fix pr_info to just give the vlan fullname and version. net: davinci_emac: fix dev_err use at probe can: convert to %pK for kptr_restrict support net: fix ETHTOOL_SFEATURES compatibility with old ethtool_ops.set_flags netfilter: Fix several warnings in compat_mtw_from_user(). netfilter: ipset: fix ip_set_flush return code netfilter: ipset: remove unused variable from type_pf_tdel() netfilter: ipset: Use proper timeout value to jiffies conversion
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-05-26bonding: cleanup module option descriptionsAndy Gospodarek
Weiping Pan noticed that the module option description for xmit_hash_policy was incorrect and was nice enough to post a patch to fix it. The text was correct, but created a line over 80 characters and I would rather not add those. I realized I could take a few minutes and clean up all the descriptions and things would look much better. This is the result. Based on patch from Weiping Pan <panweiping3@gmail.com>. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> CC: Weiping Pan <panweiping3@gmail.com> Reviewed-by: Weiping Pan <panweiping3@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-26net: davinci_emac: fix dev_err use at probeJohan Hovold
Use platform device rather than net device in dev_err calls before net device has been registered to avoid messages such as (null): DaVinci EMAC: Failed to get EMAC clock Also replace remaining printks in probe with dev_{err,warn}. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-26mfd: Use mfd cell platform_data for janz cells platform bitsSamuel Ortiz
With the addition of a platform device mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Cc: Ira W. Snyder <iws@ovro.caltech.edu> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Use mfd cell platform_data for timberdale cells platform bitsSamuel Ortiz
With the addition of a device platform mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Acked-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26wan/pc300: Drop __TIME__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Acked-by: David S. Miller <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (89 commits) bonding: documentation and code cleanup for resend_igmp bonding: prevent deadlock on slave store with alb mode (v3) net: hold rtnl again in dump callbacks Add Fujitsu 1000base-SX PCI ID to tg3 bnx2x: protect sequence increment with mutex sch_sfq: fix peek() implementation isdn: netjet - blacklist Digium TDM400P via-velocity: don't annotate MAC registers as packed xen: netfront: hold RTNL when updating features. sctp: fix memory leak of the ASCONF queue when free asoc net: make dev_disable_lro use physical device if passed a vlan dev (v2) net: move is_vlan_dev into public header file (v2) bug.h: Fix build with CONFIG_PRINTK disabled. wireless: fix fatal kernel-doc error + warning in mac80211.h wireless: fix cfg80211.h new kernel-doc warnings iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabled dst: catch uninitialized metrics be2net: hash key for rss-config cmd not set bridge: initialize fake_rtable metrics net: fix __dst_destroy_metrics_generic() ... Fix up trivial conflicts in drivers/staging/brcm80211/brcmfmac/wl_cfg80211.c
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits) arch/tile: prefer "tilepro" as the name of the 32-bit architecture compat: include aio_abi.h for aio_context_t arch/tile: cleanups for tilegx compat mode arch/tile: allocate PCI IRQs later in boot arch/tile: support signal "exception-trace" hook arch/tile: use better definitions of xchg() and cmpxchg() include/linux/compat.h: coding-style fixes tile: add an RTC driver for the Tilera hypervisor arch/tile: finish enabling support for TILE-Gx 64-bit chip compat: fixes to allow working with tile arch arch/tile: update defconfig file to something more useful tile: do_hardwall_trap: do not play with task->sighand tile: replace mm->cpu_vm_mask with mm_cpumask() tile,mn10300: add device parameter to dma_cache_sync() audit: support the "standard" <asm-generic/unistd.h> arch/tile: clarify flush_buffer()/finv_buffer() function names arch/tile: kernel-related cleanups from removing static page size arch/tile: various header improvements for building drivers arch/tile: disable GX prefetcher during cache flush arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD ...
