path: root/drivers/net
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] Fix numerous kcalloc() calls, convert to kzalloc()Robert P. J. Day
All kcalloc() calls of the form "kcalloc(1,...)" are converted to the equivalent kzalloc() calls, and a few kcalloc() calls with the incorrect ordering of the first two arguments are fixed. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Fix inotify maintainers entry Fix typo in new debug options. Jon needs a new shift key. fs: Convert kmalloc() + memset() to kzalloc() in fs/. configfs.h: Remove dead macro definitions. kconfig: Standardize "depends" -> "depends on" in Kconfig files e100: replace kmalloc with kcalloc um: replace kmalloc+memset with kzalloc fix typo in net/ipv4/ip_fragment.c include/linux/compiler.h: reject gcc 3 < gcc 3.2 Kconfig: fix spelling error in config KALLSYMS help text Remove duplicate "have to" in comment Fix small typo in drivers/serial/icom.c Use consistent casing in help message EXT{2,3,4}_FS: remove outdated part of the help text
2006-12-12e100: replace kmalloc with kcallocYan Burman
Replace kmalloc+memset with kcalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Acked-By: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-12[PATCH] net, 8139too.c: fix netpoll deadlockIngo Molnar
fix deadlock in the 8139too driver: poll handlers should never forcibly enable local interrupts, because they might be used by netpoll/printk from IRQ context. ================================= [ INFO: inconsistent lock state ] 2.6.19 #11 --------------------------------- inconsistent {softirq-on-W} -> {in-softirq-W} usage. swapper/1 [HC0[0]:SC1[1]:HE1:SE0] takes: (&npinfo->poll_lock){-+..}, at: [<c0350a41>] net_rx_action+0x64/0x1de {softirq-on-W} state was registered at: [<c0134c86>] mark_lock+0x5b/0x39c [<c0135012>] mark_held_locks+0x4b/0x68 [<c01351e9>] trace_hardirqs_on+0x115/0x139 [<c02879e6>] rtl8139_poll+0x3d7/0x3f4 [<c035c85d>] netpoll_poll+0x82/0x32f [<c035c775>] netpoll_send_skb+0xc9/0x12f [<c035cdcc>] netpoll_send_udp+0x253/0x25b [<c0288463>] write_msg+0x40/0x65 [<c011cead>] __call_console_drivers+0x45/0x51 [<c011cf16>] _call_console_drivers+0x5d/0x61 [<c011d4fb>] release_console_sem+0x11f/0x1d8 [<c011d7d7>] register_console+0x1ac/0x1b3 [<c02883f8>] init_netconsole+0x55/0x67 [<c010040c>] init+0x9a/0x24e [<c01049cf>] kernel_thread_helper+0x7/0x10 [<ffffffff>] 0xffffffff irq event stamp: 819992 hardirqs last enabled at (819992): [<c0350a16>] net_rx_action+0x39/0x1de hardirqs last disabled at (819991): [<c0350b1e>] net_rx_action+0x141/0x1de softirqs last enabled at (817552): [<c01214e4>] __do_softirq+0xa3/0xa8 softirqs last disabled at (819987): [<c0106051>] do_softirq+0x5b/0xc9 other info that might help us debug this: no locks held by swapper/1. stack backtrace: [<c0104d88>] dump_trace+0x63/0x1e8 [<c0104f26>] show_trace_log_lvl+0x19/0x2e [<c010532d>] show_trace+0x12/0x14 [<c0105343>] dump_stack+0x14/0x16 [<c0134980>] print_usage_bug+0x23c/0x246 [<c0134d33>] mark_lock+0x108/0x39c [<c01356a7>] __lock_acquire+0x361/0x9ed [<c0136018>] lock_acquire+0x56/0x72 [<c03aff1f>] _spin_lock+0x35/0x42 [<c0350a41>] net_rx_action+0x64/0x1de [<c0121493>] __do_softirq+0x52/0xa8 [<c0106051>] do_softirq+0x5b/0xc9 [<c0121338>] irq_exit+0x3c/0x48 [<c0106163>] do_IRQ+0xa4/0xbd [<c01047c6>] common_interrupt+0x2e/0x34 [<c011db92>] vprintk+0x2c0/0x309 [<c011dbf6>] printk+0x1b/0x1d [<c01003f2>] init+0x80/0x24e [<c01049cf>] kernel_thread_helper+0x7/0x10 ======================= Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-11[HAMRADIO]: Fix baycom_epp.c compile failure.Ralf Baechle
Fix foobar in 15b1c0e822f578306332d4f4c449250db5c5dceb and e8cc49bb0fdb9e18a99e6780073d1400ba2b0d1f patch series. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-11[NET]: Fix WAN routers kconfig dependency.Randy Dunlap
Currently WAN router drivers can be built in-kernel while the register/unregister_wan_device interfaces are built as modules. This causes: drivers/built-in.o: In function `cycx_init': cycx_main.c:(.init.text+0x5c4b): undefined reference to `register_wan_device' drivers/built-in.o: In function `cycx_exit': cycx_main.c:(.exit.text+0x560): undefined reference to `unregister_wan_device' make: *** [.tmp_vmlinux1] Error 1 The problem is caused by tristate -> bool conversion (y or m => y), so convert WAN_ROUTER_DRIVERS to a tristate so that the correct dependency is preserved. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-11[PATCH] smc91x: Kill off excessive versatile hooks.Paul Mundt
