path: root/drivers/net
2008-07-11Merge branch 'linus' into core/rcuIngo Molnar
Conflicts: include/linux/rculist.h kernel/rcupreempt.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-04fs_enet: restore promiscuous and multicast settings in restart()Laurent Pinchart
The restart() function is called when the link state changes and resets multicast and promiscuous settings. This patch restores those settings at the end of restart(). Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ibm_newemac: Fixes entry of short packetsSathya Narayanan
Short packets has to be discarded by the driver. So this patch addresses the issue of discarding the short packets of size lesser then ethernet header size. Signed-off-by: Sathya Narayanan <sathyan@teamf1.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ibm_newemac: Fixes kernel crashes when speed of cable connected changesSathya Narayanan
The descriptor pointers were not initialized to NIL values, so it was poiniting to some random addresses which was completely invalid. This fix takes care of initializing the descriptor to NIL values and clearing the valid descriptors on clean ring operation. Signed-off-by: Sathya Narayanan <sathyan@teamf1.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04pasemi_mac: Access iph->tot_len with correct endiannessRoland Dreier
iph->tot_len is stored in network byte order, so access it using ntohs(). This doesn't have any real world impact on pasemi_mac, since the device only exists as part of a big-endian system-on-chip, but fixing this gets rid of a sparse warning and avoids having a bad example in the tree. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ehea: Access iph->tot_len with correct endiannessRoland Dreier
iph->tot_len is stored in network byte order, so access it using ntohs(). This doesn't have any real world impact on ehea, since ehea only exists for big-endian platfroms (at the moment at least) but fixing this gets rid of a sparse warning and avoids having a bad example in the tree. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ehea: fix race conditionJan-Bernd Themann
When ehea_stop is called the function cancel_work_sync(&port->reset_task) is used to ensure that the reset task is not running anymore. We need an additional flag to ensure that it can not be scheduled after this call again for a certain time. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ehea: add MODULE_DEVICE_TABLEJan-Bernd Themann
Required to allow distros to easily detect when ehea module needs to be loaded Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04ehea: fix might sleep problemJan-Bernd Themann
A mutex has to be replaced by spinlocks as it can be called from a context which does not allow sleeping. The kzalloc flag GFP_KERNEL has to be replaced by GFP_ATOMIC for the same reason. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04forcedeth: fix lockdep warning on ethtool -sTobias Diedrich
After enabling CONFIG_LOCKDEP and CONFIG_PROVE_LOCKING I get the following warning when ethtool -s is first called on one of the forcedeth ports: ================================= [ INFO: inconsistent lock state ] 2.6.26-rc4 #28 --------------------------------- inconsistent {in-hardirq-W} -> {hardirq-on-W} usage. ethtool/1985 [HC0[0]:SC0[1]:HE1:SE0] takes: (&np->lock){++..}, at: [<ffffffffa000c5fd>] nv_set_settings+0xc8/0x3de [forcedeth] {in-hardirq-W} state was registered at: [<ffffffffffffffff>] 0xffffffffffffffff irq event stamp: 3606 hardirqs last enabled at (3605): [<ffffffff8068106f>] _spin_unlock_irqrestore+0x3f/0x68 hardirqs last disabled at (3604): [<ffffffff80680d38>] _spin_lock_irqsave+0x13/0x46 softirqs last enabled at (3534): [<ffffffff80246ba5>] __do_softirq+0xbc/0xc5 softirqs last disabled at (3606): [<ffffffff80680b33>] _spin_lock_bh+0x11/0x41 other info that might help us debug this: 2 locks held by ethtool/1985: #0: (rtnl_mutex){--..}, at: [<ffffffff80596072>] rtnl_lock+0x12/0x14 #1: (_xmit_ETHER){-+..