2011-05-25bonding: documentation and code cleanup for resend_igmpFlavio Leitner
Improves the documentation about how IGMP resend parameter works, fix two missing checks and coding style issues. Signed-off-by: Flavio Leitner <fbl@redhat.com> Acked-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25bonding: prevent deadlock on slave store with alb mode (v3)Neil Horman
This soft lockup was recently reported: [root@dell-per715-01 ~]# echo +bond5 > /sys/class/net/bonding_masters [root@dell-per715-01 ~]# echo +eth1 > /sys/class/net/bond5/bonding/slaves bonding: bond5: doing slave updates when interface is down. bonding bond5: master_dev is not up in bond_enslave [root@dell-per715-01 ~]# echo -eth1 > /sys/class/net/bond5/bonding/slaves bonding: bond5: doing slave updates when interface is down. BUG: soft lockup - CPU#12 stuck for 60s! [bash:6444] CPU 12: Modules linked in: bonding autofs4 hidp rfcomm l2cap bluetooth lockd sunrpc be2d Pid: 6444, comm: bash Not tainted 2.6.18-262.el5 #1 RIP: 0010:[<ffffffff80064bf0>] [<ffffffff80064bf0>] .text.lock.spinlock+0x26/00 RSP: 0018:ffff810113167da8 EFLAGS: 00000286 RAX: ffff810113167fd8 RBX: ffff810123a47800 RCX: 0000000000ff1025 RDX: 0000000000000000 RSI: ffff810123a47800 RDI: ffff81021b57f6f8 RBP: ffff81021b57f500 R08: 0000000000000000 R09: 000000000000000c R10: 00000000ffffffff R11: ffff81011d41c000 R12: ffff81021b57f000 R13: 0000000000000000 R14: 0000000000000282 R15: 0000000000000282 FS: 00002b3b41ef3f50(0000) GS:ffff810123b27940(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00002b3b456dd000 CR3: 000000031fc60000 CR4: 00000000000006e0 Call Trace: [<ffffffff80064af9>] _spin_lock_bh+0x9/0x14 [<ffffffff886937d7>] :bonding:tlb_clear_slave+0x22/0xa1 [<ffffffff8869423c>] :bonding:bond_alb_deinit_slave+0xba/0xf0 [<ffffffff8868dda6>] :bonding:bond_release+0x1b4/0x450 [<ffffffff8006457b>] __down_write_nested+0x12/0x92 [<ffffffff88696ae4>] :bonding:bonding_store_slaves+0x25c/0x2f7 [<ffffffff801106f7>] sysfs_write_file+0xb9/0xe8 [<ffffffff80016b87>] vfs_write+0xce/0x174 [<ffffffff80017450>] sys_write+0x45/0x6e [<ffffffff8005d28d>] tracesys+0xd5/0xe0 It occurs because we are able to change the slave configuarion of a bond while the bond interface is down. The bonding driver initializes some data structures only after its ndo_open routine is called. Among them is the initalization of the alb tx and rx hash locks. So if we add or remove a slave without first opening the bond master device, we run the risk of trying to lock/unlock a spinlock that has garbage for data in it, which results in our above softlock. Note that sometimes this works, because in many cases an unlocked spinlock has the raw_lock parameter initialized to zero (meaning that the kzalloc of the net_device private data is equivalent to calling spin_lock_init), but thats not true in all cases, and we aren't guaranteed that condition, so we need to pass the relevant spinlocks through the spin_lock_init function. Fix it by moving the spin_lock_init calls for the tx and rx hashtable locks to the ndo_init path, so they are ready for use by the bond_store_slaves path. Change notes: v2) Based on conversation with Jay and Nicolas it seems that the ability to enslave devices while the bond master is down should be safe to do. As such this is an outlier bug, and so instead we'll just initalize the errant spinlocks in the init path rather than the open path, solving the problem. We'll also remove the warnings about the bond being down during enslave operations, since it should be safe v3) Fix spelling error Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: jtluka@redhat.com CC: Jay Vosburgh <fubar@us.ibm.com> CC: Andy Gospodarek <andy@greyhouse.net> CC: nicolas.2p.debian@gmail.com CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25Add Fujitsu 1000base-SX PCI ID to tg3Meelis Roos
This patch adds the PCI ID of Fujitsu 1000base-SX NIC to tg3 driver. Tested to detect the card, MAC and serdes, not tested with link at the moment since I have no fiber switch here. I did not add new constants to the pci_ids.h header file since these constants are used only here. Signed-off-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25bnx2x: protect sequence increment with mutexDmitry Kravkov
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25via-velocity: don't annotate MAC registers as packedUlrich Hecht
On ARM, memory accesses through packed pointers behave in unexpected ways in GCC releases 4.3 and higher; see https://lkml.org/lkml/2011/2/2/163 for discussion. In this particular case, 32-bit I/O registers are accessed bytewise, causing incorrect setting of the DMA address registers which in turn leads to an error interrupt storm that brings the system to a halt. Since the mac_regs structure does not need any packing anyway, this patch simply removes the attribute to fix the issue. Signed-off-by: Ulrich Hecht <uli@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25xen: netfront: hold RTNL when updating features.Ian Campbell