This looks like a result of too many auto-merges. The CONFIG_ARCH_VERSATILE case was handled a total of 6 times. This kills 5 of them. Signed-off-by: Paul Mundt <lethal@linux-sh.org> -- drivers/net/smc91x.h | 90 --------------------------------------------------- 1 file changed, 90 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] myri10ge: update driver version to 1.1.0Brice Goglin
Update driver version to 1.1.0. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] myri10ge: fix big_bytes in case of vlan framesBrice Goglin
Fix sizing of big_bytes in the case of vlan frames. The 4 VLAN_HLEN bytes were omitted, leading to sizing the big buffer 4 bytes smaller than it should be. Due to how rx buffers are carved from pages, this was harmless for the common (9000, 1500) byte MTUs, but could lead to data corruption for some MTUs. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] myri10ge: Full vlan frame in small_bytesBrice Goglin
Receive full vlan frames into smalls when running with a jumbo MTU. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] myri10ge: drop contiguous skb routinesBrice Goglin
Drop the old routines that used the physically contigous skb now that we use the physical pages. And rename myri10ge_page_rx_done() to myri10ge_rx_done() as it was previously. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] myri10ge: switch to page-based skbBrice Goglin
Switch to physical page skb, by calling the new page-based allocation routines and using myri10ge_page_rx_done(). Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] myri10ge: add page-based skb routinesBrice Goglin
Add physical page skb allocation routines and page based rx_done, to be used by upcoming patches. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] myri10ge: indentation cleanupsBrice Goglin
Indentation cleanups to synchronize to our tree which is automatically indent'ed. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] chelsio: working NAPIStephen Hemminger
This driver tries to enable/disable NAPI at runtime, but does so in an unsafe manner, and the NAPI interrupt handling is a mess. Replace it with a compile time selected NAPI implementation. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] MACB: Use __raw register accessHaavard Skinnemoen
Since macb is a chip-internal device, use __raw_readl and __raw_writel instead of readl/writel. This will perform native-endian accesses, which is the right thing to do on both AVR32 and ARM devices. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] MACB: Use struct delayed_work instead of struct work_structHaavard Skinnemoen
The macb driver calls schedule_delayed_work() and friends, so we need to use a struct delayed_work along with it. The conversion was explained by David Howells on lkml Dec 5 2006: http://lkml.org/lkml/2006/12/5/269 Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] ucc_geth: Initialize mdio_lock.Scott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-11[PATCH] ucc_geth: compilation error fixesScott Wood
Fix compilation failures when building the ucc_geth driver with spinlock debugging. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-09[PATCH] Amiga PCMCIA NE2000 Ethernet dev->irq initKars de Jong
Amiga PCMCIA NE2000 Ethernet: Add missing initialization of dev->irq Signed-off-by: Kars de Jong <jongk@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-09[PATCH] m68k/HP300: HP LANCE updatesKars de Jong
- 7990: request_irq() should have SA_SHIRQ flag set - hplance_init() printed dev->name before register_netdev() had filled it in Signed-off-by: Kars de Jong <jongk@linux-m68k.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[AX.25]: Fix default address and broadcast address initialization.Ralf Baechle
Only the callsign but not the SSID part of an AX.25 address is ASCII based but Linux by initializes the SSID which should be just a 4-bit number from ASCII anyway. Fix that and convert the code to use a shared constant for both default addresses. While at it, use the same style for null_ax25_address also. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[BNX2]: Add an error check.Adrian Bunk