}, at: [<ffffffffa000c5e8>] nv_set_settings+0xb3/0x3de [forcedeth] stack backtrace: Pid: 1985, comm: ethtool Not tainted 2.6.26-rc4 #28 Call Trace: [<ffffffff8025f190>] print_usage_bug+0x162/0x173 [<ffffffff8025fa8b>] mark_lock+0x231/0x41f [<ffffffff802607cf>] __lock_acquire+0x4e7/0xcac [<ffffffff8025fe64>] ? trace_hardirqs_on+0xf1/0x115 [<ffffffff80272c3a>] ? disable_irq_nosync+0x6f/0x7b [<ffffffff80261375>] lock_acquire+0x55/0x6e [<ffffffffa000c5fd>] ? :forcedeth:nv_set_settings+0xc8/0x3de [<ffffffff80680b15>] _spin_lock+0x2f/0x3c [<ffffffffa000c5fd>] :forcedeth:nv_set_settings+0xc8/0x3de [<ffffffff8058f8bb>] dev_ethtool+0x186/0xea3 [<ffffffff8067f446>] ? mutex_lock_nested+0x243/0x275 [<ffffffff8025df2b>] ? debug_mutex_free_waiter+0x46/0x4a [<ffffffff8067f469>] ? mutex_lock_nested+0x266/0x275 [<ffffffff8058e1ce>] dev_ioctl+0x4eb/0x600 [<ffffffff8068106f>] ? _spin_unlock_irqrestore+0x3f/0x68 [<ffffffff80580f91>] sock_ioctl+0x1f5/0x202 [<ffffffff802a322e>] vfs_ioctl+0x2a/0x77 [<ffffffff802a34d6>] do_vfs_ioctl+0x25b/0x270 [<ffffffff806807b6>] ? trace_hardirqs_on_thunk+0x35/0x3a [<ffffffff802a352d>] sys_ioctl+0x42/0x65 [<ffffffff8021fffb>] system_call_after_swapgs+0x7b/0x80 This is caused by the following snippet in nv_set_settings: netif_carrier_off(dev); if (netif_running(dev)) { nv_disable_irq(dev); netif_tx_lock_bh(dev); spin_lock(&np->lock); /* stop engines */ nv_stop_rxtx(dev); spin_unlock(&np->lock); netif_tx_unlock_bh(dev); } Because of nv_disable_irq this is probably not really a problem though (I guess) and replacing the spin_lock with spin_lock_irqsave could keep interrupts disabled for a longer period of time because of delays in nv_stop_rx and nv_stop_tx. Signed-off-by: Tobias Diedrich <ranma+kernel@tdiedrich.de> Cc: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-04Add missing skb->dev assignment in Frame Relay RX codeKrzysztof Halasa
Commit 4c13eb6657fe9ef7b4dc8f1a405c902e9e5234e0 ([ETH]: Make eth_type_trans set skb->dev like the other *_type_trans) removed skb->dev assignment from hdlc_fr.c:fr_rx(). Unfortunately it was also needed for cases other than eth_type_trans(). Adding it back. It's quite serious and may be a security risk as it causes a wrong input interface indication (the physical hdlcX instead of logical pvcX). Probably -stable class fix. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-02libertas: support USB persistence on suspend/resume (resend)andrey@cozybit.com
Handle .reset_resume() so that libertas can survive suspend/resume without reloading the firmware. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Acked-by: Deepak Saxena <dsaxena@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-02iwlwifi: drop skb silently for Tx request in monitor modeZhu Yi
This patch fixes the problem to keep mac80211 resubmitting SKBs when Tx request cannot be met in monitor mode. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-02iwlwifi: fix incorrect 5GHz rates reported in monitor modeRick Farrington
This patch fixes the rates reported in monitor mode operation (Wireshark) for iwlwifi. Previously, packets with rates of 6M..24M would be reported incorrectly and packets with rates of 36M..54M would not passed up the stack. Signed-off-by: Rick Farrington <rickdic@hotmail.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-30hostap: fix sparse warningsPavel Roskin
Rewrite AID calculation in handle_pspoll() to avoid truncating bits. Make hostap_80211_header_parse() static, don't export it. Avoid shadowing variables. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-30hostap: don't report useless WDS frames by defaultPavel Roskin
DEBUG_EXTRA is reported to the kernel log by default, but DEBUG_EXTRA2 is not. Unrelated WDS frames pollute the log unnecessarily. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-27hamradio: remove unused variableAndre Haupt
Signed-off-by: Andre Haupt <andre@bitwigglers.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-27prism: islpci_eth.c endianness fixHarvey Harrison
clock is already cpu-endian (see le32_to_cpu slightly before), so le64_to_cpu doesn't make much sense. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-27rt2x00: Fix lock dependency errrorIvo van Doorn
This fixes a circular locking dependency in the workqueue handling. The interface work task uses the mac80211 function ieee80211_iterate_active_interfaces() which grabs the RTNL lock. However when the interface is brough down, this happens under the RTNL lock as well, this causes problems because mac80211 will flush the workqueue during the ifdown event. This causes mac80211 to wait until the driver has completed all work which can't finish because it is waiting on the RTNL lock. This is fixed by moving rt2x00 workqueue tasks on a different workqueue, this workqueue can be flushed when the ieee80211_hw structure is removed by the driver (when the driver is unloaded) which does not happen under the RTNL lock. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-2.6