Konrad reports: [ 0.930811] RTNL: assertion failed at /home/konrad/ssd/linux/net/core/dev.c (5258) [ 0.930821] Pid: 22, comm: xenwatch Not tainted 2.6.39-05193-gd762f43 #1 [ 0.930825] Call Trace: [ 0.930834] [<ffffffff8143bd0e>] __netdev_update_features+0xae/0xe0 [ 0.930840] [<ffffffff8143dd41>] netdev_update_features+0x11/0x30 [ 0.930847] [<ffffffffa0037105>] netback_changed+0x4e5/0x800 [xen_netfront] [ 0.930854] [<ffffffff8132a838>] xenbus_otherend_changed+0xa8/0xb0 [ 0.930860] [<ffffffff8157ca99>] ? _raw_spin_unlock_irqrestore+0x19/0x20 [ 0.930866] [<ffffffff8132adfe>] backend_changed+0xe/0x10 [ 0.930871] [<ffffffff8132875a>] xenwatch_thread+0xba/0x180 [ 0.930876] [<ffffffff810a8ba0>] ? wake_up_bit+0x40/0x40 [ 0.930881] [<ffffffff813286a0>] ? split+0xf0/0xf0 [ 0.930886] [<ffffffff810a8646>] kthread+0x96/0xa0 [ 0.930891] [<ffffffff815855a4>] kernel_thread_helper+0x4/0x10 [ 0.930896] [<ffffffff815846b3>] ? int_ret_from_sys_call+0x7/0x1b [ 0.930901] [<ffffffff8157cf61>] ? retint_restore_args+0x5/0x6 [ 0.930906] [<ffffffff815855a0>] ? gs_change+0x13/0x13 This update happens in xenbus watch callback context and hence does not already hold the rtnl. Take the lock as necessary. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25Merge branch 'for-davem' of ↵David S. Miller
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2011-05-25Merge branch 'timers-ptp-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-ptp-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ptp: Fix dp83640 build warning when building statically ptp: Added a clock driver for the National Semiconductor PHYTER. ptp: Added a clock driver for the IXP46x. ptp: Added a clock that uses the eTSEC found on the MPC85xx. ptp: Added a brand new class driver for ptp clocks.
2011-05-25arch, mm: filter disallowed nodes from arch specific show_mem functionsDavid Rientjes
Architectures that implement their own show_mem() function did not pass the filter argument to show_free_areas() to appropriately avoid emitting the state of nodes that are disallowed in the current context. This patch now passes the filter argument to show_free_areas() so those nodes are now avoided. This patch also removes the show_free_areas() wrapper around __show_free_areas() and converts existing callers to pass an empty filter. ia64 emits additional information for each node, so skip_free_areas_zone() must be made global to filter disallowed nodes and it is converted to use a nid argument rather than a zone for this use case. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: James Bottomley <jejb@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25hdlcdrv: Drop __TIME__ usageMichal Marek
The kernel already prints its build timestamp during boot, no need to repeat it in random drivers and produce different object files each time. Acked-by: Thomas Sailer <t.sailer@alumni.ethz.ch> Cc: linux-hams@vger.kernel.org Cc: netdev@vger.kernel.org Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-25baycom: Drop __TIME__ usageMichal Marek
2011-05-25mtd: convert remaining users to mtd_device_register()Jamie Iles
The older add_mtd_device()/add_mtd_partitions() and their removal counterparts will soon be gone. Replace uses with mtd_device_register() and mtd_device_unregister(). Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-24Merge ↵John W. Linville
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2011-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: Make struct pcmcia_device_id const, sound drivers edition staging: pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Convert pcmcia_device_id declarations to const pcmcia: Make declaration and uses of struct pcmcia_device_id const pcmcia/sa1100: put sa11x0_pcmcia_hw_init[] to .devinit.data
2011-05-24iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabledWey-Yi Guy
Fix compiling error when CONFIG_MAC80211_DEBUGFS is not enabled drivers/net/wireless/iwlwifi/iwl-agn-rs.c:351: error: 'struct iwl_lq_sta' has no member named 'dbg_fixed_rate' drivers/net/wireless/iwlwifi/iwl-agn-rs.c:1076: error: 'struct iwl_lq_sta' has no member named 'dbg_fixed_rate' Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-24be2net: hash key for rss-config cmd not setSathya Perla
A non-zero, non-descript value is needed as the hash key. The hash variable was left un-initialized; but sometimes it gets a zero value and hashing is not effective. The constant value used now (not of any significance) seems to work fine. Signed-off-by: Sathya Perla <sathya.perla@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-24CDC NCM: release interfaces fix in unbind()Alexey Orishko
Changes: - claim slave/data interface during bind() and release interfaces in unbind() unconditionally - in case of error during bind(), release claimed data interface in the same function - remove obsolited "*_claimed" entries from driver context Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-24bnx2x: fix inverted conditionDmitry Kravkov