This patch adds a missing error check spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Jeff Garzik <jgarzik@pobox.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] tty: preparatory structures for termios revampAlan Cox
In order to sort out our struct termios and add proper speed control we need to separate the kernel and user termios structures. Glibc is fine but the other libraries rely on the kernel exported struct termios and we need to extend this without breaking the ABI/API To do so we add a struct ktermios which is the kernel view of a termios structure and overlaps the struct termios with extra fields on the end for now. (That limitation will go away in later patches). Some platforms (eg alpha) planned ahead and thus use the same struct for both, others did not. This just adds the structures but does not use them, it seems a sensible splitting point for bisect if there are compile failures (not that I expect them) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert cosaJosef Sipek
2006-12-08[PATCH] crc32: replace bitreverse by bitrev32Akinobu Mita
This patch replaces bitreverse() by bitrev32. The only users of bitreverse() are crc32 itself and via-velocity. Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Add "run_scheduled_work()" workqueue functionLinus Torvalds
This allows workqueue users to run just their own pending work, rather than wait for the whole workqueue to finish running. This solves the deadlock with networking libphy that was due to other workqueue entries possibly needing a lock that was held by the routine that wanted to flush its own work. It's not wonderful: if you absolutely need to synchronize with the work function having been executed, any user strictly speaking should have its own completion tracking logic, since when we run things explicitly by hand, the generic workqueue layer can no longer help us synchronize. Also, this is strictly only usable for work that has been scheduled without any delayed timers. You can not mix the new interface with schedule_delayed_work(). But it's better than what we had currently. Acked-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (43 commits) [wireless] zd1211rw: workqueue-related build fixes [netdrvr] netxen: workqueue-related build fixes [PATCH] sky2: sparse warnings [PATCH] skge: fix sparse warnings [PATCH] myri10ge: write as 2 32-byte blocks in myri10ge_submit_8rx [PATCH] sky2: receive queue watermark tweak [PATCH] sky2: beter ram buffer partitioning [PATCH] sky2: add comments to PCI ids [PATCH] sky2: add PCI for 88ec033 [PATCH] AT91RM9200 Ethernet: Use dev_alloc_skb() [PATCH] AT91RM9200 Ethernet: Add netpoll / netconsole support [PATCH] AT91RM9200 Ethernet: Move check_timer variable and use mod_timer() [PATCH] AT91RM9200 Ethernet: Remove 'at91_dev' and use netdev_priv() [PATCH] ipw2200: Fix debug output endian issue [PATCH] ipw2200: Fix a typo [PATCH] ipw2200: Update version stamp to 1.2.0 [PATCH] ipw2200: Add IEEE80211_RADIOTAP_TSFT for promiscuous mode [PATCH] softmac: fix unbalanced mutex_lock/unlock in ieee80211softmac_wx_set_mlme [PATCH] softmac: Fixed handling of deassociation from AP [PATCH] ipw2200: replace kmalloc+memset with kcalloc ...
2006-12-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (48 commits) [NETFILTER]: Fix non-ANSI func. decl. [TG3]: Identify Serdes devices more clearly. [TG3]: Use msleep. [TG3]: Use netif_msg_*. [TG3]: Allow partial speed advertisement. [TG3]: Add TG3_FLG2_IS_NIC flag. [TG3]: Add 5787F device ID. [TG3]: Fix Phy loopback. [WANROUTER]: Kill kmalloc debugging code. [TCP] inet_twdr_hangman: Delete unnecessary memory barrier(). [NET]: Memory barrier cleanups [IPSEC]: Fix inetpeer leak in ipv4 xfrm dst entries. audit: disable ipsec auditing when CONFIG_AUDITSYSCALL=n audit: Add auditing to ipsec [IRDA] irlan: Fix compile warning when CONFIG_PROC_FS=n [IrDA]: Incorrect TTP header reservation [IrDA]: PXA FIR code device model conversion [GENETLINK]: Fix misplaced command flags. [NETLIK]: Add a pointer to the Generic Netlink wiki page. [IPV6] RAW: Don't release unlocked sock. ...