2008-06-27Hold RTNL while calling dev_close()Ben Hutchings
dev_close() must be called holding the RTNL. Compile-tested only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27qla3xxx: Hold RTNL while calling dev_close()Ben Hutchings
2008-06-27[netdrvr] Fix IOMMU overflow checking in s2io.cAndi Kleen
s2io has IOMMU overflow checking, but unfortunately it is wrong. It didn't use the standard macros, which meant that it only worked on POWER and SPARC because only those define DMA_ERROR_CODE. Convert it to use the standard macros instead. I also commented two more bugs in the IOMMU handling. It assumes that 0 DMA addresses cannot happen, but that's not true in all IOMMU setups. The information if a buffer has been already mapped needs to be stored elsewhere. Didn't fix those because it needs careful checking of the buffer handling by the maintainers. Cc: ram.vepa@neterion.com Cc: santosh.rastapur@neterion.com Cc: sivakumar.subramani@neterion.com Cc: sreenivasa.honnur@neterion.com Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27e1000: only enable TSO6 via ethtool when using correct hardwareAndy Gospodarek
When enabling TSO via ethool on e1000, it is possible to set NETIF_F_TSO6 on hardware that does not support it. Setting TSO via ethtool now matches the settings used when the hardware is probed. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27e100: Do pci_dma_sync after skb_alloc for proper operation on ixp4xxKevin Hao
The E100 device can't work on current kernel (2.6.26-rc6) and will cause kernel corruption on intel ixdp4xx. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27[netdrvr] netxen: fix netxen_pci_tbl[] breakageAl Viro
PCI_DEVICE_CLASS sets .device and .vendor to PCI_ANY_DEV, which overrides the effect of preceding PCI_DEVICE() and makes all elements of netxen_pci_tbl[] identical. Introduced in the commit dcd56fdbaeae1008044687b973c4a3e852e8a726. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27[netdrvr] 3c59x: remove irqs_disabled warning from local_bh_enableIngo Molnar
Original Author: Michael Buesch <mb@bu3sch.de> net, vortex: fix lockup Ingo Molnar reported: -tip testing found that Johannes Berg's "softirq: remove irqs_disabled warning from local_bh_enable" enhancement to lockdep triggers a new warning on an old testbox that uses 3c59x vortex and netlogging: -----> calling vortex_init+0x0/0xb0 PCI: Found IRQ 10 for device 0000:00:0b.0 PCI: Sharing IRQ 10 with 0000:00:0a.0 PCI: Sharing IRQ 10 with 0000:00:0b.1 3c59x: Donald Becker and others. 0000:00:0b.0: 3Com PCI 3c556 Laptop Tornado at e0800400. PCI: Enabling bus mastering for device 0000:00:0b.0 initcall vortex_init+0x0/0xb0 returned 0 after 47 msecs ... calling init_netconsole+0x0/0x1b0 netconsole: local port 4444 netconsole: local IP 10.0.1.9 netconsole: interface eth0 netconsole: remote port 4444 netconsole: remote IP 10.0.1.16 netconsole: remote ethernet address 00:19:xx:xx:xx:xx netconsole: device eth0 not up yet, forcing it eth0: setting half-duplex. eth0: setting full-duplex. ------------[ cut here ]------------ WARNING: at kernel/softirq.c:137 local_bh_enable_ip+0xd1/0xe0() Pid: 1, comm: swapper Not tainted 2.6.26-rc6-tip #2091 [<c0125ecf>] warn_on_slowpath+0x4f/0x70 [<c0126834>] ? release_console_sem+0x1b4/0x1d0 [<c0126d00>] ? vprintk+0x2a0/0x450 [<c012fde5>] ? __mod_timer+0xa5/0xc0 [<c046f7fd>] ? mdio_sync+0x3d/0x50 [<c0160ef6>] ? marker_probe_cb+0x46/0xa0 [<c0126ed7>] ? printk+0x27/0x50 [<c046f4c3>] ? vortex_set_duplex+0x43/0xc0 [<c046f521>] ? vortex_set_duplex+0xa1/0xc0 [<c0471b92>] ? vortex_timer+0xe2/0x3e0 [<c012b361>] local_bh_enable_ip+0xd1/0xe0 [<c08d9f9f>] _spin_unlock_bh+0x2f/0x40 [<c0471b92>] vortex_timer+0xe2/0x3e0 [<c014743b>] ? trace_hardirqs_on+0xb/0x10 [<c0147358>] ? trace_hardirqs_on_caller+0x88/0x160 [<c012f8b2>] run_timer_softirq+0x162/0x1c0 [<c0471ab0>] ? vortex_timer+0x0/0x3e0 [<c012b361>] local_bh_enable_ip+0xd1/0xe0 [<c08d9f9f>] _spin_unlock_bh+0x2f/0x40 [<c0471b92>] vortex_timer+0xe2/0x3e0 [<c014743b>] ? trace_hardirqs_on+0xb/0x10 [<c0147358>] ? trace_hardirqs_on_caller+0x88/0x160 [<c012f8b2>] run_timer_softirq+0x162/0x1c0 [<c0471ab0>] ? vortex_timer+0x0/0x3e0 [<c0471ab0>] ? vortex_timer+0x0/0x3e0 [<c012b60a>] __do_softirq+0x9a/0x160 [<c012b570>] ? __do_softirq+0x0/0x160 [<c0106775>] call_on_stack+0x15/0x30 [<c012b4f5>] ? irq_exit+0x55/0x60 [<c0106e85>] ? do_IRQ+0x85/0xd0 [<c0147391>] ? trace_hardirqs_on_caller+0xc1/0x160 [<c0104888>] ? common_interrupt+0x28/0x30 [<c08d8ac8>] ? mutex_unlock+0x8/0x10 [<c08d8180>] ? _cond_resched+0x10/0x30 [<c07a3be7>] ? netpoll_setup+0x117/0x390 [<c0cbfcfe>] ? init_netconsole+0x14e/0x1b0 [<c013d539>] ? ktime_get+0x19/0x40 [<c0c9bab2>] ? kernel_init+0x1b2/0x2c0 [<c0cbfbb0>] ? init_netconsole+0x0/0x1b0 [<c0396aa4>] ? trace_hardirqs_on_thunk+0xc/0x10 [<c0103f12>] ? restore_nocheck_notrace+0x0/0xe [<c0c9b900>] ? kernel_init+0x0/0x2c0 [<c0c9b900>] ? kernel_init+0x0/0x2c0 [<c0104aa7>] ? kernel_thread_helper+0x7/0x10 ======================= ---[ end trace 37f9c502aff112e0 ]--- console [netcon0] enabled netconsole: network logging started initcall init_netconsole+0x0/0x1b0 returned 0 after 2914 msecs looking at the driver I think the bug is real and the fix actually is trivial. vp->lock is also taken in hardware IRQ context, so we _have_ to always use irqsafe locking. As we run in a timer with IRQs disabled, we can simply use spin_lock. Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27ipg: use NULL, not zero, for pointersPekka Enberg
Fixes a sparse warning in a code block that's hidden under JUMBO_FRAME #ifdef. Tested-by: Andrew Savchenko <Bircoph@list.ru> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27ipg: fix jumbo frame compilationPekka Enberg
Make jumbo frame support compile again. It was broken by the cleanup series before the merge because the code is hidden under JUMBO_FRAME #ifdef. Tested-by: Andrew Savchenko <Bircoph@list.ru> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27drivers/net/r6040.c: Eliminate double sizeofJulia Lawall
Taking sizeof the result of sizeof is quite strange and does not seem to be what is wanted here. This was fixed using the following semantic patch. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression E; @@ - sizeof ( sizeof (E) - ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27pcnet_cs, axnet_cs: clear bogus interrupt before request_irqKomuro
Signed-off-by: Komuro <komurojun-mbn@nifty.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27e1000e: fix EEH recovery during reset on PPCJeff Kirsher
EEH is not recovering in a reasonable amount of time on PPC during e1000e_down(). Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27igb: fix EEH recovery during reset on PPCJeff Kirsher
EEH is not recovering in a reasonable amount of time on PPC during igb_down(). Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27ixgbe: fix EEH recovery during reset on PPCPaul Larson
EEh is not recovering in a resonable amount of time on PPC during ixgbe_down(). Signed-off-by: Paul Larson <pl@us.ibm.com> Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27tc35815: Fix receiver hangup on Rx FIFO overflowAtsushi Nemoto
On Rx FIFO overflow error, the controller consume a buffer descriptor but currently the driver does not give it back to the controller. This results unrecoverable 'Buffer List Exhausted' condition. This patch fix this problem by moving a "fbl_count--" line to proper place. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-27tc35815: Mark carrier-off before starting PHYAtsushi Nemoto
Call netif_carrier_off() before starting PHY device. This is a behavior before converting to generic PHY layer. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-25iwlwifi: improve scanning band selection managementRon Rindjunsky
This patch modifies the band selection management when scanning, so bands are now scanned according to HW band support. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-25rt2x00: Fix unbalanced mutex lockingIvo van Doorn
The usb_cache_mutex was not correctly released under all circumstances. Both rt73usb as rt2500usb didn't release the mutex under certain conditions when the register access failed. Obviously such failure would lead to deadlocks. In addition under similar circumstances when the bbp register couldn't be read the value must be set to 0xff to indicate that the value is wrong. This too didn't happen under all circumstances. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-25b43legacy: Fix possible NULL pointer dereference in DMA codeMichael Buesch