2011-05-24net/irda: convert bfin_sir to common Blackfin UART headerMike Frysinger
No need to duplicate these defines now that the common Blackfin code has unified these for all UART devices. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) PCI: Don't use dmi_name_in_vendors in quirk PCI: remove unused AER functions PCI/sysfs: move bus cpuaffinity to class dev_attrs PCI: add rescan to /sys/.../pci_bus/.../ PCI: update bridge resources to get more big ranges when allocating space (again) KVM: Use pci_store/load_saved_state() around VM device usage PCI: Add interfaces to store and load the device saved state PCI: Track the size of each saved capability data area PCI/e1000e: Add and use pci_disable_link_state_locked() x86/PCI: derive pcibios_last_bus from ACPI MCFG PCI: add latency tolerance reporting enable/disable support PCI: add OBFF enable/disable support PCI: add ID-based ordering enable/disable support PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot. PCI: Set PCIE maxpayload for card during hotplug insertion PCI/ACPI: Report _OSC control mask returned on failure to get control x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs PCI: handle positive error codes PCI: check pci_vpd_pci22_wait() return PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio ... Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461 moved the intel SMBUS ID definitons to the i2c-i801.c driver.
2011-05-23ehea: Fix multicast registration on semi-promiscuous modeBreno Leitao
Ehea will not register multicast groups in phyp if the physical interface is in promiscuous mode. But it should register if the logical port is in promiscuous mode, but the physical port is not. Ehea physical promiscuous mode is defined by ehea_port->promisc, while logical port is defined by IFF_PROMISC. So currently, if the user set the interface in promiscuous mode, IGMP will not be registred in PHYP, and PHYP will never pass the multicast packet to the logical port, which is bad So, this patch just fixes it, assuring that we register in phyp if the physical port is not on promiscuous mode. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-23ptp: Fix dp83640 build warning when building staticallyJohn Stultz
If the dp83640 driver is not built as a module, the MODULE_DEVICE_TABLE reference to dp83640_tbl nops out. Since the table isn't referenced elsewhere, it it causes the following warning: drivers/net/phy/dp83640.c:1095: warning: ‘dp83640_tbl’ defined but not used This apparently is common with mdio_device_id table structures, and is avoided by using __maybe_unused annotation. Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-23ptp: Added a clock driver for the National Semiconductor PHYTER.Richard Cochran
This patch adds support for the PTP clock found on the DP83640. The basic clock operations and one external time stamp have been implemented. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-23ptp: Added a clock driver for the IXP46x.Richard Cochran
This patch adds a driver for the hardware time stamping unit found on the IXP465. The basic clock operations and an external trigger are implemented. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: John Stultz <john.stultz@linaro.org> Acked-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-23ptp: Added a clock that uses the eTSEC found on the MPC85xx.Richard Cochran
The eTSEC includes a PTP clock with quite a few features. This patch adds support for the basic clock adjustment functions, plus two external time stamps, one alarm, and the PPS callback. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: John Stultz <john.stultz@linaro.org> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-23Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits) serial: 8250_pci: add support for Cronyx Omega PCI multiserial board. tty/serial: Fix break handling for PORT_TEGRA tty/serial: Add explicit PORT_TEGRA type n_tracerouter and n_tracesink ldisc additions. Intel PTI implementaiton of MIPI 1149.7. Kernel documentation for the PTI feature. export kernel call get_task_comm(). tty: Remove to support serial for S5P6442 pch_phub: Support new device ML7223 8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter ASoC: Update cx20442 for TTY API change pch_uart: Support new device ML7223 IOH parport: Use request_muxed_region for IT87 probe and lock tty/serial: add support for Xilinx PS UART n_gsm: Use print_hex_dump_bytes drivers/tty/moxa.c: Put correct tty value TTY: tty_io, annotate locking functions TTY: serial_core, remove superfluous set_task_state TTY: serial_core, remove invalid test Char: moxa, fix locking in moxa_write ... Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and drivers/tty/serial/Makefile. I did the hci_ldisc thing as an evil merge, cleaning things up.