2006-12-07Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits) [PATCH] x86-64: Export smp_call_function_single [PATCH] i386: Clean up smp_tune_scheduling() [PATCH] unwinder: move .eh_frame to RODATA [PATCH] unwinder: fully support linker generated .eh_frame_hdr section [PATCH] x86-64: don't use set_irq_regs() [PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq [PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM [PATCH] i386: replace kmalloc+memset with kzalloc [PATCH] x86-64: remove remaining pc98 code [PATCH] x86-64: remove unused variable [PATCH] x86-64: Fix constraints in atomic_add_return() [PATCH] x86-64: fix asm constraints in i386 atomic_add_return [PATCH] x86-64: Correct documentation for bzImage protocol v2.05 [PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code [PATCH] x86-64: Fix numaq build error [PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header [PATCH] unwinder: Add debugging output to the Dwarf2 unwinder [PATCH] x86-64: Clarify error message in GART code [PATCH] x86-64: Fix interrupt race in idle callback (3rd try) [PATCH] x86-64: Remove unwind stack pointer alignment forcing again ... Fixed conflict in include/linux/uaccess.h manually Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Pass struct dev pointer to dma_cache_sync()Ralf Baechle
Pass struct dev pointer to dma_cache_sync() dma_cache_sync() is ill-designed in that it does not have a struct device pointer argument which makes proper support for systems that consist of a mix of coherent and non-coherent DMA devices hard. Change dma_cache_sync to take a struct device pointer as first argument and fix all its callers to pass it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[wireless] zd1211rw: workqueue-related build fixesJeff Garzik
2006-12-07[netdrvr] netxen: workqueue-related build fixesJeff Garzik
2006-12-07Merge tag 'r8169-upstream-20061204-00' of ↵Jeff Garzik
git://electric-eye.fr.zoreil.com/home/romieu/linux-2.6 into upstream
2006-12-07Merge branch 'upstream' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream Conflicts: drivers/net/wireless/zd1211rw/zd_mac.h net/ieee80211/softmac/ieee80211softmac_assoc.c
2006-12-07[PATCH] sky2: sparse warningsStephen Hemminger
Get rid of sparse warnings in sky2 driver because of mixed enum usage. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] skge: fix sparse warningsStephen Hemminger
Fix sparse warnings from using enum as part of arithmetic expression, and comment indentation fixes Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] myri10ge: write as 2 32-byte blocks in myri10ge_submit_8rxBrice Goglin
In the myri10ge_submit_8rx() routine, write the 64 byte request block as 2 32-byte blocks so that it is handled by the hardware pio write handler if write-combining is enabled. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] sky2: receive queue watermark tweakStephen Hemminger
This patch makes the receive performance on some systems go from 714MB/s to 941MB/s. It adjusts the watermark of the receive queue to be lower, thereby avoiding excess hardware flow control. This is most important on the systems which have little/no additional buffering. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] sky2: beter ram buffer partitioningStephen Hemminger
Different chips have different sizes of ram buffers, and some versions have no ram buffer at all!. Be more careful about sizing the ram usage because it maybe a problem if vendor keeps changing sizes. There is the (unlikely) possibility that some of the errors on some of the chips have been caused by partitioning not on a 1K boundary. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] sky2: add comments to PCI idsStephen Hemminger
Add comments to sky2 driver to show relationship between PCI id and hardware. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] sky2: add PCI for 88ec033Stephen Hemminger
Add another new/missing pci id for 88ec033 chip. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] AT91RM9200 Ethernet: Use dev_alloc_skb()Andrew Victor
Use dev_alloc_skb() instead of alloc_skb(). It is also not necessary to adjust skb->len manually since that's already done by skb_put(). Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] AT91RM9200 Ethernet: Add netpoll / netconsole supportAndrew Victor
Adds netpoll / netconsole support. Original patch from Bill Gatliff. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] AT91RM9200 Ethernet: Move check_timer variable and use mod_timer()Andrew Victor
Move the global 'check_timer' variable into the private data structure. Also now use mod_timer(). Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07[PATCH] AT91RM9200 Ethernet: Remove 'at91_dev' and use netdev_priv()Andrew Victor
Remove the global 'at91_dev' variable. Use netdev_priv() instead of casting dev->priv directly. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-07Merge branch 'master' into upstreamJeff Garzik
Conflicts: drivers/net/netxen/netxen_nic.h drivers/net/netxen/netxen_nic_main.c