This fixes a possible NULL pointer dereference in an error path of the DMA allocation error checking code. This is also necessary for a future DMA API change that is on its way into the mainline kernel that adds an additional dev parameter to dma_mapping_error(). Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: stable <stable@kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-25b43: Fix possible MMIO access while device is downMichael Buesch
This fixes a possible MMIO access while the device is still down from a suspend cycle. MMIO accesses with the device powered down may cause crashes on certain devices. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-25b43legacy: Do not return TX_BUSY from op_txMichael Buesch
Never return TX_BUSY from op_tx. It doesn't make sense to return TX_BUSY, if we can not transmit the packet. Drop the packet and return TX_OK. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-25b43: Do not return TX_BUSY from op_txMichael Buesch
Never return TX_BUSY from op_tx. It doesn't make sense to return TX_BUSY, if we can not transmit the packet. Drop the packet and return TX_OK. This will fix the resume hang. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-23Merge branch 'linus' into core/rcutip-core-rcu-2008-06-23_09.29_MonIngo Molnar
2008-06-20pppoe: warning fixStephen Hemminger
Fix warning: drivers/net/pppoe.c: In function 'pppoe_recvmsg': drivers/net/pppoe.c:945: warning: comparison of distinct pointer types lacks a cast because skb->len is unsigned int and total_len is size_t Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17Merge branch 'davem-fixes' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2008-06-17tun: Proper handling of IPv6 header in tun driver when TUN_NO_PI is setAng Way Chuang
By default, tun.c running in TUN_TUN_DEV mode will set the protocol of packet to IPv4 if TUN_NO_PI is set. My program failed to work when I assumed that the driver will check the first nibble of packet, determine IP version and set the appropriate protocol. Signed-off-by: Ang Way Chuang <wcang@nav6.org> Acked-by: Max Krasnyansky <maxk@qualcomm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17atl1: relax eeprom mac address error checkRadu Cristescu
The atl1 driver tries to determine the MAC address thusly: - If an EEPROM exists, read the MAC address from EEPROM and validate it. - If an EEPROM doesn't exist, try to read a MAC address from SPI flash. - If that fails, try to read a MAC address directly from the MAC Station Address register. - If that fails, assign a random MAC address provided by the kernel. We now have a report of a system fitted with an EEPROM containing all zeros where we expect the MAC address to be, and we currently handle this as an error condition. Turns out, on this system the BIOS writes a valid MAC address to the NIC's MAC Station Address register, but we never try to read it because we return an error when we find the all- zeros address in EEPROM. This patch relaxes the error check and continues looking for a MAC address even if it finds an illegal one in EEPROM. Signed-off-by: Radu Cristescu <advantis@gmx.net> Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-17net/enc28j60: low power modeDavid Brownell
Keep enc28j60 chips in low-power mode when they're not in use. At typically 120 mA, these chips run hot even when idle; this low power mode cuts that power usage by a factor of around 100. This version provides a generic routine to poll a register until its masked value equals some value ... e.g. bit set or cleared. It's basically what the previous wait_phy_ready() did, but this version is generalized to support the handshaking needed to enter and exit low power mode. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Claudio Lanconelli <lanconelli.claudio@eptar.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-17net/enc28j60: section fixDavid Brownell
Minor bugfixes to the enc28j60 driver ... wrong section marking, indentation, and bogus use of spi_bus_type. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Claudio Lanconelli <lanconelli.claudio@eptar.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-17sky2: 88E8040T pci device idStephen Hemminger
Missed one pci id for 88E8040T. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