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) bnx2x: allow device properly initialize after hotplug bnx2x: fix DMAE timeout according to hw specifications bnx2x: properly handle CFC DEL in cnic flow bnx2x: call dev_kfree_skb_any instead of dev_kfree_skb net: filter: move forward declarations to avoid compile warnings pktgen: refactor pg_init() code pktgen: use vzalloc_node() instead of vmalloc_node() + memset() net: skb_trim explicitely check the linearity instead of data_len ipv4: Give backtrace in ip_rt_bug(). net: avoid synchronize_rcu() in dev_deactivate_many net: remove synchronize_net() from netdev_set_master() rtnetlink: ignore NETDEV_RELEASE and NETDEV_JOIN event net: rename NETDEV_BONDING_DESLAVE to NETDEV_RELEASE bridge: call NETDEV_JOIN notifiers when add a slave netpoll: disable netpoll when enslave a device macvlan: Forward unicast frames in bridge mode to lowerdev net: Remove linux/prefetch.h include from linux/skbuff.h ipv4: Include linux/prefetch.h in fib_trie.c netlabel: Remove prefetches from list handlers. drivers/net: add prefetch header for prefetch users ... Fixed up prefetch parts: removed a few duplicate prefetch.h includes, fixed the location of the igb prefetch.h, took my version of the skbuff.h code without the extra parentheses etc.
2011-05-23b43: fix comment typo reqest -> requestJim Cromie
Recent trivial fix corrected 'occured', but left 'reqest'. codespell needs another dictionary entry. cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-22bnx2x: allow device properly initialize after hotplugDmitry Kravkov
2011-05-22bnx2x: fix DMAE timeout according to hw specificationsDmitry Kravkov
2011-05-22bnx2x: properly handle CFC DEL in cnic flowVladislav Zolotarov
2011-05-22bnx2x: call dev_kfree_skb_any instead of dev_kfree_skbVladislav Zolotarov
replace function calls when possible call in both irq/non-irq contexts Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22net: rename NETDEV_BONDING_DESLAVE to NETDEV_RELEASEAmerigo Wang
s/NETDEV_BONDING_DESLAVE/NETDEV_RELEASE/ as Andy suggested. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: Neil Horman <nhorman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22netpoll: disable netpoll when enslave a deviceAmerigo Wang
V3: rename NETDEV_ENSLAVE to NETDEV_JOIN Currently we do nothing when we enslave a net device which is running netconsole. Neil pointed out that we may get weird results in such case, so let's disable netpoll on the device being enslaved. I think it is too harsh to prevent the device being ensalved if it is running netconsole. By the way, this patch also removes the NETDEV_GOING_DOWN from netconsole netdev notifier, because netpoll will check if the device is running or not and we don't handle NETDEV_PRE_UP neither. This patch is based on net-next-2.6. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Neil Horman <nhorman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22macvlan: Forward unicast frames in bridge mode to lowerdevDavid Ward
Unicast frames between macvlan interfaces in bridge mode are not otherwise sent to network taps on the lowerdev (as all other macvlan frames are), so forward the frames to the receive queue of the lowerdev first. Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22drivers/net: add prefetch header for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22rionet: Remove pointless printk of skb pointer.David S. Miller
Casting to u32 warns anyways. Signed-off-by: David S. Miller <davem@davemloft.net>
